code 43
Old Nov 26, 2003 | 06:03 PM
1.8turbolsvtec's Avatar
Default code 43
i have a lsvtec turbo civic 95. at 6 psi in 3th and 4th gear after vtec comes on i get a code 43 and when i up the boost than it comes on sooner have 450 injectors and fuel pump and hondata. if any one can help thanks
Old Nov 26, 2003 | 06:35 PM
b18crx's Avatar
Default Re: code 43 (1.8turbolsvtec)
i think that may be O2 sensor.
Old Nov 26, 2003 | 06:48 PM
Default Re: code 43 (b18crx)
i put a new o2 in it to
Old Nov 26, 2003 | 06:50 PM
b18crx's Avatar
did you unplug the battery for like 15 mins after? try again...
Old Nov 26, 2003 | 07:05 PM
ya. it comes on every time over 6 psi after vtec i pulled the 7.5 radio back up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18crx &raquo;</TD></TR><TR><TD CLASS="quote">did you unplug the battery for like 15 mins after? try again...</TD></TR></TABLE>if it ant broke you are not pushing hard enoff
Old Nov 27, 2003 | 03:00 AM
crxste's Avatar
Code 43 is Fuel System, perhaps you're running way too rich on boost?
Old Nov 27, 2003 | 06:51 AM
blackeg's Avatar
Default Re: code 43 (crxste)
its prolly your o2. code 43 sucks.
Old Nov 28, 2003 | 04:48 AM
Default Re: code 43 (blackeg)
ok i will change the o2 again and see what happends thanks for all the help
Old Nov 29, 2003 | 10:02 AM
EG-lowrider's Avatar
im having the same code, after checking the plugs, (whiteish color) and now expierencing low end (under 2k) misfire, i believe the code discription is right, you know, fuel supply. but never rule out the 02 sensor, but thats probably not it.
Old Nov 29, 2003 | 10:05 AM
oh yea, fuel injectors, could be an issue. just because there working dosent mean there working properly, like the spray pattern may be horrible, or they could be dirty and clogged up,
you say after 6 psi, the code throws,, well, your probably getting into a lean condition, just my guess.
but defidently check the plugs
Old Nov 30, 2003 | 10:37 PM
Default Re: (Broke@$$tuner)
thanks for the help everyone
91ef_ls
Nov 15, 2006 06:15 AM
JDMhondalude22
Nov 8, 2006 04:55 AM
Rudelude22
Sep 29, 2005 10:20 AM
DOHC hatchback
Oct 9, 2004 08:26 AM
1.8turbolsvtec
Jan 13, 2004 05:25 AM
