Removing Rust from INSIDE of Exhaust Manifold ------>
Old Nov 25, 2003 | 10:37 PM
sirminder's Avatar
Default Removing Rust from INSIDE of Exhaust Manifold ------>
A friend of mine "borrowed" my stock B16 header and the bastard left it out in the rain for the season. Anyhow, I got it back but the chambers are rusted from the inside. The flat side where the exhaust manifold gasket goes, is also rusted. Im thinking I can slightly sand the flat side to remove the rust. But how would i go about cleaning the chambers?
Old Nov 26, 2003 | 08:45 AM
Tweakmeister's Avatar
Default Re: Removing Rust from INSIDE of Exhaust Manifold ------> (sirminder)
hmm, you got me on that one.
no matter how much crap you try to "wash" it with only a coating will prevent it, and even still the coating won't be able to grip very well once a header is used.
got pics?
Old Nov 26, 2003 | 10:49 AM
Jimmy's Avatar
Global Moderator
Default Re: Removing Rust from INSIDE of Exhaust Manifold ------> (Tweakmeister)
Go to your local Advanced autozone and buy 1 or 2 cans of PB Blaster and soak that ****...it will be gone in mintues..
Old Nov 26, 2003 | 01:13 PM
sirminder's Avatar
Default Re: Removing Rust from INSIDE of Exhaust Manifold ------> (USDMDC2)
Ill put up pics in a while......stay tuned.
Old Nov 26, 2003 | 03:57 PM
TREVER's Avatar
sandblaster
Old Nov 26, 2003 | 06:37 PM
b18crx's Avatar
i wouldnt worry about it if its just surface rust. probably wont affect much.
go stainless...
Old Nov 26, 2003 | 06:38 PM
b18crx's Avatar
some steel wool will help
Old Nov 26, 2003 | 07:24 PM
sirminder's Avatar
Default Re: Removing Rust from INSIDE of Exhaust Manifold ------> (b18crx)
Here are some pics...
Old Nov 26, 2003 | 07:38 PM
rofl, is that a STOCK manifold?
it's cast iron, it's fine.
time to buy a new _better_ one anyway.
Old Nov 26, 2003 | 07:44 PM
sirminder's Avatar
Yah thats the STOCK manifold thank you very much . But I only need to put it back for a smog check. I have a Kamikaze manifold and that would deff not pass the visual. Reason I bought that one is cuz it was almost free. Anyhow, Im only gonna use it for the time being to get a smog check. I wasnt too sure if the rust would have an affect on emissions or can somehow someway damage anything when the rust particles fall off.
Old Nov 26, 2003 | 07:57 PM
hahaha
I'd bolt it up and not connect it to the cat.
then let it run till it warms up a bit just to flush it out.
4drctr420
Feb 1, 2014 01:04 PM
94 IntegraLS
Jul 21, 2011 02:12 AM
curtie94
Mar 24, 2011 08:56 PM
PearlH22
Jun 24, 2006 06:05 PM
