View Full Version : Tech / Misc
- Opinions on Tanabe suspension
- how do i know if my vtec is working
- Gone uberdata!!!
- B16a vs. mini-me
- Questions on 2000 Si Dizzy
- Which tools?
- Skunk2 stage 2 cam tecnical info
- eradic idle...HELP
- b20 or itr crank
- Need a Q answered ASAP!
- Can I move B16A intake cam to exhaust side?
- LS Cams... JG1001's VS. Crower 403's
- suspension question
- why am i burning anti freeze?
- Ignition Pulse Question
- Idle on my B16 is at 1700....whats the problem?
- how to rig up disconnect switch on a 96 Prelude VTEC?
- LSDs, H22a vs. b18c
- For those who have gotten swain coating!!!!
- Synchro Compatibility??
- need quick answer or Opinions...shiflinkage...
- Spring and Shock Install
- What to put in my 94' Accord EX?
- anybody delt with importbuilders?
- Need Help Alternator wiring diagram
- price plz.
- I want to build a header please help
- ITB's and emissions
- DC2 springs on EK civic
- Idle acting up help?
- HELP!!! I have an oil leak where my tranny meet the block!
- Hydraulic Press Questions?
- how safe is it to have type r pistons with gsr head withe the compression at around 12.5:1?
- Q's about my brembo blanks are thye real? (BIG PICTURES)
- Tein coil over wrenches...
- buying a tranny need tips
- what causes rod knock?
- catback exhaust weights
- Uberdata questions
- NEED HELP! WHAT TO DO! 2000 B18B1
- No Vtec in my B series
- Tranny or clutch Failure?
- dust boots on struts/coilovers necessary?
- Dual diaphram pressure plate ?
- How long will I last with a leaky clutch master?
- What chip does Hondata use for the p28?
- IAT...
- want opinions on a quick write up i did...
- A question about dsm 450cc injectors
- KMS products
- NEED HELP ON H22A SWAP INTO 97 COUPE
- timing question after head work.??
- with no ac and ps belts will my rpms go up faster?
- k24a4 motor with a k20a clutch?
- Can you read this dyno? (ignition problem?)
- cold air help
- ticking noise
- Odd Problem with Engine Build...
- Putting b18b head together, help please.
- Front Brakes Seized up...Advice please.
- help, no vtec and early redline, no CEL's
- ECU Help!!
- 01+ civics obdII.5?
- B20 head Vs a Ls head
- Auto tranny problem... Reverse to park/neutral.. Grinding??
- 99 gsr head on 1.8LS non v-tech
- Acura Parts Catalog
- DOHC ZC Crank Pulley removal
- BLOWN HEAD GASKET/ HEAD GASKET INSTALL???
- Finishing up engine now how to tune this thing. Help and Ideas appreciated!
- exhuast manifold gasket
- bent rod/resleeve
- insane motor swap idea!
- clevite engine bearings
- quaife install- wrong diff. & bearings???
- Machine shop in San Diego?? Need some work done
- 99 Civic SI - Transmission Mainshaft Bearing - Replacement
- ITR difference stock calipers and mugen calipers
- Insane Idle Problems
- YESSSS h23/vtec runs!!!!!!! one question though????
- How to clean out oil from a d16y8 head out of the car?
- JDM front end conversion?
- Want to turbo my car, will these injectors work?
- Fully break in motor before tuning?
- Need recommendations on MAP sensor to use with AEM EMS
- jdm front end head light and fog light wiring.
- gsr swap in a 96 hx ?
- GSR Main bearing bolt thread pitch and size?
- Apex PS revolution muffler?
- When is the recomended time to change your spark plugs/wires
- DOHC ZC Timing, is it off??
- Bucking honda NEED HELP PLEASE!!!!!!!!!!
- What are good compression numbers for sohc.....heres mine.
- 93 civic cx engine harness Fitment?
- 96 CIVIC DX MOTOR, GOING INTO 94 EG COUPE????
- 99 obd2 EX wiring harness and 99-00 si OBD2 dizzy.
- Wanted: Relay box or diagram for installing JDM ITR power folding mirrors on DC2!
- Braking in head?
- Intake?
- I can't find my wheel lock...
- Please help, figured one problem out, 1 more to go!
- whats this sound coming from?
- do these sparkplugs look like there in normal condition...> ?
- i need help fast
- Cementing a block.
- Injector signal from ecu question
- Custom cat, needed to be sprayed for rust?
- new injectors and v-afc
- with bigger exhaust piping, how much whp will i gain???
- obd1 dizzy ignition signal wire voltage?
- filling up tranny
- how to wire check engine light?
- valve adjustment tool.
- what size of tires
- b series flywheel
- testing IACV and FITV
- How can a key for honda civic 2002 model be reprogramed
- ITB'S, Map Sensors, TPS, Vacuum, Fuel .........Relationships
- Questin about Hondabond and oil pans...
- ECU chipping which brand
- HONDATA s200 / CEL ON DASH BUT HONDALOGGER SHOWS NO CODES???
- Proform Shift light install...
- Differential Free spins
- heptagon lug key broke what to do!!! please help
- Changing a Header
- Should I even bother?
- Engine clicks or knocking after warm-up
- Questions about hood pins
- WTF
- b20 vtec (crvtec) vs b16a2
- wiring problem
- 92 & up clutch in d16a6?
- HELP mini me wont rev past 6800
- 183whp with stock block and stock cams
- will a worked b18c1 head make a difference to my performance
- Rod bolt stretch gauge recommendation & related question
- got a Q on removing LMA (lost motion assembly)
- ignition related?
- Just failed emissions for NO...what could it be?
- 97 acura integra rear view mirror questions!!
- CEL 14 and car turns off after temp reaches normal?????
- JDM ZC SOHC VTEC ? ?
- need help?
- Anyone in Flagstaff Arizona?
- Identify LS crank
- strange issue
- pic of vtm wire VAFC
- JDM parts/svc manuals??
- Missing a part for Greddy Oil Block Adapter??
- Manual Transmission Disassembly
- HELP!! what AN fitting is this??
- b16/problems
- car barley start and wont run. hit the gas and bogs out
- arp head studs going into my dohc zc.......some ?'s
- Throttle body question
- ls motor w/ gsr pistons
- Whats The Difference? OBD0/OBD1/OBD2 ???
- Help with lights... PLEASE!
- Ever heard of KMS Engine Development?
- Help! "idle" / "accelerate" problem!
- violent shaking on acceleration
- how do i know if a tranny is good or not?
- TRANNY is rough and MAY grind...catch point CHANGES?!?!
- injector tech...
- Car bogs and hesitates on idle and moving...fuel cut while moving?!?!
- itr ecu not working with ls vtec
- CEL after swap
- rubber couplings
- problems w. high rev....on & off
- Quick question about VAFC install and splicing!
- LS head cam lift clearance issue questions....head experts needed
- ticking related to timing?
- Smoke from engine
- Need help with tranny
- 99 gsr w/type r sway bar..sugestions for agx settings?
- need parts.... good ones!?!? b-series swap
- Can I put...
- Rear swaybar Qs: ground control, stock info etc
- 94 D15 dizzy fit a 95 D16 motor?
- Honda trans shop in SE Michigan?
- revlimiter Q on my 95 gsr ecu
- a/f gauge
- lowering problem..
- swap question
- ecu question
- HELP in VA getting off this M0th3|2FUc|<ING axle nut
- hondata throwing codes 4 no reason????
- O.S. Gikken Dual-Disk Clutch
- JG Cam Gears?
- h22 eg civic vtec problems
- 92 hatch POWER SUNROOF INSTALL?????????
- Vtec Trouble...need expertise
- please please please help........
- OBD1 PR3 ECU pinout the same as OBD1 P30?
- Calling honda employees, part number from majestic honda????
- CEL code 13 Atmosphere Pressure HELP?
- momo steering wheel with horn button in a 97 integra
- H22 Swap
- JDM ITR B18C and CTR crank pulley. Which alternator belt do I need?
- gurgling noise from exhaust
- what size for o2 bung
- where to buy engines in NJ?
- CRX SI MOTOR WITH DX INTAKE MANIFOLD......JUST READ DPFI TO PART MPFI SWAP
- Any honda techs in Flagstaff AZ to install ECU chip?
- 96 prelude tech
- didnt know where to pos this but i need opinions on head build(allmotor)
- help on OBD0 TO OBD1!!!!
- 92 civic brake mc rebuild need help
- So, with all the talk of intake manifolds lately...
- Cam gear question
- distributor swap (already searched)
- Any air conditioning experts in here, whats the difference cx, dx civic ac
- Civic R pistons...
- Valve cover
- JDM ZC Valve Questions
- no spark no fuel
- High Compression D-series super bogging help?
- will a 96 ex engine harness run a 98 b16 ecu with out modification???
- Honda wont help me. Is it legit?
- Crank Journals
- Horsepower ????????
- what size wrench should i use to remove the stock oil pressure switch (B18B)
- NEED A D16Y8 motor wiring diagram ASAP!!!
- What tool should I get to torque down the main caps??
- HX to EX swap problems, CEL & Idle
- coilover problem
- main caps help
- Wiring?
- clutch break in period?
- Type R valve train
- DAP window sealant for homemade mounts?
- B18b1 exospeed cams gains??
- GSR tranny
- Can I clay all the journals at once?
- Definition of Spun
- Axel Moves Up/Down @ Intermediate Shaft? Half Shaft Bad?
- d16y7 I.M. help plz!
- car wont start without...
- Civic parts diagrams?
- does comptech header only come in 4-2-1?
- h22a woes
- Dyno's
- AEM FPR diaphram bad.
- did a COMPRESSION check and my #'s are fuckin crazy.........HELP!!!
- 99 accord knock sensor in b16 2nd gen
- I think I'm running lean on a few cylinders (Help)
- A/C Compressor question! Please Help!!!!!
- Check engine light when going into VTEC
- car wont start....bad grounds or not enough??
- did i mess up bad and how do i fix it???
