View Full Version : Tech / Misc
- stock injectors with skunk stage 2 cams
- Skunk2 Valvetrain
- Clutch
- Question about thermostat housing
- H22A tranny question--what are these holes for??
- B16 clutch plate torques
- Did majestic honda make an error or am I the retard???
- Fan makes Strange Noises
- Horn Doesnt Honk....help
- Typical Cost to have a Head Milled/Resurfaced?
- Need Some Help! Regarding Oil In Throttle Body!
- Vtec kicks in when high beams are used!!
- MSD differences
- Clutch Install - need tranny jack
- need a part no. for longer intake manifold stud
- ANYone Know someone in JACKSONVILLE fl that can swap a motor
- jumping service connector in integras. (to get ECU code)
- Is this alot?
- part number for ctr intake manifold gasket
- throttle rotor removal...
- who are you guys using for sleeves, when going 86mm bore in an b18 block
- anyone used NipponMotors?
- apex Vafc
- putting OEM power windows
- greddy a/f wiring
- ITR and LS timing belt cover the same?
- Catalaytic convertor from hybrid garage???
- Welding question
- wiring?
- car too low
- car wont start, black smoke
- Will an exhaust from a 2000GSR fit a 1998 GSR?
- Swapping Pistons and rods with Eagel and Je Standard bores....
- Is aluminzed exhaust piping ok?
- Golden Eagle Question
- GSR Radiator into EG with A/C (searched already)
- Which Cams to buy/ Pistons to buy...?
- Brake opinions
- motor mounts HAsport place racin
- Exhaust Pipe size, no cat, no muffler (air Velocity)?
- Cold Start Engine
- Part number for pressure plate mounting bolts? (94+ integra or 99-00 Si)
- Question for suspension gurus, alignment specific
- will 88 accord springs fit into a eg civic sedan???????????
- OT. does anybody have any f1 car diagrams?
- Best block for built NA setup???
- 3rd gear redline -> 2nd, ouch
- ZC Head gasket??? timing belt??? U.S. equivalent plz help
- Clutchmasters Stage IV
- need help on a motor building question
- LS crank in a B18C
- VTEC solenoid connected to a button ? :ehh:
- Valve Adjustment Tools
- What do you think of this car I'm thinking of buying.... *pics*
- Driver's with P28 ECU's
- main bearings
- HELP! Whats wrong with this#@!
- Compression Ratio increase by milling head?
- How to tell if it's a 99+ JDM B20B???
- what are the exact parts i would need for a s2000 antenna conversion?
- whats the difference in an inline and an offset FPR?
- Neuspeed Race Springs!
- Torque Wrenches
- what is considered a bad toe in?
- my antena stop rolling up! help.
- strut bar?
- anyone out there make an OBD0 to OBD2 harness?
- Paa ecu
- Greddy B-series headers??????
- Question about knowing if a ECU is good
- hondata s200
- Piston rings the same????
- HID Cleaning? Quick help needed.
- What do i need to change my brakes?
- Control Arm being pushed out.
- still need help with my motor..
- Help me identify this flywheel please...
- need help(engine)
- d16z6 valve clearance specs..
- Substitution for the bottom retainer
- Standalone on LS/VTEC, where to put the knock sensor.
- gsr mugen head gasket
- PLEASE HELP...91 accord oil pressure sensor location?????
- head install ?
- Need bushings, maybe pn# if you could help please.
- aftermarket harmonic balancer?
- Do I need a camber kit?
- does winter affect longevity of summer tires?
- Increased brake pedal travel after rear disk swap?
- springs
- (ls vtec hatch) code 23 after cruising at around 60mph, then holds a higher idle. wtf?
- lockup of differentials q?
- shocks vs. springs, easy explanation
- why is 50/50 weight distrib best for FR's
- JDM Type R Front Conversion
- need help, serious help
- Engine age-strange things are afoot...
- EDM Cluster for my CRX - Need techies help!
- Help! car is not running, possible electrical/ecu problem
- Will exhaust line-up if you Swap a B18c itr into 95 coupe.
- Odd torque lump
- smog check
- Ignition timing
- '01 ITR intake cam in '99 GSR with stock cam gears....Ignition timing Q??
- Cruise control
- rebuild quesion
- Tokico Sport Shock VS. Illumina... Which is best for my application?
- double resonators....who's actually done it?
- who builds good blocks????
- Engine Experts: Check my wrecked H23 VTEC!
- vibration under load?
- Euro R intake manifold question...
- easiest way to remove axle
- tires will they fit???
- 98 h22 head gasket kit
- what one is better
- B16A Limited Slip Diff
- 3 inch piping
- Tranny Question
- gsr +2g's vs. type R
- Preparing for Hondata tuning...please read
- Sparkplugs for the B16A2
- Does the ECU affect the speedo/odometer ?
- Anyone with a good sense of output guessing? Just picked up some 01 ITR cams.
- pr3 to p30 ecu, obd1, question
- How to.....EK hatch skirts on EF hatch
- Anyone running Crane HI-6 ignition & Coil?
- JDM B18C swapped into a 2000 Honda Civic Si (HELP PLEASE!)
- GSR Questions
- breaking in the VTEC
- LSD in 93 GSR YS1?
- B&M FPR compared to FULL replacement FPRs
- my engine is acting weird, help!!!
- cheapest place to buy skunk2 cams!
- Tomm i plan on installing my Skunk2 cams, retainers, and springs.
- quick question... jcwhiteney exhaust pipes OD= diameter??
- Question about Apexi timer....
- Wiring help needed
- HELP!!! Turbo? Supercharger? or Nitrous? or all motor?
- cali smog ?
- pic of pistons need to know if damage
- Cracked Spring on 90 accord lx
- Which tools will i need to replace springs and retainers?
- '92 CX body w/ a '95 b18b - wiring
- Timeframe for subframe tear out
- My F'n oil squirter broke off in the #1 cylinder I NEED HELP
- too lean/too rich
- Look what came out my exhaust!!!!
- Is the msd draining my battery??
- Need help installing greddy oil pressure gauge, and oil temp gauge
- Do I need a new tranny??
- better suspension ..what do you have ?
- Idle surge on start up .
- failed smog, need some suggestions
- Someone help me figure out how to take the breather chamber out!!!
- How do you remove the pin that holds the shift rod into the tranny?
- When I start my car up it sounds like this.... "sccccreeeech"
- Vafc, 255 fuel pump, H22....
- Noise
- Can I use a 96+ gsr harness on a 95 ex swap?
- Anyone running 13's all motor, on street tires, full interior coupe?
- rotors
- Audio problems
- greezy block, pressure wash OK?
- Sensor near crank pulley on B18B1
- how much is my stuff ??
- What is a D16A1???
- reputable shops/people in NJ/NY area
- csi catch can
- switching to single alternator pulley
- special tools, where to get? need tool to adjust differential preload
- m
- does any one make a hp cam for a f22a
- Can I ?????
- my lsvtec motor buildup
- Throttle Body - Coolent Lines
- OO Si - Strut tower bar - nut size and thread type?
- can someone with a helms manual for a 1996-2000 civic help me???
- USDM vs JDM Header DC Header (diameters)
- What clutch set up should I go with?
- Block help(want my car to run) help
- Flat line and Inline
- Copper Headgasket???
- need help with swap
- Roller setup in my d16y7?? compatability question..
- Car bogs at random times!!!!
- what are your ls/vtec or b20 vtec setups?
- G-TECH/Pro Performance Competition Meter? Real or Rice??
- skunk2 or stock cams for jrsc???
- quick super newbie question regarding Integra GSR spark plug!
- slight GSR build-up
- Stock injector for 11.3:1 compression?
- Endyn breather/catch can
- b18c flywheel
- what size are CTR brakes?
- What doI need to do to participate?
- Modifying P28 ECU for Hondata
- repair/bodyshops in southern cali?
- testpipes.com
- toda oil pump gear
- Air/Fuel Ratio Gauge
- Evap
- im looking for a place in new jersey to tune my hondata
- >>>>>NEED HELP ASAP! Ignitor/Starter/Distributor/Fuse?!?!
- test
- just cant figure it out
- I got the new 4 piece Crower cams!!!
- lakewood traction bars.....
- HELP ME!!, putting INTEGRA TYPE-R engine in civic 93
- B16 oil cooler
- brake problem
- Which catalytic converter for 93 hatch with B18C?
- What exactly is a 3.23 rear end?
- Anyone been following this build? I cant wait to see his numbers...
- o2 sensor...rewiring..
- pcv on b18a/b
- Symptoms of cams one tooth advanced or retard
- pr3 7800?
- Oil leak problem - LS/VTEC
- need help on swap????
- 84mm....that big of a difference?
- injectors????????????????
- radiators support hhelp
- ECU chipping removal help plz.
- What is the most stock looking exhaust for integs(gsr).
- mugen d serries..?
- compression ?
- cam gears slipping?
- 4th gen accord tranny swap
- b16a1 starter from autozone?
- Request: Instructions for B&M FPR
- Any good Tuners in the Seattle Area??????
- cai help?
- Help Diagnose these pics (piston tops and cylinder walls)
- RPM Civic 93
- Gasket?
- surge in powerband, low idle..
- 93 Civic hesitation
- ecu question need help asap
- GSR front brakes relocated to rear...?
- ACL engine bearings
- Cam for my Z6...JG or Exospeed?
- Autometer Tach, VTEC controller and stock tach, differences.....
- shaving flywheel
- CRX swap to H22? info? possible?
- Toda Cam Gears - 5mm Allen Bolt Torque Spec
- cel code P0420
- Custom exhaust smog legal? help!
- what pads??
- Timing belt tension and loss of top end power?
