View Full Version : Tech / Misc
- race engine harness (any info on how to make em?)
- Auto GSR into auto EG
- oil light keeps flashing
- aem cam gears......good or bad
- diy itbs ???
- rack and pinion help!
- oil temperature
- Good tranny shop in 626 so cal, TOYOTA this time
- Tuning itself
- running rich need help ....thanks for lookin
- pistons and rods...help
- Transfer case symptoms
- Fuel Injector Guide (Honda/Acura, Toyota, DSM, Mazda, etc. Injectors)
- Need help badly................................
- tranny help!!??
- d16y8 head d16z6 block help please
- Off Topic but worth viewing....
- ITR cams with GSR valves ???
- what r good Header and exhaust
- JDM b16a into 99 Civic Si Wiring Issue
- Help with new civic. please help
- BOUGHT MY FIRST CIVIC. GOOD DEAL OR BAD?
- How to tell if my 90' hatch is an ef2 or ef9?
- Which Axle?
- my apexi vafc2's LED display doesnt work now.
- Thinking of going Ls/V-attack
- Only come in if you have done MANY B-Series swaps!
- ring degrees/positioning?? piston installation
- aluminum rod brands
- YS1 Rebuild?????????????? help me...911
- right hand drive
- 01' V-6 accord, Varnish on one head, and not on the other??? normal?
- Radiator Barn ?
- Occasional oil light... Weird symptoms- HELP!!
- Good brand?
- Idle drop and noise
- P30 flywheel broke on my b18c1
- what ecu to use
- Helicoil Install
- muffler
- Cali Smog
- Need some advice for engine build.
- how do i finish installing my itbs???
- What color is the wires of the IAT sensor? in a 98 gsr
- Fuel Injectors (size, type, impedance)
- How to check if a virgin p28 is working properly?
- difference between a turbo cam and NA cam...
- code 7 need help h22
- weird q. A20 engine...what trans?
- can chrome be used to tune twm itbs?
- buying a turbo honda
- Whats the Difference..obd1 vs obd2 gs-r heads and how can i tell???
- Timing Belt Service needed in Nashville area....
- b18c1 block with b18b crank and rods
- Hondata S300 P28 Question
- Ls Tranny build?
- piston speed/rev limit
- dynamics for tuning
- LSvtec Knock Sensor in block
- Remove the Timing Balancer Belt
- P28? used for vtec dohc swaps? possible? or not?
- need help on my DA. speedometer wont work. dont know the prob.
- distributor?
- B2D adapter plate?
- anybody crack a header from racing?
- Aluminum rods
- Strength of the stock gsr connecting rod
- Calling out all backyard mechanics!
- do skunk2 stage 2 cams idle stock?
- Biggest complaint about your car
- Oil leak from oil pan drain plug
- How do I remove oil pan studs?
- Z6 mini-me build-up?
- Tailights dont work!
- Could an aftermarket PCV valve be screwing up my idle?
- Battery was drained, now lights dim at idle
- WTA: Experience with the SS work's block girdle/block brace.
- B16a1....
- filler neck hose
- s100 tuneing and other options.
- WIRE TUCK I'M IN EL PASO TX
- how to identify skunk2 stage1 cams?!?! NEED HELP!
- p28 max rpm mapping
- JDM swap with auto tranny?
- .Bin file page?
- Vtec head diagram?
- Upgrading to ITR throttle body, need cable as well?
- No Spark-Tested- Bad ICM put in a good ICM still tested out bad???
- distributorless cam sensor setups...
- Already searched about sleeved block break-in??? How
- 13sec na b16
- socketed ecu's
- Leakdown Testing F.Y.I.
- crv with h23 swap, h2b trans adapter and crv auto awd trans. possible?
- What cams are better?
- ABS light on at all times unless it rains
- different throw out bearing for a ys1
- f series motor x-changes
- Main Bearings
- Re-Torque Head Bolts????
- How to put a d16y8 into 96-98 civic dx...little help
- ACT streetlite clutch/ flywheel trouble *searched*
- IAT Intake airtemp sens CEL Problem.
- Mugen F1 Engine
- 3rd gear grind / pop. PLEASE HELP!
- Re-routing Breather Kit Filter to Remote Location???
- obd0 LS ecu Chipped to run a vtec b16
- 92and94 integra rod bearins diff??
- D16 question
- Parts to replace during a clutch/diff. job
- Power Steering Removal kit... Topmount Bseries guys i need advice...
- Weird Problem...
- VTEC dont engage when there is a CEL???
- Change transmission fluid now or wait?
- oil filter fitting and the block coolant drain plug?
- B series oil cooler ?
- Wipers wont return to park?
- Help Enigne Problems!!!
- 11,000 dollar budget.
- 94 Civic Wiper SwitcH
- B18C4 from EG to EK
- WHAT MODIFICATIONS?
- wth is up with my 240...Please help
- aem uego pc software wanted!
- surface mount
- Could a bad build cause the motor to overheat?
- ticking sound
- rockers...which way?
- ? On buying ACL bearings for my LSVTEC build
- stage 3 (sprung 6-puck) vs. stage 2 (carbon kevlar street disc) for daily driving?
- H22 EG Problems
- auto to manual
- can u use a m2u4 tranny on a h22a long block?
- i need help big time for b16a gen2
- Vtec Solenoid Senor Question Help B16a2
- TRANNY PROBLEM HELP!!!!!!!!!!!!!!!!!!!
- whats the voltage for TPS on a B18C1?????
- a6 oil pan on a z6?
- DO THEY MAKE ROLLER ROCKERARMS FOR B18C
- drill holes for aftermarket Injectors?
- Easy Drain on Gas tank?
- Fuel pressure setting!?
- Plastigauge resdue safe to leave?
- D series clutch combos?
- b16: tps adjusment voltaqge
- Need Proportioning Valve Hel!!!
- wiring help...
- D16y7 to d16b7 question
- B16. Car is breaking up around 6+ psi???
- Which cams are best for all motor daily driven ?
- Bad Limited Slip?!?!?!?!?
- Average rate for dyno tuning?
- new engine. Doesn't look that healthy. help me diagonse.. *tons of pics*
- cometic head gaskets
- tranny help
- K and B-series crankshaft journal diameters.
- this stuff smell good?
- What bearings to use?
- recently built ls wont start!!!! need help!!!!
- 99-oo b16 into my 96 hatch???
- Reducing knock sensor Voltage. What size resisitor?
- Hydro clutch/ Cable clutch- Question??
- Wipers are not returning home?
- vtec controller install
- question about vitaras in a z6 after rebuilding!
- Need a shop to Tune
- Tranny Help
- green/black O2 wire where does it plug into?
- No oil? What happen??
- Question about universal mufflers.
- any place i can look
- B16A idle. Sometimes high, sometimes just right
- Need help on ignition coil
- tick tick tick
- Quick Question guys..
- anyone use zeitronic wideband w/hondata and know the voltage settings???
- Bad head gasket and bad piston rings
- Engine builders I need your advice
- Rod bolt stretch gauge question.
- how to tell between 16 and b18 crank?
- *** HELP *** Replacing HEAD on high-mileage motor a bad idea??? or get new motor? ***
- EUGO and Crome Pro, where do I connect the Wide band?
- MOTOR MOUNTS!!!!! 93 CIVIC EX H22A
- Check out this massive destruction
- bouncing idle will not go away!
- need help!!!!!! putting a 00 gsr motor in my 00 civic ex dizzy plug is different
- idel problem
- Tranny Rebuild
- relocating oil filler on H22 VC
- Starter Cut Relay Part number
- VTEC problem
- Cable to hydro conversion using OEM parts????
- AUTO LIGHTS
- make ls rods like Vtec rods
- obx lsd
- headgasket
- Quick question
- Removing MSD 6AL Ignition and BTM
- HEYY H23A question!!!
- how many mm is the b18c1?
- any one recomend a good tune shop for me in northern CA
- blown head gasket questions, need help
- POST PICS OR BAN!!!!!!!!
- strange faint clicking noise when i press in clutch ?
- !!!!!!!!!!!!!!IACV cross reference parts!!!!!!!!!!!!!!!!!!!!!!
- Rebuild b16 tranny or go GSR?
- Synthetic oil vs Standard oil dyno and pics
- anybody ever heard of wang tuning around new england
- Turbo on Type R
- Espelir cat back vs Vision Technica axle back
- Transmission problem on 03' accord
- H22A Valve Lash Adjustment?
- shifting linkage
- 91 Integra Pressure Plate Assembly
- Questions Reguarding Spoon Products | Please Click and Read :)
- Revs cut at about 3400rpm {H22}
- Need Hehp been working/ seaching for info sense b4 sept so plz look and help me
- Honda Civic EX coupe conversion
- HELP! differences btwn b16 automatic and ls automatic
- Check engine light on??
- Fuel Injectors??? To repl or not ot repl.
- Does running the heater really help the motor run cooler?
- Life Expectancy to Change Timing Belt
- Top Fuel original cross mission?????
- conversing b engine to i-vtec
- Throw out bearing spring clip
- RT4WD EF Conversion (axles question)
- wire tuck+cruise control
- LS ecu running a stock B20. what do i need to raise the fuel pressure to?
- B16 from 99 SI, Timing belt snapped at idle... how bad can it be
- Pivot a/f data logger
- EX Manifold cover plate?
- Help me
- short ram question
- WANT TO BUY ***Complete d16Y8 VTEC Engine Harness***
- neuspeed N2 header? any good?
- h22a need some help
- WHich engine should I choose?
- Tuning: Recommeded Exhuast System Approach. FYI
- AN Fitting Dimensions...anyone?
- Head gasket help/advise
- battery and alarm
- battery and alarm
- ***HELP*** why am i still getting boost creep?
- Sloppy / Loose Steering -- All of a sudden
- y8 intake manifold
- Motor Swap Tool List??
- Need Help Could a bad release bearing/fork cause slave cylinder to pop out?
- Lower Ball Joint.. Axle removal!! Help!
- I could be mistaken..
