HELP!!! CAR wont start!!! tried everything please help
Old Nov 29, 2003 | 02:58 PM
DeDonDeRosa's Avatar
Default HELP!!! CAR wont start!!! tried everything please help
My 1990 CRX has been acting up for a little while. First off the car would run regular once i got it started, then after awhile of driving it would start to buck really bad and didnt want to rev at all. Then the car would stall out and whenever i got it started again then hit the gas it would stall out. And now it wont start at all.
i checked the wires, plugs and i dont know what else it could be possibly the fuel pump??? it just cranks and cranks now but will not turn over
PLEASE someone help me !!!!!!!
Old Nov 29, 2003 | 03:20 PM
Green94GSR's Avatar
Default Re: HELP!!! CAR wont start!!! tried everything please help (DeDonDeRosa)
Had a 90 Civic and the igniter was a recall item. Just a thought. Have you checked for spark or fuel?
Old Nov 29, 2003 | 04:09 PM
PolySquared's Avatar
Default Re: HELP!!! CAR wont start!!! tried everything please help (Green94GSR)
My car is currently going throught a similar process, but my techician told me I need a new ecu. My ecu got shortage.
Old Nov 29, 2003 | 07:46 PM
Default Re: HELP!!! CAR wont start!!! tried everything please help (PolySquared)
and the tach has been jumpin all over the place
Old Nov 29, 2003 | 10:34 PM
salbaje's Avatar
definitely igniter problem
Old Nov 30, 2003 | 09:06 AM
Default Re: HELP!!! CAR wont start!!! tried everything please help (salbaje)
how do u know it could be the ignitor prob???
Old Nov 30, 2003 | 11:09 AM
cyrk007's Avatar
could be a bad distributor.. after time the coil wears down and if it getts bad enough the car won't start
disconnect the fuel line at the filter and turn over if it pumps you eliminate that..
(edit: use someone to help you with this as it is dangerous and can ignite the fuel)
I think it sounds like dist. tho.. a buddy's 91 crx did the same thing.. $ for a used dist. tho
Modified by cyrk007 at 3:28 PM 11/30/2003
Old Nov 30, 2003 | 01:45 PM
Default Re: HELP!!! CAR wont start!!! tried everything please help (cyrk007)
well after letting the car sit over night i got in it today and it started right up no problem it was driving fine untill after a little while once i start to really give it some gas it starts to buck and buck and buck and the tach goes nuts. but besides that it started right up no prob and then after a little bit of driving it starts up again.
and then after it starts doin this if im in nuetral and try to rev it a little bit it wont rev it like it wont let it at all
Old Dec 1, 2003 | 11:12 AM
the car starts fine it just that the tach jumps and it bucks i asked some mechanics at my job (honda) and they said its prob the ignitor cause that would be the only thing that could make the tach jump like that. cause it sends a signal to the tach so i will try swappin it out and hopefully it works
Old Dec 1, 2003 | 04:22 PM
yep it was the ignitor swapped it out with a brand new and it works fine
Old Dec 1, 2003 | 04:29 PM
vteczone's Avatar
check out the distributor..that was my frens problem.used mine and it work fine.
Old Dec 1, 2003 | 04:31 PM
vteczone's Avatar
lol...so ur car is fine now.forget what i said b4
fire_king
Engine Management and Tuning
Mar 8, 2012 02:45 PM
BolivianFuego
Apr 9, 2011 09:34 AM
crxabi
Jul 11, 2010 05:45 AM
boostedpleasure
13
Oct 12, 2006 09:10 AM
Honda Sport
Jun 4, 2003 05:27 PM
