View Full Version : Tech / Misc
- JDM B18C V-TEC Pressure switch
- HONDAs mass air flow system
- howstuffworks.com wrong on fuel injection
- Someone must be wrong
- major problem with brakes guys.. need help..???
- how low can i go on my em1
- Car dies sometimes
- vtec solenoid wiring on a h22 in integra p28 please help
- Problem with Coilovers and ride height In Civic Si...... Tein SS
- D17 Gearbox with D15B Engine
- Does anyone make aluminum trailing arms? Are they even possible?
- VAFC INSTALLATION HELP
- Question about a mount
- b20 oil pump on ls block?
- Testing Lost motion assembly
- can anyone help?
- What's wrong with my motor...
- Car Idle's Ok, but car won't barly move with some gas
- Man what now (alternator related)
- Brake Question
- Sway Bar Question
- Can an upgraded ignition kill power?
- Dual VTEC head springs with Type R cams...
- Turn right or left there are noise come from the wheels ?
- Check engine light
- What Happened? (Help Please)
- b18c1 skunk2 intake manifold in b16 head
- Nippon racing CTR pistons with racing nitrite coated rings (BUY OR NOT) Help!!!
- compression test on the R
- Where to Find Honda Hardware.
- Smsp header vs Anr header
- Cleaning O2 sensor?
- LsVtec B18c5 head?
- Brakes squeel like pigs in a butcher shop...
- b16 swap - Part identification help! please
- Trying to install air fuel guage can someone help?
- Car shakes like hell!!!!!!!!!!!!
- Stock ignition 450whp??
- H22a EK civic clutch replac. ques....enuf clearance to drop trans?
- is the gsr timin belt same as the ls timing belt?
- Radiator Install on 1994 Integra LS
- Any place in the fuse box under the hood that I can get a 12v only with the car on?
- NO SPARK got fuel, wtf ??????
- MSD Digital 6 Query
- changed fuel filter, still bogging!!!!!!!!!!!111111
- wideband air fuel guage.
- size ratchet for removing spark plugs?
- ed in the wrong thread, but i tried posting it in the motorcylces thread but i got no help so im loo
- HeLp with piston install...
- What should the tps read at closed throttle??
- cam gear
- HELP!!!!!!! valve cover problem
- RC engineering 770cc injectors - what style plug do they use?
- Engine Starting
- using kerosine to clean engine?
- solid cel after getting codes...
- Dyno: Built D16A1 lacking power (big time)
- lowering springs
- New GSR Intake Manifold
- piston ring question
- Honda techs help!
- HELP! rpm/ acceleration problem
- A/C help!
- Brake Problem
- Any body ever wire up a EGR valve/ EGR control solenoid?
- Difference Between PR3 and Pr4 ecu's
- Help! Clutch won't allow shifting into any gear.
- 1st gen B16 throttle body compatibility question
- header problem.
- Jdm H22a motor swap... QUICK QUESTION/opion
- NEED ECU PINOUTS FOR OBD2 P2P
- dyno ?
- not sure whats wrong, ill try to explain, help please
- b18b head gasket question
- NA motor build question
- pocket programmer password????
- Engine Bearings??? ACL and King ???
- sorry for the newbie question but...
- fuel pump and injectors.
- jdm gauge swap
- Custom pistons.
- Timing Belt off?
- Classic no start situation
- Engine Swap
- cam gears
- gear-dependent boost controller
- What head gasket for LS VTEC...
- charcol canister 99civic si
- Car starts to shake when not moving and then shuts off . (Please help)
- 2000 civic obd-2b CEL codes
- Head swap
- EMERGENCY!!
- help jdm tranny question
- vacumn
- high reving....
- Block drain bolt for coolant - need to replace washer?
- B18c1 into 00civic, wire harness questions
- replica mugen muffler
- Honda Technician School???
- I got my valve springs mixed up!
- Engine Coolant Drain Interval now 110,000 miles?
- pr4 vs pm6
- Vlavetrain / Camshaft replacement
- zc cometic headgasket
- CEL code 4 (crankshaft position sensor)
- Skunk2 Stage2, where is the power at?
- Is a flywheel considered a Motor mod, or a Drivetrain mod? Please reply.
- distributor question
- D16A6 stock bottom end limits
- Im I running rich or lean? CEL 45
- reving out at 6000 RPM with a JDM Type R Integra Comp
- AWD/ VTEC
- Converting automatic PR3 ecu to manual...
- What would cause distributor rotor not to spin??
- Alignment Degree to Inch?!
- Help with OBD
- skunk2 drag launch kit
- really bad alignment = seperating axle
- help! gsr intake springs are shorter
- 96+ civic parts and 96-97 del sol parts.. whats really different.(manual swap concern)
- turbo gauge question
- Vtec engagement/backwards.....did a search
- 96 Ex o2 Question...HELP PLEASE!!!
- Water Pump Leak? New motor/pump/gasket...
- Replacing rings with block in car
- ticking under load
- possible to weld un-like metals?
- rod bearings, what size......this one is tuff
- Plug wires???
- How do I check CEL for an OBD1 conversion form OBD0?
- Want to replace only one cam cap bolt-Torquing Question
- 92 Civic brake MC to BB compatibility
- redline from the start up
- Accord vs. TSX
- o2 sensor question
- CAR SHUTS DOWN
- 04 Ex Civic
- EDM d15b2 1992 to JDM D15B head swap
- ECU QUESTION
- when i jack my car w/factory jack i cantr slide my jackstands on the same spot so how do you lift th
- Clutch went to the floor, what happened?
- Aluminum VS Chromoly Flywheels
- which Camshaft??
- ls block clearance size
- NEED INFO
- why?
- LSVTEC Power steering Bracket??
- Head gasket set
- Plug on oil pump .. ok to tap?
- ctr rod torque specs
- water pressure sensor fried?
- those f*@^%g heater hoses under intake manifold again!
- piston rings... what are the best?
- b16 high compression pistons
- crower 403 or 404
- b16a and tranny
- main cap/crank brace
- S2K oil filter on B16 results
- Hondata part number for CN2 pin header
- Zdyne people.. Just put in my 3 bar map, running real rich, what to adjust
- are ARP head BOLTS ok for boost?
- Confused wit part #s for ARP head studs on LSvtec.
- im confused...help on emissions?
- N1 SUSPENSION
- B16 ecu flashing code 23
- b16 swap/oil light stays on
- fresh rebuild and thre is oil all over the engine bay, wtf gives seriously this shit is pissing me o
- Legend of Mosquito Joe
- Compression test analysis
- VTEC Solenoid compatibility question
- rust around a rotor?
- Usdm ITR vs. JDM ITR pistons in b18b/a
- any1 can hel me pls?
- what works better
- ECU WIRES
- Clutch Won't Disengage at High RPMS, PLEASE HELP...
- oh brother where art tho injectors, dawg?
- ::Coilovers::
- b series cam specs
- Wideband o2 sensor
- Engine codes
- this is gonan be the nubest of the nub questions ever , but here it goes
- Skunk2 IM problem
- who makes these cams?
- VACUUM LEAK****PLEASE HELP****
- brake questions
- Questions about Vtec after dyno tune
- Brake line and Caliper Fitting Size
- odb2 to 1 quick question
- What is required to remove A/C?
- Average temp of a header during operation ?
- Valvoline Needs Help
- turn left and white smoke out of engine!!
- help VAFC setting...??
- B18C1/B16A2 HEAD
- where is the water temp sensor??
- full sweep oil press. gauge options.
- b18c-r eagle 900hp h-beam or extreme duty rods w/ toda pistons
- prelude 5 lug same as type r 5 lug?
- Hubcentric ring bore size for Rota Circuit 10?
- car dies when warm...
- Need help Installing Passengerside Front Hard Brake Line
- Can someone help me decide on this exhaust setup???
- compression test results... your opinions???
- 7000 rpm launch=loose heatshield, opinions on exhaust repair tape or?
- changing aspects of the suspension
- Swapped my d16z6 Throttle Body for a B16, Now jumping idol Pls. Help
- IDLE PROBLEMS......*****PLEASE HELP****
- New oil pump gasket?
- Doesnt look like anyone plays with trannys anymore?
- Timing belt questions
- Oil leaking from exh. ports? Doesnt burn off though....
- Type R pistons , pr3 rods will they fit B18a ?
- cat questiion
- Got a question! Need help!!!
- octane
- Rev Potential of my bottom end
- Injectors not injecting fuel?
- correction rates
- CRX tokico illuminas
- speedometer only works in reverse....
- del sol dual core radiator in eg ??
- Motor has trouble starting
- Vapor Lock
- I NEED HELP WITH MY WINDOW...
- Eagle rods: Honda or ACL bearings
- 125 or 150 shot on B18A1
- Air compressor keeps blowing my damn house fuse....
- Helms Manual quick ?
- few problems after rebuild, need help.
- replacing pistons and rods on b18b....
- Compression ratio of a Motor
- burning a piss load of oil,,, on a pretty fresh rebuild, wtf
- Oval Pistons
- can running rich...?
- Need Help, Specs, And insight for the horrible future
- o2 sensor wiring
- painted stripping
- prothane driver side engine mount install
- 2nd gear problem
- what kind of wire to use for shielded o2 sensor wiring
- Friend of mine Over REVVED his motor PICS INSIDE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Speedo and Alarm problem help TIA!
- Brake Booster Braided line?
- Newbie into Tuning Cars
- b series differences
- Intake Question
- Reverse not working.... reverse swap from LS to B16 tranny possible????
- need a fat fender
- Header wraps and purple ice?
