View Full Version : Tech / Misc
- how do you adjust valve lash?
- o2 simulator question
- did a compression test and didnt get any results
- oil pressure gauge help!!!!
- Codes 6 And 7 At the Same Time
- K20/24 R/S???
- Why Do You Want to Retard Timing at Top End?
- H22 external coil distro question
- Fuel Pressure Questions
- MSD Digital 6 Plus Ignition
- I have a problem
- anybody want to make a little extra money???
- Tranny Swap????????
- idle air control valve, please help
- Gunk Engine Flush?
- WHAT FLUID SHOULD GO IN MY ITR TRANNY
- What is the difference between Disc Brake and Drum Brake?
- Fuel gauge question
- d16z6 and wanna stay obd0...dizzy question
- Mini Me help, ANYONE KNOW WHAT DISTRIBUTOR CODE THIS IS?
- JDM B18C into 91 LS-S
- brake questions
- how to clean injectors??
- Valve Seal Replacing Question...
- searchimg for ecu pr3 obd1
- Air conditioning and intake question
- brake problem
- p28 ecu chipped??
- Code 74 B18C
- white smoke, did a search, but is it a headgasket??
- fuel injector ?
- MOTON Suspension
- Fuel Pressure D16Y8
- anyone using ACT 6puck disc?
- im planning to put a fuel cell got some questions can anybody help
- ls-vtec help
- Header and O2 sensor question
- Anybody knows a thing about A Haltech E6K
- TONIGHTS 3 HOUR TRANNY SWAP.....
- Compression Ratio Conversion
- bent valves
- OT: How do I format my harddrive in XP?
- Batronix burner users/EE gurus...
- what is hone? what does it do?
- Intermediate Function on wipers?
- Where does the feeler gauge go?!! QUICK HELP PLEASE!
- Nasty backfire!!
- ECU issues...
- Honda Bearing Color Sizes
- need help with tranny related math
- Tac going crazy
- Sounds like broken glass....Broken O2 ?
- Cable and Hydrolic clutches, interchangeable?
- Noise coming from my resonator
- like to put a d16y8 head on d16y5 bottom
- have a problem with rebuild not starting...got spark, fuel, timing is on?
- Need to press in syncro hubs? And a fitment question
- Emergency Blinkers work-Turn Signals Don't?What's Wrong?
- help! S-AFC base settings 90 Integra
- will changing wheel size effect gear ratios?
- car dies after sustained high rpm
- weapon r coil overs
- Ref questions
- heat wrapping entire exaust....
- windshield wipers
- 96 b20b
- Turbo is reliable?
- lightly used rings on freshly honed block.
- Building up my suspension
- what solvent should i use to clean my block.
- Check engine light and code P0133 need help
- Need help choosing which Header to get
- blown headgasket
- Valve and valve seat question
- Putting in an intake and need help...
- N/A vs Turbocharger
- 1 b16a o2 sensor
- anyone heard of Zee's exhausts?
- Glass beading piston domes
- Car cranks, but wont start. HELP!
- how can i get the nut off that holds the line into the slave cylinder
- D16Y8 head on D16Z6 block. Headbolts?
- different steps with installing an exedy clutch
- 5-lug on a 99-00 Si with ABS
- How long to break in new engine, when to dyno tune?
- metric brake line fittings, what size are honda's
- can you say hydrolock!!!
- HEAD BOLTS
- Need Major Help (h22 in eg)
- Just received a Y8 head for free from a friend-Can I save it?Or part it?
- Help making power to D16Y8
- quick question on harness
- Fluid fills overfill...what is wrong???
- need help with head bolts
- EK Tuning questions... (long post... break out the reading glasses)
- Built B18C5/CRX runs fine untill VTEC hits....?
- ATTN: ALL B20 OWNERS!!
- Thrust washer problem
- Need help making more power
- Need help with CEL 7
- Is it normal for worn brakes to screech even when not braking??
- adjusting skunk2 cam gears......adjustments soooo small
- help please car is acting wierd please help
- Rear Disc pissing me off. grrrrr
- quick tuning question
- OBD1 stand alone and semi stand alone
- Ha Ha
- arp head studs?? which end goes into the block?
- Do you have to pull tranny with the block
- b16a flywheel bolt torque specs
- Prelude: getting out halfshaft on ATTS unit
- Car just died.
- idle oil pressure
- thta's right... another radiator fan post
- web cams 148e
- EG W/ LS swap, wont start with map harness plugged into Map sensor WHY !?
- How to strengthen motor mounts....
- EDM Cluster for my CRX - Need techies help!
- resistor box ?
- Fuel management ?
- Checking Timing Belt for proper installation
- how to remove oil stains?
- Clutch sticking and tranny popping out of gear, etc.
- sinking brake pedal
- how to get more torque?
- Help with timing belt and cam gears.
- help- wiring diagram for 8 wires coming out of a 2000 civic EX distributor?
- Lift points?
- B18c1 Rods & PR3 pistons - Any mods needed???
- what bolts for itr lcas?
- smog help
- Idle problem
- Replacing the hub
- intake piping?
- Will jdm S1 gears work in 92+ USDM LS tranny case? - Hybridizing
- Is Runing Lean Dangerous?
- Removing a GSR block girdle?
- CAR WONT START! I NEED SOME HELP/ADVICE!
- is this ture for the d series
- KYBs G2
- gasket questions
- Adjusting door hinge?
- Brake MC
- Throwing a Code...suggestions please...
- ignition timing ?
- best injector size for 12:5cr 86mm bore
- Oil Pressure & Oil Pressure Gauge Issues (autometer phantom mechanical)
- got a code 2 long lights followed by 1 short light. is this code 21 on a b16 computer? wtf is it?
- starting problems
- is this common
- d16y8
- which tranny? J1 or S1?
- Honda-bond on these sensor threads?
- 2000 Ex civic "TURBO IT OR NOT?"
- stock B16 catch can
- Car Not Starting
- another question about an oil catch can, unbaffled.
- Tools For Engine Building
- Timing on a D16A6 Head
- putting integra power windows into a civic door
- i have a 1990 honda civic with a b16a1 (DOHC) engine and tranny it is
- HELP FAST!! at shop now!!
- Does a new transmission need to be broken in?
- Engine sputter problem
- 02 sensor proplems?
- jdm h22a in 94 accord ex which aftermarket cold air intake fits?
- WTB either CRX, EG Hatch, or an early 90's Integra. Please help.
- V-AFC... "hack"?
- OEM Oil Filter Update
- 92-95 Civic Hatch guys.. hatch wiring question, help please!
- 96 JDM B16A2 question about wire harness!!! Please Help In process of swap
- MSD ignition problems
- Good Engine shop in Maryland or close!!!!! ( for swap)
- How much difference does tire height make?
- what size bulb in wrx?
- how much am i holding back?
- Ls/Vtec ?
- Newbie Question
- Nitto Tire Problem - Anyone have a similar problem?
- Could you give me hand figuring out what tranny parts I need???
- Hey Sleeper, about your starter...
- crank and stroke of d15's
- surge problem?
- would the newer engine ivtec in newer accords fits easily into an accord 94-97?
- cleaning iacv website
- setting fuel pressure for b16a
- I need help with a question about exhaust insulating wrpa
- How do i become a member?
- Tire advice
- What's tha diff?
- Need your help Tech's
- H22 throttel body help
- HARD TO PUT IT IN GEAR!..NEED HELP!!!!
- oil pump??
- where to buy...
- question for tuners... tuning and the effects of an 8lb flywheel...
- Maybe it's a long shot, but......
- Skunk2 cams + Skunk2 cam gears = PROBLEM?!
- K-Series guys. Transmission questions.
- CAMBER KIT?
- installed new driver side driveshaft.. now there's noise
- OIL PAN!!
- B16 boost?????
- difference in camber kits?
- What is THE BEST cat back exhaust
- alternator affecting idle?
- converting obd1 distributor to obd2, need pinout please
- best place to purchase?
- Somethin real bad with my car today...please any help is appreciated.
- Oil in exhaust port?
- got new axel put in
- What other thin head gaskets are out there??
- Are all b-series AC mounts the same? If so, I have a couple quick q's
- Problems with b18c swap in a 92 vx
- Integra tails in a 94 bubble
- Cleaning TB PLATE
- help removing momo stearing wheel hub on 00 Si
- b16a1 valve adjustment
- clicking when i release clutch?
- Oil Pressure Sender/Sensor Q
- Getting wheels\tires mounted and balanced?
- Which bearings to use in a 1st gen B16?
- tein lowering springs any good
- ITR/SI throttle cable are they the same????
- b20z CRV engine and AUTO tranny swap into 92-95 AUTO civic
- anyone know of a good machine shop for block work around the ny area???
- This really sucks!!!!
- LS/vtec oil lines
- gsr idle problem (HELP)
- compression is down
- Whoosh whoosh!!!
- coolant leakdown
- quickie: timing belt keeps skipping
- Weight of a d16z6
- What to do...what to do... header-tech or jdm dc/skunk2 mani
- USDM gsr 170hp with a 10.1 CR. What if i.....
- Tips on how to keep the engine bay temperatures cool.
- Blow off valve
- Virginia Members!
- Please help with my tuning issue.
- last min check before starting up engine for the first time ... break in
- Trans rebuild question...
- are ls auto trannys split differential?
- B&M New Volt (keyword add: newvolt 20v 20volt ignition)
- I'm a very very lucky person!! Why is my engine still on one peice?
- Can I Un plug my secondary O2 Sensor?! Please help.
- Dynojet dyno- Mustang dyno ----Whats the difference????
- Oil Pressure gauge with light
- Radiator
- How mich lag with this
