View Full Version : Tech / Misc
- my car only runs when the "D" connector is unplugged from the ECM
- I cant get my timing right
- b18c1 smoking after high rev's
- H22 troubles
- itr axleback
- i need help with my motor setup!!
- Left to Right play in gearstick.
- Wont rev past 1k with chipped po6!! HELP
- Exhaust painting.
- Intermittent rev drop and stall while stationary (B16A2)
- 97 civic gsr
- clutch problem
- <---- Plug Identification -----> someone bust out their HELMS OBD2
- Idle speed affecting mileage???
- ZC Tranny reassembly problems
- Tranny
- knock sensor help code 23
- IDLES TO MUCH!!
- RPM'S GO TO LOW & THE CAR TURNS OFF
- 2ND GEAR GRIND ??? 96 INTEGRA LS
- need help identifying cams
- Can you run only a wideband o2, no narrowband with s300?
- ***Need feed back on Wix oil filters***
- need help
- please help
- WILL STOCK TRANNY WORK WITH B20??/
- Syncros??
- 1997 honda civic GSR swap problem
- CTR PISTONS ON JDM B16 RODS
- help with my ls head!!! bent valves??
- Transmission issues...
- OBD2a to OBD1 Conversion CEL and VTEC questions!!!
- Put in a different transmission and having shifting issues..
- GEARBOX SPRINGS???? play in gearstick tracked to gearbox.
- Will the ATS 4.9 FD fit on B16 JDM YS1 Tranny
- any 1 got obd0 ecu wiring pinouts
- royal purple good or bad
- Knock Sensor Question
- installing power folding mirrors
- Apexi Neo wiring diagrams help
- Shi77y Milage?
- Is power steering fluid corrosive?
- Who has the lowest price on OEM honda oil filters?
- Odd carbon deposits on pistons
- What is transmission diagnostic code 15? 1998 Accord
- 1994 Integra LS (obd I) will be getting a 1997 jdm obd II gsr swap ...
- a20a3 head on a18a1
- M2B4 Quarts
- normally closed relay/switch, but open circuit when given signal?
- Distributo condenser and internal coil question
- H22 RBC intake spy photo....
- How to use this?
- hondata s300 question
- AEM Cam Gear Bolts Recall
- B-series Tranny Bolts size.. please help asap!!
- flush carbon boot???
- perspex bonnet???
- Hondabond, left in heat :(
- leaky SS clutch line
- JUN valve springs: what does the paint mean?
- 92-93 GSR YS1
- Header to exhaust problem (2.25"- 2.5")
- Need tranny/axle oil seals..need some help
- over - torqued rod bolts
- ARP head studs/Cometic HG combo
- can i use bleach?
- LCA scraping dustshield and rotor...
- Car sucks at driving on the highway and I need insight badly.
- i have a wieard problem
- Crower stage 1 cams and s2 gears in jdm b20b, expected performance gain?
- need help
- need help with a swap
- Built engine sat for 3 years...
- short shifter in EM1
- 3 wire iacv to 2 wire.
- Toyota celica question... window wont roll down
- HUGH PROBLEM NEED TO KNOW WHAT VALVE SEALS I HAVE
- What is my problem?
- carfax
- OBD2a --->OBD1 Conversion check engine light diagnose?
- my car dies
- switched ecu's, now have check engine light
- H22A/H23a Swap..Possible?
- Question on Slave Cylinder replacement(clutch), bleeding procedure
- Is my battery kill switch wired right?
- Need to find a slim fan, but no luck.
- Fresh h22 swap wont go into gear!!
- f22 h22
- cel 9 with 2 month old distributor !!!
- Buddy Club Spec 3 Exhaust Diameter?
- Swapping valve springs using current retainers
- will this clutch work with this transmission? ..
- B16A + BCIII+ - where is a gain?
- will a bad main relay cause you to have NO ELECTRICAL at all?
- Most accurate way of milling a head or decking a block?...
- Machine a Camshaft?
- 3/4 Grind after new slider assembly?
- Going to look
- automatic k20 on 2000 honda civic hatch
- NO POWER WHATSOEVER!....
- FREAKING NOOB!!!
- Power door locks and window conversion HELP
- I need help in regards to a battery relocation....please!
- Alternator? I cant figure it out.
- freshly assembled short block question
- question about ls 81mm to 82mm
- eg/dc chasis
- radiator hose?
- belt part number
- Oil Pressure Drop?? have searched and checked
- Which inline fuel filter to get?
- REVERSE LIGHTS PROBLEM
- brian crower stage 3's
- question about wat my motor is doin
- Car bogs powering through corners
- no compression
- h22 swap in civic overheating???
- NEED HELP!!! CANT DO WITHOUT YOU GUYS!!!
- GF left windows down before big rain
- Heater question for a 91' CRX HF
- looking to buy this "non working" honda, but have some questions.
- Help! Smoke coming from my Intake!
- b18a1 tuning
- P30 burned ECU
- distributor base timing on h22???
- no spark no start.....
- RPM Jumping erratically - g1TEG
- 'Heat Wrap' on part of radiator hose?
- suggestions on the ACT stage 2, 6 puck clutch
- Relay delay. Anyone know how to delay a circuit 1 second. Electronics people look at the question th
- LS VTEC Head Gasket issues.
- Side effects of driving with hand brake on?
- Clutch problems
- Tranny fluid?
- b20 rod bearings..need help asap
- stock ecu with vafc2
- Deciding on which Quick Release and Hub combination
- Transmission / Clutch Problem. HELP!
- msd ignition trouble?
- coil pack keep burning up!
- B16 Help
- max compression ratio on 87 octane? 89?
- iacv?
- Could it be the throw-out bearing??
- Catch Can/PCV Setup for MAF based system (LS1)
- where is this leak coming from? picture inside
- help with h22a
- Anyone have some kind of setup to get air into the car for those without AC?
- Ls vtec trouble plz help
- cell 43
- Does the new FD2-R 5.06 final drive fit the 02-04 rsx-s tranny's
- bad distributor or not, wont start $5 paypaled to who ever figures it out
- QUESTION: transmission
- How to remove oil from combustion chamber?!
- Question about ARP head stud install
- cable b18a ys1
- Broken axle, sparks shooting from flywheel cover, need input
- ECU wiring
- lsvtec ecu question
- ARP headstuds causing Oil leakage????
- anyone know how to wire cornering/ intersection lights??? (DC)
- Noise in engine? LS-Vtec
- K20A gearbox issue
- Tach help
- b16a - oil pump resealing
- ring gap issues on stock bore GSR
- Phantom Grip...
- Intake Manifold Fitment b16a in 1g CRX (skunk2 vs. aebs vs. victor x)
- Gear selector button
- OEM Headgaskets: Ishino vs Nippon Leakless
- Question: GSR Brake Swap
- Differences between B16, GSR and Type R OEM Dampers?
- is too much too bad
- Few Loose Plugs and Tach Issue - Recent Swaps - Help Appreciated
- High Comp. Hesitates. No Power. Runs hot. Dies Up Top
- boost activated switch
- how to adjust cam gears???
- rebuild problems
- Compression during break-in
- rhd clip
- Timing Belt not tensioning???
- Painting engine/transmission??
- borken ring scrached cylinder
- LS/b16 trans issue
- BDL rail and aeromotive regulator?
- Price to expect to get hone, piston rings and bearings done on a motor?
- Honda Transmission Fluid / or will other do fine
- E3 spark plugs?
- i'm stumped on an h23 timing belt
- clutch help
- DYI: Protect your CF hood with Automotive Insulation
- Intake: Comptech or Injen
- Question on fuel injector cleaners
- cam holder bolt broke off
- b16 tranny question
- Coolant odor from air conditioner?
- worn journal pics
- Increase the stroke of an engine?
- O2 Theory, hot manifold vs. cold heated vs non heated O2 sensors
- H22 in a wagovan?? has it been done and what needed to be done???
- What cams for a nitrous motor??
- Porting intake on a "vertical ridge"
- boost problems??????
- ecu pin outs
- Wideband question
- vtech not as strong as it was before........type r swap
- differential stamp number
- Replaced head on h23, Now it wont run. Help
- Front drivers side brake creak when releasing pedal pressure?
- Aluminum cleaning
- Oil Cooler Questions...
- HELP h2d ef
- Honda City EX 1998-2003 D13B4 Engine have knock sensor?
- Dual Point Gasket Question..
- cam gears
- Specifically which LS tranny is the strongest, toughtest, best, etc?
- What does Circuit Worx Spool do?
- Help with car puchase!
- Engine Rebuilt - Problems With Idle/Stalling
- i can hear my fuel pump when I start my crx but there no fuel.
- Dimming aftermarket gauges anyone figure this out ??
- A Frame braces on EK chassis who is using them and what brand
- Cannot get more than 6 degrees advanced ignition timing on jdm b20b swap
- Autometer oil pressure gauge acting funny. Help me figure this one out! Please!
- standard hubs and dss 3.9 axles
- first time porting a turbo... w/ pics n q's
- Toyota parts websites?
- mustang harmonic dampener pulley on honda engine.
- High Idle after swapping heads?
- Solutions for engine pinging/detonation?
- Tuned honda ecu in my car.....i have never seen or heard of the company Help!
- Help!!! 99 prelude only starts with OBDII scantool plugged in??!!??
- Keep Braking 2nd gear on my itr tranny....is there an stronger option to fix my problem?
- Need help
- i have a couple questions about the jdm d15b
- h2b exhaust question
- question about wideband ?
- how do you keep the muffler looking good?
- 00si, hesitating, jerking, 6 different codes... give me some ideas please
- d16z6 runiin sluggish after it warms up
- Wheel Not Centering In Wheel Well. Need Help
- header help
- technical question about oil consumption.
- will a d-series thermostat work for a b-series?
- fluidampner race pulley, what belt?!
- Can I replace my stock plastic coolant reservoir with this...
- Does anyone have a diagram for wiring a b16a1 into a 92 hatch?Also resister box wiring.
- SPEC Clutch 3+
- help difference between SOHC and DOHC ZC transmissions
- HELP! Spark Plug Problem!!!!
