View Full Version : Tech / Misc
- Electrical issues
- car wont turn on afterswap
- DA integra wiring problem
- Hayden Oil filter relocation kit, pressure drop?
- oil and water mixing everywhere
- Cv axle/transmission play?
- 00 Civic Coupe passenger power window not working. spent 2 days t/s so Pls help!
- s2k cluster swap
- S2K Gage panel
- Just notice my axle boot ripped today
- turbo question
- 180cc injectors to 240cc in B16A2
- check engine light not working Accord 2004 EX 2.4 coupe
- Octane question
- B18c1 just cuts off when motor gets warm please help?!!
- 06' Accord. what part is this?
- B16A rev problem HELP!!!!
- 94 b18c1 eg hatch problems please help new to site
- Battery Light?
- My bad.
- valve guide?
- h22 civic bucking at 6k
- Battery relocation not working
- Power steering noise?
- HELP:No spark no Fuel
- 96 civic cx power window
- Can a Fuel Additive Really Increase Horsepower in Your Car? (with Proof)
- need help asap
- how many Rpm can a mini me take????
- what ecu should i run in my 93 honda civic with a b18a1?
- What t bracket do i have ?
- poormans type r questions
- Need help, aftermarket Intellitronix Speedometer issue
- Help with CEL
- All civic and integra catalytic the same?
- A/c oil help
- can iacv be damaged by carb cleaner?
- 2015 cr v touring audio
- Slowly resuscitating a 93 hatch
- Oil Pressure Gauge with Small Sensor
- HP & MPGs
- no fuel from pump
- B15b swap issues.Please help!
- 87 Accord Lxi PGM FI Will Not Start Hot-SOLVED
- Car jerking error code p1381
- V2V Cam gear technicalities and degreeing.
- Results from leak down test
- b20b over heating!!!! HELP!!!!
- Brake / ABS experts? ABS modulator reservior keeps overflowing
- Rev limiter issue? need some help
- Need help
- Driver side Window problem
- 96 Civic gauge needle and climate control lights don't light up Please Help!!
- Aftermarket steering wheel problems
- F22A6 Engine stalls athe just over 4000 rpms.
- New to ht
- Very disappointed in the skunk!!
- rod knock or something else? Plus a couple other small issues
- Wire from ignition to starter... help!
- guys need help for cams
- WALKER exhaust parts - Yea or Nay?
- CRX oil burning issue
- 88 PRELUDE IDLE ISSUES
- obd0 to obd1 distributor plug swap?
- Whistle noise from TB
- Purge valve cap?
- Honda Idle Issues
- O2 relocation
- 95 gsr with 2001 b18c exhaust?
- D15 Crankshaft Oil Leak
- Fuel pump tone change
- Humming IACV + other issues? (H22A in 96 CD5)
- Help me identify this exhaust
- 1994 Honda Accord H22a Turbo 5spd in limp mode. Need input.
- 2005 Honda Civic No Power, No lights, will not start
- 98 V6 Accord cat vs Ignition diagnosis? 300k
- spark driving me nuts
- billet/forged k20 crankshaft
- How often should I replace my plugs and wires
- Help! Please, 95 Accord 2.2 lx
- How to remove plastic retaining clips quickly
- alarm troubles
- d16a6 block with jdm d15b vtec head
- aftermarket fuel rail
- VTEC WONT KICK IN?
- Need some mechanic advice
- Help Disconnecting Driver's Air Bag - 99 Civic EX Sedan
- 03 civic radiator and fluid help
- J Swap Questions, If you ever did a J-swap I have questions
- em1 crank but no spark
- cloths got suck in the d15 timing belt
- smoke coming out of the carberater on mg d15
- 80 amp fuse keeps blowing
- HELP! 97 CIVIC THAT SHUT OFF RANDOMLY AND WONT START BUT HAVE POWER!!
- B20 and B16 hose kits
- Speedo - Halp!
- 97 Accord LX lock system
- green valves on my D15B1 head
- distributor problem
- Rebuilt Head: Oil Orifice Confusion
- Sold a b16a2 power steering pump and buyer says its wrong?
- obd1 check engine light
- check engine light help
- 1991 Civic DX Hatchback D15B2; Thermostat wont open
- 'Cheap' FPR
- 88 civic hatch check engine light
- ecu label ripped off -- how can I tell which ecu I have?
- Anyone heard of action clutch
- 3.0 engine swap
- 99 Civic Sedan Automatic - Jacking Issue
- AEBS Headstuds
- banged up head fixing?
- Running TOO rich, unburnt fuel and smell out the exhaust
- my car is going crazy please help b18c1/b16a
- how do you test a p28 ecu? no start
- 99 Civic VP Fuel Pump Replacement
- Help - Vacuum Noise 2007 Accord V6
- 2004 Honda Accord Engine Codes
- Back probing ECU
- b16b o2 sensors connection HELP !
- HELP PLEASE!!!
- 95 CX starting issue
- HELP! 1998 Honda civic dx swap
- Engine Vibration Causing Shake
- Can I use my old wire harness?
- piston weight
- BRAINSTORM: What would make a car die on idle and hard time starting again
- no start?
- b20 piston mystery
- Any info for this NPR pistons and bearings? R18A engine
- Need CAN Codes for New Honda/Acura Transmission Temperature
- td28u distributor rotor?
- Intermittent loss of throttle control after 30 minutes of driving
- small engine surge & bogging
- need help with routing catch can
- Custom fuel lines?
- H22 ECU Fuel Pump!!!!
- Backup Sensor Kit Install Question?
- looking for a good tuner from maine to mass
- omni clutch master cylinder
- HELP, DISTRIBUTOR BROKE, PEICES IN ENGINE
- 1994 Acura timing belt tensioner
- fuel problem/ecu?
- accel coil users review
- Car overheated and now it wont...
- does the distributor has to come out to change the icm?
- Looking for a reputable mechanic in the KC area
- b18b distributor
- Neutral/Shifting gears turning CEL on/off Blowing ECU fuse 15 [w/Video inside]
- oil leaking and sludge on everything, fuel in oil pls help
- coolant in all intake ports.
- Crank Pulley Wobble
- Stock 1995 Civic CX CA. SMOG FAIL!
- Flywheel locking tool
- 96 integra bogs on acceleration only when cold
- B16A OBD1 interior wiring loom options??
- Timing Belt Tension B18C1 GSR
- rebuilding jdm itr block
- Header to Catback Exhaust compatibility question
- Should I do a full rebuild?
- b18a1 not getting enough fuel to run
- 93 Accord won't stay running...
- 2001 Prelude momentary loss of power/check engine light.
- F23 rear main seal plate- does that have a gasket? + are h22 sump gask. same as H22?
- Any ideas on TCS/ABS/Climate not working after maintenance?
- Looking to build bottom end
- 96 hatch Frankenstein motor problems
- building a harness.. All input needed!
- Best way to make sure my new head gasket doesn't fail
- Help!! E85 in k24a3 with ITBs, k20 camshaft and vtc 50 degree, but STOCK INTERNALS
- Electrical help needed!!
- 1999 civic hx hood latch
- Hydro-static Drive?
- honda powered dune buggy
- Intermittent dying with tough restart
- 99 Accord does not shut off when ignition is turned off
- itr intake cam gsr ex cam
- Fuse Replacement issue D16z6 93 SOL
- 98 honda accord
- Reverse light switch compatability
- JDM D15B misfires at 6k rpm?
- drag slicks
- new build turbo question
- obd0 b16 dizzy wiring issuses.
- Looking to buy this B swapped EF, second opinions?
- B18b1 cyl 1 misfire
- Advice on aftermarket H22 valvetrain setup.
- Vtec not working?
- NEED HELP WITH SPEEDOMETER 07 ACCORD
- removing an upper radiator support at junk yard
- heater core inlet bent
- 91 lude h22a4 engine swap
- b18a1 in 93 civic lx injector issues
- Exhaust Leak CO poisoning
- Tick/Knock When Engine is Warm
- Increased CR, pinging. Best way to reduce ping?
- No start when engine is warm
- Bad valve seals or rings
- 1998 Civic DX Lights pulsate
- noob fuel question
- 88 accord LXi fuel injected 5 speedwon't accelerate
- B series Fuel Pressure Regulators the same??
- H2B header vs. H-series header
- Idle gets higher as loads are turned on
- Mdb4879's "Another K2B build Thread" any pre-fabbed kits out there?
- need help
- Door panel upholtery. Del Sol door panel.
- oil leaks from back of the block
- Snapped Timing belt, safe cam position?
- 95 integra turn signals
- B18 Fuel Pressure w/Crx
- how to rebuild my d15b7
- AC Condensor Fan Question AC line
- Fusebox Relocation -- 1999 Civic EK
- Raadiator Hose Question for 92-00 B series swap
- moroso oil pan & moroso pick up tube qestion
- conversions
- JDM D16A timeing belt
- ECU loses power and all drive cycle data after shutdown
- 99 civic vp door harness connector problem
- New to Hondas
- Cooling fan temp switch plug
- Truhart lowering preformance springs
- Aftermarket water temp sensor location b16
- jdm itr low compression in 2 cylinders
- Help with a/c idler pulley verification for Civic w/GSR B18C1 swap
- Fuel leak need help
- Roller lifters
- alldatadiy coupon code
- Couple issues I can't put my thumb on
- Floor Mats.
- Reverse Rotation of H series engine?
- help identifying car
- poor mans type r
- NGK OEM vs. spoon sports B series wires
- Need help with skunk2 ultra
- need help guys asap fuel pump not priming
- Jb Weld On Cam Seal
- Rpm problem after first tune up Honda city
- Engine Overheating! Please Help! b18b
- Hondoctors in North Las Vegas
- 1994 Acura integra LS broken timing belt caused engine damage
- DA/DB integra roof racks?
- B16A3 help
- Main Relay problem solved
- 03 Element Instruments repairable?
- Fuse box tuck
- b18c po355 code
- Sohc rods m3 7
- Sunday Ratchets
