View Full Version : Tech / Misc
- TDC Sensor Test
- Clutch Kit Question
- Where Can I Get A New Wiring Harness (JUN ECU)?
- Need a mechanic
- Trans leak
- Head Gasket Question
- h22 in a EG
- Tow Hook
- 98 HX trans Swap done but issues!
- b18b1 need help
- brake light wont turn off (NOT e-brake) / brakes losing pressure
- B18C in need of some help...
- o2 sensor spacer
- Can i use a 96-98 EX TB cable for a Bseries swap?
- Big Brakes and ABS
- Weak engine power at low RPMs
- What do do after spun bearing?
- Kinda a n00b question about a spun bearing...
- D Series Cable Tranny Question
- TDC Sensor Test
- TPS issue. Getting TPS CEL and datalogger says my tps is always at 26%
- gsr wont pass 3grand
- B20 Basemap Q's
- need help asap
- Spark plug choices? New Pulstar or NGK iridium?
- Honda Beat 1991 Upgrades?
- Reverse Flow Cooling?
- Can't get my Moates Hulog to work.
- bought a 90 hf crx but... NEED HELP
- y7 block a6 head?
- How do I check resistance on my TPS
- 3rd gear, 7000 + RPM starts to hesitate?
- Engine Struggles after 5k rpm
- Honda Techs please help!
- rev limiter kicks on at 2500 after swap HELP!!!!!
- Best way to measure pressure in exhaust
- glowshift oil sender gague + cdm oil sandwich = oil leaks
- trans issue
- will whale penis fit
- E-3 Spark Plugs with DIAMOND FIRE technology --anyone have dyno results??
- **RHD A/C SYSTEM QUESTIONS*****
- anyone have a diagram to repin obd2 dizzy to obd1
- Fuel Pressure/12v Problem
- Need advises to upgrade a B16a2 ( NA no supercharging ) Little french inside
- If you've done a JDM H22 swap, check in here
- clutch fluid in 99 LS
- Prosport water temp gauge - long time to heat up
- Checking the stock o2 sensor with a wideband
- Caught air in my Si
- explain/translate/help
- eg build
- alternator swap
- B16b with ls crank ?
- Sputtering when held at constant RPM, fine idling, fine WOT... Where to start?
- Best motor combo for my car!
- New transmission for my 94 civic ex with m/t
- car wont start! ecu problem
- "HELP NEEDED" 88 Honda CRX air condtioning
- will a 96-98 auto civic ecu work on a 97 auto prelude?
- 98 prelude injector issues
- WANT TO: Make major power out of a boosted sohc.
- k24 wit a k20z3 head
- odd gear ratios, help me identify trans
- I have a missing rocker arm bearing
- tuners in the middle tn area?
- Injector Compatibility
- sourcing trans synchro parts
- Driving w/bad LMA's?
- ctr/pct/b16b piston compression?
- OFF Timing need help ASAP!!!
- NEED HELP! missing Exhaust stud on B18b1 after engine swap!!
- Distributor Question???
- Help With K20 Tranny Removal...
- 92mm crank in a b18c5 what rods length?
- Shift Light Question (searched)
- Throttle body, What Car???
- B16 swap failed emissions BAD! HELP!
- Looking for a Turbo cam d16a6??
- Shipping a block to the UK
- Engine Build Questions - Cylinder Bore, piston size, ring gap after cylinder honing.
- 93 del sol a/c gage reading question
- HELP!!! What Is The Trans Code For a 98 ex d16y8 sohc vtec?
- having a issue with b18b into 98 ex.
- What looks wrong here?
- Reverse locking up?
- jdm b16 first gen or second gen ??? plz help!!!!!!
- i know there is an H2B adapter, but does a B2D exist?
- FiberLocking...? NEED HELP!!!
- 4th gear and 5th gear problems
- head gasket question
- Problems holding a cruise
- b16 not starting after upgraded cams? Please look, weird problem...
- p28 thats chipped I want it back to stock
- Car got sort of flooded!!! Need Diagnoses...
- stage 3 cam
- beefing up d16 tranny
- car runs bad when weather is hot
- cam gear hatch marks
- D16y8 - Accessory Belts Won't Stay On
- Coolant Problem!!!
- HELP!!!! JUST PUT IN NEW CAMS EXHUST COMING OUT OF INTAKE
- Car running odd, any suggestions?
- coolant temp sensor?
- Reverse idle gear shaft washer
- wobbling when in vtec
- b20 vtec head gasket question
- Anyone with a NRG short hub. please look
- Valve Seals Rotting?
- how much difference between b7 and b8?
- HOW COULD I FIX UP MY 99 HONDA CIVIC DX OR IS IT EVEN WORTH IT?
- weakness of honda stock sleeves
- Block Guards - Good or Bad
- hondata help
- how to calibrate tps? multimeter?
- looking for the best cam for my motor!!????
- Accord 5 speed swap need help!!
- Help! Did my Tranny took a dump on me???
- 94 GSR help
- doing a swap having some issues
- cam gear breaking
- Missing link?
- fried ecu?
- bought new ep3 where can i get parts cheap what should i start with
- 1997 crv ac problems need help
- zex nitrous kit in a d15 io need help
- pgmfi.org?
- Not entirely sure what the problem is...
- need help with big transmission problem
- Need help removing broken stud.
- rear drum to disc brake conversion - help needed
- OBD0 and OBD1 chips???
- P73, not all the same
- 98 civic dx knocking/stalling
- rc injectors???
- Torque specs for LS ARP head studs?
- Overheating problem on race track only.
- db1 fuel question
- Honda Odyssey, parking Brake and brake lamp warning light are on
- HELP define this!!
- 3Bar Map Problem
- Gsr motor, Found Little clip in oil pan?
- Converting OBD2a P75 to manuel. What pics do I need to move?
- mixing blocks and heads
- Brale line size???
- clutch pedal adjustment
- Dowel pin
- I sucked water up with my turbo!??
- help... car idles
- 97 Dx W/ B16a2 Swap [Help]
- Need Tranny bearings!!
- ls swap in 96 ek coupe help!
- p72 ecu need help to chip
- NEED HELP PLEASE
- timing problem
- oil presure is low!!!!!!!
- weird problem
- AEM FPR honda/acura
- Coolant tank doesnt seem to be working.
- crisis
- OEM Spec GSR Pistons
- PROBLEM!! ObdIIB ecu / 2000 Dash / Si harness
- another tranny question...cricket like sound.
- American Si b16a del sol clutch kit to Europan VTI?
- Only 1 spark plug providing spark?
- Help identify piggy back ecu
- Will A H22 ACT HD pressure plate work with OEM DISK?
- Problems with my tranny/clutch...help
- WTF is wrong with these dang honda's at high boost.........????
- the ups and downs of ls/vtec
- eg with h22 problem (need help)
- rust on cylinder walls
- vtec solinoid
- fuel gauge stays on empty after cluster swap
- help with dohc zc problem please
- Learn to tune...
- Are 96-00 civic lx and ex oil pans interchangable?
- detonation?
- 4.4 FINAL DRIVE to 4.26 from LS into a Y21 PLEASE HELP!!!! Searched!!!!
- Transmission install
- gsr lsd
- Are GSR differential bearings the same as 99-00 Civic Si B16 diff bearings?
- Vtec question????
- Puzzling mileage reading from Autocheck
- Injectors
- GM Synchromesh Friction Modified, Canadian part # and photo inside
- Gearspeed custom built Gsr Trans.... NICE
- car dies when rev... NEED HELP>...
- tore apart the tranny and found a couple things. B16 trans
- jdm civic sir climate control into a 00 civic si
- itr vs ctr
- Help me install my Spool DIff.!!!
- Wavetrac LSD!!!
- need help
- VTEC BOGS DOWN WHEN KICKS IN
- Need help with custom tranny's gear ratios
- Question About Torquing Bolts
- Chrome Pro Bugs?!?
- Late vtec engagement.
- cel 7, 16, and 42 but car runs fine?
- help with breaks locking up plz
- I NEED FAST HELP ON FLARING KIT
- 1988 Honda CRX SI Air Conditioning
- How much power can stock fuel pump consistantly hold?
- 1988 Honda Airconditioning
- blowby could it be valve seals
- crome not working
- OBD1 Question
- swap options? keeping tranny.
- Tranny Help Please
- ive got some play with my lsd, is this normal?
- b-series tranny help
- 00 si tranny help
- Integra resistor wiring question
- bell house question ?
- b16 lsd/tranny help!!!!!!
- help needed 4 H22 swap
- BAR question
- ek b18a1 hydro tranny?
- Major failure of MSD spark plug wires
- B-series tranny help
- B16 S1 cable tranny FD torque specs
- Wont start, no spark
- droppig in a new motror complete swap need help!!!!!!!
- best tranny
- what should i do next?
- Help Sputtering FULL BUILT D-Series 85 miles on fresh motor
- A lot of you guys probably knew this about oil, but worth a read.
- quick help with coolant flush problem
- HELP! 5th Gear won't engage
- Alternator removal
- Drive transmission with car off ground?
- ls head on b16 block
- 98 teggy auto locked tranny?
- need help on which tool to use
- Need Help ASAP!!!!
- Help me buy a compressor !
- oxygen sensor weirdness
- Cant put gas in?!?
- Nitrous question.
- Help with door conversion
- YSK-3???? WTF?
- 99 Integra GSR - Failed emissions - details enclosed.
- kind of laggy when car is under load....help
- Trouble dialing in H22 Pro1 cams
- rev limiter at 4500
- help please honda tuners. ecu probs?
- Did a compression check , how did i do? Gsr
- 97 civic si wont start
- hey guys...would love to hear something about this build up
- On the market for a new tune???
