View Full Version : Tech / Misc
- How Well Will a Toda Racing Flywheel Run In My Motor?????
- Which ECU?
- VW headstuds for ZC??
- how to identify type r internally?
- JDMShit.com 5 Speed Conversion Mount Issues!!!!
- Weird noise when accelerating!!!
- Idle problem with h22a in EG
- Idle Surge?
- Is this the part # for O/s rings (81.25mm)?
- HELP!! Can't get my sway bar link out !!HELP
- CTR pistons have 25 written on top of them???....they're supposed to be standard bore. Are they?
- 8900 on stock internals!
- torque specs for crank and connecting rods.
- b20/b18b differences...
- engaging first gear weird sound
- Cylinder for a B21?
- AEM guage type uego controller fix to work with hondata
- Can we please stop the whole ricer thing???
- Gotta Problem (alternator related)
- Please help me ID this intermediate shaft.
- quick tech question
- Need Advice!! Feild Vtec controller in Ek
- S2000 seat into EG6
- Cardboard Exhaust Gaskets, Theyll Work?
- 97 Odyssey 2.2L What kind of engine problems should I look for ?
- Sputtering at idle after spark plug change.
- K-Sport Kontrol Pro Coilovers
- Stock radio with ecu swap
- which power steerin belt to use
- can i use a b16a/b20 etc.....oil strainer on a b18a?
- HELP...how do i hook up a tach?
- daily driven Civic needs Koni/Comptech settings
- HEADGASKET JOB GONE WRONG!!!! PLEASE HELP ME!!!!!!!
- Yet another question about car shaking...
- 98 Cx with 98 gsr engine AC conversion
- DC Sports ceramic vs stainless steel??
- ITR head info...
- ECU QUESTION
- Strange wire under the dash...what is it?
- Need help wiring primary o2 sensor
- Installed VAFC and get code 22 at higher RPM's.... WTF?
- another way to do valve adjustment?
- GREDDY E-MANAGE WORKS ON OBDO ECU???
- Are Honda B16 and Acura B17 Oil Pans Different??
- need to identify an ecu
- dont feel VTEC ENGAGEMENT?!?!
- ITR suspension..on EG...i need help!!!
- Check out all these VACUUM DIAGRAMS...for most honda's.
- E-MANAGE TUNING???
- iac valve d16y8 pics?
- Eg Drums to discs
- ls/vtec: 185hp - 145tq. is that good?
- Need some assembly help.
- Mini Me help!
- i need to know......!!!!!!!!!!!!1
- Timing light with dial: tell me if I got this down, also jdm d15b timing question
- Swapping Front and Rear springs on coilovers
- if your in texas and are in need of....
- Integra Bleed Screw
- hepl!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
- 91CRX crossmember and 91 teg crossmember the same?
- Does this Cam look like it has 48,000 miles and is it a GSR cam.
- b18 valves<supertech or REV
- resleeving a b16
- INSTRUCTION OR PICS OF FUEL PRESSURE REGULATORS????
- Piston Ring Break In - I searched...
- Dianogstic tool?
- alternator
- +size rims and its effect on fuel efficiency
- O2 sensor question
- immobolizer system
- lsvtec... timing belt install... confused
- 92 integra gsr, need help! :( bearing number? ready please!
- timing problem...give me some ideas
- Mugen chipped ECU
- Will this pass smog in california?
- Bad question but need answer: How to pick 97 honda civic DX door lock?
- Grommet leak? Oil on Sparkplug wires!
- AEM plug and play VS Hondata
- oil pressure sender
- low clutch engagement outta no where?
- High Flo Cat Converter turns Engine Light on (99 LS)
- Need help with my suspension...camber
- suspention help
- phantom grip lsd system
- How do I know if my head is milled?
- VAFC2 vs. VAFC
- need help badly!!!!!! getting no spark!! help help help!
- Brake Rotor Recommendations??
- Car died on a complete stop after warmed up, then wouldn't start for a minute
- suspension for CRX ee6
- whats the difference between jdm eg6 brakes and gsr brakes
- Engine Machining Prep
- H22 head on a h23?
- engine rebuild: main bearings dont fit...
- any good AEM tuners?
- LSD available for b16 cable tranny?
- problems after cam install
- 88 Accord keeps stalling...???
- exact motor codes...
- Problem with LS swap in my 93 Si Hatch
- constant vtec concept.......
- Which Rota wheel weighs the least?
- Electrical problems...... ECU/ fuel injection related (fuses)
- compression ratio calculators
- HELP WITH MY TEIN SS!!!! ASAP
- Tap size for a B16A head bolt.
- Odd trouble code (OBDII)
- dyno tune or no?
- i have a VX... time for wideband.
- Oil drain bolt stripped...Need help.
- Vafc on a non-vtec motor?
- Haltech Issues
- d17 tranny on EK?
- 17" Wheels: Effect on dyno?
- Sway Bar / Strut Bar
- tryin to make sure it'll all work,2000 b16a2 block, 95 gsr head, 90 obd0 car
- don't believe the hype, h22 swaped civics and integras can handle
- Can't Find my Exhaust header downpipe anywhere?!!
- Does anyone know a good place to buy O2 sensor ?
- Head wont hold valve adj. wtf!?
- ECU pin plug question
- underdrive pulley?
- 5lug VS 4 lug weight difference..here's your answer
- Head
- weird vtec pressure switch problem. code 22. what else to check
- HELP !!! Which alternator
- Whistle noise from clutch?
- Newbie Help - problems
- Difference between a USDM 22mm rear sway bar VS. JDM 23mm rear sway bar?
- Idle troubleshoot
- CRV (36mm) outter splines on civic axles?
- Fujitsubo exhaust
- tell me what you think of this b20 setup
- engine rotation ??? not graspping the concept
- Engine Specs
- Classic question
- 91 Protege - Fuel Pump??
- torque spec for light weight skunk2 lug nuts, dont want to strip.
- crx cam timing
- str fuel rail. what size drill bit ?
- sensor/ electrical issues..... grrrr.
- External fuel pump hook up
- what does this wire do?
- All D16 piston rings created equal?
- best valvetrain (poll)
- NEWBIE help.. Civic is running really rich
- should I plastigauge?
- fresh build and car won't accelerate past 3500 rpm's
- TRANNY PROBLEM - GEARS POPPING BACK INTO NEUTRAL ON ITS OWN
- removing ITR axles?
- how to:Clutch install and adjust
- Real fact about mileage engine from japon
- b16a Gen2 JDM strange problem
- shaking car
- Original Factory Manual
- b16 head put on b20z, has no power!!!
- torqe spec?
- D16A6 troubles... Cam timing? 1990 CRX Si
- Fuel setup question**
- I know, WHY WOULD YOU WANT TO DO THIS, but i still gotta ask, "Is it possible to..."
- car bogging after head gasket install
- camshafts, which one is intake and exshaut?
- obd2 d16 into 93 civic........problem with Iac sensor...how do i wire it
- Urgent! Buying a b18c1 head for a b18b1 ls engine.
- tuning....what should i use? please help (uberdata, hondata?)
- The new clutch thread. every1 with an aftermarket cltuch post.
- Injectors Not Working HELP
- New buddy club exhaust
- Cold Start Idle Problem
- AEM EMS and Battery Offset?
- Reversing VTEC for a turbo?
- Socketed P28 question....What are these?????
- mysterious fuel pump
- small nick in crank, take a look
- bleeding the brakes and no fluid is going to the front
- Paint Job
- Tranny Questions
- d-16 vtec w/turbo or sir??
- OK to reuse ARP Head bolts?
- fuel injector info
- Clutch Problem Need Help!!!
- skunk 2 stage 2 cam problem
- Extra torque necessary on head bolts with thin headgasket?
- Troubleshooting: Code 43
- Quick vafc2 question
- Cleaning Your Engine
- h22 swap
- tein ss install help (brake hose bracket)
- Oxygen Sensor: Failed Emissions - which O2 sensor is bad?
- What tool to use to tighten stuff like this?
- Help, looking for Eprom chip*searched
- engine swap
- vtec head: symmetrical porting or no?
- vx rockers on other heads?
- 03 4dr honda civic what to do?
- Differences between alternators?
- can a jdm engine be put into a 96 src h22a1 ... (obd 2 ) and if so what do i need to change?
- WHAT PLUG is this?
- Techedge install, need help hooking up the unit!!
- Need Help, Auto to Manual conversion for a 90 Integra..
- brake light problems
- help,accel dfi electrical problem
- tunerz (mase???)
- LSD trannys
- what size are this valves?
- Bought a "socketed" P28 a while back......few quetsions. SINNER and ih8ricerz come in!!!
- Problem with brakes on Toyota Corolla. Someone help me out.
- ecu wire harness list? what color wires are for what?
- sensor for fuel?
- need info on ZC
- Skunk 2 Coilover
- TOOL QUESTION?!?!?!?!?!?! ..... TORQUE WRENCH????????
- Which catback would fit?
- itr girdle torque specs
- Got a bad problem with a rounded bolt.
- Check Engine Light stays on!!!!
- head stud/bolt questions Type R/GSR
- apex n1 sound clip
- Another coilover question!
- Cusco 1 Way LSD?
- Passport engine problems... I am a hot chick that needs the TSB for my SUV.
- air velocity in intake?
- Which upgrades should I do first???
- Exhaust leak causing Idle problems?
- Clutch Job $950???
- RPM
- GSR diff. backlash
- air compressor ?
- apex n1 decibel level
- !!! valve adjustment: torque specs on 12mm lock nuts???
- type r distributor??
- Worse case scenario when driving with bad o2 sensor
- b18c1/c5 crank in a b18a/b
- 2 block guard questions
- Bad Master Cylinder or Brake Booster?
- Timing Advan. and Concerns!
- Best mods for the $$$ on B18c1???
- setting my tps
- Better r/s ratio on b16?
- NEED HELP, Throttle Issues
- ls vtec engine/ white smoke comes out after hitting 7,000 rpm
- desoldering holes to chip ECU...
- Funny rattling noise coming from drivetrain
- water temp gauge install on a d16y8 HELP NEEDED!!
- LS/VTEC tuning (running too lean)
- Champion Spark Plugs
- Internals of VSS; what kind of grease??
- coolant problem...
- F20B ?'s
