View Full Version : Tech / Misc
- ECU Question
- ATS FINAL DRIVE KIT QUESTION
- LSVTEC wierd problems.
- cracked injectors
- Engine Build Shopping List and a Few Questions... d16 rebuild...
- HELP. ignition trouble
- New Alternative to GM Synchromesh available.
- injector test
- accord reving problems
- how to tell 1st or 2nd gen??
- Help: Custom harness has problems
- Tranny rebuild
- ecu chips
- What do you guys know about evaporators?
- Engine Running Rich? Please help!
- whining noise
- quick throttle body question...
- A few questions... Tuning.... Ignition... MSD shit....
- 1982 civic with B series swap is it possible?
- 94 integra fuel pump wont turn on?
- i have a question???
- Anyone need a Test only smog ?
- oil pressure gauge install
- Adding Nos to a stock B16
- Need help with the air conditioning
- so cal peeps!!!help me find an acid dip for my datsun
- What would cause VTEC to disengage early?
- Question on Tuning Devices
- piston ring installation ?
- How do you measure your tolerances for main bearings??
- just boosted solid cel runs great
- some help please!!!!!!!!!
- o2 bung high flow cat
- B16 help, is my oil pump bad?
- Transmission/ putting in a cv axel help!
- ?? Please help with car issues, it sounds like it has diarhea :crook: ??
- need help asap!!!
- A Spec GSR into a J SPec EG Hatch
- d16 itake on my d15
- Throwing Codes 7 and 14- Need Help
- Engine knocking, but internals look fine.
- OBD2 GSR engine into Automatic OBD1 LS
- final drive and ls fifth gear engine speed calculator
- b18 in crx will mounts line up
- aftermarket 3 bar sensor
- zc swap and its sputters when it runs
- ls vtec compression
- je 9:1 pistons in b18a block with b18a ls head what compression ratio?
- clutchmaster
- i need hondata rom editor software v2.5
- TruFilters... Total BS or Something Worthy?
- pgmfi.org, real-time programming, uberdata
- redline and vtec point on lsvtec
- Converting Automatic to Manual??
- Safe to Start Car With No Tranny Fluid?
- Type R swap in florida????need installed too
- Tach Connection for PGM ignition
- More power???
- B16B IAT Sensor Location???
- piston help!
- electrical help needed.
- problem with rpms after shifting
- Installing AEBS H22 head studs
- GSR Engine Problem
- TPS issues, ( an issue that I have never ever encountered )
- car not starting..... lil help?
- Cat on a Stock 1992 CX
- MINI ME SWAP QUESTION !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- What size thread for ball joint??
- d15b2.. did my timing belt jump a tooth? *pics*
- Need Help ASAP!!
- Tool for checking spark?
- oil in b16
- short exhaut system
- problems starting car...
- Ignition timing ajsutement when intake side cam gear is 3 degre of advance (SEARCHED)
- Brand new block from factory, need info about the oem sleeves!
- distribibutor o-ring size?
- Help with Question. Uneven headbolt torquing
- what is the silent exhaust syetem for EP1?
- benefit to keeping heat off of the header head flange?
- motor mounts going bad.. will these work?
- so i put a 'TORNADO" in my car
- Electrial Problems...
- crx window
- whats the deal with my brakes?
- Will a Exedy Organic hold this?
- best way to seat moly rings
- SOHC valvetrain issue
- safc hack-missin link question
- Settings for the S-afc hack transferred? not workin right..
- Need help understanding countershaft bearing locknut torque spec ?
- Which B series trannys come with Dual Cone Syncros?
- Battery Question!
- h22 specs
- "T" for oil pressure gauge?
- pics of memebers
- B16 tranny bearings same as ITR bearings?
- Question Skunk2 IM GSR
- MSD Launch control and Clutch Switch
- 91 Accord Condensor fan RELAY location
- hotspots!?
- help with digital msd window switch
- Exhaust rattle noise
- Quick question? Missing nipple on thermostate housing. It's in manual??
- vtec not engaging - open to ideas - no vtec pressure switch
- vtec swap
- 95 DC4 Bogs down/misses/stalls then CEL comes on, runs rich.... Any Help?
- New Tach
- engine running rough....problems?
- what head should i go with ??
- SOHC ZC Cam for a D16A6...
- Where to get Fleet Charge coolant?
- clutch master stage 4
- what aftermarket muffler to get for an ek h22.....??
- tranny code on a 93 accord EX
- HELP Please: Honda ECU, what does it control?
- is the vtec sensor off the d16 the same as b16?
- OEM or Aftermarket crankshaft?
- bigger diameter=bigger hp gains???
- B20 Tranny
- Quick question about jdm dizzy's
- 2 Strange Noises - What are they?
- does a tranny have a VIN number??
- what mods should I do
- 4puck or 6puck
- 50mm crank pulley lock
- swap question
- 89 CRX B16 Problems (Dizzy)
- stock p28 on stock lsvtec
- LS vs GSR tranny ratios?
- sometimes stalls when coming to a stop???
- Diff. between oil pres. sender/sensor
- CRX Power Windows
- speed sensor input voltage
- Speed Sensor Beeper
- Tranny adapter plate to make RWD???
- weird vtec problem
- cams questions
- port & polish head/b18c1
- D16y8 homemade turbo kit instructions?
- Problem with my HID's!!! Any help is appreciated.........................
- Header gaskets
- k20 into 01 civic coupe
- Opinions???
- low oil in my new gsr... compression test.. your opinion?
- Battery Relocation Wiring Inside or Outside?
- skunk2 cam ID?
- matching headers & exhaust
- chipped ecu problem
- tranny noise
- oil temp sending unit
- can't check CEL, car's in limp mode, i've searched but not found anything really usefull
- 7400 rpm redline
- ls valve springs and retainers
- just cleaned egr ports and gas mileage down WTF?!
- what oil pump, water pump, timing belt, and tensioner do i need for ls/vtec?
- teeth count on ls and gsr tranny hydro
- Swap k20 or k24 into 01 civic ex
- 2000 type r..... rods and mains torque specs....
- code 21 need help
- h22 balance shaft etc..
- CCing a head
- Rod selection Help!!!!!!!!!!!!!!!!
- Another VAFC Questions, Not Wiring, Already Searched?
- Throwing CEL no code? (searched)
- Engine Building Techniques
- Would you buy wind-tunnel tested aero components? Wings, etc.
- header collector temp at operating temperature, and wot.
- swapping in b18... need help w/ im sensor
- can i chip a "P3Y" ECU ?
- HELP with rewiring SI harness into DX driverside harness(san diego)
- Help me please!
- civic 97
- Need opinion of choice of spark plug wires and set
- I went to install a Integra Steering rack into the 93 honda civic - Help issue with spline
- pistons
- Can compression keep your car from starting??
- Rado and Durst on The Speed Scene Tonight, any V-Drive questions??
- does anybody have a 5" autometer tach laying around
- How do you identify the year of a JDM motor?
- New Valves
- car keeps shutting off... need some help guys
- How do I wire my secondary O2 sensor straight to my ecu?
- over torqued arp rod bolts, what do you guy's think??
- Weird OVERHEATING Problem all elite tech people check this out
- 84mm more with acl?
- Motor Break In Write Up
- Need fuel pressure help
- 74HC3737N Hondata chip in P30 ECU
- 1st gen b16 cams
- photo quiz!!! can some tell me what brand this is..
- how to plastigauge bearings? anyone got a how-to?
- ZC and D series Crank compatabillity
- 02 sensors
- Are B16 and B18 crank pulleys the same?
- stripped oil squirter
- noob question on valve adjustment
- I forgot where the hoses go to please help...
- B18C1 Engine Specs Official Honda
- Aftermarket fuel filter Q's
- No cel and no vtec on a minime?!?!?!
- need copper crush wasers for brake calipers
- pr3 wanting hondata
- .::MSD 6AL install??::.
- Overflow tank relocation (show me yours)
- Need help please!! Car being very sluggish
- please help.............which rear mount do i use for 97 b18c1 into 97 ek
- anyone with sppon or mugen thermostats and thermo switches
- Whats the differents between SHOWA & DENSO radiators?
- Rough Idle with my turbo gsr with RC 440 injectors
- timing gear not sitting fluch with bearings/block
- LMA's clicking loudly
- JE piston/ring problem with bore.....
- Possibly made a mistake on bottom end build, need some advice...
- having problems with my stock eg gauge cluster need help
- Pr7 ECU
- Question about spark plug wire
- Apexi V-AFC II - good for i/h/e?
- swapping built ls...problem with rear tranny bracket
- Why are wider tires better?
- step by step vtec wirng?!
- reading codes little problem
- uberdata have some ?'s
- Break in New Clutch on Dyno....good idea or not?
- Block Assembly Complete - should it *blurp* when rotating by hand?
- aem ems boost controller option?
- oil pump plug ?
- 94 si w/GSR swap...Can't rev past 6k, and no vtec. Only code is IAT sensor. HELP!!
- ODB2 Code Reading Question?
- Tranny help...wont' go in first or second
- Car not accelerating! Need Help!
- cleaning...exhaust?
- jdm vs usdm p13 pinouts (obdI)
- anyone know if jg iron ductile sleeves good?...
- Just started my new motor and it won't hold idle??? Any ideas????
- gsr block sleeved 81.5mm (Any problems)
- Wiring question
- ABS light
- NEED HELP!!! ASAP
- swapping valvetrain, should i do valve seals?
- Civic Fan fit Integra
- obd0/1 b16's
- Emissions light on Honda Accord
- CEL for "Catalyst System": What could that mean?
- Does ITR TB fit a B16A IM?
- supertech pistons vs forged pistons
- Next Racings Miracle X rear cross bar
- black box under gsr intake
- Worth tuning?
