View Full Version : Tech / Misc
- head gasket seeping.... AGAIN
- engine coolant temp sensor code please help!!!
- Anyone using an Audi Wastegate?
- Emissions question
- Need help with CEL and wiring
- 98 civic 02 sensor question.
- Tilton Clutches - Anybody With Experience??
- P72 Vtec Pin
- My b16a3 sounds like crap.... Help please, VERY detailed info included
- Confirmation Question: Rear disc swap
- 3rd Gear Synchronizer Replacement in 1st Gen b16 (S1) Tranny?
- H22 EG Civic parts list
- How do u keep a header clean???
- Is Tein any good?
- Are all the Final drives the same???
- help help b16a1 tranny blown ...what parts to buy?
- JDM B16 Valve Adjustment Specs?
- vafc help
- compession on a jdm b16 motor
- need help. H22 type s piston question
- JDM Tranny?
- Am I makin a mistake?
- bearing question
- ls ecu on b18c1????
- Going back to N/A (need advice)
- Reaction-Time Tester!
- Tranny problem (rebuilt and still grinding..maybe clutch?)
- swap guys!! HELP ME PLZ!! BIG PROBLEM!
- will 91 teg front rotas fit a 97 gsr??
- Searched with poor results- Code 6 & 14 OBD I GS-R: surging idle...
- tie rod end???
- HELP!!! Is this LSD BAD? or Fixable?
- will integra comptec icebox fit in ek w/ b18c?
- taking wheel off BMW??
- 5 lug conversion on an EF
- .......b16A HEAD GASKET!!!!!!!!!!!!!!!!!!!AH!!!!!!!help please????
- b18a/b crank in a b16???
- OBD1 KS wiring fun!!!!!!!
- Cap and Rotor from b18c1 94 GSR fit b16a3 95 Del Sol VTEC?
- jg single springs
- best engine harness to use?
- moving to Glendale, Arizona.
- VTEC solenoid question
- perf. of Greddy header on B18c
- seat rails?
- Question about a stock fuel pump...
- Overheating...HELP
- 1/4 mile time with h22 in a 96 EX
- Emergency Brake Handle
- Pinging at 1/4 throttle
- finally decided to go custom exhaust.....where to go to learn a few basics?
- 2000 Gs-r ECU Immobilizer????
- my engine CLICKS mechanics READ THIS
- how do i turn off this check engine light??
- car only heats up 1/4 way
- quick help....
- gonna be putting my b16 back together soon ?'s
- Mugen vs ?????
- JUN or Skunk2
- how much does h22 lude weigh, and 1/4 mile time
- replace belts...
- JG,Portflow heads etc...
- Grease or some kind of liquid on my brakes/rim
- Need cam advice. (I got a PnP head, but what cams?)
- Valvespring Compressor that Works on D Series Retainers?
- auto to manual, is it hard?
- b20 compression help
- EGT & A/F Gauge Question
- Smoking in fresh rebuilt GSR w/ CTR Pistons
- Which fuel/engine management for a car with 2 different types of FI (JRSC & Nitrous)
- Cable gears into hydro tranny
- please post good site that shows jdm tranny gear ratios
- First tranny drop on a 90 CRX...A couple of questions
- vafc work on obd0?
- EFI Progamable Management System
- B18b in a 90-93 Integra...need some help figuring it out
- oil everywhere
- oversized arp head bolts anyone?
- Drag racing and a lightened flywheel doesn't make sence to me.
- Question on Feul Pressure for 98 Integra LS
- Help with mount ID
- Timing belt problem, gear keeps on jumping one tooth!
- no fire on #1 cylinder... please help
- I need help with wiring of my V-AFC controller......Please HELP!!!
- Jetta 16v Arp head bolts in 87 Teg?????
- Oil change = Louder VTEC?
- how much weight loss can i get from taking out the sound dedoning?
- piston
- whining noise coming from the front left wheel
- For anyone that wants to know
- done before but not for me...MIG WELDERS...
- Highest Compression on a B16 Daily Driver
- 02/hybrid GSR/Civic VX problem..
- Skunk2 Stage 2 and Springs
- oil question for type R
- dead battery or dead starter?
- Would it be worth to get my injectors cleaned?
- 94-96 prelude vtec distributor schematics?
- Are these genuine P1 Racing Mags?
- best place too mount a csi catch can
- Spoon or Mugen exhaust header?
- Timing Belt Cover
- Anyone ever rebuild a Distrubutor.
- Best oil for a 1st gen b16a
- Need help removing the breather chamber off a b16a2...
- Anyone have a 190lph Walbro fuel pump?
- tire wear patterns VS alignment issues
- OT:anyone know where they sell heavy duty parts
- What could be wrong with my Type R swap?
- machine shop
- Anyone tried/have installed oversized type r pistons?
- How to adjust/increase idle?
- Strut Tower Brace Question
- brake question
- Opinions wanted...
- Y cant i post in the Selling thingy?
- 92-95 radiator + bseries high compression built motor.... COOLING ISSUES?
- Will a first gen b16 starter work on a 2nd gen b16a (USDM Del Sol)?
- Point me in the right direction...
- Valve Adjustments on 90 accord
- brake rotors only question
- What catbacks are true 2.5"? Where to find flow rates?
- putting ctr pistons into a b16a ?'s
- pr3 knock sencor
- 93 Prelude
- Which ecu..
- Are all B-series hydro tranny casings interchangeable?
- What retainers and valves are recommended with Toda Spec B cams?
- Grease Lightening or Simple Green?
- ***************FOR SALE: P61 ECU************
- Camber change for xx" of drop?
- which octane to use with b16?
- who has a good ecu program/aftermarket ecu.
- headers that shine but won't change color....toda-jun-JG-mugen?
- Looking for Autocad or 3DS Models ~ Honda Civic Blocks & Exhaust Manifolds ~ $$$
- Coil-over kits, which one??
- modifying any header with a 2.25" collector to 2.5"???
- Help with undercar neons
- Engine Hesitation
- Z-10/b18c-r block girdles...
- Vibration.
- golden eagle block owners ...take a look
- camshaft question!!!
- HAMP Oil filters...Large or small?
- Tightened Timing belt and car hesitates some and other Qs...
- new pistons in a 70k mi motor = needs hone?
- APEXi USA Factory Garage Sale : March 8th & 9th (Giveaways - civic turbo kit, vafc, intercoolers, n1
- where to get GM syncromesh???
- Valve cover bolt wont come off. I'm out of ideas......
- please help me TECH gods...
- too many welders to choose from..
- Rod Bearing?? can I use a different size?
- getting my car registered tommorrow... question about tags..
- do i NEED new head studs?
- how do I clean injectors off the car?
- Anyone think THIS might be my problem??? *pics*
- questions about brakes
- Which Fuel Pressure Regulator?
- Tuning a Apexi VAFC
- Just bought a new car, but it wont' start... Help?
- i have no vtec , please help (did search couldnt find anything usefull)
- How can I do this?? H22 T/B and Intake mani problem
- H23a, anyone got some info on this motor?
- 2000 si cluster plug and play???
- b18c head bolts?
- Post all dyno vids
- hondata help please......
- need your guys help..
- front mount for crx!!!!!!!!!!!!!!!!!
- Wierd Idle.....
- polyurethane foam (air filters)
- valve seals leading to burning oil
- my car runs like a Harley D
- valve lash adjustment??
- Internal Combustion Engines
- can i put a b18c R in a 96 or 97 civic?
- Anyone heard of Evanscooling???
- SOHC or swap?
- Burning Oil ?
- need help in jersey
- type r crank in ls block
- Transmission oil for Hondas: which is best?
- Any Honda Parts For Sale...
- aem v2
- EF B-Series Hydro Tranny Question?Which Axles??
- Compression Ratios. Turbo D
- how to get double sided tape off..
- B18C cam timing quest..
- Interchangable cams for a JDM ZC
- What next?
- shorter 4th &5 th gear
- valve adjusting Question
- Mystery sensors on B16
- The cost of 30whp from a B16A1?
- Dynoed a b16.
- Are all vtec solenoids the same?
- ECU wich one do i have
- EAC Valve?
- brake problem?
- manifold studs trq???
- whats a good alarm system to get?
- what are you doing to SAVE GAS?
- Mod Suggestions needed for D16Z6 Civic Si
- any info on Indigospeed flywheels?
- Bad Vibrations
- what do u guys think of thes gearing on a y1
- smog and the aem fuel rail
- question about H22a tranny...
- Head Studs???
- ECU Question
- k20 in a 6th gen CIV -- can it be done?
- tranny question
- hondata intake gasket ?????
- kill the cat?
- gsr rod strength?
- CRV AWD Conversion to a 93 Civic Coupe
- wiring knowledge needed??
- need help ASAP with Block Guard and Sleeve for B20VTEC Turbo Setup
- Hall effects vs inductive inputs or sensors
- Anyone have a DIY for the ITR swaybar on a 94-01 Teg?????????
- 93 Cx A/C removal & fuel / other lines. Engine Removal Pt.2! **56k grab a pillow**
- Where can I get a ball joint replaced?
- need ls vtec help
- B20 crank ??
- Is my car dying?
- catylitic
- People with azenis...
- Ecu upgrade?
- Overheating problem
- 97 Accord Ecu pinout needed.
- catalytic converter for my civic
- springs on the integra!!!
- adding power windows & locks on 97DX hatch
- HT distributor of SS exhaust...
- VTEC???????
- Converting from Auto to Manuel... **SEARCHED**
- how far i can go
- need to know what cams....second thread.....serious reply's
- Help on identifying Distributor, What car does a TD87U Distributor belong too?
- what the hell is this thing?
- GSR 5th gear...
- d16z6 I/M on d16y7 head?
- battery light on in a 94 civic coupe with a b18c1/obd1-p72 ecu
- anyone know how to set the v-afc to a 1st gen b16
- Anyone now how much and where? OEM Parts guys needed!
- Who can answer this?
- 94 jdm gsr motor in 97 hatch...HELP PLEASE!!
- any one wanna help
- Will Y1 LSD fit into USDM LS tranny????
- cel code 43?
