View Full Version : Tech / Misc
- Clutch problem? Help
- Suspension a little "messed up" HELP!?!?!?!?
- test pipe?
- Can you figure out how much a cyl. head has been milled?
- Symptoms of a Burnt Valve? AGGGGHHH!
- WRX lsd ???
- main bearing letters on ls block???
- Resizing Rods
- b16 tranny question...
- Moroso pan + Fram SureDrain?
- Car suddenly won't start... *scratches head*
- What's the best header for an H22a?
- Tire Spinning
- can someone look at this (56k beware)...
- suggestions for basic tech info (suspension, engine, trans, etc.) on 96 integra...
- overheating problem
- Engine Code for a 2001 EX sohc Vtec?
- CTR pistons in a C1?
- 2001 civic dx 5speed tranny-hard to shift into second when cold
- can u put a air conditioning unit from a 1989 civic dx into a 1990 honda civic with a b16a1 engine i
- Help Diagnose Noise
- dx to si tech, where can i find?
- Nice Kit
- t28 or t3/t4
- 5 wire to 4 wire O2?
- Battery Relocate "WIRING"
- Replacing my rotors...
- Amsoil Bypass Oil Filters
- Will using a stock resonator hurt my performance on my exhaust?
- does an ls oil pan fit a gsr block?
- D series
- fluctuating gas gauge???
- Evidence of a blown shock?
- Critique/Suggestions on my Dyno
- P28 code 20 (Load detection) HELP !!!
- itr compression ratio..
- hey i got a impresvie motor tell me what u think
- jdm itr..
- compression check question
- a/f gauge why is it bad to install at ecu?
- shaved door handles??
- Car wouldn't start.. ignition fuse blown...??
- Battery Charging Prob
- B20 Bored out need help...
- 99si Skunk2 manifold
- main bearing colors?????
- Type R head with skunk2 stage 1 cams
- Average compression for the K20A2 motor?
- throttle body help
- Pistons poll!!!
- H22 civic withOUT EGR!?
- After market pistons for all motor
- Main Relay/ Electrical problems? Please help!!!!
- Blockguard or Posting??? Pros and Cons
- What oil do you use?
- Hi Rev Tuners, I feel ill
- B16a timing belt on a b18b?
- easiest/quickest thing to make a civic faster?
- which motor?
- Im considering a k series head swap....
- h22 ??? will it fit??
- Knock? Detonation?
- Reset stock ECU?
- V-AFC leanout %'s vs. actual leanout %'s???
- can u put a air conditioning unit from a 1989 civic on a b16a! engine
- Spring help!!!!
- power tips for 4th gen accord
- jdm f22b
- n e one know thread pitch/size bolt/allen head for AEM cam gear ?? need to replace
- What kind of tach is this?
- Wideband with Apexi Auto Time?
- what do I need to do this
- northeast roll call
- Itr
- B18C headbolt ??
- s2000 motor into EF?
- best pistons/rods for d16?
- LIghtweight flywheel
- Need help to rebuild D16Z6 in EG5
- D16Z6
- 1994 vavle adjustment tool
- Just weighed my car.. not sure if the scale is off or not..
- ......................removing ac from integra?
- Why is everone buring up new mobil 1 supersyn??? so easily
- GSR with CTR cams? Spark plugs
- oil control jet question
- motor spudders and back fires?
- does anyone have specs on the D16y8 and the D17vtec EX?
- DIY: Cooler JRSC temps...
- how to remove the tps?
- Lemme know wat ya think
- Stock rods on a GE resleeved b18c-5 okay?
- taking off Honda IM gasket
- are the b series crank pulley all the same?
- Is it Dangerous to run tires with different speed ratings?
- Anyone know the front/rear torque split on the earlier AWD wagons, say, up to 1991?
- shifter bushings
- Help: Whats up with my car?
- what to do for whaight reduction?
- no knock or secondaries
- Hondata? Accel? Speedpro??
- wheel studs keep breaking on me since engine swap ?? need help
- Need a little help with wiring...
- ls #2 rod???
- stage 2 clutch
- why get black/white wheels?
- RPM Switch or Stock ECU?
- SKunk2 Stage2 cams on stock type r valve train???
- o2 sensor, ecu, and SRS problem!
- building block on budget
- Turbo
- Yet Another Timing Question
- crunchy gear box
- hey will an 87-89 integra d series head fit a d15b7
- How long to install Cam & Cam Gears?
- Downshifting Honda automatics - safe or not?
- Spoilers: Functionality: 4-Door Integra
- FPR + VAFC... whats the actual tuning difference
- need a little hep with my civic
- my build up plan. need opinions.
- Headlight aiming help...
- i want to maximize midrange power on my ls/vtec, 4-2-1 or 4-1 header?
- oil leak on h22 need some help
- changing pads/bleeding brakes?
- changing the radio in a toyota
- 91 Civic HB Swap info??
- post pics of your nitrous setup
- Cleaning Combustion Chamber, how?
- fluctuating temp gauge???
- y7 head on d15b8 (cx)
- ... swap info... 86 crx si
- likelihood of stripped bolt leaking?
- i have a b16a1 engine swap in my 1990 civic how can I pick some low end power
- I wanted to know if i could pick up some horse power if I added an B18 Integra intake manifold on my
- camber kitt help?!?!?
- clutch ??? can't find answer in search
- should i sleeve my block by GE?
- Best Oil Pump for D16 motor?
- white valves??
- Anyone lightened thier stock B16 flywheel?
- Found source of oil leak.. now what??
- CVT Info
- quick question about jacking car up
- Opinions wanted on buildup...
- speedometer works when it wants to
- how do you test a resistor box?
- axle ring clip question
- speedometer cable clicking?
- Grease Buildup/Leak In CV Boot
- Speedometer showing half of actual speed
- timing belt problem.
- JUN foam kit ?/A ...56k gets smote...
- car shut off while driving
- fields sfc pics
- apex N1 bolt up a d16/ls
- Can you just buy a clutch disc?
- DIY Links
- Crank pulley replacement (stock-stock)
- Light Smoke from top of Valve Cover
- Main bearings: not looking good.....
- Would we need a GSR or a Type R Clutch/Flywheel Combo?
- sputtering problem ...
- What do you think of this engine?
- HID temperatures
- Cost/availability of a DC sports b-pipe?
- Ok It seems like no one can answer....
- EG Hatch, Code 12, and 48...
- need help on some tranny info
- rear lca problems
- use gsr or itr exhaust cam with itr intake cam? some specs?
- What kind of compression test numbers are you seeing with...
- exedy clutch good???
- Buy a new car to learn stick... or get a beater car?
- Lash Valve...need help fast.
- 2000 civic si REPAIR BOOKS
- Difference between Hondata silver and blue boxes
- exhaust mani question...
- oil pan gasket pinched?
- Converted to OBD1; erratic starter "click" problem
- i need major help turbo guys !! T3/t4 turbo kit????? fuel management experts read!!
- Fuel Presure is 58 PSI and will not adjust down or up?
- Will coilovers out of a Del Sol work on a 1990 hatch?
- so i need ITR LCRs??
- Car won't start, need help.........
- To rebuild or not to rebuild?
- ANOTHER 4wire to 1wire o2 sensor problem..
- b20 purchase???
- Cam question?
- Custom Cams?
- How does your rotor get messed up?
- Best place to get B16 VTEC head Ported
- Dzus fasteners - anyone with any experience using them to hold bumper on?
- Gearing Question!!
- Real Real Real Real Urgent Question?
- B-Series Cam Spec List (Specs all @1mm)
- msd ignition question ??
- question abou car insurance and good student discount....
- 93 teg rotor on 99 si?
- Diluted coolent causes bad gas mileage?
- IS there a plug on the engine wire harness for cruise control?
- Engine build up...
- Cold day, car overheating, but heater still hot??
- HELP!!!!!!CEL #9 CYP Sensor (Cylinder)???????
- bad msd coil??
- Cam install. Assembly lube?
- header?
- K&N Oil Filter- Good?Bad?
- Tach fluctuates at 4g
- skunk 2 manifold
- Throttle Plate stuck
- OT: but i need info on that magnus morris act
- Suspension Techniques Front Sway Bar?
- KOS (King of Street) Header
- Questions Before I Begin Motor Swap
- How have you improved your gas milage? Please respond here --->
- Anyone experience with ZC pistons in ZC block??
- ls and gsr oil pan??
- Top speed probīs with civic ee9 (b16a1)
- 90 accord with KYB/Koni/Tokico
- How easy is it to burn a clutch?
- the nos thingy in front of the intercooler......????.
- Raised wrist pins/Longer rods worth it? Downside?
- b18b head vs. b18a head?
- Need HELP Quick Removing axel bearings for Dropping My Tranny!!!!
- Best Pistons
- Wierd gas problem, help.
- apexi n1 ???
- please help car overheats and heat is not working
- RHD shifting
- H22 swap help please.
- How to remove JB Weld?
- nitrous question??
- how do you distinguish gsr tranny from an sir tranny?
- maintenance required light
- New here
- ls/vtec power output
- exospeed shortblocks
- gasproblem
- Swap Article Published, very informative.
- Flames coming out of my Exhuast?
- Dropping in a Block Guard
- intercooler question....
- 4.785 fd and LSD
- Transmission?
- Dakar Rally mitsu - wire going from inside body to hub ?
- can someone please post a picture of the back of their gauge cluster!!!!!
- suspension setup for an ek with a H22a
- Do Skunk2 stageII cams have a rough idle??
- possible to use a smaller fuel nozzle to lean out no2 mix?
- Intake / Exhaust cams... This setup better than stock? and what about turbo...
