- Civic Ex 97 Engine compartment shaking
- i blew engine but i dont know what actualy happened help..??
- b16 and b18 what is the difference
- Dreaded P4020 code 1999 Honda Civic LX
- .040-.050" headgasket in 84.5mm cant find it
- Please Help
- gsr trans only goes in gear with the car off
- 1995 GSR IAB Problem
- b16 in ex not getting spark or fuel
- 1996 honda accord problem
- Mystery flywheel
- NEED HELP HESITATION WHEN I SHIFT
- Zeitronixs ZT-2
- b series ktuned shifter
- Power to manual rack
- Timming issue
- 99 B20b high comp swap car breaks up
- Timing Belt Problems
- Looking for South Texas tuner
- B16 Camshaft Caps Dowel Pins
- d16z6 valve seat replacement
- 98 Integra not cranking
- What (sensor) is this next to the oil dipstick?
- Rebuilt H22a burning alot of oil
- Huge power loss, loud exhaust
- 2001 hons CIVIC LX - CRANKS BUT WONT START AGAIN1
- B18C1 Oil Pan Sealant?
- Horsepower Math Challenge - Calling all math nerds!
- Spal Fan Relay?
- oilpressure failure ?
- Supertech Pistons ??
- 99 civic rear jack point
- 97 hatch cranks but won't start
- Building / bending your own hard lines for fuel and turbo oil feed...
- 1994 civic hatch h22a
- B20Z2 DA Integra Fuel Pressure Regulator question
- GSR/B16 CRX Project Ideas!!
- 94 Civiv EG Hatch - Ignition Lock Buttons all Too Big??
- a season-high 13
- Would you drive another 10000km on a 10000 km old honda oil filter?
- Door wont stay open..
- How would you plumb up a b16 coolant expansion tank?
- HELP!!! 1993 civic lights dimmed/no power
- H2k adapter ?????
- Skunk2 Pro1 Cams Pitting..
- heater/front defrost blowing cold air?
- flywheel fixable?
- any tips?? eg auto to manual trans conversion
- D16Y8 Full Build - Oil Clearances
- 1998 Honda civic dx d16y7 throttle body adjustments
- Skunk2 LMA vs Science of Speed LMA
- What's the difference between a non vtec head gasket and vtec head gasket
- 1990 accord now has misfire after changing alternator
- oversize valves +1mm
- Heater wont work (how to diagnose and fix)
- Front motor mount hitting frame. How do I fix it??
- H swap won't start. just cranks and throws flames
- 1994 honda accord failed high NO
- Tanabe racing medalion t3008z on 91 acura integra
- left wheel grinding
- b18 bearings
- How to charge Odyssey PC680
- TAKATA MPH-341 vs new TAKATA (made by SCHROTH)
- 92 Prelude Si Electrical Problems Please Help!!!
- Intermittent hesitation around 2000RPM
- Possible ignition problem, or slipping (new) clutch
- strange overheating problem
- Who has good understanding of Automatic transmissions?
- Misfire code
- hisseling sound exhaust drives me crazy !
- Strange hiccuping when decelerating out of VTEC?
- b18a1 build help
- 2000 hatch dx replace window cranks?
- How to Aim Headlights (and fog lights)
- ls vtec oil pressure issues??
- Idling up and down
- B18C misfire problem
- Stalling problem
- B16 TPS problem code 7 obd0 wiring checks out new TPS
- best degreaser?
- How to measure rod bearings?
- S2000 odometer correction/change
- dash swap, VIN rivets?
- AEM Digital Water Temp Sensor help!
- oil change Civic 98
- looped power steering but persistent leaking
- Mystery B Motor I bought for $50 lots of Pics
- H22a getting no spark
- Starter Noise
- B18vtec build ?'s
- Car keeps overheating
- Any guess on my compression ratio?
- head/waterneck leak
- EM2 - K20 swap worth it? Other options?
- 93 Acura Integra GSR stalls out and wont start back up....NEED HELP!!
- Automatic Civic loud noise in drive
- rc injectors missing o rings??
- sandblasted journals/ acid etched
- H22a not getting spark HELP
- alternator fuse problem
- Garage Floor Coating
- 96 accord 2.0L auto wont start
- Any ideas on why my car won't start?
- H22a swapped rebuilt engine wiring problem
- Acura Integra Build HELP
- Start engine outside of car
- Ignition coil problems
- which intake manifold.
- How much is too much water coming out of a tailpipe?
- check engine light
- Bad battery vs. Alternator charging output
- Car wont start when it wants and when it wont it takes a few hours for it to start
- b18c1 noises
- Stainless steel o ring removal
- rebuilt d16y7 smoking issue please help me out
- D16 wagon TurboMax Rev limit help please
- checking for wear instead of throwing away good parts
- B16a cylinder head cam caps ?
- Next time I'm going to use Google for this answer.
- YS1 GSR Manual
- Idle problems
- Confusing problems.
- How do you remove AN fittings?
- cant find b16 at tmmotorsports
- 1991 civic si help me!! Please!!
- 97 Accord Interior Lights
- 5th Gen Civic History Question
- Rad Fan Fuse blowing, but not with larger fuse...
- Can someone verify this as an original spoon header?
- What steel is the stock exhaust pipe?
- coolant loss but no visible leak
- 92 civic
- burning excessive amount of oil after 2 valve jobs
- Q1 transmission (need info asap)
- What do you think about my spark plugs
- Civic Ignition key question
- Does a Works Bell lock fit on a NRG quick release?
- Rattling car?
- 99 ex b20b swap
- Golden Eagle Main Girdle Pin Dowel
- Location of VSS on 2014 CR-V?
- 91 crx pedal assembly?
- problem fitment tri y replica header b serie and leaking now at joints
- b16a2 compression question
- Fuel pump power source?
- Ignition Coil Test results question
- What am I Missing? b20v alt. belt
- Honda Accord 1994 Problems =(
- Temp Gauge Hitting the full
- F23A1/Manual swap accord, revs like Nuetral auto tranny
- Idle issues...
- Limp mode? 93 delsol z6
- 0bd1 car to obd2 distributor
- B16 running rich
- Car got broken into. They broke my ignition
- Want new seats but having sizing issues
- Bogging at low rpm .. looking for suggestions??
- how do i connect a wideband to the ecu ?
- Thoughts on theses ...
- Injector stays wide open. HELP ME
- Engine Loses Power when accelerating
- Bay Area Machine Shops??
- Confusing/Unexpected engine build issue
- Fully built b18 turbo hardstart/extended crank
- Pulled the head - here is what I see.
- '96 Honda passport ticking
- What clutch to use for b18c5?
- neptuneRTP datalog
- 96 honda ex d16y8 Starter will not crank, No spark
- balancing parts how to tell the machine shop is good?
- looking for a good machine shop miami Ft. lauderdale area.
- 1998 Honda Civic DX Coupe Lights Pulsate
- OBD1 Custom Wiring harness for Custom car
- The Car Game! Lets play!
- golden eagle sleeve boring out. do i need a deck plate?
- aem ems 1020 AFR help
- RPM dropping very low
- Help!!! Ac not working !!!!!
- alternator dies, battery dies, burnt electrical smell in underhood fuse box
- power window conversion
- Crankshaft seal - quick easy question
- tranny swap
- 94 integra starter issues
- HELP ME PLASE, error code 8: TDC obd1
- edelbrock mustang throttle body
- 91 honda accord no gas
- 91 Crx si cluster wiring
- Serious question on the finer points of Ac compressors
- skunk2 throttle body
- Engine shuts off while driving
- 88 Civic Hatch High Idle
- Starting Problem
- 89 crx si b18a1 swap
- Odyssey LA-RB1 Absolute Data Stream
- Oxygen sensor
- crx start than die
- fault codes
- Timing Belt Question! B18C
- Loading into the root file of the usb stick
- 2012 CRV uploading images into info screen background
- 98 honda civic cx loses power during acceleration
- Identifying Rods
- ABS light Integra Type R with OBD1 ECU
- crx si chokes/dies when given gas
- need help installing electric oil pressure sender
- B20b Timing issues and lumpy idle. A few questions PLEASE HELP!
- vtec mechanism failed?
- 2003 Honda Accord remote key and passengers side window not working
- 88 shuttle help please
- battery light flashes sometimes
- 2001 gsr swap to my 98 gs
- 95 civic lowered on 15in rims?
- can a carb'd civic run without an o2 sensor temporarily
- D16y8 harness 02 sensor/ power steering switch wires missing
- Trans help
- Fuel Pump Fuse Problem
- some kind of eletrical demons
- No Crank/Start
- Blown Main Fuse?
- f20 Intake manifold identification.
- obd2b d16y8 injectors wont spray
- b20b3 Crankshat broken?
- An Introduction To Honda B-Series Engines
- d16z6 valve cover question solution
- 1989 honda crx wont start
- Eg 92 Fuel problem NOT STARTING
- Low oil pressure at Vtec port (no Vtec)
- what's your opinion on Japanparts ?
- 95 delsol racecar no start.
- D16Z6-EXHAUST DIAMETER?
- Starter doesn't disengage?
- 1989 CRX wont start. battery light on but nothing else Xpost
- I have a vacuum leak
- HELP no power to injectors on 2007 accord
- Dry Sump System and 3 breather catch can
- SMSP/PLM Header Fitment
- brand new Clutch CHIRPING in neutral
- an fitting on fuel rail im confused
- 03 Odyssey Front center console
- DIY for an o2 sensor circuit?
- does oil pressure sending unit throw a code?
- Ecu questions.
- Random Bolt Thread Question
- pass side tail light doesnt work when lights are on. 98 DC integra
- Problems with JDM b20b swap (help)
- D16Y7 Valve Seal Question
- Does my J30A5 drop RPM in steps in neutral?
- Advanced Engine Blueprinting and Technology Video
- B16 Intake Manifold and Boost Setup Help
