View Full Version : Tech / Misc
- 2 Quick Questions?
- need help! need to replace fuel filter in b16a
- Gasoline Pressure Issue
- anyone try super-tech?
- is it worth to rebuild stock block?
- sputter when driving stock D16y8
- b16b into a 98 civic DX coupe
- clutch problem
- integra starter problem
- iacv plug voltage
- Main Relay
- DTC P0441
- ITR cams
- idle problem after car warms up
- getting a new b16b... what to do?
- Honda Engine F22 in a Corvair
- Window Guard ?
- crx b18a1 swap problems
- 98 Civic A/C hair pulling problem
- No fuel out of injectors
- All About Wheel Spindle Nut
- CEL code 15, what do i do?
- HARD START / STUMBLE AT WOT
- converted auto-manual..do i need to wire reverse so car can start?
- Motor up xtreme?
- Oil Line Kits!
- vtec trouble
- Alternator connector swap??
- Obd1 FANC-A12 wiring.
- accord won't start :( (no spark?)
- Slim fan brackets
- can you use a y7 head on a y8 block???
- Question about a radiator support
- Ignition Timing Issue
- aftermarket rods for ctr b16b????
- List of Engine Check Codes
- How do I reinstall cruise control on a B swapped EK?
- Putting intake springs on exhaust side
- Skunk2 pro 1 cams breaking valvetrains??
- Car continuosly turns of (need help)
- 93 civic 4dr dx auto to manuel firewall harness swap
- What oil grade ? Accord 2001 31k miles
- LSD problems
- ramco
- axle trouble
- EGR valve code
- Civic has no power
- OBD1 RPM signal
- Need DIY fuel pump 91 integra
- oil cooler sandwich plate
- OBD1 b16a2 - w/PR3 pistons?? EDM not JDM p30? what motor is this?
- Stock valve retainer rpm help
- IACV issue
- 2000 civic SI burning a ton of oil.
- steering column damage from theft
- Some engine advice...
- 98 ODYSSEY REAR DECK LEAK
- Help with Distributor rotor screw breaking
- ELD trouble shooting on 91 EF
- Snapped rear lca bolt
- Mustang 70mm tb off the 5.0 EFI, Does the butterfly open the same rotation as bseries
- suggestion where to mount vafc in an EK
- interior light issue
- throttle and idle issue
- NO HEAT and its freezing out Help plz
- H22 Bearing Help!!
- Wont turn over...........
- bee*r rpm signal?
- Repeatedly blowing my interior light/accesory fuse!!
- Resistor box on stock motor?
- B18c1 head oil flowing out need help
- car wont start
- Used Battery from Junk Yards??
- injector clips obd1 to obd2 question please help
- HELP!!!!!!!!!!! LS/VTEC questions,need help ASAP!!!
- what B series cams are these??? HELP
- Dual Zone Heat only works on one side
- Need second opinion on spark issue
- B Fuel rail with no flange for stock mount FPR?
- OFFBRAND INTAKE MANIFOLD ?
- State Ref! Need Help!!!!!!
- how strong does a roll cage make a car?
- dry cell battery question
- fuel pump or fuel pressure regulator?
- Car's Weight
- What is Brake & Light Inspection?
- Blox/Omni Power Test pipe adjustability question
- help please
- Should i worry about this?
- 93 civic took turbo kit off and car wont crank,using stock parts & ecu,injectors
- what powers #18 fuse under dash?
- b18c4 engine info
- Is it worth it? $1650 for B18c bottem end, gsr head, tranny...ect.
- Edlebrock intake manifold trouble
- Battery cable size?
- 1997 civic HX coupe trouble
- i need help in eastern ct
- question about aem fuel rail
- 1994 Honda Accord fuel pump help
- Fuel Pressure: PSI
- 97 Civic DX Maintainance Question (Timing Belts, etc...)
- Cylinder Head Oil Starvation
- fuel problem
- engine wont turn over, no dash lights?? after swap
- Car not starting and no electronics on
- Fixalbe head(dropped 2 valves)>> pic inside<<
- MSD Issue, please help!
- honda bseries swap can be posible in daihatsu charade gtti???
- Bad to let an engine sit too long?
- Obd2a and obd2b dizzys are the same?
- quick wiring (wire tuck) question
- 2.25" gasket on 60mm exhaust okay?
- First time cleaning engine Bay: NOT GOOD! HELP
- Quick oil pump question
- help on gm 3 bar
- Good deal for Si rear brakes?
- Dead or dying Aeromotive A1000?
- help diagnose problem with my y7 turbo
- 91 HATCH D15B2 TIMING HELP!!
- Intermittent problem with p28
- da gas tank
- help ASAP, short circuit.
- B18B High Idle 3k
- 94 gsr baddd oil leak
- 98GSR Problems
- Problem with Srs and break light
- HELP!! CLUTCH ISSUES
- Really need some help! Car not cranking - '92 K20 EG
- Keep blowing ignitors wtf
- OBD0-OBD1 conversion not starting?? HELP
- I need some brains to help on probably wiring problem
- Overheating Tried everything
- Tiptronic!
- Fresh GSR swap VTEC no Speedo working
- Who wants to attempt to decrypt my alignment spec sheet?
- 1992 Accord wagon Fuse box diagram
- CALIFORNIA GUYS HELP.....CRAZY CA SMOG
- NEED HELP ASAP!! Half shaft install!
- Having problem with my 93 ex HELLLPP!!!!!!!
- Looking to build 350-400whp honda! Suggestions please
- IACV: Needs to be replaced, adjusted or ???
- Motor problem
- 1994 Honda Civic EX 1.6L HIGH HC
- 94 gsr fuel pump wiring diagram
- Ordering from HMOTORS, replacing parts?
- which is faster?
- anybody know which b-series cams these are??
- Will you using these "new" Wheel Bearings
- warped head
- Sub in trunk, w/o taking up space
- wiring up my B18c1 in my lx civic. need help.
- Couple of quick EG/LS swap questions
- Someone Help Me With This...
- Integra Climate control problem
- h22 skunk2 intake manifold install help
- FRONT SUBFRAME ???
- Carburetor tuners
- Idle's weird but no CEL code thrown.
- BOOST questions, help!
- Super Noob Question
- Valves
- eg civic drum to disc conversion HELP!
- VSS I think
- dont kno were i should post this but stupid quick question on jensen indash
- Water temp gauge adapter size?
- Failed emissions horribly.. tried just about everything.. NEED HELP!
- my car is sputterin help
- 05 Odyessy Valve Adjustment
- HELP ME WITH MY B2O VTEC
- k20 type r A/C help.....
- D16y7 with y8 head will it work???
- what ecu for my build
- Keep Cruise Control with a non-cruise control steering wheel?
- clogged oil passage ways
- vtec not working for 96 acura integra gsr on 1st gear only
- No flow of coolant in the Iac
- skunk2 intake manifold help
- Bad Distributor
- brake proportioning valve leak
- dashboard help needed please
- bogging at high rpms
- help, no vtec, sputtering
- mini me help
- fuel pressure issues
- auto to manual conversion on a dc2 teg
- No catalytic and cel on
- loss of power!
- please delete
- torque spec on clutch bolts
- anyone ever cut open a B16 head?
- Ive got a coolant leak from behind the timing cover
- stock valve springs mixed up (LS head), help identify
- h22a engine ticking knocking
- Starter casting broken ...
- 2nd Gen Integra, LS-Vtec without the vtec troubleshooting?
- Cross reference
- Distributor casting numbers?
- Dash board clock
- how to wire vafc to a non vtec ecu (p75)
- Burning oil on b18c1
- KMS Stainless Intake Manifold Stud Kit
- clicking from wheels since I lowered my car???
- Physical Dimensions of J series engine
- cylinder head chamber boring?
- I need some tips on removing some weight from my D/D 94 eg 4dr LX
- Avid torque mounts
- 12ga milspec wire ok for alt/starter power wire?
- HID's foglights illegal in California ?
- Wheel bearing for 96 Spec ITR?
- Timing belt loose with pics..WTD?
- 3 " exhaust for my 97 hatchback ?
- strongest engine build up cleaner possible
- Metrinch life time warranty?
- bought a sleeved block...
- Ebay Clutch
- 96 JDM type-r bogging badly HELP!
- Need SMOG help.... bad numbers, what to fix?
- 00 ITR swap into 00 ex.no spark CODE 15
- Cams
- 1994 civic dx won't start!
- What wires/plugs needed
- Recaro/Rails?
- need help on installing tsx exhaust
- b16a wont start
- map sensor swap?
- GSR lost compression
- 90 Civic B16A SiR II ODB1 IACV/Idle Question - Searched
- JDM civic vent,when to put dimmer!
- motor is in limp mode
- I need AC, HELP!
- Rocker Arm Configuration - Bseries
- need master tec** 94 civic d16z6 head ** what is this called and which one do i use??
- Strange, low-speed D-series mod
- Need help with gsr head swap
- something wrong need help!!!!!1
- help, car wont start!
- Check Engine Light not working
- Dude Really??? broken spark plugs
- no more importing?
- Harness firewall plug
- idle problems
- Need help fixing someones botched wiring...
- Vibrating Issue...
- SWITCH PANNEL TO HONDATA?
- Torque converter housing bearing replacement
- distributor ?
- TB QUESTION?
- length of B series passenger axle
- Wire Harness Plugs
- Valves too tight?
