View Full Version : Tech / Misc
- skunk 2 TB
- Difference Between D16 Engines??
- I ran 14.6 with a blown motor! Need some help with engine diagnosis
- What is needed to tune?
- smell & heat from painted manifold
- Exhaust question
- ENGINE SWAP NEED HELP CRANK NO START-B18C5 INTO EJ1
- OEM type R or LS headers?
- Tranny Binding !!!
- What ECU is this?
- CAN I REUSE MY HEAD GASKET ? ? ?
- how do I go about taking this bolt out? Is it even possible? (sway bar hole)
- New engine install...car wont go into gear
- obd2 gsr harness on 99-00 si ???
- spin a bering
- when you rebuild a motor...do you absolutely have to go with a larger bore?
- harnesses illegal on street?
- Throttle body too big?
- Valve spring install/removal on VTEC head
- "pre-building" and throttle bodies
- So you have no spark? TRY THIS!
- clutch question
- Misfire when letting of gas to shift
- Can't rev past 3k rpms/ engine miss fires, fuel, spark, valve clearance, timing checks in
- Car Stalls, CEL light, but weird problem HELP!!
- d16y8 please help
- b16 sir II into a 97 ek help!
- Best way to clean garage floor.
- main differences between series
- CEL on, need help!
- h22 head bolt question
- Walbro Fuel Pump Installation Kit - lacking pump isolator bushing
- Having o2 sensor wiring problems with my mini-me............
- Kaaz LSD Question????
- torque specifications ?
- 10K motor Installed and have NO SPARK!!! PLZ help
- go b20 vtec or stay gsr ???
- ebay cam gear any good?
- obd 2b to obd 1 conversion problem
- GOOD GAS MILEAGE
- replace tensioner pulley
- Mitsu 3000GT not accelerating
- Boggled.. AUTO or MANUAL ECU, i know theres tons of threads, just help!
- car not starting after new injectors install
- new set-up???
- motor mounts
- High volume fuel filter
- 05 Accord V6 Tranny Swap
- B16A2 VTEC problem after swap.
- Problems with Profec S??
- Is there an original evo?
- Need help with timing!!
- LOOKING FOR VTEC HEAD!!!!
- Clutch Bearing for B-series
- how to tell if iacv is working??....
- Question for ACT Clutch Owners - How long have u been running on ACT
- 2000 Si starts to vibrate/chug between 3000 - 3500 rpms any idea why
- rpms too high for h22??
- 87 LEDGEN IN A 99 CIVIC
- Intake manifold question
- about my crower cams...how to ajust them ....
- Can you tell me where to finf the wires needed to pull codes on a 95 accord LX please
- HELP WITH MY DOORS!!
- %%% Will my knock sensor still work %%%
- H22a vs. JDM F20
- aftermarket head bolts
- guys i need the AEM software
- Bent valves. How long is it okay to drive?
- main journal messuremance? anyone know d series?
- A pic of a broken part in my tranny!
- 20:1 AFR HELP PLEASE ASAP!
- Can Y1 Clutch Kit work in Type R gearbox ??
- Modification to valve guides necessary for crower nonvtec 403's ?
- Feedback from OBX about problems with their LSDs !!
- Running a stock P07 on D15B VTEC, cause problems?
- How Much could i Gain ?
- B20b head on GSR BLock!! WILL THIS WORK???
- how to datalog with aem uego and uberdata
- Analog to Digital? Wiring RSX cluster into 95 EG
- Need answers quick: OBD0 head in OBD1 car
- HKS Sport exhaust?
- when you buy pistons and rings, do they come with specs on what to gap the rings to?
- TypeR TB on B16 manifold?
- hot start problem
- injectors question
- Correct Ignition Timing for DOHC ZC
- Chassis code reference sheet
- still cant decide, someone help
- hondata s200 installation instructions?
- A\C Condenser not turning on, but fan comes on?
- crazy gas mileage? 47mpg?! Gsr
- Do I need headwork for new valves?
- searched.. and about to set my car on fire
- Noise when clutch pedal is up??? SEARCHED
- Weird IACV Electrical Humm noise?
- stock gsr axels how far would they go ............
- vss causing vtec not to engage?
- jdm b16a intermediate shaft vs usdm LS shaft
- PRELUDE TYPE-S (H22A JDM) how to identify?? HELP PLEASE
- Does anybody know how to install these???? PLEASE HELP!!!!
- Car fires up for 1 second, and then dies
- b16a head to stock LS 1.8 block in my 90 integra
- what could this part be?
- HELP! 98 GS-r No power when accelerating
- Question about my HID's not workin
- 02 Accord Fuel Gauge Problem?
- If I put ITR pistons in my b16.....
- '02 accord EXV6 front turn signal bulb change. WTF?
- oil temp sensor
- Numbers on rad. cap?
- wiring intructions for hks turbo timer
- Can i use a b16 or b18c girdle in my b20 block?
- do i need larger injectors
- Knock sensor problem, but VTEC still works!!
- tranny problem!
- planning on ls vtec build, which helms manuals do i need?
- Zeitronix A/F zt-2 meter?
- k20a swap help
- Im going through the test procedure in the for the TechEdge wideband and can't get RPM values to rea
- k series specific specs
- STR fuel rail question about injectors
- ok rebuiliding a transmission that hesitates to go into gear... not clutch
- wiring help
- Benifits of Polishing Combustion Chambers
- After swap: NO VTEC... And no CEL... WTF?
- dumb question, which is obd1 b18a or b18b?
- check engine light when i hit vtec
- s80 or y80?
- 94 GSR Diff into a B16 Hydro tranny?
- HELP NEEDED!!! WHERE DO I FIND A SMOG STATION TO SMOG A JAPANESE MOTOR?
- Inline injector resistors
- Ticking noise
- internal mods before boosting?
- rad fluid overflowing
- cat air tube
- What timing belt for DOHC ZC?
- diy RPM converter?
- help needed wrecked skunk 2 springs
- tach and speed. wiring
- Idle surge when switching between ECU's
- ***SSBC Rear brake upgrade***
- Help me please. JDM GSR problems.
- warming up
- Help me fix this!!!!!!!!!!!!!!!!!
- How to check if T-belt has jumped a tooth? (D16Z6)
- obd2 EVAP???
- breaking in cams
- cutting valve cover
- rebuilding b16 tranny??????
- integra plug wires???
- ACT HD/SS or Exedy stage 2, 3 puck......I have 10hrs to decide.....
- safc on dx spray 45 shot
- 3.2 honda passport engine
- main relay?
- B Series Transmission Tech
- Removing IACV with no CEL
- 1990 honda civic ex Itr Console reconstruction
- LSVTEC EXTERNAL OIL LINE need help
- Newbie Tuner - Timing belt/Drive belts/Valve clearance
- Towing automatic crx four wheels down?
- P28 on a eg vx?
- MSD igniton into b16 and/or EF wire harness, do i have to buy something?
- QUICK HELP!!!clutch release bearing!!!
- headstuds torque specs
- Valve Lash Adjustment.
- b series block plugs ?
- What does this wire do?
- Any DYNO sheets form the new SKUNK2 H22 intake manifold?
- obd conversion harness difference???/
- apex power fc knock sensor ?
- Information about Motor Oil and FAQ
- b16a wont go into vtec
- HELP!!-----DIPPING/LOW IDLE----did search...
- New to Honda tech - type R head question
- Headgasket help
- Sun Auto's MR Voltage System
- Question on VTECH™
- no spark on my h22a1 obd1 engine obd2 harness with external coil???
- Need help understading cam specs
- car is hard to start
- Stock fuel injectors or no?
- front bearings working their way out of hubs
- problems when shifting at high rpms
- engine code 43 on 93 accord
- what can replace the b16(pr3)dizzy??
- Hydro Clutch on a Cable Tranny? Fits but.. does it work?
- JDM Front End Install......
- Coversion Question!!
- 99-00 Si Gauge Cluster problem.
- MLS Mr. Gasket headgasket?
- endyn breather kit instructions
- how do you tell the diffrence between resistor and non resistor injectors
- headlights dim when i hit the brakes?
- Question about B series and D series OBD0 engine harnesses.
- crome tuning
- headgasket on a 99 3x sohc d16y8
- hondata question
- oxygen sensor
- STR fuel Rail
- OBD2 cars with no FITV
- MSD soft touch install p/n 8728
- Couple Questions concering ls/vtec with n2o
- b20vtec..but no vtec
- universal O2 sensor
- KAAZ LSD Hard on front end components?
- running on 2 cylinders - need help
- valve seal installation
- AWD Dyno in PA?
- use or replace bolts?
- proper valve adjustment on b16
- Installlin a Vtec Controller
- p28 or p75 for ls motor
- engine building
- Brake Booster vacume check?
- what type of oil
- drilling your own rotors
- input shaft bearing making noise...time for rebuild and possibly lsd, what all is needed?
- what does a b16 rod weigh?
- How to rewire engine bay ???
- Putting the tranny onto the motor. Couple Questions.
- z6 into 89 dx bogs smokes and runs super lean! WTF!
- distributor problem???
- BLOX
- blown clutch or tranny read inside for symptoms
- Compression w/ standard CTR vs Oversize in GSR???
- NEED HELP IN DFW WITH FINISHING INSTALL
- Where to find brand new USDM ITR tranny?
- installing pistons
- ok, need ur info on these parts
- Rc 270cc injectors
- AC
- Somethis is on my exhaust... Corosion ? Melted plastic bag?
- clutches
- vtec oil pressure switch problem
- How to take apart D series tranny?
- altnernator belt rubbing against something..help please
- Mega Squirt
- Vafc h22 tdc and vtc ?
- metal node broke on fpr is this cover under Warranty?
- ss brake line ripped!! what should i do?
- Programming chips
- vacuum line broke on my FPR what do i do now????
- Maintenance for 95 VTEC lude @ almost 100k
- <> JDM B16a MOTOR DIAGRAMS <>
- Helm's Manual unclear at times
- Fuel System Questions
- Is changing piston rings hard?
- Need help on idle and 4000k to 6000 ish
- why do I have to keep my fuel pressure so high?
- a/c alternative?
