View Full Version : Tech / Misc
- which cams for b16
- HELP!!! Car wont go into gear!!!!
- 5 lug conversion???
- CRX front end swap onto civic 4 door 4th gen?
- trany swap ?
- Difference between Apexi N1 2000 and type 5?
- Whats the stock bore on a b16??
- how do you tighten the antenna on a dc coupe?
- Need to bleed brakes, help
- Help! How to install a slave cylinder.
- power steering plz help
- On going problem with Power Windows -- please help
- s80 to ys1 coversion??????????????
- Need some suggestions *just got 2k gs-r ecu back
- Throttle's sticking after shifting
- HELP! acorns stuck in my heater blower!!!
- Where to buy ARP Headbolts?
- Valve spring question
- Fuel Pressure Regulator
- Del Sol dual core radiator
- Double-Check Torques
- a lil kick when i shift to 2nd gear!
- LS valves, what size are they??
- front end question?
- regular oil vs synthetic oil???????
- who can fix my head in Arizona
- Install a fuel cell? Yes? No?
- Some questions about the H22A head for port & polish job...
- will an ls fuel pump give a gsr motor with big cams enough power at 9000 rpms?
- what is needed to?
- got the ELD code what do i do to fix.
- ITR Tensioner, Water Pump.......Fit on a B16A2?
- Dist. questions, OBD2 converted to OBD1, or replacing CYP sensor...
- Opinions on My motor...
- can someone please identify these injectors
- Clutch choice
- obd2 b18b and obd1 b16a oil pumps interchangeable?
- I have cheap coilovers but getting good struts. KYB AGX's or 5 way illumina's.
- What is a good redline setting for a type R valvetrain
- b20 stroker kit * worth it?
- Question on B20??
- broken crankshaft? you tell me.
- What letter is stamped on a CTR intake cam??
- Throttle Position Sensor help needed!!
- Fuel pressure value related questions
- Valvetrain on B16
- name of cutout thing?
- auto to manual in eg hatch?
- How to ID engine wiring harness???
- Whats the best set up??
- AutoMeter Fuel level gauge?
- 2 rear shocks leaking .. whats next?
- EK w/JDM GSR Hybrid Problems!! Please Help!!!!
- canadian p73 ecu
- do I have to modify valve reliefts on stock b20 pistons with b16 head?
- Broken shift fork...Please looks at pics and help me figure out what to do
- How does this look for 180/130 +/- 5% at wheels corrected on a budget of $1750-2000
- 97 EK w/JDM GSR engine w/OBD1 P72 ECU.
- Fuel supply for direct port nitrous
- Spark Plugs?
- fuel pump / filter
- Koni Shock Height Adjustment Clip
- hydro to cable tranny adaptor kit
- Honda/Acura ECU question.
- tensioner
- passing inspection in NC on OBD2 cars
- GSR transmission question please read!!
- Help me decide LS/Vtec or Build my b16??
- Oil spraying out of dipstick?????
- ABS rear disc's onto a NON abs drum car
- 8.5lb flywheel effectiveness
- Intiresting non honda swap
- Anyone tried replacing their tie-rod ends before?
- y8 manifold pictures
- ? about extra thick head gaskets
- floating pin ctr pistons in b16a2
- a/f gauge
- question about itr tranny?
- will wilwoods fit inside 16x7 slipstreams?
- How do you check engine codes
- just out of curiosity
- Ponder this electrical problem.
- Which fuel pump??
- Dunlop SP Sport FM901 or Falken Azenis Sport RS
- why would steering fluid pour out of the reseviour???????
- decah.net
- Troubleshooting: Low Idle (pretty in depth)
- law suit question and car question
- How many plugs attach to the gauge cluster in a 94-01 integra?
- What to do?
- Why do my hoses keep breaking!?!?!
- need little help
- Headgasket to raise compression?
- aftermarket cams--not passing smog
- Weird problem...
- Intank or inline fuel pump for allmotor setup
- billet vs. forged???
- I need proper adjustment procedure for my Konis.
- Motor cuts out when RPMS drop to idle
- Fuel delivery problems on my Z6 equipped CRX...help!
- stock ITR head flow rate
- Stupid ?. Closing Spark Plug Gap.
- Which 02 sensor comes on what year of car? (4,2,1 wire) Which one do I need?
- vtec head milling
- Differences between B16A engine and US Spec GSR B18 engine mounting points?
- 92 accord coupe runs cold
- Why jdm?
- How much Tranny fluid?
- fan wont kick on after swap
- Some of the best suspension tech ever.
- will these wheels fit my civic
- MPFI swap
- HELP! Which are intake valve springs and which are exhaust valve springs??
- strange sound above 6K rpm
- Type-R Rods on B18B crank ?
- attn tranny experts: a question about syncronizers...
- obd0 to obd1 questions???
- Coolant lines smell of exhaust
- Just installed ITR cams in my b18c, is valve clearance adjustmant needed?
- bored out b16 or b20/vtec
- Strange charging problem...
- Skidplate for JDM DC 4-1 Header
- How much does it cost to port a header?
- oil... where's it coming from?
- RSR Springs vs Neuspeed Race Springs
- Clutch Break In Question - More Specific Then Ones In The Past
- obd2 to obd1
- HELP PLEASE! My car Died tonight
- quick q, reaction time doesn't affect final ET right?
- ek9 carbon fiber gauge overlay
- Quick>>diagnose my timing belt problem--sways side to side and...
- bent valves on vtec head.
- suggestions on use of bypass valve?
- Diagnostic Codes for 94 civic
- Tranny fluid
- intermittent wipers for 01 civic
- What do you guys know ?
- is yaws search form working
- testpipe / fuel pump question
- Drop Zone Lowering Springs
- 94 GSR stutters.
- Car won't start, no spark, constantly blowing ecu fuse...
- Cant find ABS code. HELP!!
- itr into eg troubles please help!!!!!!
- B16 (1.6 VTI DOHC) Noisy Lifters ?
- need an answer asap about a tranny
- Car stutters under cold takeoff...clutch?
- Got my tranny today...Just one question (a noise it makes)
- gsr disc brake problem
- New Overheating Problem :*(.............again but opposite
- B&M Fuel pressure gauge, DONT buy one, read why...
- What exactly are the benefits of having ITBs ?
- Street Legal Exhausts
- Where to locate the engine code ( as in b16a, b18c etc..)
- headwork?
- DFW peeps, I need your help with tranny and clutch install
- Cam gear bolt question. Yes I'm stupid..
- 89 integra to 89 dx hatchback
- SOHC Cams?
- Scared to start engine!!
- IM: Coolent bypass
- indenify differential
- engine builder: SOUTH CALI, HELP!
- torque wrenches on ebay
- JDM b18C into a 1998 LS... (i hate this car) (HELP!!)
- the B16 tranny grinds have gotten worse -- what will happen now?
- How many teeth on 5th gear from teg LS tranny ? (did search)
- ignition boxes?
- problems w/ skunk2 camber kit
- How to spot detonation on a dyno w/ wideband?
- Change generic filter?
- CDS sensor in VAFC???
- oversize bore & piston?
- rebuilding a tranny..??
- Screwed up cat &/or header
- Low Idle then cut off???
- greasing ball joints on the car
- heat wraping intake??
- do u need a different shim to put a type r lsd in a gsr???
- need opinion on built motor problem...
- Oil Cooler question
- H23 still no start condition?
- Question about RHD and front clips...
- I need help w/ code on h22a swap!
- torque to yeild bolts?
- my car wont start after obd0-1 conversion
- brake problem need help asap!!!
- agh, stupid stupid I must be?
- ECU Question
- Stronger steel bolts From Design News magazine.
- Questions On Running JDM b18c with PR3 Electronics
- condensation in head light
- What else can I block?
- Mini me question
- am i right with my calulations
- suspension?
- OBD-1 H22A injectors?
- your car ever just decide to get REEALLY fast?
- spark plug o-ring
- driver side doesnt close all the way?
- jdm itr final on a y1
- VAFC revlimit?
- How to get A/C in the car
- B18C JDM and B18C1 USDM. PARTS interchangable?
- axle nut size for eg civ and 95 h22 or prelude
- could I add........
- compression calculator?
- Another timing question...i know, i know....
- Tein rear spring rate, why so low?
- Using B16a2 header with B16a motor.
- I need help now!!!! engine swap in progress!!!
- Honda gasket sealer or the stuff you get at parts store?
- srs is on after putting back steering wheel
- Civic EX Rods/Pistons fit into CRX Si motor?
- Stock B16A cylinder psi??
- marking on side of eagle rods
- check engine light (code 41)????
- How do you know if you got real JUN stuff?
- idle wont go down after...
- Race Bearings?
- B-series Engine Mount Question
- I have decided on cams but still a couple more questions!!! feed back needed!
- mugen or spoon head gasekt
- Integra Ls front seats ?
- Is lithium grease bad for bushings?
- is this possible to do
- tell me if this was a good exchange
- Need CTR valve lash ASAP
- clutch loosing pressure!!
- were to get oem gaskets?
- '96 GSR died, honda-tech saved me $$... TY
- Starter acting stupid / occasional skreech
- car idles at 2k
- Best Transmission?
- I CANT wire my 99 SI harness on a JDM b16a2 help!
- Type R rear LCA vs 88 CRX rear LCA
- Sandblasting your engine is NOT good! Mmmkay?
- Best piston rod combo
- Mitchell On-Demand System
- Fast Idle Valve and IAT sensor
- clutch for my tranny
- B18B vs. B18C
- turbocharged oil temp?
- GSR into a Civic ex, help!!!! asap please
- ?'s about a B20
- ACT clutch (hdss)
- wild idea
- dc jdm 4-1 vs dc 4-1
- another timing question??
- Engine Swap
