View Full Version : Tech / Misc
- b18c1 wont hit vtec
- civic problems
- SRS light come "on" - which code is this (video)
- why such wide variation for fuel pressure?
- codes p0170 and p0172 b16a2
- Help! Civic acting weird out of the blue
- top mount turbo manifold w/6266 turbo
- CaMs...need help!!!!
- d15b stage 3 HELP!!!
- B16a2 AEM fuel rail from eBay
- carburetor on B-motor??!!
- 1989 honda accord lx-electrical issue
- 95 del sol wiper/light wiring?
- Timing Belt to use 20vtec?
- Gsr - bad misfire / bareless runs
- Reliable mechanic San Diego
- P28 OBD1 converted B18C EK questions
- p72 gsr oil pan vs ls oil pan
- 98 Hatch Steering Woes
- Head turning.
- 2003 alarm and dash light problem
- B16 Almost bare block questions
- need some ideas on turbo downpipe
- HELP!!! car died on freeway while my gf was driving it HELP!!!!!!!!
- gsr oil pan question
- LS/VTEC intake back fire
- Cheap EK axleback
- civic problem
- How do I unpin my dizzy harness ?
- Headstud noob question
- Need help!!!! 94 ls swap to 98 GSR
- How Realistic does this swap sound?
- Nardi steering Wheel help (Real or Fake)
- Anybody know what flywheel this is?
- 1994 honda civic issues
- Idling issues H22a
- OEM Honda electrical plugs
- Anyone using Hondata cpr
- Can someone explain how to use an adjustable cam gear
- h22a maybe timing issue?
- Crazy problem. NEED Advice please.
- civic was just running now wont start
- Car died on the freeway no spark
- 6x12 Bolts are what exactly?
- CANNOT find the right bolts...
- 2005 Honda Accord Electrical Window Problem
- Hit pothole, blinking engine light, can't accelerate as normal.. HELP
- b20 block cracked or nothing to worry about ????
- need some help d16z6 head d16y8 block
- died and wont start..
- obd11 scan tools
- 94 Civix EX wiring issues
- Missfire on open throttle
- 1989 honda accord lx no spark
- [HELP] EM1 with B18C swap ECU problems
- catalytic converter bad?
- honda v6?
- Need a B series EXPERT to identify my head with cinfidence
- OBD2 Scan Tool Not Working-ChaseBays Harness?
- 96 Integra intermittent stalling problem
- stock 6th gen exhuast diameter for doughnuts gasket
- Can ANYONE answer this question?!!
- Guys please help me answer this question
- Battery relocation on a EK civic sedan
- JDM parts
- 93 Accord Fan stays on after shutting off.
- Cam Cap bolts Interchangable ????
- B16a2 idle fluctuate problem
- Anyone know where I can get this? (HID)
- What size TAp n drill is needed to put timesert into gsr block?
- Cams binding or normal with aftermarket LMA?
- b18b1 into 2000 acura el?
- Odd valve tick at times?
- Acura and Honda Catalytic Converter Interchangeability
- 2002 ep3 on limp mode
- IMMOBILIZER REMOVAL?
- Swivel AN ORB to AN ORB adaptor where to find?
- Wiring issues
- [HELP]turbo wont boost?
- 1992 civic lock issues
- da integra no start no crank
- metal shavings in radiator
- 88 crx climate control swap
- Female gauge cluster connectors for EG civic
- 1992 Civic exhaust "pops/puffs" at idle, driving me mad!
- 4x114 conversion EF
- 2002 Civic stalls at 1000rpms
- integra ls so slow...
- Lsvtec crank timing drive pulley help
- MSD ?
- 93 civic dx no start issues
- HELP! Cylinder misfire 1,2,3,4 cylinders
- B, D, H, F alternator comparison, pulley interchangeability
- CSF sensor
- Valve cover bolt issue
- B16 SIR Wont stay HOTT??
- 1998 Honda Civic DX Speedometer
- Swap or Not
- lsvtec, timing covers
- Engine Swap or Not
- Door locks and ignition
- Cause for metal dust in oil?
- Kill switch install
- AEM oil pressure gauge and sensor
- does transmission and wheel size affect dyno numbers?
- B18 head gasket issues
- Turbo ls/v catch can question
- turbo not spinning on idle
- AEM fuel rail ?
- 2001 Civic 1.7l Head removal
- Custom engine harness
- bosch o2 sensors revised model?
- Proper Drive Cycle?
- 91 integra wont turn over
- D16 Cam Identification?
- Newb question
- Nicotine patch?
- Honda crank hardening
- rebuild issues please help!!!
- Looking for input on an air compressor
- 97 civic average temp on mechanical gauge
- usdm p73 ecu
- exhaust leak!?!?!?
- Please help idk what drive shafts to buy
- Skunk2 intake manifold
- Double check that torque wrench!
- What you guys think of my car?
- b17a1 help!
- Bard civic b18b
- discs brakes on 91 si hatch
- B16a single valve spring on intake side ??
- Honda Bond or tran lube
- Mahle Clevite rod bearing question *pic*
- Power windows not working, HELP!
- all cylinder misfires + crank pos. sensor codes thrown
- overheating
- H23 cylinder wall wear pattedn, WTF?
- What type of helicoil to repair gsr block head studs ?
- What clutch for 500hp?
- Injectors differences
- ap2 cluster fuel gauge accuracy
- Problem: Random Misfiring on '98 Civic EX ??
- crank pulley help???
- What temp does the fan turn on in a 97 civic
- Swap ex cluster into dx plzzz help
- Check engine light doesn't work
- transmission to block strip tread help!
- Strange noise when driving
- Walbro Quickie
- 92 civic vx starting n driving issues need help!!!
- pcv valve help
- JDM DC2 - Strange thing under my bonnet...
- Crank pulley bolt removal help
- Pits on cylinder head dome area, couple pics
- Ecu
- Can a automatic wire harness be used for a manual transmission?
- What happened????!!!!!
- Body Rattles
- D15 on E85/Ethanol/Alcohol - Any thoughts?
- b16a swap 90 civic
- changed out 88 civic engine no start
- 3pin to 16 pin obd2
- engine dies after 2000rpm
- Ultra Street IACV install issue
- Teflon LockNut vs Castle Nut and Cotter pin. LBJ
- cleaning gasket surface
- Bar Code Format for VIN#s
- Rev limiter problems.
- 95 integra heater not working, replaced resistor
- Help 98 civic ex won't start!
- Wag throttle cable to use with type r swap in eg hatch
- timeing belt keeps on walking out on b16a2.. now its rubbing
- sir-g climate control question
- Are / were dual sun visors ever an option?
- Alarm stays with factory stereo? Yuck!
- Which Clutch Should I buy?
- Fuel bypass and injector pulse questions
- Roll cage specs? 96 ek hatch
- Cranks Fine, But Slow/Sluggish Start When Warm
- code 9 bypass trick db8
- need help with fuel pump relay
- window motor brushes for integra
- skunk2 lost motion assemblies, reviews?
- Low vibration rumbling in motor after dumping clutch
- Cel 6 need help
- Please Help B16 Turbo Motor Noise
- 2-wire Vent selection motor wiring
- Window off track
- Using Crome
- Honda V6 piston rings
- denso 234-4011 or 234-4209
- Turn key = silence, battery good
- d16z6 harness b20?
- Timing belt crank gear loose
- Remove SRS and ABS electric system
- ITM timing belts are garbage
- ...gas smell only in the morning..
- no prime
- failed emissions pretty bad
- chem dip for cleaning O2 sensors?
- *Write-Up* Nardi Classic single contact horn into NRG 2.5 quick release
- b17a1 compression
- Looping power steering lines
- Car shuts off randomly
- Procedure to check condenser fan relay
- Condenser fan operation question
- msd in obd0 b16 coil wires
- Leaking Distributor O ring cause vtec to become more quite
- need a shop
- Injector wiring?
- Fluidyne Radiator cap Part number??
- oil change time
- Radiator fan not coming on
- Which rod bolt stretch gauge would you buy?
- Water Temperature Sensor?
- Difference Between Mufflers for Custom Installation
- Check engine light and speedo not working after storm/rain?
- running lights won't work!!
- Tranny whine after new clutch
- B18B crank case vent
- gsr pickup tube/pan, ls block
- Need help from the wheel/suspension experts
- distributor timing wattahell
- Car not running in a straight line
- 2005 Honda Civic won't start after overheating
- b16a help ?! water pump head gasket cams??
- V6 into 99 ex?
- wheel hubs/Berrings
- 98 honda civic
- 97 Odyssey Idles rough when in gear
- H22 swap died
- 1998 CRV with VTEC
- JGE Sleeves???
- 1994 Accord AT Replacement Difficulty
- msd sci in b16 wont stay running
- motor swap advise?
- 99 civic non vtec to vtec conversion HEELLLLPPP!!!!
- need help with ecu problems
- How to identify a real rhd eg6 sir
- 98 Accord shutting down, possible immobilizer problem
- Rebuilding block and see micro crack v.PICS
- a pipe header lengths for aftermarket
- low mileage d16
- 07 CRV Trans vibrating at idle in gear
- jdm f20b problems!!
- JDM DC2 Aircare Fail
- Use 2 Oils??
