View Full Version : Tech / Misc
- Golden Eagle Sandwich Plate Leak
- Electrical conductive compound
- car losing power
- will a gsr valve cover fit a b16
- wire issue!
- VOIP FORUMS
- real spoon cf duckbill for eg
- Can you reuse the head gasket
- Funny idle when VSS is connected to ecu
- Brand new A/C expansion valve faulty...??
- vibrating glove box??
- no spark
- car wont start OVERHEATED (d16y7)
- having a little issue here
- aem ems questions...
- Chiltons or Haynes??
- smog problem?
- all electrical power gone
- ect sensor causing low rpm starts?
- Burnout bog down..
- which oil dip stick do i need
- Bad Ignition Timing
- where to buy vss?
- how to test for a bad head gasket
- Check Engine Light One
- need help b20 wont rev pass 2K
- 7.5A Electric Impact Gun
- ticking/knocking noise from a serviced head
- Re-use Head Gasket?
- where can I get extended studs for the head?
- car wont turn over, help me out H-T!
- CRX H2B alternator problem
- What head do I have
- 92 Integra GSR Start Problem !
- car starts then immediatly dies
- How to bypass a resistor box.
- oil pressure
- Need a Honda Guru! RHD TEG WONT START
- integra window won't go down
- a/c install on integra
- "X's" on headlights
- ? injector seals for s2 rail
- B16 Oil Leak Question, What is this!?
- Oil leaking everywhere!!! HELP!!!
- b20vtec help
- HELP!!! 91crx dx ignition timing
- cpf stickers?
- Code 9
- B16 chaindrive or wheel
- wiring diagram for 97 civic
- need opinion
- newbird for tuning
- e-manage or hondata
- project cars are frustrating!
- i need help with my type r
- dohc zc motor and tranny swap.
- Please help me diagnose, car running rich
- Refinishing Header/Header coating?
- Rear wheel bearing on 97 GS-R did not come completely off HELP!
- Autometer Digital Boost Gauge install question
- Which Timing Belt Cover?
- 1999 honda passport climate control unit help
- K20 oil pan
- Catalytic Converters
- flywheel lightweight or stock
- Rev limiting at 2500
- spark plugs
- d15/b18
- Having a slight issue with my d16a6 in my sandrail
- Removed A/C condenser - options for block off?
- HT: Help me! Oil Restrictor/Fitting Size Issue
- weird noise when decelerating
- what kind of water/oil pump?
- eg fenders
- need help for firing order obd1 sohc zc p28
- oil advices... d16 "low" oil pressure.
- CV Joint Measurements
- Recaro Repair
- Check Engine Light Question - How to turn off
- skunk 2 inlet manifold question?
- car won't start need help
- problems adjusting TPS
- Intermittent prob in my 93 4dr ex...any ideas?
- RUNNING HOTT ISSUE!?!?!
- ISSUE with B18 swap
- Rough idle, car running poor/too rich. 93 Accord w/F22B SOHC VTEC
- HELP! List of my engine build problems
- question about exhausts
- help tachometer not working
- What mirror is this?
- apexi vafc1 issue. please help!
- CRX EXHAUST
- Cant get my damn VC off?!?!?
- Honda's air conditioning o-rings full specs
- Aero Designs Cross Strut Tower Bars for the Civic
- b16 gears in a ls tranny??
- [HELP] Car will not start after sitting for 6 months.
- civic or db8 or dc
- compare/opinion/review low down seat rails
- How does 5Zigen Border sound
- aem ems questions?
- please help oil in intake manifold
- aem fuel rail help!!!
- WHAT HAPPENED TO MY GSR HEAD? PICS.....
- trans question.
- Smoking Si
- Piston specs
- Auto Tranny gear changed. Help
- Need HELP!!
- fuel pump not priming please help
- Leaking A/C Compressor
- couple questions from the honda noob
- d16 to b16. big project??
- NEED HELP WITH MY INTEGRA
- B20 and ITR/CTR oil pumb
- sluggish after driving on interstate
- LS & B20 part swaping ?????
- H22a How do I wire IAB to Vtec
- NEED HELP Im going H2B I have 3 trannys b16 LS and GSR I want to make 1 h2B tranny!
- injector sizing
- Idle fluctuations
- REAR O2 SENSOR
- Ceased Trailing Arm Bolt!!!!
- speedo problem
- Any good machine shops in Wisconsin?
- better oil pan baffles?
- Help me to identify this B-series oil pump..
- Cam replacement/timing question
- GSR Swap into EG Hatch
- how do you fix rasied sleeves in a block?
- ignition problem?
- How to set your idle?
- B20 Head stud Question READ ME
- Measuring cams camshafts
- Cheap/easy way to quiet interior
- scratched cylinder wall?
- Bypassing map sensor !!!
- Fuel pump not priiming. Help
- looking for good philly area tuner
- no headlights, taillights, dash lights or corner lights or brake lights on 91 accord
- Car overheats! help
- SpeedOMeter & Tach Jump
- msd install
- Nail in tire...need advice ASAP!!!
- spark plug wires poping out of the head
- clutch fork stuck. help.
- Remove a broken tap
- 99 civic si A/C installation
- HELP ME " WHAT THESE PARTS ARE FROM ?? @LOOK@
- exhaust system preventive maintenance
- How do you install gauge cluster needle
- b16 head part questions
- Anyone know where I can get this Wēk'sôs decal.
- Added too much R134a
- Autometer Stainless Steel Hose Kit for Mech Gauges
- Vtec contollers
- making a knock light, electrical guru's help!
- Where to buy OBX Twin Loop
- Header/Exhaust Gaskets, where to buy?
- Relocating battery
- Shimming oil pump for more pressure
- Tranny stop going in gear!?!? Help
- WHATS WRONG WITH MY CAR!!!!
- Bent shift rod? (where the bitch pin goes in)
- Distributor problem
- Question about oil burning in a B16a
- turbo ls over heating
- CEL 9
- Stuck in limp mode.(searched)
- Measuring for rod and main bolt stretch
- Installing valves
- reusing arp head studs
- RPS Carbon Carbon Install. HELP!!
- What can cause a spun rod bearing?
- H22A Swap issues
- which size straight edge should i get?
- Major Issue with Ridgeline RTL 17 codes...ecu, wiring?
- weird problem
- V-Tec Question
- b16, ait sensor hits fpr?? fuel rail help
- Check engine light No vtec !!!
- Are 90-93 and 94-97 ac compressors the same?
- browish orange spark plugs?
- Honda Accord Euro-R H22a7 engine problem
- power window problem.....PLEASE Look!
- Mastercraft 8 Gallon Compressor - Good for any car job?
- WTF happended! HELP
- plastigaue for oil clearance, help
- b18 wont respond to ANY throttle movements
- what is this cluster?
- my h22 build
- What would cause no fuel injector adjustment
- axle problem solution...pic inside...
- Honda Civic: Humming Noise?
- ned part idef. help!!!
- B18 Timing belt gear issue
- d16 bare block build parts list?
- what is B18 and B20 diffrences?
- euro export valve spring compressor
- Could tps be bad but not throw cel
- Who has experience with car shipping?
- full-race cam gears
- Quaife rack/pinion kit problem
- anyone know of a B2K
- What kind of tools do you guys use?
- Rekey a door lock?
- rebuilt motor,,water out the tailpipe
- idle problem
- Car stumbles, then i smell gas
- Racecar fuel issue??
- HALP!! ecu guru's chime in mystery ecu
- Question on timing belt kits?
- b18b pcv question?
- Tracking down my battery killer (Possible electrical short?)
- ECU HELP
- Good Alluminum Degreaser?
- FUEL PROBLEM HELP
- Engine breakdown for storage
- Battery fuse keeps blowing
- How do I find out if my motor is stolen?
- i meesed up bad need help!!!
- Bare b16 head, need assembly help
- How do you compare combustion chamber size with Compression ratio?
- (Jack) Max. Lift Height on Jack, Allowable Clearance Space for Working Underneath Car
- About how much to reupholster a seat
- code 43 gsr
- block damage
- b16a and LS vss compatability?
- IS MY CLUTCH GOING?????
- Are all f-b-d-h altenator pulley the same?
- Iridium IX Spark Plug turbo honda
- timing belt drive pulley 22 tooth
- Clutch wont disengage?
- Tire tear?
- GREAT unexpected way to remove rust from ANYTHING?!
- Look at this tire wear...what happen?
- Looping Power Steering in 93 Integra
- b20 project wont start
- fuel filter ?
- tach issues
- helppppppp installll
- helppppppp
- Difference between b20 and b18b oil pan?
- Pressing a bearing that is .30mm larger than the bore?
- Car wont idle once warm
- Temp gauge problem
- camshaft question
- ABS Light Stays On - How to Fix?
- CP Pistons?
- Driver Side Axle dilemma
