View Full Version : Tech / Misc
- 98 obd2 b18c1 engine issues
- Weird Clicking chatter noise when turning.
- Can someone tell me what this part is?
- Gauge wiring issue
- oem and aftermarket rod length
- 2003 honda accord chronic p0430
- honda civic under hood fuse box missing wires
- Fuel injectors
- Air intake Resonator delete question
- Gas light won't go off
- ATF Warmer Failure Question
- Fan not working
- Test pipe swap for cat
- Best Aftermarket Option for OBD-1 B-Series VTEC Oxygen Sensor...?
- ac compressor bypass pulley
- Air Intake Removal 2007 Accord V6 LX
- What leather seats are these
- Which oils/fluids are best for my '91 Accord LX?
- making a F23A external distributor to an internal distributor
- Air in fuel system
- how good are the newer moroso oil pans for seal?
- better oil pickup filter?
- 2007 Accord V6 Haynes Manual
- Ovearheating and overflowing radiator
- Vtec issue
- Help Needed - Radiator Replacement
- swap help
- Help! Coolant In Transmission Fluid
- Where do I spread the RTV??
- Question about parts
- Loom trimming.
- Prototype Edelbrock VTEC cylinder head
- Motor swap
- 2000 accord coupe vtec problem
- OBD2a Unknown Connectors
- Vtec Pin does not LOCK
- Yet another ECU question
- injector digram
- Alternator wire orange hot!
- Help.. Lsv turbo running on 3 cylinders..
- Need help with car shut down while driving to work.
- Da9 started running rich and won't start
- Plz help with my b16
- Oil breather chamber
- Radiator cap pressure.
- b18b1 problem..
- Guidance need on my new (to me) 98 ex 2 door
- need help...water in car
- ECU fuse keeps blowing
- headgasket leak pics
- spark plugs
- GSR vs. TYPE R VTEC engagement
- Help Finding Coolant Leak 2007 Accord V6
- 94 integra fuel pump not priming
- b18c5 without pcv box? problem?
- h22 keeps dying while driving
- Still no spark
- Harmonic Balancer Wearing into Timing Cover and has Erased Ignition Timing Marks
- help with part number
- random stalling
- Exhaust for ef sedan
- cleaning head/block surface and pistons
- B18c1 won't crank but will start when rolled??
- Amsoil coolant in my b18c ?
- Are itbs on a bseries worth it
- Urgent: Noise in valve cover
- ek b16a2 turbo oil pump help
- rattle? exhaust leak or..?
- power window problems
- /96-00 civic sedan door harness pin, shell, etc question
- What do I need to replace for new cams?
- skunk2 stage2 camshafts fake or original?
- Fuel pump repair
- Skunk2 Intake Manifold confusion
- 17da1 broken timing belt
- Throw out bearing?
- Accord will crank but not start -possible flooding
- Loose alternator belt and tensioner.
- What engine is this?
- Jdm h22 or h23 long block ? Hmmmm
- rsx type s seats in a ep3?
- looking to turbo my em1 si
- blow hg or waterpump failed
- Bad TPS Sensor?
- Cruise control help
- Window regulators?
- what are these rims off of?
- Propane gas vs unleaded gas
- GE intake manifold help
- Read ABS codes?
- help :o
- REBUILT MOTOR/MISFIRE#2 HELP PLEASE
- 1992 Acura Integra DA9 starting problems
- can someone please explain to me what EXACTLY vtec does for an automatic 4cyl accord?
- B20 burning oil
- Eg6 interior wiring harness swap please help!
- Can a alternator short out?
- Gauge cluster
- Trunk Floor/Spare Tire Cover: Need Opinions Please
- are these itr cams?
- Temp guage test
- Engine breaking vs neutral and foot brake
- Hood Latch Failure Damage
- D16Y8 with goodies off a tooth?
- Integra gsr not starting after rebuild
- PCV Valve Questions
- Fuse 15 melted and fuse box kinda melted?
- Limp mode but no CEL
- Lost all of my Coolant!
- Questions on my crx si build
- Power Steering leak, new pump (Acura) and o-ring
- B20b swap for 2200 help
- Speedometer not working
- Limp mode trouble shooting
- Looking at a sleeper civic, need some information
- 1991 Honda Accord shuts off in parking lots
- Two atypical distributor questions (actually they're probably elementary)...
- Turbo engine overheat issues.
- aluminum recycling
- ATI Super Damper Removal? How to remove crank bolt?
- Help pls - JDM B18C - Smoking, Losing oil from valve cover breather and dipstick tube
- What pipe or hose to use with blox induction box?
- How to fix my sunvisor
- Radiator dimensions
- JDM ITR Front HID Ballast Dead
- How necessary is ECU brass kickplate cover?
- Weak spark, no voltage to ICM. Jumping TACH.
- need help on removing engine
- Towing with my Accord?
- Alternator
- Washed engine bay car won't run correctly
- What is a troll thread???
- 929rr throttle bodies
- Motor shake around certain RPM range
- Smoke during high rpm shifts?
- Prototype b series cams??
- Skunk2 Alpha 70mm throttle body TPS issue
- Jun springs?
- Can you delete vtec without killer cams
- 99 Honda Civic DX Automatic Gauge Cluster Dead
- eg6
- 98 prelude oil light blinking
- HELP
- H22a1 cylinder 4 compression low
- valve adjustment
- Main Relay Failure
- My Dipstick broke inside the tube
- 94 D16Z6 Overheating
- sir navigation system on 97 civic ex
- Oil squirter question
- Goldiewang is going AWD
- launch control need help
- 1994 civic si decreased gas mileage and long starts
- Speedometer
- Ls Vtec turbo running rich.
- Vibrant Performance Universal GESi Universal OBD2 Catalytic Converter
- B18cr seems to be misfiring?
- Camshaft and crankshaft position sensors
- 95 honda civic ex ac not working right
- Deka Power Sports ETX20L
- turbo ls vtec over heating.. can't figure this out
- Black spray from exhaust
- Which parts help bring the power of your motor to your wheels?
- B20v first start up went bad
- honda losing water with aluminum radiator
- d16a6 head bolts are mixed up
- Engine swap laws in California Year difference?
- Fuel Injector/fuel pump cleaning and testing
- Ls/vtec overheating on highway only (code 11)
- Main relay ticks when trying to start
- Safe to run PCT ecu with USDM b16?
- Help! ECU acting weird..TPS...IATc...wiring issue or bad alternator?
- CRV post JDM issues!
- ek secondary o2
- K20a2 swap into Miata wont start!
- Cylinder 1 misfire Any solution?
- Is my alternator bad?
- Dashboard and A/C doesn't work when the weather is hot outside.
- dual bosch 044. Fuel pressure way too high
- Suggestions on a 3/8 socket/driver set?
- Cooling Fan Issue
- Car off..brake light above trunk stays on???
- Part came off undercarriage of 2012 CRV, What is it?
- rebuild
- suspension set up?
- 98 Dx Inner Tie rod BOOT HELP!!
- Do you have a video camera?
- 99-00 SI T bracket Bolt
- Freaky Cam gear
- A/C after market switch makes car die out
- 93 Honda Civic EG Si
- Only hot when idle
- b16a2 running b18r oil pump. timing question
- old nos stuf
- Weird random misfire B18b1
- p1298
- 98 Accord no spark help
- Help with B18C
- weird sound when accelrate
- Honda civic hx killswitch
- 1995 accord starting issues
- *H22*Thread size and pitch clutch slave bleeder and mounting bolts?
- Clicking noise from front wheel area just started
- oem fabric adhesive vs aftermarket.
- 95 accord lx turns off while driving
- Rear hatch window won't lock
- J35 valve adjustment on 05 Pilot
- db2 runs like crap
- b16a oil light stays on for longer like5-8 secs help???
- Fuel rail feed.
- Knock sensor plug!!!
- Still strong vibration at idle after tune
- Acceleration issues driving me crazy
- !plz help b16a oil in spark plug chambers even after replacing seals
- ExplicitSpeed still open for business??
- 98 Accord 2.3 VTEC Fuel Injectors
- D series transmission studs & bolt thread/pitch
- Real Time OBDII/OBD2 Mode $06 Scanning Software
- A/C compressor recommendation
- Buy New Pioneer DDJ-SX2| Pioneer DDJ-SZ DJ| Pioneer CDJ-900-Nexus| DDJ SX DJ @ $500
- Engine Check Light on and Car moving back and forth
- electrical help needed! starting problem integra
- NEEP HELP from experienced techs! VTEC system error!
- 07 Honda PIlot overheats when idling...
- 03 CR-V using 10w-40, what to do?
- Intake air temperature sensor and air filter question
- Car wont start after replacing battery and alternator
- S300 issue regarding A/C
- A/C Question '98 Civic (HELP)!
- Need help getting correct bolt for B16 head
- Not getting enough ohmz to dizzy
- Changed my cam gears, marks seem out?
- My intake manifold is packed with coolant?
- PLM Fitment issue on B18C
- HELP! 94 integra rear speakers are working, but no sound is being created.
- SOMEONE PLEASE Help ME OUT
- 93 del sol d15b7
- throttle body sizing (I didn't try to search for the answer)
- Comp cams 59300 Spec
- H22A ticks when warm?
- 2002 civic lx crank but no start!
- Of the wall question
- Will a S2000 oil filter fit on my d16z6? Is there negative effects, positive?
- A quick question?
- Ecu connector identifcation (picture)
- Ignition switch bad???
- Integra LS sputtering please help..
