View Full Version : Tech / Misc
- 3 d16 eagle rods and 1 other brand
- d16z6 port and polish
- air conditioning gurus??
- E85 Fuel in a honda Prelude
- battery relocation and distribution blocks
- Measure of adjustment cams and valves jun3
- socketed ecu for hondata/crome/what does that mean.and i need maps
- fresh build few flakes in the oil
- how many miles is too many?
- P0453 FTP Sensor Missing???
- JDM P30 ECU Pinout
- how to clean rusted header??
- No start/weak spark?
- help me identify sensor
- help ecu chip
- King bearings! WTF?!
- crower connecting rod part number?
- turbo exhaust manifold studs keep breaking :(
- Unorthodox Crank Pulley help!
- rings and bearing help
- car starts fine, idles, then dies
- Welded block durability?
- 08 civic stuck in 5th gear
- Oil orifce pins install on bseries vtec heads
- cant get p28 codes
- 2000 civic si misfire
- Power steering pump bracket???
- Using Smaller Charcoal Canister Hole for Oil Pressure Sender?
- what are jdm type-r cams worth?
- Bride rails fit Sparco Reclinable Seats?
- OEM Cat. for 94 Integra to pass C.A.R.B. State Referee
- crank differences????
- my vtec dosent kick in wtf
- another vtec not engaging thread
- 92 eg civic hatch hesitation to start
- record hp for stock sleeve b series motor
- Battery Relocation Ground issue?????
- random loss of power when warm
- Cooling Problem
- Do unorthodox crank pulley make or break power?
- ring filer??
- Intake manifold swaps?!?!?!?! NEED HELP ASAP
- Radiator Support Questions!
- AEM Wideband Question
- Installation MSD blaster 2 coil on honda(b16a)
- B18 transmission bolts?
- 90 Civic Dx overheating problem
- 1990 Civic dx overheating problems
- built engine on long trips?
- can someone confirm whether a 90 teg has ELD?
- Power LOSS wtF?
- acl race bearings?some dont have color code and just to slap on
- cam caps surface bent
- Frequen tLog out on Honda-Tech
- Throttle Plate Sealing Goop
- Help with alternator bolt
- turbo or non turbo
- d16y8
- catch can/breather therory. Something different.
- Can i Reuse My Head Bolts
- cel 23 knock sensor
- Where to buy axles that dont fall apart within a year
- Car wont start, HELP!!!!!!!
- BUILT MOTOR NOT SEALING PROPERLY
- hy-tech replica header flange
- da swap help
- help
- hard to turn bottom end
- What is SRS Error Code 15-4
- 90 Accord EX 2.2 Auto ? about oil Overfilled
- RSX won't power down when key removed...
- Manley Rod Bolts / torque
- AC delete necessary for turbo ?
- b16a3 del sol.tranny wont come out
- S40 Shift Forks on a S20 ???
- soldering dizzy connectors
- OEM Harness connectors
- Putting gauges in place of climate control
- B16 help
- cel 22
- power steering question/ what do i need to go to obd1 from obd2
- gsr swap help
- Rc injectors, O ring not fitting??
- Short Shifter
- The truth about catbacks
- B20vtec compression test
- Cam Gear install d16z6
- link to shop manual.
- transmission case wont sit flush..help
- Why am i getting bad mpg
- How do i get rid of CEL code 17 , 61 , 67 ?
- do i really need a harmonic dampener?
- Is there accident fuel shut off reset button on 87 Accord?
- obd0/obd2 o2 question
- obd2b b20 swapin obd1 hatch
- power steering eg swap info
- My sunroof wont pop up!!!!
- Difficulty Passing Emissions on my CRX
- IACV problem
- how do you set timing??? not so easy with this setup...
- Help behind EG dash...
- Fuel Line Size?
- DASHPOT DIAPHRAGM...
- hood dampers ?
- Dash lights not functioning...
- Transmisoin soft line
- help on Tow Car Dolly in CA
- 95 Civic Wierd Hot Start/Idle Problems
- help me plz
- b20 vtec... help needed
- NEED HELP i deleted cat n throw code
- timing b20...HELP PLEASE
- 96 accord idle surge / aftermarket fan hookup?
- Need help with powerlocks and sunroof...
- Which MSD distributor cap for b16b?
- How do I look? (the engine lol)
- physics project.. gsr specs. please help
- timing problems
- Conrod And Piston Weight
- Popped Upper Radiator Hose 95 Accord LX
- Bypassing Launch Control?
- ECU CODE 7
- Need help identifying my injectors
- 91 Integra GS or 99 VW Golf?
- differences with buddyclub spec 2 exhaust?
- Repairing hard oem fuel filter line help
- b20 swap leaning
- uhhhh where can i find a 94 civic Si Hatch headliner????
- yes or no question about oil pressure.
- swap decision??
- fuel line ?
- fuel gauge issue
- h22a swap!!!!!!
- ITBS and vacuum
- turbo timer
- GSR squealing noise, but not the belts...
- D15B1 to D15B2
- seatbelt help please
- balll hone grit?
- how to remove ignition cylinder on a eg
- o2 Sensor help!!
- D Series
- OBD0 EG Hatch?
- Throttle Body says HAD on it whats that MEAN?
- Where can i find a new Trans sticker Y21
- civic trouble
- 95 gsr,,vtec comes in and out when i race
- Engine mount name please
- D15B Oil Pan Emergancy!!!
- Engine Builders: Non JE rings on JE pistons? A (logistics) dilema.
- Prosport Gauges - A Warning
- Problem....Distributor??
- Hard going in and out of gear help!
- lost motion
- Delta 272 clearance ???
- cranks, pump wont prime, no relay click, permanent CEL
- Propane Torch on Caliper Bracket Bolts
- Valve spring compressor
- Can ANYONE Figure out this overheating issue?!?!
- obd2/obd1 Harness Question
- Interior fully sprayed with rubberized paint
- The situation 99 ls motor in a 1994 civic
- single cam crank specs.
- Bouncing idle No CEL and TPS tested at .719 closed and 4.57 WOT TPS to blame?
- Electrical Issue... Suggestions Please?
- Which of these plugs is VTEC?
- reading spark plugs/compression test
- Distributor Rotor Life
- Code 71 and 72?
- B16 valvespring retainers
- DC header question 91 DA
- How do you guys rev match??
- SirII engine block numbers
- 94 civic Hatch putting in Rear Disc Conversion
- How many timing belt washers ???
- Changed spark wires and now won't start!
- I think my car is running lean
- TURN OFF SWITCH???/
- GSR swap wiring up VTEC
- fresh stock gsr build (220milse) do i need get it tune???
- eg door lock help????
- Car wont start, I'm gettin pretty pissy
- 92 hatch b16a problem
- Do b16 and gsr trans use same starter?
- IACV how can i check it?? H22A
- ls motor compression test results
- alternator quick question
- 90 accord ex 2.2 Auto ? about power drainage?
- Quick B series questions.
- RBC Intake manifold adapter for B-series?
- B18c1 Bellhousing Bolts
- Two issues: Temp guage and door locks
- strange gsr idle issues
- Heater core delete plug?
- Speedometer acting weird
- Аnyone used CompTurbo?
- EG One piece fiberglass front end
- !HELP! Idk why my DA startup idles at 2000 RPM
- Honda Technicians: Is there such a Honda specialty tool?
- getting pre ignition....
- Weird jdm itr misfire problem
- Question about if my engine is the original or not?
- Dropped cars can't be aligned
- DA Integra Check Engine LIght Question
- i have a few questions about B series valve cover venting with AN fittings
- New Gaskets worth it?!
- How much does honing remove????
- 93 del sol engine died while driving need help
- traction bar question
- The simple 5 lug conversion.
- my 94 civic y8 swap wont start now?
- Code 8
- 92 eg hesitation to start
- Help my shit wont stop!
- Does ANYONE know? JUST LOOKING FOR A SOLID ANSWER!! INPUT PLEASE!***
- Just swapped JDM S20 Transmission problems :( help?
- B18a1 timing question
- Wiring... what is this plug/wires
- crx connector issue on f20b
- piston and bore size
- Bad OEM Oil Filter Bypass Valve
- 2 quick questions
- hidden coolant leak, no idea where it is? help
- 96 hatch coverting steering wheel back to stock, need horn help
- Help Possible clutch problem?Idk
- Need Help, No Fuel
- crank pulley cracked... unsafe?
- Changed dizzy, now car is slow
- P72 obd1 ecu with obd2 injectors no resistor box?
- 90 Accord Coupe EX 2.2 Automatic ? about transmission Computer
- h2b video install
- Help 00 ls motor in a 94 ex civic
- What to do with Evap line?
- fuel injectors
- help loosin antifreeze
- A/C Compressor Shims
- 94 Civic automatic harness, convert to manual?
- Odd cams, quick ID help
- cams how do you measure the lobes
- help with 96 hatch w/ stripped steering wheel stud/post
- d16y7 into eg wont start, no spark help
- Cometic Headgasket instillation necessities: What NEEDS to be done?
- Can I use this seat bracket/slider/sidemount combo?
- identifying cams
- Electrical help please (should be easy)
- d16a block w d16y8 head need some help
- B series alternator.....I thought all obd0-obd1 were the same
- help with noise/knocking ***video inside
- Firefox 3.6 keeps freezing and becoming non responsive
- Exhuast Pipe Size????
