Map Sensor? Does it or is it supposed to click/tap?
Old Nov 27, 2003 | 06:06 AM
KTeller8's Avatar
Default Does it work if it clicks/taps?
i was looking and doing some minor tuning and i heard some tapping.. never noticed it before and made my way up to this sensor, where i heard it tapping and clicking.. unplugged it and the noise stopped,,.. so its the map?
what you think? this ok? or time to drop 175+ and get a new one?
Modified by KTeller8 at 11:08 AM 11/27/2003
Old Nov 27, 2003 | 06:54 AM
SpoolnG2's Avatar
Default Re: Map Sensor? Does it or is it supposed to click/tap? (KTeller8)
never heard of it doing that, but if you unplgged it and it stopped, then i'd say thats the culprite. However you dont need to spend $175+ on a new one. I actually have an extra one sitting here if you wanted to buy it for me. If your interested, just PM me or Instant message me at SPOOLNG2. godd luck otherwise
Old Nov 27, 2003 | 07:06 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">i was looking and doing some minor tuning and i heard some tapping.. never noticed it before and made my way up to the map sensor, where i heard it tapping and clicking.. unplugged it and the noise stopped,,.. so its the map?
?</TD></TR></TABLE>
No, there's no moveing parts in a MAP sensor. If you unplug the MAP sensor the engine will stall. (Or come close to it.) Are you sure it's not the IAC valve?
Old Nov 27, 2003 | 07:53 AM
KTeller8's Avatar
Default Re: Map Sensor? Does it or is it supposed to click/tap? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
No, there's no moveing parts in a MAP sensor. If you unplug the MAP sensor the engine will stall. (Or come close to it.) Are you sure it's not the IAC valve?</TD></TR></TABLE>
hmm it says like Denso on it.. i can pull off some numbers if needed, it connects by a 3 way t with a few other parts .. might is above the intake arm?
let me see if i can find a picture.. i could be wrong on the part
Old Nov 27, 2003 | 07:56 AM
Chiovnidca's Avatar
let me see if i can find a picture.. </TD></TR></TABLE>
Yea, a pic would be good.
Old Nov 27, 2003 | 08:07 AM
KTeller8's Avatar
your right its not the map. i just seen the map on the TB and it says map lol..
NOT MY PIC
but looks like this is the best i can do..
why is his close looped? Mine runs down to a little T or 3 bracket...
Old Nov 27, 2003 | 08:16 AM
Chiovnidca's Avatar
Looks like the purge control solenoid.
Old Nov 27, 2003 | 08:20 AM
KTeller8's Avatar
why is his close looped? Mine runs down to a little T or 3 bracket...</TD></TR></TABLE>
Old Nov 27, 2003 | 10:33 AM
mmuller's Avatar
Mad Scientist
its closed looped, cause i guess somebody wanted to eliminate it, one of the ends is supposed to go to the evap canister and the other to the im. you can just take it out
Old Nov 27, 2003 | 10:37 AM
KTeller8's Avatar
Default Re: Map Sensor? Does it or is it supposed to click/tap? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">its closed looped, cause i guess somebody wanted to eliminate it, one of the ends is supposed to go to the evap canister and the other to the im. you can just take it out</TD></TR></TABLE>
any benifits to why you would bypass the canister? would all byproducts run straight to the manifold then?
it would only be good for me to bypass only cause it would free up some room and i can knock otu other problems.. or hose realted issues i think..
Old Nov 27, 2003 | 10:45 AM
mmuller's Avatar
Mad Scientist
horsepower wise its not going to do anything, since the evap dont work at wot.
taking it out will save space and weight. once you take the evap canister out you can route the hose that comes from the gas tank to outside of the car or under, so the gas tank fumes dont go inside the engine bay
here are some more threads about this:
https://honda-tech.com/zerothread?id=463317
https://honda-tech.com/zerothread?id=521563
https://honda-tech.com/zerothread?id=613953
Old Nov 27, 2003 | 11:14 AM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">horsepower wise its not going to do anything, since the evap dont work at wot.
https://honda-tech.com/zerothread?id=613953</TD></TR></TABLE>
Thanks way to much work for me.. this car wont be around more then two more months..
once its fixed and runnign right. its out of here!
rdssk8rcs1
Mar 10, 2008 07:52 PM
kpowerdhatch
Oct 20, 2007 02:43 PM
kornerk12
May 29, 2007 05:26 PM
hatchinprogress
Nov 23, 2004 08:21 PM
11psiTurboSI
Apr 13, 2004 07:42 PM
