View Full Version : Tech / Misc
- how can i TELL wat cams I got ????
- tranny case swap
- Troubleshooting: SRS Constantly illuminates during code checks
- tranny gear ratio
- Wilwood BBK problem?
- bolts from engine side motor mount to engine
- exaust swap
- what is this bearing called
- Tapping fuse box for switched 12v
- GM Manual Trans. Fluid?
- Engine will not start afeter straight swap. No spark
- quick question: what steering wheel hubs have a working horn button?
- NEED A / C HELP!
- Is this normal?
- Starter Problem?
- Transmission replaced...electrical issues now...please help!
- Coil problem or something else?
- distributer jumper harness
- vacuum routing for b20 vtec any one know
- Anyone try using S200 box to datalog in Crome?
- Start help
- replacement ARP2000 rod bolts for eagle rods?
- H E L P !!! > rod knock AGAIN > local shop fouled up
- rebuild problems
- Tranny shaft play
- 94 GSR ECU Question to pass smog
- LS in 4 d00r
- Can someone please tell me the difference between dyno jets and mustang dynos????
- 90 DX B16 obd0 CEL problem
- DOES GSR INTERIOR FIT DA'S
- HELP HOW do i put a gsr into a non vtec shell
- new tranny?
- HELP: just used crome and now i have a check engine light
- jdm momo non srs removeable steering wheel question?
- Stock ECU Chip Code/ID
- rocket m22 cam questions
- Possible Dumb question for Racing Transmissions
- GSR final drive into a LS gearbox
- Problem with AFR using S300 and Ngk AFX
- Is it true....
- PR3 CEL help...
- quick nitrous question
- Question???
- Cam gear marks.
- Getting Bar'd.....I need help.....which throttle body?
- clutch problems
- 1990 ef9 w/jdm d15b. have a couple of ?'s about power gains???
- Dizzy questions
- where can i get a new type r bottom end cheap?
- AEM Wideband problems??
- no spark please help !!!!!!!!!!!!!!!!!!
- Think i cracked my block!!!!!!!!!!!
- Engine help!!
- TurboXS oring leaking....
- texas tuner
- 98 CIVIC EX / MISS AT 70-60 MPH HELP!!
- Tech question, but not Honda
- Release fork and bearing???
- Can I use hydro b16 tranny parts in a ys1 gsr tranny?
- rpm needle jumping
- Techno-jargon-babble
- ? about installing MSD blaster SS external coil
- s2000 muffler tip on civic
- H22a only running on cylinders 1 & 3 wtf?
- removal and relocation of engine bay parts
- Aem EGT gauge
- The "perfect" 1.75 rod ratio
- exhaust question
- H22a Skunk2 Manifold****************************************** *****
- trans problems: out and rebuilding
- Engine Bogging
- Help plis with 02 sensor
- Street Tune vs. Dyno Tune?!? Kpro / Stock Motor!
- alright so am taking off the step down harness. will it work ????????? thats the question
- ZC Turbo???
- NEED HELP!!!!!!!!!!!
- anyone ever use THREE shims for an LSD install? (B-series)
- Bad trans fluid Leak...which axle seals?
- Belt Throwing Problem
- How to fix leaking oil pan
- Cant get the right cv shaft
- OBD-1 pr4 ecu auto to manual conv. *SEARCHED*
- Tuning question
- VTEC Solenoid Code 21 CEL...bad VSS connection?
- need help wireing
- oil filter plate question?
- will a ex vtec selinoid..
- TIMING BELT + WATER PUMP PART # HELP
- Russell / Earls Hose Ends - Looking for good supplier
- d series tranny question....
- break in motor need pcv??
- Anyone recognize this filter?
- 04 Honda CRV Problems Starting Engine. PLEASE HELP!
- p30 headgasket for gsr?
- B18C Type R???
- Surging idle
- BIGGER WHEEL DIAMETER... SPEEDO IS OFF??
- LSD for D16Z6 Tranny.
- need valve adjustment specs for ctr cams in b16
- vtec head, couple questions
- "stretching" arp rod bolts for tq'ing. plastic guage for bearing size???
- How many miles does your Honda have?
- LSD vs. Open Diff.
- Turning my H23 Lude to H22a
- tuners opinion needed. Motec & Hondata for K series
- RAD HOSE HELP ASAP PLEASE B16a
- hydro lsd fit in a cable YS1?
- Oil Squirters?
- >>>Answer needed as soon as possible: crank pulley<<<
- what will i need to know about redoing my bottom end
- what sequence?
- might me DUMB , but I wana KNow!!!!?!?!??!
- b18c5 block b16 head what timing belt/ water pump
- Intermittent CEL codes (Injector & O2 Content) -- solve this mystery please
- OEM INJECTOR FILTER QUESTION DO YOU NEED THEM OR CAN YOU RUN WITH OUT THEM
- lil expertise needed with this problem plz .........starter problem or so i thought
- A/C "Clunk" Noise When I Turn It On first time each day?
- DMV problems!!! Am I in the right place? Motor vin?
- h23/vtec build ?
- Which ECU?
- Rolling w/out axles- bad??
- Engine swap, remove engine with tranny or seperate in the engine bay?
- just got an innovate xd-16 standalone lc-1 wide band need help with install
- tranny making noise? pls help
- automatic to manual conversion
- Break in tune
- simple engine break in questions
- HELP AEM 29-500R Big Brake Kit $$$$$ Question
- Differences In GSR Blocks From Year To Year?
- ls-vtec is their a difference
- Brake Bleeder Recommendations
- T3 Turbo
- EK4 SIR civic help
- Dry ice on crank pulley bolt?
- What are those sock/sweatband type things that go over brake n clutch resevoirs?
- Tempature problems on Si B16a
- will small weld on press plate throw motor out of balance?
- Gearing on ls..improvement?
- Which stock trans came with non-helical LSD???
- engine timing
- NEED HELP with cluster!!!!
- HWY drive to tune shop on new engine
- Inline Fuel Filter Questions (Cleaning up and Wire Tucking Bay)
- engine cuttin out at 3000rpm
- F20B swap w/ PCB ECU - won't hold trouble codes
- ODB1 dizzy wiring h22 to civic
- Where could we find a good CR calculator?
- Which Pressure Plate for a 99 Accord SiR-T (F20B motor)??
- b20b bottom end
- Stuck spark plug
- my car sucks
- Frustrating, Alarmingly Strong, Shake Under Acceleration.
- 100 shot safe on stock sleeves?
- Clutch install, now got some problems
- B20 vtec fresh bluid leaking headgasket?
- b20 or lawnmower?
- Transmission Issue, and Dilemma
- Apexi N1 mufflers in different colors
- civic type r tranny rebuild help
- water pump replacement
- Ethanol?
- what to do w/ the gas tank vent line????? help
- ever had a tiny water leak in a head port?
- y7+y8 intake manifold=pass smog?
- Explanation on D series motors
- Cold Air Intake doubts =(
- head gasket removal
- wiring s2000 steering wheel into ek
- Clutch/Flywheel... suggestions?
- Which ECU?
- lets make a good converstion about motors
- is my water pump bad??
- Need some help
- Does a D15B2 engine have LMA's?
- anybody using plx dm-5 sm-afr w/s300
- Block guard...is it worth it?
- Y80 rebuilt question
- question???? please awnser only if you know for fact
- Don't buy Distributor King Distributor
- What Fluid id best for an Helical/OBX/Quafe LSD?
- Blown head gasket
- HELP WITH VAFC2
- Is anyone using a modified trans?
- b18b1 rebuild for turbo.
- Who can do block sleeving?
- Car wont rev over 6 grand
- my short stroke 1.8 theory, possible build? your opinion please.
- Help, no spark!
- tuning
- what to do with a 99 ex shell?
- hondata w/program on stock gsr ok?
- Curiosity question about auto trannys
- yel/grn distributer wire
- Oil leak:to hondabond or not to hondabond?
- Tranny still making noises. (already searched, replaced bearings, etc).
- Shaking Problem
- HEADER PROBLEM... LEAK???
- block hone cleaning and lubing?
- Spark PLug Change
- throwing code 68 which I can not find on any check engine code list
- Twin Dual Induction JRSC and GT28RS
- no crank sensor with obd1???
- thrust bearings going out?
- What would happen if Charcoal Canister system wasnt hooked up?
- ARP rod bolts?? Strengthen LS/VTEC????
- h22 fuel rail dilemma
- Donut Gasket Install, ? about flange
- gearspeed fifth sleeve kit PLEASE HELP
- egine freshen up
- What do you think cause this is the pressure plate
- Do Honda dealers offer synthetic?
- clutch job?
- 2 Questions, How to tell if a rod bearing is spun, Plus shaking...
- cheepest header for a 89 integra
- I just lost reverese! how much for a bearing and synchro kit???
- Pulling an engine without transmission?
- HELP!! Gas mileage???
- d15b motor in a 96 dx????
- CRV axels on JDM ITR 5lug conv.?
- dohc zc turbocharged engineering project
- PS fluid foaming
- Ls/Vtec Turbo w/Nos.. help???????
- Cylinder Rust
- Cant tune OBD0 Should I even buy cams?
- throwing code 58 or 67
- No Idle/Unstable RPM
- knock sensor
- How does one drop a valve?
- just changed head gasket now burning coolant
- Car wont start, throwing 2 codes
- vtec pressure sensor wires?
- lean and low idle
- ITR lsd into GSR trans
- How long do catalytic converters last?
- pissing out coolant around water pump area... HELP
- trying to bar 2000 civic hatch
- Buying a new block... Questions...
- Timing troubles on GSR hatch...
- '86 CRX Si interference or non-interference motor?
- help with timing belt
- Cable to hydro?
- Blown ECU: What component is this?!?!? Fuel pump not turning on
- New LS VTEC build, high oil pressure?? help
- i need some advice about a D-series please help
- where to buy shift linkage pin and bolts?
- Timing for 1.6 SOHC ZC
- Polishing Headers?
- d15b lsd transmission questions??
- gear ratios
- ignition system question for 400HP
