View Full Version : Tech / Misc
- ls>2.0 sleeving question
- 02 Sensor reading probs
- Spoon Head Gaskets
- Need Answer ASAP! Coilover Adjusting...
- Internal question about LS integra??
- carfax this plz
- how long do turbo in cars last?
- Low brake pedal
- Prothane bushings...
- i don't know jack shit about car, but i want it to be my best friend
- hestiation to start on cold or hot weather: where can i start?
- Identifying year on LS head
- electric impact wrench - worth it?
- It's on now!
- Where to wire up Secondary Butterflies (on engine)???
- D16Z5 engine.....
- Engine assembly question, JE rings.
- Getting very frustrated with JRSC hoses will PAY!!! someone to come and help me
- Compression Questions... JE GSR in b16
- B16A in 1st gen CRX. No VTEC!
- can a b20b,z crank fit in a b16 or b18 block???
- Alternato batt question
- KYB and what kinda springs?
- Code 91 WTF????
- Causes of Limp Mode?
- US ITR tranny vs. JDM CTR tranny
- Flywheel question, To resurface or Not to resurface
- square cat. VS. cylinder cat.
- 98 hatch with 95 Gsr motor, OBD harness?
- removing axles
- Kenji............... ????????????
- JRSC water hose line ques????? help
- ATT: NEWMAN regarding HCP EK-H22a mounts for Automatic hatch
- I need a OBDII secondary O2 bypass sensor!!
- No speedometer after Quaife install??
- Piston Installation tool.
- b16 head shave?
- SPARK retard help
- Jun 3 cam specs
- A little advice/help please!!
- need p08 pinout
- ebc greenstuff pads warping rotors
- High Idle on ls/vtec
- anyone have bearing codes for b16a?
- F22 and H22
- Question regarding wheel upsizing
- JRSC "Tee" into vaccuum line or not very confuse????????????????????!!!!!!!!!!
- HEADER QQQQQ'ss , what size primarys to use
- what is the diffrence between b16a internals and d16a?
- Failed Smog Test
- Installed gauges now temp. is reading HOT!??! Pinned, What happened??
- ball joint removal
- Cylinder head/intake manifold heat transfer Q's regarding Hondata IM Gasket.
- Can an obd-1 motor be converted to obd2 (motor wise not ecu!!!!)
- florida people
- Bad thermo or head gasket?
- 2000 civic si misfires. ... did a search important please read and help
- does anyone here have short stroke dampers?
- change trany oil on a b16Trany Oil
- orEngine help.........head gasket
- D series engine building books?
- Venom Intake Manifold for NA ?? Is it worth it??
- Fuel Filter on 3.2 TL
- Brake Calipers, can someone help me?
- CTR LSD same thing as the ITR LSD?
- Overtorqued
- Obd2 query- Katman?
- Hearing chatter and burning oil??
- what is needed
- anyone running crower 403 LS (B18A/B) NON VTEC 62403
- Where do u hook up boost guage on JRSC???
- Need Advice on Swap
- Need to retard timing on GSR how to??
- cat length
- Don't really know where to post this.....
- Spoon vtec controller with a knob!
- compression
- need advice on tranny remounting
- Is my Differential shot?? Help!
- C.E.L. code 13 help
- EK lower spring into Delsol, PLEASE HELP
- anyone done this?
- OBD1 or OBD2
- o2 sensor question
- Is 20w-50 bad in a D15B2 motor?
- H22 rebuild: opinions of results: BUILDERS please reply
- DataSystem Vtec Controller
- Brake question... part of rotor not being "swept"
- best suspension setup for $300 on del sol
- Rpm sputter between 7k-8krpm
- not sure about this...
- Advice on buying a Civic <need tech info>
- need help with a school project
- San Diego I Need Your Help ....
- Ring filing ?'s
- Which clutch to buy?
- vtec doesn't engage- fluctuation in idle
- Need help quick... compression test bolt stuck....
- Exhaust System?
- Fun Little Hypothetical Situation.......
- help my new wip out
- Alternator ground fried is it reusable?
- engie mount insert question?
- portflow inner springs which side is up or down?
- Where to hook up MAP sensor for ITBs?
- cant get the pulley on the crank off...
- Looking for decent machine shop in Sac, Ca for B16 work
- Differece between Eiback spring in GC coilovers and spring Eibach offers directly?
- Wiring Guru's OBD0 to OBD1 conversion alternator woes ?
- Damper integrity question
- handasaver cams
- Question for those who have replaced an LSD
- what head gasket and arp head studs to use ?
- toversized trottle body question
- Questions about boring out my B18c bottom end
- Parts List For B16A2 Swap and 5spd Converstion
- spark plug wires problem
- need help can't decide on injector size & fuel pump size
- Anybody using an ITR master cylinder/booster?
- '4 ccod will ot stay running, unless
- Camber Kit
- Highest compression I can go on regular pump gas?
- nalB16 crank pulley on Ls/vtec
- Bore Motor Over
- b16a2from 99 si into 96 civic
- Labor... How much to pay?
- b16a vs b16b
- car DIED.
- High Idle on fresh ls/vtec motor, heeelp!
- Would new stock size injectors from AutoZone be a bad thing??
- does anyone know what XS-2 is??
- To squirt or not to squirt?
- 2000 civic si (black), suspension and engine mods
- CEL code 20...
- Ignition timing Clarification
- muffler for an 89 hatch si
- Chipped LSD, can I still drive?
- no vtec. all trouble shooting methods tried (at least we think)
- 0.25 oversize prelude pistons..do they use the same oem prelude rings
- Shift Linkage.. Bushing ?
- ecu pin #'s for EG 4 wire o2 conversion
- brakes
- Will any CTR 96+ ECU work for my obd2 b16a2 out of del sol 97?
- how to get into high to mid 12s w/ full interior
- msd cap and external coil
- JDM engines????
- aem cai versus aem short ram
- b series tranny parts
- Tool for adjusting VTEC head valves
- DYNO'd my car!!! I need your feedback.
- Failed Smog =(
- Bogging in 3rd and 4th
- Header Question
- ECU???????
- car died!!! need help!!!
- ghetto inline fuel pump
- Calling All People in Florida
- Does the Skunk2 IM weigh less than the ITR IM?
- Could use some ideas for my 1991 Integra - Turbo related.
- 97 LS injectors same as 99 Si injectors?
- Using EX vtec solenoid on a b16.
- do 97 acura CL 2.2 have vtec motors?
- A THANKS to all the guys on this board !!!!
- Changing Head Gasket
- First Mods For A B16A2?
- Maximum rev Capabilities on H22a Closed Deck FRM stock sleeves..
- b16a3 into a 90 integra
- Anyone wanna make some money???????????? need help on install with JRSC on GSR
- am i launching too low?
- Can someone vouch for JDM_DOHC_Sir?
- ACT clutches - Heavy Duty vs Xtreme Pressure plates
- Another stupid LS/VTEC question??? Already did a search...
- B16This is very stupid but it's bugging me!
- Help ASAP 00 Si Rod Bolts???
- Where is oil pressure switch on 97 GSR need to remove it for JRSC!!!!!! help
- new clutch problem
- high rpm hesitation, please help!
- Hybrid Cable transmission questions
- ITR Valves?
- bigger brakes and 15" wheels
- Antenna install
- suspension/brake options
- Does anyone Know
- Me and my friends are wondering ??????????????
- i am not really sure how to phrase this, but i know it has been posted somewhere before
- Wiring Guru's OBD0 to OBD1 conversion hasport errors ?
- exhaust problem?
- The limit of stock D-Series injectors?
- Cluster swapping problems
- Need advanced troubleshooting help W/87 accord DX Engine Problem
- thread size?
- QUICK Help PLEASE! (installing now)
- Cracked ringland, now I have a few choices...
- Please help, what Engine CODE is this?
- MiniMe question?
- 89 integra trans. question
- will a 94 integra ls Idle air control fit..
- B16 Block
- Please vouch for this person
- Ring gapping?
- lightened Flywheel ?
- Quick Yes or NO question!
- Swap TIme
- loud intake & exhaust
- type-r sway bar
- PVC intake!
- Dented header needs help
- Techedge WBO2 with Hondata
- CEL, need help
- T-top Honda B-series sleeves?
- Not Honda related, but emergency!!
- Vibrateing
- Are there any cons to milling a head to reach higher compression???
- MOTORs from importbuilders.com
- Alternator wiring???
- whats a normal compression of a b20/vtec?
- LS rods in sohc, need some help
- B18C Turbo Setup
- injector cleaning?
- Will an Ecu out of 2000 civic si work for a 97 del sol obd2 b16a2?
- 97 ex rear drum convo.
- tein stech performance springs
- zeal b2 coilovers
- oil jet bolt thread stripped
- Stock EX and SI exhaust questions....
- newbie ?: what is the steps a machine shop takes to balance a motor? (search has been done)
- Exhaust Suggestions, please.
- Honda Accord rims weigh......
- How is this suspension setup?
- which valve guides for ferrea valves
- taHondata?
- exhaust shine
- GSR rods into LS Block?
- Swaping 89 CRX Si seats into a 90 DX hatch
- Which ump ls/VTEC
- Help!! ....... Crank bolt
- dyno question
- problem with steering
- what year did obd2a switch to obd2b for the DC chassis...
- Slicks Question
- If use a VTEC water pump and OIL pump
- camber kit problem
- where to tune a hondata?
- b16 and LS crank pully the same?
- help help ASAP 6:40pm eastern
- I need resident *expert* help: B-series tranny
- Itr/gsr head components
- Need Help with idle and overheating.....
- Anything else needed?(some may think this is a dumb question)
- I think I've got my set-up down...
