Pros and cons of B18c1 head on B16a block
Old Nov 25, 2003 | 02:11 PM
CRX Si's Avatar
Default Pros and cons of B18c1 head on B16a block
hey guys, trying to find a vtec head for my bare block, planning on building it for a turbo so any info you can give me would help, thanks
Old Nov 25, 2003 | 02:33 PM
mattssi's Avatar
Default Re: Pros and cons of B18c1 head on B16a block (CRX Si)
The gsr head has an open chamber design! It will yield very low compression, and I wouldn't suggest this, even for a turbo setup!
Old Nov 25, 2003 | 03:20 PM
Kendall's Avatar
Default Re: Pros and cons of B18c1 head on B16a block (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't suggest this, even for a turbo setup! </TD></TR></TABLE>
Agreed wholeheartedly. In fact I would go the other way around if possible and put the b16a head on the b18c1 block. The simple fact is that a b16 head is a better flowing head. I would try to find the b16 head, or maybe a CTR head, depending of what kind of cash your looking at.
Old Nov 25, 2003 | 03:54 PM
lazy bum shaughn's Avatar
I would keep the GSR cams because they are great for turbo. If you're not upgrading the throttle body, keep the GSR one since it's bigger than a B16's.
Old Nov 25, 2003 | 05:07 PM
CRX Si's Avatar
Default Re: Pros and cons of B18c1 head on B16a block (lazy bum shaughn)
well I have a gsr TB and I did know about Gsr cams for turbo, I will keep looking for a B16 head though... Thanks guys...
Old Nov 25, 2003 | 06:11 PM
mmuller's Avatar
Mad Scientist
first of all, gsr head will yield HIGHER compression. Also putting a gsr head in a b16 is a great idea since the iab's will help midrange torque.
Also the flow differences are minimal....and a lot of people like gsr heads better, including me.
Go to IB website, they have a comparison between pr3 and p72 head and the gsr made more power...
Old Nov 25, 2003 | 06:50 PM
doublejz's Avatar
Default Re: Pros and cons of B18c1 head on B16a block (mmuller)
but on the other hand, there are people like me that like b16 heads better. better flow
Old Nov 25, 2003 | 11:50 PM
92 civic VX B18c's Avatar
HT Black Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">The gsr head has an open chamber design! It will yield very low compression, and I wouldn't suggest this, even for a turbo setup! </TD></TR></TABLE>
You have that backwards buddy.. p72 head on a b16 block will yeild higher C/R then a stock b16 head..
Old Nov 26, 2003 | 04:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Si &raquo;</TD></TR><TR><TD CLASS="quote">well I have a gsr TB and I did know about Gsr cams for turbo, I will keep looking for a B16 head though... Thanks guys...</TD></TR></TABLE>
Kenny Tran runs GSR cams on his 8 second Civic.
Check out the Forced Induction section.
Old Nov 26, 2003 | 09:04 AM
AzG35's Avatar
Pros: higher compression, with revability of a B16
Cons: still torqueless, probably want to upgrade to Skunk2 manifold
Old Nov 26, 2003 | 11:16 AM
CRX Si's Avatar
Default Re: Pros and cons of B18c1 head on B16a block (AzSi22)
I wanted a skunk mani also, But do you guys recomend the single or dual chamber manifold design?
408EJ1
16
Jan 8, 2014 03:23 PM
SpoonEk253
Apr 14, 2006 04:35 PM
spoon95eg
Feb 26, 2006 01:16 PM
john_racer
Jan 13, 2005 04:07 PM
hb4u2nv
Jun 13, 2004 03:37 PM
