View Full Version : Tech / Misc
- 94 Integra VSS ?
- Cool Auto Insurance Commparison Site!
- P75 Hondata or P72 Hondata URGENT HELP NEEDED*!
- Timing belt or Timing chain, pro's and cons.
- how many quarts of oil does a b16 cable tranny hold
- Radiator fan not working??
- Technique of finding vacume leaks?
- OUCH!!!!!! PICS INSIDE
- Lsvtec pics requested..
- Rethread
- Stud removal?
- tranny
- Air/Fuel guage not jumping anymore
- Tuning Educational Video: Base Fuel Table
- ECU wiring diargam
- ECU QUESTON!?!?!?!
- Lights out: Climate Control and Gauge Cluster...
- b16a stalling need help
- Timing Belt for F22B2 Engine
- Engine Storing Question?
- h22 into ek help?
- Integra gauge cluster compatability
- What head gasket do you use for a ls\vtec setup?
- best ecu??
- *Warning* Be careful of sandwich adapters
- What sensor is this?
- 91 ls hatchback what ecu to use
- need help with fully built head
- Code 43 Fuel Supply system....Need help!!!
- headlight relay wiring!!!
- TDC w/ GE Cam Gears & Valve Adjustment w/ S2S2 Cams
- d16y8 header on a 91 dohc zc engine
- Wut obd is my B16A motor??
- ACT clutch with stock pressure plate
- iacv sensor
- Can this MSD 6a be used on a 4 cyl?
- B series motor in non-honda vehicle
- Anyone use Brad Penn oil? Kendall? Any of you guys from the PA area, read!!
- AEM underdrive pulley kit
- Radiator fan problems
- steel braided lines
- How to polish???
- What is the name of this tiny hose??
- Anyone paint in RI area?
- PROBLEM!!!!!!!!!!!!!!
- Strange clicking noise
- Please help...B16 into ESI
- Greddy oil sandwich adaper question..
- Which OBX lsd for s1 tranny?
- Whats my oil pressure suposed to be?
- Messed up Eagle rod threads question..
- LS vs GSR tranny
- what is different in a b16 and b18c both vtech
- dual valve spring install same as single?
- B16 Oil pressure problems.
- poor man type R and timing belt
- Auto Insurance Compare Site
- Emission Help??
- GSR block, B16 head, which timing belt and water pump?
- Injector question...
- distributor differences?
- High Fuel Pressure
- Changing springs, retainers, valves... what else to buy?
- building motor
- This Honda has me stumped -- Fix it and I'll paypal you $20!
- overheating
- Can/will ARP main studs warp my journals?
- need help w/vafc on my b18c/turbo!
- changed my wheel bearing but....
- How do you adjust idle on a 98 gsr throttle body?
- Fresh built motor overheating
- boring out sleeved z6
- D15B swap questions
- B16A cam camps.......
- 4th cyl. leaning out..dont know whats wrong. help
- Engine running lean
- I need an answer ASAP please
- Balljoint press
- Couple of questions about a valvetrain setup...
- my mystery..
- Greddy A/F guage??
- Tranny Issues
- Ecu tuning
- blown engine - b18 bottom on zc head
- hey PM3-18?? can u tell me what it is?
- full or half radiator?
- B18 Motor Swap Q's ((Car Not Starting))
- main relay question
- anyone wanna help me do a swap?
- Pistons for b18c1
- LS compression ratio???
- Ls Vtec Girdle question
- b16 head anyone?
- help with h22 intake manifold
- injector Size
- smoking b16
- Datalog question. need help troubleshooting. EcuControl5
- help!
- distributer
- !HELP!TPS problem.
- What's the best way to clean paint and corossion off of older bolts?
- Where can I find OEM connectors for engine harnesses? Part #s?
- Running Open Header And BackFiring
- Primary cam lobe specs needed
- which headstuds for lsvtec?
- Trying to Find out which color bearings I need in GSR PLZ HELP URGENT
- to replace a hub bearing will i need a press machine???
- causes of early rev limiter engagement??
- gear broken in distributor... can i replace that?
- ICM ignition HELP!!
- obdI or II
- b20 vtec
- where to go to get crank oulley milled and balanced
- jdm b16a head question reguarding cam caps
- no heater core
- b18c1/b16a Rebuilt Engine Break In!!!
- port and polish good or bad?
- euro R intake manifold? trouble shootin and Throttle body
- Ys1 Tranny
- my clutch/tranny is giving me problems, PLEASE HELPPPPP!!!!!
- New FPR that eliminates the diaphragm
- Replacing Rear Caliper Dust boot??
- Hondabond and RTV temperature range
- Honda Aerosol products?
- Throttle sticking?
- Tuning Help
- 88 civic idle issues
- Coverting B18a1 to Obd1?
- question about timing belt cover
- Axle problem AND Quaife
- brake problem
- 89 Si dash/cluster in an 89 std 4 spd hatch.
- Timing Help Please!
- b16 Running rich help
- D16Y8 head...humps in intake runners?
- Needing a wiring diagram for pilot??
- What header options for a 92-95 civic jdm b16a......
- clutch Q:
- replacing window motor and reg need help please for DC2
- Throttle cable lengths? LS/GSR/ITR
- Hondata s200 cold idle low
- b-series fuel rail...are they interchangable?
- abs to non abs
- Blown Headgasket Pics NEED ADVICE!
- idling issues with itbs
- How to make the pullies grab better?
- Will a p28 chip work with a p30 ecu?
- b16a cams or b18c cams
- So I broke the valve cover stud... what to do?
- vtec ecu with a non-vtec motor
- Stock civic
- radaitor problem
- Euro R Intake Manifold & Flywheel..????
- problem: cyclical leaning out while in closed loop
- ls dizzy for lsvtec
- tuning: fuel needed at startup.
- where to buy 96 type r 4x114.3 rotor replacements?
- obd0 ecu codes
- brake question
- i need help rewiring my obd 0 b16a vtec noid
- How to tell P72 from PR3 cams???
- what do i need to check if i can Vtec my D14A4.
- Injector question
- 91 teg starts then stalls
- wire colours for apei avc-r
- Damn Wilwood brakes
- Important info that I need to know about the B20B/Z
- new car prblems
- Vtec
- clutch / transmission
- Starting problem still need help diagnosing..
- Oil Filter
- water temp gremlin
- Y7/Y8 mini me in a 1989 CRX SI
- vacuum question
- Secondary (After-Cat) O2 Simulator
- Polish the piston crowns?
- Stock thickness HG fine on this setup? Pro1's plus zero deck block...
- H23 transmission making knocking sound??!
- Strange idle issue.. never seen it before lmk what you guys think
- engine builder in maryland
- y1 to s1 final drive ?
- choosing an ecu...
- **i need help on VTEC wiring!**
- if i micropolish the crank do i need different size rods?
- aem uego wide band o2 sensor problem
- Ever heard of this transmission?
- Questions on clutch sizes and spefications.
- Need some help with a project of mine
- Need the radio code
- short turn radius
- FI & NA, not which is better, but...
- TPS and O2 Sensor!!
- Muffler Baffle, fixable by muffler shop??
- civic ek dx coupe serious help
- More B16 Problems
- CTR CAMS
- D16Y8 into a 94 civic DX coupe "swap trouble" soldier in distress
- Intake Manifold Design...a few pics/questions/comments...
- optimal coolant pressure?
- In need of Tony1
- CTR N1 pulley, will this fit a 1994 h22a?
- D16a6 cam
- kenji211.com ECU !!! ANYONE!!!!
- VTEC and revlimite for B16a2/B18c1
- anyone ever have timing problems on a decked motor?
- LS/VTEC bolts/studs NEED HELP
- Can I Use A P28 On This Setup?
- what rods are these?
- basemap for itb's
- quick fuel filter question
- JDM b18c is weak.....wtf???
- Engone Break In (quick question)
- Rebuilt Engine Break In
- CTR AND ITR CAMSHAFT QUESTION?
- DC sports 02 sensor plug...searched...
- Just wondering... which car has better traction as stock... EK or EF
- NORCAL people!!!
- VTEC wiring and Map sensor problems!?
- car makes whining sound while cruising.
- GETTING a code 43 and code 01...need some sugestings????????? real tech heads PLS LOOK
- Fuel Cell Problem
- Speed Chip
- accord 91 cooling fan problem really weird
- jdm b18c r maintenance HELP!
- Where is the EEC relay?
- misfire
- Brake pedal sinks slow. . .
- just some ? bout obx lsd
- Need help bad! Please help asap!
- EMISSIONS!!!
- Acura RDX
- H22A Swap. Has fuel, compression and spark. Car won't start. Help appreciated.
- Modified Exhaust Ticket...
- info on dohc zc
- Car starting problems HELP PLZ.
- i need some help PLEASE!!!!!!!!!!!!!!
- alternator whistling
- Could this be a valve problem?
- stupid trans question
- SAN DIEGO TECHNICAL HELP THREAD.
- yes, another oil catch can question...this should be a simple one.
- subaru guys I need your input
- What does a missfire feel like?
- Tighter bearings without machine shop work?
- Nissan 280ZX rev problem HELP
