View Full Version : Tech / Misc
- late for work...need answer ASAP...JDM H22A in a '97 integra....HELP
- Will a JDM final drive fit into a Y21 Tranny..
- Hood pins
- Where in So Cal can i get my block resleeved for a good price.. Pls Help..
- Building an LS.VTEC.... Problems
- ignition timing advance question:
- motor leaking oil! real bad.....
- removing a-pillar
- ITR Head Clarification
- toggle switch question....
- would overfilling my oil cause it to leak?
- H22A hybrid in civic....will not start. HELP!
- CFK, crankshaft fluctuation sensor code 54, help to diagnose
- Greddy Trust Exhaust ID
- exhaust piping for ES oval muffler
- i have a question about b18b1 rocker arms...
- how do I get the tranny cases to go back together.
- Need massive Help. Turbo Type R kind of starts.. ????
- ECU Fuse keep on Blowing PLEASE HELP
- CEL code 23, knock sensor. How do I fix???
- PLEASE Help NO Fuel PRessure
- EG civic coupe auto x pics out there???
- Adjusting timing?
- what injectors to use?
- PGMFI Project Web Page Revamped! Come hack your ECU! Coders Needed!
- anybody use skunk 2 stage three cams????
- Taking off the Rod end Cap?
- SHIT!!! Where did my Vtec GO?!!
- popping out of gear??
- piston slap,spun bearing, valve lash, etc...how can you tell the difference??
- 90 CRX Starting problems
- Timing Belt Problem
- my ecu light is going crazy
- When you are coasting in gear...
- VTEC Head on a B20 without the VTEC?
- ARP Headstuds for a GSR work with an LS head?
- OBD 1 diagnostic
- help miss fire
- Will a 95 lx intake manifold bolt on a 98 cx??
- my EG wont start!???!?!?! help
- Detonation in the b20. What to do??
- another oil cooler question...
- yet anohter VAFC question from me....
- b18 vs. h22
- very basic alignment questions
- Im getting AGX shocks, but what coilovers?
- hybrid wont start..
- shifter feels like jelly
- adjusting camber?
- Head swap
- rev limiter on MSD
- Sporadic shuddering from front suspension (95 Integra)
- need help to eliminate rotor shake
- ctr pisons in a b18a block
- oillar pod
- Cylinder Bore Dial Gauge Question - Getting a proper reading
- JDM B16a1 Auto tranny, same as other trannies?
- Attn ECU Guru
- Probs In LS/VTEC land!!!
- B16 02 sensors - help!
- Rear brake pad replacement
- i turbo questions
- Whats' ESP webpage?
- Where's a good spot to draw oil for my turbo feed line?
- hmmm... I drop a bolt into my girlfriends tranny....
- What would my c/r be?
- these alignment #'s ok/
- Does the JDM ITR ECU have a speed limiter?
- Golden Eagle Deck Plates.....
- O-ringed head
- does anyone know what a stock intank fuel pump flows?
- HELP! Need instructions for GC coilover install
- Tensioner Bolt
- A'pexi V-tech AFC fuel controller?
- PCV box Leaking Oil
- Ahh. stupid some help here
- blue wire for 1998 automatic integra
- need DPFI-MPFI help
- itr shocks mod to fit ex...will it work?
- gona make my own exhaust piping..wat do u guys think?
- Helms, tie end rods, inner, outer ??
- H22 Check engine Light
- 02 sensor wiring on 98' GSR
- ITR pistons GSR block?
- ... suspension questions
- estimated B18C5 lifecycle at 215+whp NA tuned
- good alarm antics
- Injectors
- b16 oil pan, ls block
- what do i have to do to make ctr pistons and eagle rods go together????
- ***92-95 D16Z6- SOHC vtec. Transmission Bearings Replacement***
- Whats the most the following blocks can be bore.....
- High revs = blown oil pan gasket?
- header, stainless or ceramic? what's the dif?
- differences with JDM trannys and USDM?
- What are the unused plugs on some engine harnesses for?
- d16 head bolt on pattern?
- crankshaft pully tool?
- lower control arm replacement
- My Diesel B18B motor...
- a little guidance from an expert
- O2 sensor
- gutted stock cat vs. carsound cat
- A/F ratio....
- emergancy, h&r sport
- skunk2 intake maniflod install question
- Extended Wheel Studs
- VTEC gone crazy, please help
- anyone with an EK using ITR rear swaybar?
- REAL QUIK: Engine Question... HELP!
- transmission gears
- What's the purpose of the dowel pin & o-ring in the middle of the head?
- NEED HELP!!! Tranny (LSD) Question???
- When do I become a full member?
- value cover 911!
- Called up ground control today.
- let it idle or shut it down
- Imrpove shifting of an Automatic Transmission
- B20 Block guard?????
- 99 SI suspension question.....
- CR-Vtec or Boosted B20
- Fuel management on a D16
- True Defenition of TDC
- Anyone ever do the DIY Wideband o2 sensor?
- Help with IGNITION Problem
- Anyone using SRP pistons ? (all motor)
- What to do to my LS?
- Relocated oil filter/oil cooler
- Color cods, Need help
- help with b18c
- INT radiator into EG
- b16 block vs. b18 block
- Part throttle surge!!!!
- wut are the best settings for a Vtec controler
- Car won't start..
- it keeps revving
- is this starter problem, ignition or what?!
- installing type-r cams
- should i get skunk2 or ferrea valves
- si question
- Quick question, can't remember the size.
- tuning
- chipped p28 in 00' EX
- Damn, Timing Belt Jumped!
- GSR tranny With B16
- Valves Bent? Rattle...
- Dimond Star Motors
- LS -> GS-R / ITR Engine
- Nissian 240/silvia
- question help throttle body
- Motor hesitates at 1500-2000RPM...what gives?
- How fast is this motor?
- removing clips in ecu plug
- You know the difference in DA and DC-R LCAs???
- FP with stage 1 cam, and basic bolt ons?
- MES (Memory Erase Signal) connector for SRS light
- need some advice
- how fast can a 94 prelude Si, v-tec go?
- Torque Spec for Type-R Rod Bolts?????
- 00 si check engine light
- ecu fired looking for best replacement
- Cry for help, W.Chester, PA, finishing mini-me, need tuning help
- How is my exhaust going to bolt up w/my engine??? I am stumped big time..
- advice on b18b rebuild
- how do i get this off????????
- any civic owner or enthusiast pleze help
- Dyno HP question
- Will a GS-R axle fit on a ITR?
- Using a Ford Mustang throttle body....anyone ever do it
- What pistons to use?
- Porting a GSR Intake manifold?
- ECU troubles: bogging, and no power !
- OT :- anyone know web sites where i can get ...........
- best programs for p28 ECU with GSR swap in a 99 HB?
- For those with aftermarket lightened flywheels...
- shift knob help
- Starting problems with Hondata - Need help!
- Fuel Pressure?
- Can I drive my car like this?!
- Dry throttle body Not Air cooled...What does that mean?
- Micrometers: Friction THimble or Ratchet Stop
- harness of 1998 integra and 1999 Si???
- HELP with turbo setup and low oil press
- Installation and Removal of Spiral Locks .... some Tips here
- Dash went out...
- greddy blue box for obd2 car
- how do i tell if its a real type r motor?
- Push starting with an ignition kill installed…..possible?
- what's the difference in size of these throttle bodies
- Can't get timing right........????
- engine rebuild misc parts advice...
- C&R radiator core how thick?
- Need help, its being a slug.
- b20 or b18c?????
- Type R Suspension
- d-series cranks
- Cable transmission
- when to change timing belt on 94 integra??
- JG Edelbrock intake manifold
- resleeving b18b
- 4 wire o2 pinouts
- K.O.S Header - Read inside
- Interchangable Parts for B series.
- H22 with forge pistons..
- Anyone here have air ride on their honda/acura??
- Clutch ????
- wheel studs
- Fitting aftermarket rods on OEM pistons?
- Head work time......need some help!!!
- b18c5/ls swap
- Intake Manifold Gasket
- What is the absolute best penetrating oil?
- Who's running a moroso oil pan? b series
- how to remve civic dor panel
- Need a good site for specs...
- Axle Nut 2 Tight?
- Will P215/45ZR17 wheels fit a '93 Del Sol?
- H22a eninge in a 1995 civic?
- PCV Valve?
- Flywheel Holder?
- Code 1 - help?
- Mini-me questions.
- lovely scratching sound from the right rear side of the car....
- AXEL REMOVEL..... need help!
- dont want to fuck up my ps rack...........
- AEM short ram intake performs WORSE than my generic short ram!?!?!
- what is this grinding noise...i need to get to school tommorow morning!!!!!!
- car's steering feels tighter after header/exhaust installed?!?
- ABS Light
- master cylinder swap question
- i need fuel help!!!!!!
- Bad throwout bearing. Live with it or replace?
- hondata base map for boosted d16
- auto ------->5speed
- map sensor problems
- Transmission and Clutch question.....is it possible?
- a/c belt broke now car will not run?????????????????????????????
- 2 good general tech questions
- 200 WHP from B16A2 Possible?
- I Need Help With SpeedPro Setup Parameter
- idle problems...check engine
- Z10 engineering
- Main fuel relay-1992 GS-R
- im still having rod bearing problems
- What the hell am i suposed to do now?
- Difficult getting into 1st and reverse....
- How do you know when...
- strut bars and lower tie bars
- 91 hatch STD to 95 b18b motor
- DC Sports gasket question
