View Full Version : Tech / Misc
- How many oil pan studs?
- low oil......help!
- Quick fuel question.
- ZIF SOCKETS FOR HONDA ECU?!?! Looking to socket my ECU
- tranny prob.
- anybody HAve a motor built by D.R.T
- when porting and polish, does intake side have to remain rough?
- greenish white flaky hard stuff is in the coolant passages of block? what is it?
- !!wacked cylinder head!!
- S2k VTEC AFC-2 I need some settings
- Quaife Lsd problem (need help)
- help me with a clutch Q right quick
- howdo i knwo if i need a new timing belt
- going distributorless so what fits in the hole?
- timing belt help and others
- 90 Hatch with a B20 and a b16 tranny..
- anyone know how to tune a pro speed stand alone???
- Reseting the ECU ?
- help please! vtec problem
- 3" inlet on 2.5" piping
- converting a cable tranny to hydrolic??
- howling sound?!?!
- test pipe
- fpr is dry...
- 92-95 civic hood
- Quaife Torque Specs
- Update on rebuild of b18c1 and a few questions if you got time
- !!!ANY & ALL EXPERTS!!!PleaseGiveAdvice
- quick question about a cel 45
- What are some symptoms of a bent valve??? Severe over revv
- ROLL THE FENDERS
- engine builders
- HELP!!!! IDLE ISSUE AND POWER ISSUE!!!!!
- converting to rear discs from 6th civic to teg
- car is bogging not running right please help, i searched and could find anything
- Leakdown test results!!!!!
- Headgasket break-in period....?
- car almost dies!!
- what could cause a weak spark?
- oh shit busted ball joint
- O2 SENORS ON A CIVIC EX
- What should i get with $500
- Hex key size?
- Drum brake piston help
- Need Some Answers on my LS/VTEC build up!!!!!!!
- Coolant System problem! steam going into my overfill, rad leaking.
- Coilover Suspension Setup Tips, Please
- Reading spoon cam gears.
- idle problem...reset ecu didnt work
- Jdm non srs wheel
- STROKER KIT. HOW?
- CROWER CAMS VS. SKUNK2 CAMS VS. JG ENGINE DYNAMICS CAMS
- B18c tuning
- accord h22 redid exhaust opinions on customfitted s2k exhaust can anyone relate??
- exhaust opinion... h22=dc ss wrapped headers>carsound 2.25 cat>apexi 2.25dunk piping>???exh
- wiring harness
- 92 Civic Indiglow Gauges install HELP
- aggressive cams and compression test results
- ITR cluster GSR car?
- do new hondas come with overfilled engine/tranny?
- advice.
- valve lock nut size on my J block?
- ingnition TUNE UP upgrade d16y8 engine????
- what timing belt
- can my B18a/b skunk2 intake manifold on a zc?
- vtec swap
- which power steering bracket do i need for my b16
- some questions about fuel pressure?
- Wheels & Tires
- Obd1 Codes
- Skunk2 Stage 1 or 2 camshafts
- p13 ecu remapped w/skunk program knock sensor ???
- weird noise at about 5000 rpm
- Suspension Question...Need some advice
- new o2 sensor still have a cel.
- ECU??
- how to adjust hydro clutch pedal??
- oil breather (did search)
- cometic head gaskets???
- to fully build a motor is this all ill need?
- wiring......
- energy suspension
- Any Comments on Apexi WS coilovers?
- exhaust ?'s
- Shotpeened rods on a boosted daily driven motor? Whats it capable of?
- Smoking alote and cant find right idle in my b18b1 ls
- synthedic oil question
- high reving engine rebuild
- n00b question...but hey
- first time pulling the head (b16a2), need some help...
- is my motor a jdm d15(b)? and power loss
- HONDATA...B16 Program needed?
- steering wheel shakes
- obd1 distributor (d15b7) on d15b2 in crx... no spark???
- Kill switch?
- Source for Service Manual?
- swapping prelude brakes to a Eg
- help?
- JDM GSR LSD worth getting?
- how many splines are on 94 + b-series axles?
- part number for crank pully? 90-93 ls... nok-90525B?
- Looking for a dealer that sales 'Baer Brakes' ... Need pads!
- twin turbo, bi turbo, two turbos......
- JDM h22a only making 115whp... help
- Top Fuel Power Chamber Kit
- function of lower tie bars? (sorry for the n00b question)
- Why does the car run rich during warm up? How is that hotter?
- helicoil install....can u stack the inserts?
- Poormans R thorwing codes....
- Please help....New Springs Or Camber kit?
- axels for swap
- what axels can i use on my swap b18
- Switch 98 Spec 36mm ITR brakes to 32mm ?????
- low oil pressure??????
- Diagnosis Help Needed!! (Brakes)
- how low is too low?...camber problem.
- should I re-sleeve my h23?
- dual runners (for accord swap)
- How hard is it to claibrate gauges?
- b17a crank
- help diagnosing my problem. engine wont start !!
- Bumpstops
- brake question: Does the capiler rest on the brakes?
- si tranny***
- crx Ls cv axles
- need a site
- secondary o2 and o2 sensor questions. (searched)
- ACT clutch....problems!
- Help with ECU Terminal Descriptions
- Check out this D-Series Clutch/Flywheel Assembly that's new on the market
- jdm gsr trans?
- 7/8ths MC and Booster
- Help wiring HALMETER AF30
- Tranny/Clutch problem - need help diagnosing.
- skunk2 valve springs + stock retainers?
- if i get an alignment do i not need a camber kit?
- z6 vtec solenoind. which wire goes to ground and which to rpm switch??
- Anyone know where I can get a crank for my d16y8 or d16z6?
- H22 in civic dropped 2.25, AXEL PROBLEMS
- botum k20a3 with a2 head + hondata
- PCV valve hose size
- Suspension question
- Converted mechanical VSS to electronic VSS. Now speedo is off. How to fix?
- i need feedbak plz
- looking for a h22 egr block off plate
- Metal Fab question! How to make a 90 degree bend on 3/8" steel bar?
- which springs?
- b20 in rex???
- Hydro Tranys??
- Coil/Ignitor or something else? I've searched...oh have i searched haha
- 1992-1995 Honda Prelude Manual Trany??
- CLutch What to do?(Clutchmasters Stage3)
- Can someone help me on this...
- Hondata Problems
- just rebuilt ls motor and it smokes alot.....
- b20 gsr vtec swap questions/problems
- b16 vtec
- failed smog..exceeded HC levels...HELP!
- Clutch hubs
- hit a curb some input pleaseee
- Upgrading Pumps + Gasgets.
- GM syncromesh
- ECU Auto converting to Manual?
- swapped my injectors yesterday, and the car idles like sh*t!
- Car wont accelerate..help
- V2 bypass valve?
- Brake Tech's Help a Guy Out!
- Anyway to tell if a transmission is bad when it is out of the car?
- Shot peening rods
- Why different endlink mounting positions for front swaybar for Del Sol Si and VTEC?
- code 54, obd1 engine obd2 ecu
- what are the best pistons in a gsr block w/b16 head
- CRV Cylinder Head On B16A2 Block
- Automatic 1.5 Civic Rough Idle w/lights, heater fan, radio on
- how do you test if O2 sensor is bad?
- Installing Injector Clips
- What to do? Poll
- compression test H23a
- recommended alignment shops in san jose/bay area
- Greddy Profec E01 ?
- Broke bolt off of exhaust manifold (88 lx-I)
- H22A with T4 and Hondata CEL!
- Clutch Not engaging (SEARCHED)
- are these the same
- piston removal
- Oil Pressure????
- Will jdm gsr lsd fit into h22 tranny?
- power plus typhoon intake junk or good???
- jdm 96 spec b18cR and 99 spec b18cR
- Coolant overflow bottle question????
- Target Air/Fuel Ratio with NOS
- i got some vtec but it sucks.... please help
- Mill or Not to Mill?
- I Need some help ONCE AGAIN!
- JUN Cam Gear allen head size??
- TRANNY SHIPPING
- intake manifolds for LS head
- gsr IM on ls
- is there a website anywhere that can be used to ca
- fuel gauge wont work
- Tuning with 720's???
- MAIN CAP BOLTS/HEAD BOLTS
- compression question
- need help with b16 swap in a EG anyone?!?!?!!?!
- Stoichmetrics reading - need helps
- is higher compression better than more displacement?
- Lovefab Sidewidder and Fuel tank guestion?
- 250hp All motor vs 250hp Turbo
- Piston Insatall
- Idle super low when stopped, almost kills.
- is 150 WHP poss with a d16z6? what do i need?
- Does P28 pick up purge solenoid on GSR
- Cleaning my iacv
- Is a simple to install device to remove speedlimiter worth it to you?
- fuel rail?
- Turn Signal socket ripped out
- OT: Parts washer Q?
- Bearing colors equal what sizes?
- Fidenza cam gears, anyone have experiance with them?
- Knock Sensor and Vtec oil presserue switch thread size?
- ITR 4lug vs 5 lug
- Gauge face help!
- I need help doing a tranny swap....
- High Idle!!!! How to get rid of it????
- Air in my braking system!
- B18B Head Oversized Valves question
- Should I even bother?
- Brake Lines Questions
- 98 ITR Brake Pads same as the 98 CTR ones?
- Can anyone give me the real info on OBX - few questions inside, opions pls
- Help
- are there oil fins under mugen valve covers?
- ARP head studs INSTALL:FINAL POST
- what lsd do i need
- head er what?
- KYB GR-2 Shocks for 00 civic???
- Header ??
- JDMp72 vs. USDMp72 ECU ???
- How do I indentify cams in a car?
- Quaife LSD for the J1 tranny?
- how to test OEM IGNITORS?
- Need tranny I.D. help
- Carbon Fiber intake system
- No Flexpipe or Spring nuts.
- compressiong test results
- CEL for o2 sensor
- Hondata manifold gaskets
- please help with bogging!!
- Calculating Comp. ratio on b18c
- DC Ceramic Headers color not looking good... How can I make them look new again!?
