Code 14 = Replace IACV
Old Nov 25, 2003 | 02:53 AM
EE_Chris's Avatar
Default Code 14 = Replace IACV
Does a Code 14 always mean that the IACV is bad?
If NO, why?
I am hoping that this poll sheds light on one of the biggest misconceptions concerning Code 14 and the IACV.
Old Nov 25, 2003 | 07:49 AM
raene's Avatar
Default Re: Code 14 = Replace IACV (EE_Chris)
My vote is NO... trouble codes indicate trouble with the part, not a faulty part. I've had a code 14 before, removed and cleaned the IACV, and voila, problem solved. Interestingly enough I've had it stick open at high rpm before - near 8k - triggering a CEL in the middle of an autocross run or drag pass. Funky.
Old Nov 25, 2003 | 07:51 AM
mmuller's Avatar
Mad Scientist
Default Re: Code 14 = Replace IACV (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">My vote is NO... trouble codes indicate trouble with the part, not a faulty part. </TD></TR></TABLE>
Old Nov 25, 2003 | 08:57 AM
JimBlake's Avatar
I vote NO. The ECM can't tell the difference between a bad IACV vs. a broken wire.
Old Nov 25, 2003 | 12:24 PM
TeStUdO's Avatar
Default Re: Code 14 = Replace IACV (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">I vote NO. The ECM can't tell the difference between a bad IACV vs. a broken wire.</TD></TR></TABLE>
True. Or the difference between a dirty one or bad connection.
Old Nov 25, 2003 | 12:35 PM
Kamin's Avatar
Default Re: Code 14 = Replace IACV (TeStUdO)
NO! the IACV is exactally what it says, a VALVE that moves to let air in and out to control the idle
if it sticks it can throw a CEL but all it needs is a good spraying with carb cleaner.
Old Nov 26, 2003 | 03:19 AM
Chiovnidca's Avatar
Don't rule out a bad ECU either.
Old Nov 26, 2003 | 09:02 AM
AzG35's Avatar
Default Re: Code 14 = Replace IACV (Chiovnidca)
A frequent code 14 on a OBD2 car usually indicates incorrect idle speed. I've seen this a million times and it is almost always corrected with the adjustment of idle speed and/or cleaning out the IACV.
Old Nov 26, 2003 | 10:02 AM
TeStUdO's Avatar
Default Re: Code 14 = Replace IACV (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 &raquo;</TD></TR><TR><TD CLASS="quote">A frequent code 14 on a OBD2 car usually indicates incorrect idle speed. I've seen this a million times and it is almost always corrected with the adjustment of idle speed and/or cleaning out the IACV.</TD></TR></TABLE>
I would definitely look into the IACV before you start compensating with the idle adjust screw. Take it off your intake manifold and clean it inside and out with WD-40 or any type of engine or brake cleaner.
Old Jun 7, 2004 | 09:25 PM
FredoSP's Avatar
back from the dead cause I think this post helped me
VAAJ
36
May 7, 2009 07:35 PM
G2_Fella
34
Jul 31, 2008 11:15 AM
drumminforev
25
Nov 11, 2006 09:19 PM
209typer
Oct 7, 2004 09:54 PM
AMG
Sep 2, 2003 07:03 AM
