View Full Version : Tech / Misc
- temp getting hot
- Dump Valves?
- 00 Ex v-tec head on 97 no- vtec block....need info....????
- Power loss w/ bouncing tach bad dist. connections?
- What size is the radius rod nut?
- distributor modification?
- am I missing something?
- Break in 6 puck clutch?
- Ignition Boxes??
- Apexi Exhaust Rattling?
- H23a Vtec
- p&p'd head. is there a break in period?
- ???Clogged Fuel Line??? Help Please???
- Z10 Block Girdle?
- Head swapping???F22 to a H22???
- suspension setup
- exhaust
- Sorry...but another ebay item question!
- Lower Tie Bar
- 98 h22 ecu immobilizer??
- need help w/ back brekes....can't drive car
- sizing bearings on 2000 b16a
- Will a 93 GSR master cylinder bolt up to a 90 teg RS ???
- One inj not firing, electrical
- Necessary to change H20 pump when changing timing belt?
- replace a cv joint in a LS?
- exhaust help????!!!!!
- 96 ex civic ls swap voltage problems
- Aftermarket parts illegal?
- anyone know the proper torque settings for the cam plates on a b18c1?
- h22 ecu decision
- OT: Mitsubishi Conquest??? Please read
- OT: Where to get a compression/leakdown test??
- difference b/w universal o2 sensor and.....
- gsr cams?
- Code 8 Help!!!!!!!
- axle problem???
- What happens when your dif starts to go bad?
- good all season tire
- 4G63 in a second gen mirage???????
- Car Sound Hi Flow Cat
- clutch break in?
- N/A to approx. 300HP? How?
- d16z6 head on a y8 block?
- Debate on Gears
- Performance Tech
- JDM H22 egr problems
- Anyone else have/had this problem???
- Installing Intake on '94 Accord
- B16 CRX SI--charcoal canister install
- Average cost of a valve job at the dealership..
- Avg costs of different engine internal modifications?
- Problem- 95' EX help plz
- JDM Motors. Do you know which one is?
- How to remove a/c compressor on integra?
- recommened reading?
- Good place to buy a motor?
- just got me a new streeing wheel
- ECM/ECU Diagnostic tool, Where to buy
- anyone tried hondata heatshield gasket B4???
- welding cast...anyone has experience with this
- can a apexi ws for an eg fit a b16a2
- B20B/Z and B18A/B oil squirters....anyone have a pic of this install?
- ECU Testing questions
- Wiring up toggle switch panel???
- accumulator question
- Volt meter gauge installed
- Will the MC and booster from a 99 Teg fit in a 95 LX Sedan?
- Has anyone really done this or did you guys all just hear about doing it???
- instrument panel light not working so is the tail lights...bulbs are good and so is fuses..where sho
- what are some good LSD's out there for a GSR tranny?
- Help me pass smog!
- Ok. My motor died on me again today...
- soch vtech head on a soch dx block
- Vtech or no Vtech
- who runs a water temperature guage?
- No VTEC - troubleshooting
- Does anyone here chip ecu's? P13 in particular
- What seems to be the problem here?????
- SCC: Suck Squish Bang Series? (not porn :)) anyone have them?
- ok heres a stupidty ?
- Can I use a CTR ECU instead of my ITR ECU?
- Bored b16 or b18...
- Vtec Controller
- Gs-R Slave cylinder problem
- Lean vs Rich
- D15 cylinder head question
- Big rear brakes - any side effects?
- . OBX header
- Im scared. cylinder head bolt under spark plug cover snapped.
- Clutch for b16
- 95 HB hybrid and Exhaust Probs, Can you post your setup?
- AEM short ram intake
- We are going to San diego this weekend. What is happening.
- building your own brakes?
- 99 LS exhaust on 94 DX? HELP!
- Valve Cover Bolts (Not a Torque Question)
- Quick brake job questions
- forged or cast in ls vtec????(pistons)
- ***Resetting SRS Light**
- Oil Pans?
- JDM Transmission
- vafc stolen outta my car, car stalls out.. help!!
- CEL O2 sensor
- Honda Technician's Three-Tone Shirt GroupBuy
- Quick Q: ITR valvesprings - which color goes where again?
- ITR manifold
- Malfunction Indicator Light with P1457 Code
- Stock valve spring pressure H22
- is this normal?
- 2.5" Collector... What Cat ?
- Is this supposed to happen?!?
- ES Motor Mount Inserts - which ones to install?
- Why can I only post 5 times in 24 hours????
- Good handling with H22 in EG possible?
- torque spec for sohc vtec
- '00 EX vtech head on a 98 DX block???
- quick motor stand question
- **oil problem**
- whats STIFFER... Tien SS or Apexi N1??
- Need some of you Engine GURU's.
- Does Radiator Have To Do With A/C Efficiency?
- can someone confirm this b20 info?
- does anyone know the thread on the fuel feed line?or what kinda fitting it is
- can someone find me a part number for the vtec solenoid wire the harness half
- where could this leak come from?
- motor mount question
- forgot..whats the size of the oil drain plug on a 97 civic again??
- Radiator blew up. Possible reasons?
- switching B18B1 rocker arms around=Noise??
- headwork Q's and ECU tuning mumbo/jumbo
- AEM CAI on my JDM B18C
- acclerating pedel hard as rock!!
- o2 sensor wiring diagram
- how to take the resonator off
- Throttle Cable On JDM B18C
- Help on lowering....
- ecu chip off ebay
- LS,ITR oil pans... any difference?
- trany choice
- people who own skunk2 coilovers... please respond
- Fluctuating temp gauge
- what will change if i switch from a jdm to a usdm ecu?
- GSR Brakes on civic question.
- apexi world sport exhaust on 99 civic si
- Forge pistons...noisier
- Tranny ?
- Shiftlinkage ???
- VTEC solenoid fitment
- How to install Type R Seats
- LS/VTEC rods
- will someone post a pic of a vtec solenoid?
- Spoon radiator cap, how does it help?
- B16b with type-r crank need help......
- intake
- oh no throwing codes :(
- Help ?00 EX head on 98 dx motor
- Any diff between obd1 del sol vtec head b16 and 99 b16 head
- Skunk2 Coilovers.. good or bad?
- Mugen RNR wheels
- Skunk2 Camber Kits - Ball Joint Information
- Copper exhaust manifold gasket vs OEM Honda gasket
- VTEC Solenoid Activation
- tranny leaking a little, oh what to do?!
- ITR coilovers swapped into a '90 CRX
- d16y8 head and d16y7 bottom end w/ d16y8 wiring harness
- A few Clutch related questions
- ball bearing grease boot damaged?
- measuring tps voltage
- TW Sensor (engine coolant)
- Gen5 dash removal
- SRS light!!
- b16a sir1 vs. b16a sir1 long block?
- sway bar questions on 5th gen hatch
- 2 questions pls help me!
- Check engine light????? Will I get one or not?????
- vafc and msd btm
- LS head on GSR block
- itr TB/throttle cable install
- H22A4 V-TEC not coming on and tops out at 6500RPM.
- Please HELP. Run- die... run- die
- H22 TPS questions?????????
- more air = less audible VTEC???
- radiator problem
- Help diagnose steering problem
- Is this a clutch cable problem or something else ??
- 02 Mitsu Lancer
- crank angle sensor question and hope for an answer...
- 96+ LS valve cover on 94-95 LS head question?
- tranny question...ls
- Judgement Day
- need to shave block webbing...what do i use???
- Just got block rebuilt now im having fuel cut off and idle problems, help!
- help me please! intake manifold, throttle body, and exhaust questions
- phenolic intake gasket - thickness?
- oil on one spark plug...??
- suspension question
- where can i find a wiring diagram on the internet
- headgasket problems
- carsound cat's.
- VSS help
- Valve Adjustment Problem
- is it CALI legal to drive around the streets with a full race cage...
- PCV system on GS-R OBD 2
- P28 question ?
- trailing arm swap = wheel rub???
- Engine rebuild diary
- Which alternaator belt
- Help PLEASE! Gotta see the Ref...
- dohc head on a sohc block???
- Brake fluid?
- v-afc owners ... the plastic buttons....
- Idle jumping from 1,000 to 2,000 RPM
- Symptoms of bent sway bar(s)
- clutch vibration
- tranny problems
- dropping headers
- Mini-me questions
- flange bolt help: how to use a torch?
- gettin rid of brake dust?
- 96 gsr swap in a 96 civic ex
- H23A VTEC- Is there such a motor?!
- Engines and Chassis Codes?
- b18c1 with Type R internals and head
- Pro's vs. Con's for a knifedged crank.
- Tire Wear Problems----NEED SOME HELP
- suspension question?
- Brass for synchros??
- best nitrous kits
- How do i know if the TIMING BELT broke???????
- All motor b18b can i do this?
- White lithuium grease, Breaks down plastic?
- Engine Heat
- fast idle control valve question
- compression test done today. what does it mean when...
- YS1 vs J1?
- help, please
- can i add vtec to my existing head? need help fast
- DO I have to have my cylinder head re-surfaced?
- OBD1 Distributors Differences
- More LS Vtec questions
- zc questions/websites?
- Hitting rev limiter - what kind of damage can this cause (NOT misshift)
- ** EMERGENCY ** -- Friend broke down in Seattle -- Needs B16A1 Distributor.
- b series distributor
- anti sieze on spark plugs
- beaks question?
- bore tb question
- What tranny's can I fit on a 01/02 Civic?
- Engine build, what tools would I need?
