View Full Version : Tech / Misc
- axles?
- GSR TURBO... leak
- which gasket with GE vtec conversion dowels?
- eg6 rhd conversion question
- Integra turned off while at idle and wont start back up
- Rethread crank
- d16z6 inital timing TDC and Comp Cam 59300 problem
- the F block...
- engine help please swap/mods
- Vtec Solenoid question
- ls or gsr crank question
- MAP sensor dies too quick?
- EG underdash fusebox and DC2 underdash fusebox. Are they the same?
- Can A GS-R Head Gasket Be Used On A LS
- CKF sensor question!!! quick question please help....
- 92-95 fog lights install
- a few questions, please help
- Help with ignition timing.
- surging idle when i give it a little gas
- HELP! CAR VIBRATION URGENT HELP NEEDED
- d16y8 OEM map
- D15z1 D16y5
- O2 sensor failure = engine light
- S2K TB on a B series manifold?
- local honda dyno tuning shops
- '94 Integra LS Timing Belt Tension.....
- Electrics cutting out momentarily regularly
- Idle surge after spraying nitrous
- very high idle problem
- Regarding oil squirter threads...
- b16 turbo in a ej1
- Need help..on type R..
- tranny help please
- Help cut mount???????
- Spool k20 type-s tranny what you guy's think.
- Car won't start!?
- New swap (B18c-type R) bad sputtering/bogging/safe mode
- GSR Rod Discoloration???
- skunk2 pro vs. tuner series camgears
- Base map: Hondata or Crome for B18C5 with PR3 pistons. Anybody have one?
- Vtec crossover (need help, searched)
- Hondata s200 vs s300, running rich, injectors, JRSC
- Piston to wall clearance
- got a JRSC but having problems, if you have one see if this has happend to you
- Pulling a B16a2 Block
- Info about Honda Engine
- Need help with a jumper harness
- What happens to the timing knock sensor is disconnected ?
- can someone tell me if this is right?
- cable transmission
- Running rich! Fresh LS swap. Timing issue??
- Can someone PLEASE direct me to a picture showing the bellhousing face?
- is there a way to roll up power windows manually?
- Clutch + Flywheel Combo (Centerforce,Exedy,Other)
- index pin your main caps??? whats that mean
- power lack
- Scored one bearing during dyno of non-vtec h22, any opinions?
- db8 sunroof problem?
- 92 hatch w/jdm gsr .. cold idle problem, reving more than 30% breaks up
- em2 automatic to manual
- Base Map
- ****CHROME PRO**** HOW TO:
- B18c1 is burning oil. Should i rebuild for turbo or N/A? Needs to be a daily driver
- b20vtec ticking noise.
- D series tranny rebuild ?'s
- d16z6 in a 2000 civic? need some help!
- ngine assembly, how far in advance?
- CV axle grease question
- Coverted Pr3 to manual Still have 7600 redline
- LS block girdle
- A/C Removal
- b16a1 intake mani on obd0 b18a1 head?
- HELP!!! 98 Accord failed CA smog test - high CO but low NO
- finished my swap but got a tranny problem!!! HELP!!!!!
- distributor.. vtec one matter?
- Buddy Club 3 cam question
- '98 CR-V: P0301 code
- ARP Headstuds???
- Brake Cleaner Valve Test?
- What MTF for LSD GSR trans?
- wet and dry compression test results can I still run nitrous? What could it be?
- Help!!!!! BDL throttle body problem
- **PICS**burnt wires....Please help
- 94 accord ex abs removal?
- obd0 to obd2 ??
- ***AUTOZONE AXLES***
- ***HELP JRSC*** HOW TO TUNE WHAT PROGRAM***
- which ecu code do i need for a SOHC NoN-VTEC ZC ? and where can i get it?
- Another Oil Pressure thread. Please Help ASAP
- REALLY BAD sputtering problem at LOW RPMS
- Squeeling noise
- my integra is acting like a vw: electrical issue
- 92 civic eg does not start
- So i searched??
- type r brake swap
- final drives louder?
- I see this thread involves theory so...
- NEED HELP: 98spec typeR cams into b16a2 head
- serious oil burning help!!!
- Helms Manuals
- weird screeching noise while driving...any ideas?
- autozone axles on DA
- auto to 5-speed swap!
- jdm ecu for usdm engine, help.
- how much for average valve stem seal job?
- obd0 90 integra CEL problem HELP!!
- The engine can't start- strange things happen- help
- Turbomag X-T Fuel Magnet that increases MPG?? :crook:
- which is recommended apexi WS2 or Greddy Sp2??
- Hola New Here
- VTEC controller wireing diagram
- Engine Coatings
- extream carbon build up
- Degreeing cams...HARD OR EASY!
- tranny help
- Car idling from 1k to 2k??? EGR Vavle? PLEASE HELP!!!!
- EVAP Purge line
- HT please help me diagnose, smog failed hc and nox too high
- Hydraulic tranny on a non hydraulic motor?
- axle help..ef axles in eg
- Where can I get larger Honda Fit injectors
- question about B16 motor with Dseries transmission
- cleaning exhaust ports
- Chipped Crank Pulley to replace Unorthodox one
- where is my coolant going?
- help installign b16 head on b20
- Rod and Piston Wrist pin?
- LSD Break in, Myth or Fact ??
- 00 Civic Si: CEL! (o2 sensor low voltage)
- DISTRIBUTOR CAPS _ DIFFERENCE LS AND GSR
- AWD Honda
- Pulling engine: drop it down or raise it up?
- JRSC need info for tuning
- Final Drive Question???
- What engine will fit my car?
- 90 drive axles popping out, replaced both of them, tried different set as well, anyone help?
- custom loom
- proportioning valves 96-00
- power steering bracket
- what else do I need for my Turbo LS Vtec before i go to a tuner?
- Cam Gears???
- AEM EMS /W Wide Band
- integ type r ITB's TPS wiring help.
- arp head studs for a b18c with a b16 head
- Check engine Light On, Need Help!!!
- what is sleeving a motor?
- check engine light turns on randomly and then when i restart the car it goes away?
- Torco Premium Break-in Oil
- Differences Between B18B and B18C1 block?
- Car turns off... Now it wont start.
- help with vtec controller
- A few questions about injectors
- Cons of Grinding a crank..
- jdm d16y7 swap
- can you reuse head studs
- axel problem, leaks, and disconnecting from transmission
- p30 piston and crower stage 3
- b series cams
- HONDA SMX B20B VTEC HELP
- Need a Brand new B series head whats the best?
- VTEC SOUND!!!!!HELP
- tranny help
- I need some help with the order of washers on banjo from fuel pump...
- tranny problem
- 84.25mm piston rings in 84.50mm pistons
- FITV bypassed. still causing idle problems?
- Help conversion harness!
- Stiff accelerator. Throttle cable?
- coeffiecient of friction of different pads listing wanted ?
- 04 Civic Si seats into 92 Si
- Not a honda but problem with brakes
- H2B INTO AN EK help?
- distributor sensor question about signals
- Will obd2 injectors work with obd1 harness???
- identifying vtec cams?
- how to lower the compression on b18c5
- Sigh!
- WHY ???? with pictures
- Timing Belt for b18
- Helms on PDF for Integra
- B16A2 into Auto EK (TCM/TCU - Umm what?!?)
- (Wierd) How To Install "JDM" Tow Hooks?
- injector clips
- timing belt help
- Fluctuating Temperature Gauge
- built h22a (smokes when cold start up)
- LS Tranny on boosted b18c1 w/ b16 head?
- Rebuilding my turbo gsr for more power
- Engine Dampers worth the $$$?
- Need Info On Tuning for Whip Factory
- distibuter question
- *** IGNITION PROBLEM???? ************
- cam journal scoring
- Gas
- Lowering Hydrocarbon Levels and Passing Emissions
- Stuck injectors?
- transmission D4 light out
- LS head with b16a bottom?crazy or stupid?
- searched and archived: str 3 bolt cam gears?
- *98 itr motor*
- LS crank in GSR block????
- d-series oil feed line nightmare
- Just replaced the axle STILL CLICKS!!
- SiR-LSD Third Gear Grind
- websitess
- Weird Electrical Problem!
- What is this part called? and how do I fix this...
- ITR FD install with gsr Fith gear issue
- transmission noises: constant grinding noises on deceleration and at high RPMs
- replace cat with resonator
- Quick ?, Are all B-series pressure plates the same? identical
- which ecu code do i need for a OBD1 SOHC NoN-VTEC ZC?
- SOHC 4-Door build
- Help with Innovative Mount install for EK
- ir
- obd1 gsr into EK 96 obd2a SWAP HELP ME
- Timing Queastion
- Weak Links of B-series Engines?
- Planing to Build, and i've got some questions...
- bad thermostat??
- Ys1 Tranny Help. 2nd gear.
- Code P0141 Help!
- Cat swap to test pipe
- rebuilding rack.
- arp head bolt torque specs b18c
- VIDEO. Vtec... myth? really IAB'S? check this and comment.
- honda crv stalls when cold
- Just dyno'd my hatch, very low HP WTF?
- Best set-up to go for an ls N/a
- S300, cant seem to upload tune correctly?
- Head gasket .5mm oversize - ok?
- chipped ecu's not datalogging and solid CEL with no codes - How to test?
- Will an OBD1 distributor work on an OBD2?
- Battery or Alternator or Both 98 Civic DX
- I need help looking for this Socket!
- Car not starting..electrical issue
- need bolts for b18c head, where to buy?
- Cable clutch to Hydrolic clutch
- Tranny on a ls-vtec info
- HEY GUYS
- battery cable connection question.. help me out!
- syncromesh
- clutch slip?
- b16 head year???
- ATI damper puller?
- I HATE CA SMOG!! HELP!!
- B-series Gearing on H22 trans...??????
- Volvo T3 specs (Garret). How much hp?
- Questions, Questions, and Questions
- IM swap - from OBD0 B16A1 to OBD2 ITR IM
