View Full Version : Tech / Misc
- coilovers...yes or no
- I need a litte guidance and some opinions..and oh yeah..some help too
- Rattle coming from distributor...
- JDM ITR cluster question
- b18b? please reply
- Help
- did search on knock sensor ?? not answered
- I recently came out from work to go home and had serious problems with my transaxle. It will not shi
- Autometer gauges...
- carb motors................no, really
- Chipped ECU
- cheap datalogging and possible group buy
- torque question
- ITR cams vs. CTR cams
- cel problem
- check engine light just came on
- ball joint snafu
- brakes
- question on coilovers, cosmo
- Type R Intake Manifold
- Is it worth it?
- rear bearing ??? weird noise coming from rear of my ek please help
- vtec question? please reply
- EG OEM Foglights
- Wiring OB1 car to OBD2 engine harness
- Does compression ratio and/or cams affect compression test numbers?
- Tire balancing question
- very weird problem, need help...
- b20/vtec turbo?
- can injectors go bad???please help
- Got a bolt stuck in my head
- VAC line for a civic
- anyone from ohio where are they test and tune shops with dynos?
- cleaning the IACV
- Code 45!!
- Valve Seals (URGENT)
- firewall hole
- do full coilovers usually drop lower than stock even if you keep it at the default hieght?
- VTEC issues
- Help with tranny fluid with kaaz lsd
- 89 B16 head..
- Balancing bottom-end,
- Attention Engine Builders/Professional Shop owners, need a favor!!
- b18b or b16a
- GSR cams in b16 rex?
- Stock clutch
- Area 51 is the sh!t!!
- clutch topic
- 4-1 header is best for supercharged applications??
- how to make a manual boot controller?
- B17a same as B16a in certain parts?
- camshaft instillation
- Fuel FIlter install
- How cheap can I put in a fully running B20b for?
- miss firing integra type r
- obd1-obd2 gsr throttle bodies? what are the differences?
- Injector & Cam gear questions for a b18b
- H&R full coilover system only lowers up to 2 inches???
- is a gsr intake cam better than a b16 intake cam?
- oil temp, more problems
- N1 Racing Pulley???
- Rear Balancer Shaft
- third gear hesitation
- Erick's Racing Head
- Summit rpm switch not getting rpm info
- Speedometer works sometimes??????
- What are people running for suspension on their hatch?
- I Failed the smog test but how do I make my car pass??
- Tie rods going bad? or just do an alignment?
- can you check compression on a engine, even if its not in a car?
- how good are PROGRESS springs?
- problems with timing belt tensioner, any ideas
- installed p28 ecu w/ harness now idle is crazy
- Propensity of Integras to Roll Over
- I have a few Questions, Someone please help!
- who knows AIR RIDE?
- how much of a diff is there btw.....
- NEED wiring help , IAC
- can someone explain O-ringed blocks to me?
- dimensions and stats of an integra front bumper?
- AC control light out.
- Will Integra Side Mirrors work on a 2000 Civic.
- Code 9 after obd1 conversion...
- Are all Honda 4 wire O2 sensors the same?
- 98 civic dx swapping in a 00 si b16a2
- HX wheels on a GSR how to make them fit right
- anyone use a p08 ecu chipped?
- Toda springs/retainers?
- thinkin of a swap...
- B16A1 Redline
- CTR Exhaust cam with stock compression
- fuel pressure(yes I searched)
- question on JUN/Mugen/other headers for USDM integras
- please help me, or i'm gonna go nuts!!!
- Will my 94 USDM gsr wiring harness & 94 gsr skunk2 ecu, plug into a 96 JDM b18c5 with no probs??
- how to distingish skunk2 cams
- my friends 00 SI reverse wont go in.
- b16a head on b18c5 block. which timing and alternator belt? which spark plugs? (b16a or b18c5)
- rear sway bar fitment on 5g civic w/exhaust
- Tranny problems HELP??????????????????????
- Camber Kits with Coilovers?
- 12.5-13:1 compression streetable on 94 octane?
- Head scratched inside near valves- what would case this
- How many 02 does PW0 use?
- front mount air intake on a GS-R are they good?
- car shaking at 80 mph
- AEM brake pads?
- DID a Search. ITR/B16 valvesprings
- Transmission Fluid question
- A/T transmission problem in 95 accord coupe please help!
- VTEC engagement....
- Please Help..Timing Issue??
- D16 question
- Catcams camshafts
- n3 one know how to do a single wiper conversion on a teg?
- Wiring diagram???HELP
- painting windshield wipers
- Power Enterprise timing belt worth $$$??
- Quick Question: B16A2 + CTR Cams + CTR Pistons = B16B?
- cutting valve cover?
- motor mount bolt question
- Detnation problem! please help?
- stock clutch removal, what kind of tool ?
- Type R, LS, or GSR tranny on my NA b20vtec???
- Yuhp , another noisy valvetrain question ( updated... )
- 90 CRX Starting problems
- Bigger Throttle body? which one? IS it worth it ???? HELP!!!
- Valve cover cutting for cam gears
- Injector resistor box
- pistons
- What are Dampers??
- HELP!!! Squeaking noise from engine bay!!
- Clutch Question on a b16a3.
- 60+ roll on.... RSX vs CivicGSR
- vafc map sensor readings
- after my swap ...need help???
- timing belt??
- Car wont go into gear, PLEASE help
- car doesn't want to start
- car won't start
- Keep your engine efficient...
- attn valve cover cutters....
- Crower 403's (NONVTEC)
- VAFC and LS block question.
- my DIY tie bar and trunk bar
- b16a cams vs b16a2 cams
- is there a cheap dyno anywhere?
- Can I swap in my secondary O2 sensor for my bad primary one?
- requesting info for a swap in my '85 REX
- cams for 200whp
- hondata , non obd, or obd1?
- going to buy 88sedan b16 for $1000
- firewall hole
- EX guage cluster question...my Seatbelt light won't work anymore
- replacin front axle
- WEIGHT 2000 - 1987 HB vs. CRX lbs.
- Differences in Trannys
- Vehicle speed sensor problems?
- Just a friendly reminder ....
- code 10 ?
- Suspension Lowering Question
- B16A or B16A2??
- Crankshaft, little scratch?
- MPH change after rims
- sparkplugs for boosted b16
- Burning oil, WTF?
- sequential shifter any thoughts
- Help with ITB's
- can someone explain the DEFI-Link system to me? and where to get a pod for their gauges?
- engine internal parts
- installing tie bar, does the car need to be jacked up?
- Graphite-impregnated poly bushings...do they squeak?
- OT: Comparisoin between Euro M3 engine and US M3 engine for E36
- B18B Vtec
- vtec working properly?
- My Suspension...any advice?
- affordable boost guages
- A little electronics help please
- vafc, 3whp?!?!
- Rod Bearing screw up.
- pic request...inside of ecu
- Broken cams = instaler at fault?
- corrosive bath
- Most powerful non-Vtec honda?
- do you think is worth getting a VAFC if i can't tunned it in a dyno?
- How to tell if my VAFC is Dead?
- what stock sway bar options and parts do i need for installation on an EK hatch
- remiving cam caps
- These seem too cheap
- Question about OBD-0 to OBD-1 ecu adapter....
- spark plugs
- b16 in 88 civic won't start~!
- WTF, VSS code...?
- Timing and the such w/deck improvements
- Valve Noise (Searched already)
- Camber Kits
- quick question about shipping a lip
- 50 Shot of nitrous????
- a/c, heater blower died...........
- carb problems on F4 bike motor
- which distributor to use
- headstuds for b16 block with gsr head
- Exhaust question> B16a into 92 hatch
- Valve Adjustment Question
- Pistons, Rods, Compression Ratios, ARP studs & Fuel
- JDM b16a1 coming!! What to replace?
- Must Read...HOT Gas Shocks!!!!!!!!!!!
- Couple top end questions
- Questions about my car...
- Skunk2, REV or Ferrea Valves?
- Boring Stock sleeves?
- dry dip stick
- Retainer question.
- MacPhersons up front....how do i drop it?!?!?!
- motor question? funny sounds.
- Code 92
- compression numbers/cam timing after head milling - B20VTEC
- What is the difference between cnc machined and billet cut?
- Good site for DIY timing belt how to?
- Loud "Tink!"
- LS Vtec in crx question.
- Crx dx with mpfi running rich. Is it killing performance?
- Turbo Question
- HID help!!
- Spoon Throttle Body
- b16a swap
- Is there any way to find out if the head i bought is actaully ITR??? PLease help!!!
- White stuff on head?
- suspension chop?
- D17 compair to D16?
- valve cover won't come off
- engine code help
- Where do you find MTF????????
- Twin canister exhaust.
- Is ACT street/strip clutch (HDSS) to much for I/H/E?
- help, my brakes suck!!!????
- How do you know that you have bad shocks?
- anyone here tech-oriented with the 93-95 rx-7 tt's?
- Engine Builders, need some advice on oil consumption
- obd-0 to obd-1 conversion question?
- boost guage
- Do you need extra Fuel supply for a mini-me swap? (different ECU)?
- stripped headstud repair link???
- CEL From Test Pipe
- B20vtec timing mark problem and CAI question.
- What function do spring isolator bushings serve?
- import builders motor?
- How to modify a b and h series motor
- Quick Question: Min. Cylinder Wall thickness of B16 & B18
- How to read transmissions?
