- 92 cx hatch brake light stays on ?
- fluctuating temperature
- blown head gasket ???? i need help!!!!!
- LSVTEC into 93 civic; rough idle and sputters!
- CRV or Rav4.
- Is a b20 and interference motor?
- Do these rod bearings look normal?
- Help Identifying a Wiring Harness Plug-
- lsvtec timing issue
- cel code
- b20 vtec
- i brought a b16a head for $100, do i have all the parts?
- 1988 Prelude tranny fluid
- GSR into 99 Civic SI
- help with wiring harness plug warning bad joo joo experts only
- ? about a motor for sale (pic)
- How F'd is this head?
- seatbelt light
- Are there any differences in throttle body brands?
- GSR or LS Timing Covers Fit B16?
- 240sx help??i know not honda but its a deal
- will 2.25" exhaust bolt up to 2.5" test pipe
- Clutch engagement problems need help...
- Clifford alarm help sensitivity
- blox header donut gasket
- NEED HELP : oil shooting out from dipstick hole?
- Will P30 ECU plug and play with now problem with a delso B16 setup?
- gsr smoking
- hasport engine mounts
- Car keeps on dying - New motor
- Poor mans Type R motor keeps jumping timing. WTF!!!
- lowering my del sol
- 97 prelude problems
- does anyone have a writeup on this type of battery relocation??
- 82mm Headgasket on stock LS block
- b series question
- hondata map ?b16 with little mods
- cel need help
- Wilwood/Tilton clutch and brake pedal
- LS VTEC Help! desperatley needed
- Mounting an in-car camera?
- Possible misfire
- HELP!!!put new b18b n civic. having issues
- Program oem key for aftermarket central locking system
- clutch/gearbox issues.
- building a motor????
- Honda Control Module Comms
- ? about Hondata s200
- F22 obd1 accord harness on H22a
- Strange pulsating sound while accelerating
- Mounting Fuel Pressure Gauge?
- ACL Race Bearings.. Fine or Not Needed?
- How do I set Cam timing afterhand?
- NGK Discontinuing ZFR7F-11
- flywheel bolts
- abs wiring
- IAC hose question
- aftermarket fuel gauge/fuel level sending unit....
- Fuel pump won't turn on
- walbro 255lphhp install question
- AEM Wideband UEGO Gauge Kit - does it replace the factory O2 sensor?
- 88 Accord Alternator Removal HELL
- D15B help help
- help no spark
- Car Wont Start After I Pulled Spark Wire!
- link to wiring diagram
- whats better then honda bond??
- b18c prob
- Little advise please..Oil on 1 sparkplug!!
- civic won't start. please help
- replacing belts
- radiator hose cap??
- 5 lug conversion (help plz!)
- can someone tell me where i can find info for custom wire harnesses?
- Parts help need!!
- Skunk 2 Throttle Body Question
- starter question?
- Lowerig/dropping a civic
- Converting a P08/P30 ECU from auto to manual
- Brake Lights don't work please help
- lug nut stripped
- can a b18c run on 2 cylinders?
- By passing IAC
- GSR head removal
- recommended exhaust setup for EJ7 HX Coupe B Series
- help car wont idle
- Jb weld radiator question!!!
- will gsr seats and type r seats fit 98 civic dx hatch back
- Quick Question on the IAC valve
- Retard timing on the fly?
- best valvetrain
- Car Wont Keep Idle (Hot or Cold)
- Car chokes When Vtec hits
- will a itr intake manifold fit a b18a head???
- EF Si cluster
- Freeze plug?
- Which trans F20B or H22??
- Signs and symptoms of a motor going bad
- wiring harness
- ls crank in gsr block
- Fuel pump kicks on but no fuel pressure in lines..HELP!!!
- How strong are stock axles?
- No spark after some engine maintaince, please help
- TPS unpluged (idle problem)....help
- b18c no cel.. starts but dont drive HELP HELP
- bad wireing problem 96 EK
- upgrading valves
- My Accords Oil Light is On, Whats Wrong?
- Excessive wear on wheel bearings?!?!
- Stock exhaust?
- intake manifold
- electrical pin out??? any1?
- Gsr Intake manifold MOD (IAB removal) ...
- timing belt help please!!!
- 1997 CX Hatch Won't Start!!!!!!
- Any knowledge of Honda Part Numbers? UK vs. Japan Part No.
- 03 EP3 interior fan not working
- Tried posting this elsewhere...
- Shielded wires
- Vehicle Speed Sensor
- Oil temp
- make cam gears look stock
- blocking off oneside of a scroll?
- Measured extremely large clearances on rod & end bearings - sanity check
- Power steering belt size for swapped eg
- Pinout for a p28 ecu?
- Earls fitting? What size?
- Civic smokes, Not Cigs....
- difficulties distinguishing rod knock or valve train noise
- gsr cam caps??
- Corbeau Seats- too low???
- Starting question
- H22 Catch Can
- Integra OBD1 engine into OBD2 car (Warning Proper English Inside)
- VTEC coolant Reservoir overflow
- head bolts must be threaded by hand?
- difference between 1.5-2.3
- Replaced 02 Sensor - check engine returns after clearing codes, thoughts?
- Chipped ecu question
- Adjustable cam gears on lsvtec
- Bride Gias Authenticity Check list
- CEL Code: P0170/P0171
- Mass Members.....Need your knowledge
- B16a into 93 civic h/b
- will a B16 manual starter work in my manual 95 Integra GSR?
- H22A throttle responce.
- type R header HELP PLZ
- BAR legal help with 01 ITR to EG swap
- JDM cluster to USDM cluster
- can anyone tell me????
- Tps Help!!
- crx si no start
- VIS carbon fiber hatch
- Oil pressure switch, how does it function and at what voltage?
- OBD1 motor in OBD2 car
- Oil light flashed
- b16 obdo o2 sensors
- Idle goes up and down
- EG auto to manual conversion: Block off plate?
- G23???
- s300
- Oem exhaust help!!!!!
- stripped block
- After market fuel rail
- Hondata map question
- High and Roaming Idle in relation to IACV
- b16 stumbles at low rpms (less than 2k rpm)
- compression ratio? z6 head on z1 block..
- Spark plug holes stripping...help needed
- cam ID question!!!!
- iacv??
- will this still fit?
- civic b18c wierd misfire
- IACV question
- Nitrous
- Civic Type R 03 ** Alarm Problem **
- Help regarding Toda Sports Injector
- Trouble With AC
- Idle at 2,500rpm when warm
- F1 Car Howl
- After startup drive- no fuel?
- Can't get rid of code 14??
- skunk2 intake manifold
- what would cause dash lights to not work
- Power Steering and AC Question
- polycarbonate V carbon fibre sunroof plug
- MSD Dizzy Problems
- cel problem... searched please help
- My car wont go passed 3k Rpms
- timing belt issue
- H2B which alternator belt?
- after going obd1...
- How to install a pedal Stopper!
- GSR scat rods with Stock GSR pistons??? need help ASAP!
- D series oilpans?
- still ticking after valve lash adjust....help!
- what cams do I have???
- GSR Swap has no power
- Clutch or tranny problem?????
- Getting no fuel or spark
- HELP! code 20
- 99 si cel on
- Failing for high CO
- NEED ASAP 98 Civic EX ECU Northeast PA
- ***shift linkage ???"***
- Seat Belt Reminder Circuit
- No dashlights helppppppppp
- Mugen shift knob dimensions
- Need help..Timing Belt installation problems!!
- Intake Manifold Gasket
- Modified Windage Tray? (found on ebay)
- How do I get my horn to work with quick release
- sub-frame question
- how do you remove this??
- Coolant fan isn't work... TRIED EVERYTHING.
- integra LCA on 92-95 civic DX??
- wiper motor won't work right
- neptune
- is this jdm h22a worth buying?
- 99 civic si won't stay started!!
- Balancer belt replacement done incorrectly
- Rough start!!!!
- wiring gurus..plz help with shielded wire
- prablem in my h22a ? help me PLZ!!!
- quick wiring ?
- >>cluster trouble!!!!! Help!!!!!<<
- D series rocker arms interchangable?
- Q about Venom VCN-1000 dry nitrous kit!
- Need some help????
- D16z6 main bearing need help
- Few questions on ls/vtec dowels
- itr valve springs
- LMA Differences
- Broken oil squirters, burning oil?
- ect switch!!!!
- swapping main caps
- Question about Knock Sensor!
- need help please
- O2/Cat problem... need some advice please!!
- Complex Custom Wiring for Windows/Sunroof Control
- Vtec arm rocker failure
- Temp help. vtec and idle
- piston question
- n00b question
- Burning Coolant after headgasket install
- exempt emissions
- enigine blocks
- will civic ex knock sensor fit in my integra motor
- any recommendations for good books?
- using o6 si muffler on gsr
