View Full Version : Tech / Misc
- lightened flywheel for my b16?
- Valve Seals, Valve lapping Compound?? Help guys
- help with homework please.
- afc neo install help...
- ecu help
- gsr nocking
- firend having trouble with clutch /tranny
- Honda Ecotec?
- HELP CEL 9!!!!!!!
- B-Series tranny problem
- OBD0, OBD1, OBD2
- Difference between SAFC and VAFC
- Apexi VAFC Question?
- d15 to b18 engine swap
- engine seals
- I need some one to tune my crx
- b18b too rich and very low idle (searched)
- fuel cell foam,
- Need engine help ASAP!!!
- RSX-s, what makes it stronger then the base?
- New Fuel is Broken
- 83mm piston rings in 82mm bore?
- jdm p30 pistons in a supercharged integra gsr
- datalogging
- LSD Gbox or not?
- redline? tach......... mileage....
- where is that amateur engine building contest ?
- IAT (intake air temperature) sensor
- GSR vs. Si OBX LSD
- vtec vS ivtec cam theory build
- Steering wheel turns by itself???
- Help- final gearing s20 trans- hybrid?
- 1999 Civic
- need help with valve adjustment.
- Fuel Pressure Setting for 200hp b series
- D16Z6 which distributor?
- Chipping a Auto P13???
- Just another headgasket post (B18B1)
- Engine Harness???? Which one???
- Question?
- rpm's shoots up then back to normal.Help plz!!!
- Two 02 sensors? what to do with them
- anyone else have trouble w/ GE oil sandwhich?? or am i just retarded?
- Tuning hondata s300
- need some help please
- B16a2 INCREASE DISPLACEMENT?WHICH AND WHAT PISTONS
- Quick Question about O2 sensor and if location has effect
- jdm itr piston question?
- Best HID ballast/bulb
- Block guards??
- Pennzoil syncro mesh vs. Genuine Honda Tranny oil. What would you recommend.
- I just F'd up. 9978 RPM missshift
- Code 3 Map Sensor Car Idles at 4,000 RPM
- shifter moves up and down?!?!??!?!
- rsx seats in the integra
- h22 problems or parts 4 sale!
- My Tranny is grinding
- B18c5 & H22A whats the difference?
- HELP::CRX::SMOKE PROBLEM::asap
- crx with a crazy idle
- interchangle d15/d16 valves?
- Stalling at Idle
- I need help like now!!
- valve adjustment?
- Steering colum/ignition switch replacement.
- Clutch Issue
- I need help with my swap!
- B16A1 Crank @B18C6 Block
- Exedy stage1 for ITR civic& lightened flywheel?
- Idle Surging
- Cannot get a head-gasket to stay, 4th Head-gasket, Head-lift all the time
- **AEM wideband**Please Enlighten me
- too much oil!!!!!
- low speed stutter
- d16a1 stuff
- Rev limit
- Neptune
- nology products
- NEPTUNE>>???? WTF>>???
- looking for a good aftermarket knock sensor
- b7 head question
- Valve instal help/advice?
- bearing noise from engine??
- Starter won't stop spinning without keys in ignition.
- How different is the exhaust for an eg coupe and an eg hatchback?
- converting nonvtec ecu to vtec?
- oversized piston question
- Electrical. Battery/alternator?
- fitting a b16 in a 97 5 dr
- Type R Oil Pump
- H2B
- Why do P29 Pistons make for higher CR in a d16a6 when they have the dame bore/stroke...
- Clutch is already gone...
- How much should a shop charge for a compression and leakdown test?
- bad sensor?? please help
- H22 tranny with B series tranny's internal???
- Brake ducts - rotor cooling theories, applications, and pics
- thinking about making a D15 go kart, any advice
- Edelbrock 70mm TB TPS
- strip thread on mounts & tranny...need help
- ctr or itr camshafts???
- b18b in ek coup question
- What metal is a ring gear made of?
- Rollcage bolting in - gen2 into gen1 CRX???
- timing belt walking
- B16 or LS spark plug WIRES???
- new clutch stock flywheel ?
- Header Cover?
- B20vtec idling problem, HELP!!!!
- ECU question
- need help with type r wiring.
- tranny things
- 98 integra converted to 0bd-1. need help wont start
- obd2 to obd1 injector plugs
- 99 gsr looking to get flywheel
- 99 gsr, what's the best cams
- 99 si harness for a 96-98 ek?
- Need Help with weird problem on a sohc
- To anyone who has used a dynojet....
- first rebuild.. Rod bearings
- The "What fits What" Catback/Axleback Exhaust Thread...
- do i have a zc trans or si ? serial # inside post
- another ys1 ?
- buddy club spec 4
- Any help is appreciated!
- 2.5" piping? mandrel?
- Who sells or makes the h2b conversion kit?
- b20 thrust bearing?
- manual swap, auto ecu?
- run hard, car shuts off
- Any tips on cleaning rods and pistons?
- B20- type r head conversion??????
- braking issue
- AEM 1000 for obd-0???? what all would i have to do?
- Difference between turbo kits.
- '99 B16 Head Valve Lash Specs
- Golden Eagle Head bolt studs GOOD or BAD?
- where does a zc come from and what parts fit it ?
- no clutch pressure??????????
- b16 wont start. have spark fuel.... dim CEL
- OBX LSD washer grade question.
- Can I use regular heater hose on back of block?
- Help! Problem with ITR throttle cable
- shift linkage in tranny (auto, Acorrd 91 ex-r)
- map sensor issues?????
- weird clutch issue
- Anyone with ebay parts experience\stories leave input
- ITR driveshaft, wheel bearing replacement problems
- HELP! AirFuelRatio
- converting 91 squareback autom into 5 speed manual
- torque damper in eg with gsr motor?
- 90 civic 1.5 transmission into 94 civic ex auto swap question?
- Help with Choosing Bearings for Rods, Mains, and Piston Rings
- Possible Clutch Master Cylinder failure?
- B18c1 GSR block question
- SI Gauge Cluster in 97 EK - speedo not working
- b16a w/autotransmission question
- Starting Issue
- need help with p72!?!?!?
- Bride Ergo II vs Recaro SRD vs ??
- Shimming transmission???????
- 5 speed swap
- now comes the fun part....
- do ingectors have part numbers? if so where?
- $$ REPLACE VALVE SEALS
- ctr pistion/ scat rods
- could a stock block..take nitrous
- How to "homemade groudning/earthing kit"
- help with timing!!!!!
- need help with apexi vafc
- Error Code P-1337/crank shaft sensor/P72 ECU with B16A JDM
- Clutch issues, need some info
- car sputtering after cleaning engine
- need help finding a repudable import performance shop in cen. cali?
- Where to buy axle
- Engine cutting out and tach going nuts, help.
- Weird overheating problem.
- Piston Ring end gap questions
- vin number?
- cylinder bore question
- Hondata S200 Romulator Q's...
- Fuel Line Fittings
- The next Honda motor series???
- LS Head With SI Intake??
- electrical short??
- B16 Head Bolts
- gsr head install
- So what happened to my Tranny?
- TRANNY ISSUES (GEARS WONT GO IN)
- auto wont shift past 3000 rpm
- 91 da auto to manual conversion, mount question
- the k24 family
- B20 Blocks
- =======URGENT HELP=======
- Question bout smoging.
- EK Hatch midpipe same as EK Coupe?
- IS THIS POSSIBLE?!...
- very low idle afta car warms up need help
- 50/50 antifreeze
- couple questions about hondata + nitrous + boost
- Swap Axle
- Spun Bearings
- TEST YOUR SKILLS // EG CIVIC OWNERS ONLY!!
- bad p2e ecu maybe?
- no tps wires... i'm stumped
- H22 SECONDARY BUTTERFLYS IN THE INTAKE!!!!!!!!!
- weird noise...
- DSM injector problem on supercharged F22
- shaft play on distirbutor?
- d16y8 to d16z6 in crx questions
- Timing Belt Issue??
- Anybody know a good trany shop for an auto in or around Alhambra,Ca.????
- What piston to cylinder wall clearance for Arias?
- 92 accord non vtec code 21
- Does it matter if an alternator was from an auto or a manual?
- making a JDM ITR pass inspection/smog?
- gasket for venturi plate?
- Hard starting after Timing Belt Change - Runs fine when started?
- What the heck happened to my motor?!
- can you bend a valve by not overreving?
- what computer to use?
- Problem With The Gears ?
- Integra eating gas?
- OEM VS NGK I know I know
- SHIFT LINKAGE QUESTION?
- WIRING HARNESS HELP?
- B18 Help with timing
- Ignition timing.
- PHILLY AREA ??? NEED HELP
- Integra windsheld wiper goes off on its own
- Electrical Gremlins
- Help! Broke my timing belt!! :(
- TPS keeps going bad
- no oil pressure in b16a2 HELPPPP!!!!
- GSR being a little F*@ker! (running bad... sometimes)
- axle broke (maybe)
- DC5-R pistons
- Car wont start. Weird problem!!
- Blown Head? Gasket?!?!
- grease and gunk on tranny
- Differential bearings both bad, why?
- Removing Stuck Wrist Pins
- distriputor not workin? car wont start
- Tranny leaking from shift linkage. Bense?
- Stiff Shifter, which bolt is too tight?
- whats the diffrence between these two fuel pumps?
- Car won't Prime
- high NOx emissions
- ctr cams question
- ferrera or comp no vtec cams and roller rockers ???
