water pump? b16a
Old Nov 28, 2003 | 11:10 AM
redcrx1's Avatar
Default water pump? b16a
I have a b16a and will be doing a timing belt and water pump soon. I'm wondering if there is a better performing water pump for the b16. I'm going to turbo charge the car once all services are done and I've heard that heat is a factor to deal with. Any help/suggestions would be appreciated. If I do go with a OEM water pump, is the pump part number the same as the delsol vtec? Thanks for the help in advance.
Old Nov 28, 2003 | 11:45 AM
EP3_05's Avatar
Default Re: water pump? b16a (redcrx1)
Stock will be sufficient. Just make sure you get the pump for the 94+ Del Sol DOHC Vtec.
Old Nov 28, 2003 | 01:27 PM
Kendall's Avatar
Like he said, stock should be fine, but there are aftermarket pumps that perform well.
Anthony Marino
Oct 27, 2016 12:21 AM
neofreak
Mar 4, 2010 10:43 AM
kantfadedisazn
Aug 5, 2009 01:24 AM
elbeanerhatch
Apr 1, 2009 04:25 PM
EP3_05
Jan 22, 2002 03:57 AM
