d15b7 crank in a z6?
Old Nov 25, 2003 | 12:15 PM
seerx's Avatar
Default d15b7 crank in a z6?
first off is it worth even trying? im planing on turboing my z6 in my cx. i have a z6 in it now with my cx tranny. its slow off the line but it takes off at 3600. i beat a 92 si with it. n e ways if i put a cx crank in it ,it will lower the comp.and at the same time have better revs. i will have absolutly no torque but once boost kicks in it should be pretty crazy. is it even possible to put in tho?and im also about to rebuild all of it over the winter. im balancing and p+p. ne little tips that i should be doing while the rebuild?should i do n e nitrating,meleniting,or cryogenics. n e info helps. if its a stupid idea with that crank tho let me no
Old Nov 25, 2003 | 03:31 PM
Kendall's Avatar
Default Re: d15b7 crank in a z6? (seerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seerx &raquo;</TD></TR><TR><TD CLASS="quote">if its a stupid idea with that crank tho let me no</TD></TR></TABLE>
Yes, it's a stupid idea (not trying to be mean). If you're going to lower the compression, do it the right way, use lower compression pistons. And the amount of compression lost with the d15 crank would be so extreme that I don't think any practical turbo setup would be able to properly compensate for it. What I think you're forgetting is that you will also be losing displacement, and with it potential for horsepower. If I were you, I'd get ahold of some inexpensive low compression pistons and a decent set of rods. Then I'd piece a turbo kit together from junkyard parts and have lots of fun.
Old Nov 25, 2003 | 05:59 PM
PHiZ's Avatar
Default Re: d15b7 crank in a z6? (dc231)
Actually, what he is talking about is a very effective way for stroking or de-stoking the motor, to achieve a safer higher redline. It is an established engine building trick, not a hack, or rig-job.
Now as far as weather or not this particular application will work, I dunno.
-PHiZ
Old Nov 25, 2003 | 06:28 PM
Jim Truett's Avatar
Not gonna happen. The main and rod journals are much smaller in diameter.
NowLoading94
Feb 4, 2014 11:23 AM
SpoonfedCivic
Feb 23, 2011 07:30 AM
94c1v1cex
Jul 16, 2007 08:15 PM
soundman
Nov 4, 2003 06:51 PM
