View Full Version : Tech / Misc
- TPS Problem
- Some questions regarding exhaust diameter size, and a few other exhaust-related quest
- Car wont start
- Resonator scraping on driveways
- crank pulley coming loose causes spun rod bearing?
- Simple question regarding gauge cluster needles..
- Theft, V-AFC wiring - car won't start
- Electrical help for EF8
- Benefits of Individual Cylinder Tuning
- Immobilizer issue
- how to remove OEM fuel rail fitting ?
- street bike forums? Anyone have any recommendations
- LS boost question
- Intake cam not turning smoothly help!
- switched out power steering rack for manual help!!
- gauge question
- b18swap in 94eg, have underdash questions...
- reusable head?
- Fuel Pressure Help!!!
- car wont start
- Need help identifiying these cams
- rebuilt motor and camshaft oil seal leaking
- B18c with pr3-2 head
- Car bogs at 5k rpm! help please!!
- wrist pin help
- Help wiring a H22 in 97 hatch
- Engine build question
- ckf question 99 si
- Need help with t bracket!!
- Integra CV boot popped loose
- Fully built golden eagle motor sitting for 6 years?
- WHEEL REMOVAL?????????????
- is this bride gias real or fake?! I have no clue ???!
- H22 hatch overheating help
- Engine will not start..
- New to the Forum and an Old Fart!! Help!!
- Compatiblity of AC Compressors
- code 20 on p28 d16z6 ef... eld code
- Mishimoto OIL COOLER TRACK DATA?
- Engine coolant temps vs HP vs MPG
- b16a pr3 ecu limp mode?????
- VTEC pressure and solenoid plugs, part#?
- Piston ring filer?
- Where to get work done?
- obd2b to obd1 convertion A/C dosnt work, ACS
- NJ OBD2 inspection wont connect!
- f20b piston rod custom
- which air compressor?
- Looking for 0-2GA wire connectors, terminals
- just came up with this stupid thought...
- 93 civic fuel pump problem..
- Changed CPS, car wont start. Please help
- TURN SIGNAL'S NOT WORKING! HELP PLEASE!
- Gsr idle problem fitv?
- Vtec harness on non V engine..
- torque specs on ARP main studs?
- 1993 civic ex wont start
- need some help HG/timming
- P28 ECU running a B17A
- Interesting story about a unique and easy way to fix bent valves...
- Motorcycle exhaust piping size
- Bizarre cooling fan problems
- How can you tell if a turbo is good
- Battery fuse after battery relocation?
- Do I have a IM or TB Leak somewhere??
- spark plug wires
- OEM Coating on Nuts/Bolts
- chrome launch control doesnt work?
- GSR swap need help
- 96 2.2 vtech misfire between 2100 2800rpm
- your home garage/workshop pictures,tips and tricks
- Electrical nightmare Ecu issue! SOLVED 2017
- Exhaust bolts size
- Re-foam stock seats?
- Switching to Synthetic Oil
- 2JZ Solstice Build
- CP Replacement Rings
- anyone try treperformance 340lph fuel pump
- B18CR knocking when cold
- need a little help
- Noise coming from the driver/front side of my EF
- D15b1 Terrible MPG Questions.
- BHP / HP and WHP - is there still a big difference ?
- Fuel pump problem
- idol issues blow.
- B16 Valve seal replacement...
- JDM H22 IAB Solenoid & Vac Box.... Same as Integra GSR??
- dipstick tubing question help!!
- B Series Cel 9 CYP Sensor Problem
- building oil pressure in my b16a2 please help
- DC or DA cluster on EF?
- oxygen sensor
- Do I have the correct valve seals? (B18C1)
- NEED HELP CAR WONT START AFTER IT WARMS UP
- gsr intake manifold on ls head?
- beginner engine builder, measurement comparison..(micrometer vs. plastigauge)
- 2011 Ariel Atom w/ a built K24
- have a stock ls motor, dies at 4000rpm in 4th gear
- oil leaking from cam seal on timing belt side
- car barely idles/drives after clutch install
- Good cut off wheels?
- '89 Civic DX starting problem
- Tach reading two times too high?
- B18C1 won't Rev past 2500Rpm
- Need Help-New Car Opinion
- LS/VTEC Timing Adjustment Issue
- Brake Line Tuck Help
- Help diagnosing a starting problem on '06 TSX - intermitently won't turn
- car radio isn't loud enough?
- engine help - help the newbie
- wont idle below 3k after intake backfire
- oil leaking from headgasket by timing belt
- 89 civic wagon question
- 93 ZC VTECH PCV VALVE TRYING TO FIND THE PART #
- 212 degrees on LS/VTEC
- Lagging motor
- oil leaking problem on eh6
- Car clicks when key is turned but wont start
- New here and to hondas as well
- P0301, Isolated to injector 1 not firing, but why?
- Help! Crankshaft issue
- civic header flange the part where the donut goes
- problem with gsr swap
- DIY How-to: Calibrating the Voltage on your TPS Sensor
- Solder Heat Shrink. where to buy?
- just watch the video
- very weird issue with cooling
- SOHC ZC head gasket replacement questions
- Noise-canceling exhaust like Corsa on a Honda?
- EMERGENCY: Automatic Civic Overheating! Need to Drive SOON!
- [noob question] ITR head compatible with OBD2 B18C1
- Retail shops in LA area
- Can a bypassed fitv cause the vtec not to engage?
- need help
- octane sensor? does it exist?
- Is tuning absolutely necessary after installing an aftermarket cam?
- bore size on oem headgasket?
- 93 accord obx header sux big time
- good price for ecu
- Header leak not sure how to fix
- Civic Si Cooling Fan Motor
- Plx m300 not reading as the dyno a/f (248c) help
- 1998 honda civic ac condenser fan fuse blowing?
- 92 civic hatch dx timing the ignition and speedometer problems anyone with advice?
- Oil pan change advice please
- Coolant bubbles when bleeding
- FITV or IACV or neither?
- What bran retainers are these? Valvespring/Retainter B16
- wassup need help k20a3 integra
- 93 dx hatch issues
- Need obd1 B series vtec dizzy pinout, cyl no 3 & 4 misfire
- Need help with A/C and HVAC control panel
- Fresh D16y7 top end rebuilt IDLE PROBLEM OMMMGGGGG
- 1996 Accord power seat swap?
- P75-6???
- B16 Supertech Valvetrain - Use stock seats?
- IACV won't work correctly.
- GSR Rebuild - Rod/Main Bearing help needed *PICS*
- 1998 Accord Alternator Plug wiring order.
- Idle Problem b16a
- ls-vtec bogs down/cuts out at 6000 rpm
- RPM gauge stopped working
- my b18b1 it ticking from the head
- Head stud question
- 93 del sol has a few issues need help
- Aftermarket fuel level gauge?
- REBUILDING MY FIRST MOTOR AND GOT QUESTIONS
- 2000 civic si cluster problem trip and mileage are stuck
- ECU Code P0420
- Accord Died While Driving.
- Wave trac LSD?
- Need a bit of help with my B17a1 swap into 79 civic
- JDM B18C1 with white smoke at VTEC
- question after removal of oil filter bolt
- WILL THIS WORK?
- A/C not malfunctioning normally
- Oversized valve seats with stock size valves
- Removed Turbo.
- what the hell is this check light? japanese
- A/C blowing warm at idle
- Really strange gas tank and MPG issues...
- ***Supercharged Poorman type R problems*** Need Sum Help any1
- help with check engine light power
- honda accord external ignition coil in civic?
- del sol not running right d16z6 motor
- discoloration on cylinder walls.
- car wont rev past 7000rpm
- air conditioning issue **input appreciated!!**
- Slave Cylinder
- Leaky fuel line
- motorcycle exhaust pipe size?
- shot ping
- Is my fuel pressure too low??? AEM FPR
- Code P0135 CEL 41 primary O2 sensor heater
- Distributor King Out of Business?
- head gasket bigger than engine bore
- EK with a JDM B18C1: Sputtering..why?
- H22 coolant line routing
- what vtec cams are these? And what is the thread pitch on the fan switch on a b18a1
- Best way to troubleshoot rear clunk
- greddy gauge question
- install 340lph pump and pressure drop?
- inconsistent bearing clearance measurements
- Kinda loud tapping from head that goes away after a while...
- Front Lower Arm Bolts
- How to bring operating temps down
- Post pics of your funny stickers
- help h22/h2b wont start up
- question about a manaul rack HELP!!
- Frozen motor
- a1000/10 micron filter
- Fitting bucket seat like this...safe?
- Spoon N1 & Turbo thoughts?
- ARP head stud washers
- limp mode help
- 1gen gsr???
- NEED HELP!!!!!!!!!
- Engine code stamp punches
- Any suggestions on 1/2" Battery Operated Impact
- Ek Amber clock wires????
- Brake Click When Reverse
- quick question??
- Finshed. ;d15b7/d16y8 Mini Me w/ Cbr954rr ITB's;
- can you buy this piece????
- 04 TSX Wheel Bearing help
- Possible to re-use a 28 pin socket ?
- Catch can..etc..
- fuel pump wiring 90 accord
- Miles to Empty Gauge?
- Turn Signal Problems
- Best car battery...
- performance shops in tn?
- Radio, blower, etc. electrical wtf (x-post)
- Are b18 and b16 intake man. sensors the same?
- Wagon ECU only?
- b18a1 turbo problem
- Throttle Body Assistance...
- gsr head break down
- Wheel Bearing Lube?
- Auto seat belts move forward but don't retract
- Electriscal issue, motor shuts off for a second while driving
- Cars compatible with '91 Honda Accords
- What lubricant for caliper slide pins?
- mini-me
- EK REMOVABLE STEERING WHEEL
- My finished 97 EJ civic mini me with CBR ITB's
- Old fuel injection cleaner
- honda parts guys, help! (harness clips)
- Tool Box Porn....
