View Full Version : Tech / Misc
- If i get lowering springs, do i need new shocks?
- serious problem after tranny fluid swap
- V6 accord motor in CR-V?
- New motor old ecu what ecu should I get
- weird question, but need some serious answers!
- Car not driving straight...
- is there a diff in auto and 5speed wire harnees on ls???????
- injector size?
- which way does exhaust manifold gasket go?
- car shuddering.. HELP!
- Bigger injectors... Need advice on resistor box for ITR head
- Any know a good site with step by step instructions for relocating battery to Trunk?
- Running b18c(jdm) On obd0 PR3 Electronics With Mugen Chipping
- Torque Specs....?
- Adding oil every week!!!
- making a homemade exhaust. what mandrel bends are needed for eg coupe?
- BG44K -- Anyone ever used this Carbon cleanser?
- WS Exhaust..Has anyone changed it for another exhaust?
- ECU Question
- Can I drive 200 miles to the dyno on my untuned B18C5 w/ Toda C's safely?
- not honda but need help for trd jdm 3s-gte mr2 motor tech
- Tranny wont come off... help!!!11
- Brakes, I have a few questions.
- Wondering about my ecu in VTEC
- Radiator Cap for PWR radiator?
- can u mount a magnaflow offset/center muffler backwards??? will it still work the same?
- integra eating up coolant.
- Very Quick question...how much MTF do I put in my tranny???
- Need help identifying this ECU
- Main relay: What color is fuel pump wire?
- Shifter is EVERYWHERE.... help needed
- Is my exhaust too big
- so simple it's stupid.......
- Can someone break down an emissions test for me?
- chipped PR3 to run ITR specs
- Axle shaft removal
- having problems...
- black box hose help?? 95 GSR
- what kind of tools do u guys use? snap-on, matco etc.
- Help! Clock, Dash, Radio Problem
- Can't downshift to 3rd
- pics: apexi turbo timer install (old one)
- Help:Irrattic at 1000-2000 RPM
- are these type s cams?
- acl bearing question
- Do you guys retorque wheel lugs after 50 miles of installing wheel(s)?
- 1st Ge Apex'i RSM...who has it? How do you hook it up? English instructions?
- I went from a obd2 to obd1 p13, problems
- how to store crank?
- camshaft
- Need gas scooter help it's a GSX 43/42cc. When it first starts a bunch of rattling/ highpitch noises
- Need chip recommendations....
- Cable Reel replacement
- Can anybody give me info on oversizing head studs? (i.e. drilling and tapping stock holes bigger an
- Black soot/ash on the rear bumper
- need help.. 5 lug conversion...
- car loses vacume and fluxuates idle at 2k rpm!!help!!
- Cryo air intake? (cry02)
- Need some advice on what to do, kinda long!
- New built motor just put in.... tranny problems... HELP!!
- vtec controller for 98 ex coupe..
- CEL Issues.... No code though.
- need specs on stock d16a6
- proform shift light problems???
- GSR tranny problem....
- !Need help with smoking engine!
- Crv oil Pump same as ITR and GSR, but for what year??
- The best tech sheet ever!
- **dyno the R not sure if i got good hp with my mods what ya think**
- can a chipped ecu be rechipped?
- Tire Check: 13" VX Rims
- OBD-2 to OBD-1 Wiring Conversion Schmantic
- Low Idle RPM and Low Oil Pressure - A Problem?
- Failed Emissions: OS2 Sensor ? ...and related things to pass.
- Clutch problem
- removing butterfly plate in GSR intake...
- 99-00Si vs 94-01GSR brake sizes
- my clutch is sticking half way up on my 94 accord
- NGK oem spark plugs, $22/ea from Acura?
- 86 CRX Si Bottom end with 92 CX top end...
- Tranny gears question Tech challenge
- cel 22 what causes it?
- shock question??
- injector resistor for sohc vtec engine question
- black box hose?? 95 Integra
- Stupid question, but is it possible to nitrous inject a carbureted engine?
- 5 feet of flames are coming out of the exhaust (possibly bent an exhaust valve?)
- spark problem
- Mustang Dyno ?'s
- excessive engine vibration pulling through 3rd and 4th gear
- MAP Sensor V-AFC Problem, Please Help!
- Surging H22
- Need help with tranny....!
- 99-00 climate control in a 96-98
- good place to get tim. belt/w.p. done in MN??
- Can't keep car running!!! please help
- Would Cv boot repair kit for 97 Civic fit 95 civic??
- Full size radiator
- Check engine lights stays on
- ES Oval Muffler Dimensions?
- Oil overfill?
- Mini-me question
- how much does a ITR oil pump cost??
- Any Ever Tried This??? Is it Worth it
- CEL 21 on a DX?? CEL/SRS blinking??
- leakdown test results, your opinion please
- Major problem after converting automatic to manual
- Distributor Problem w/ car not staying running.
- wiring help!!!
- need help, can a bad alternator affect idle?
- ECU Question?
- abs problem by honda accord aerodeck 2.0i SE (94)
- Horn not working and SRS light on?
- Weird vibration between 40 and 50 mph :crook:
- B16A2 Intake Manifold HELP!!!!
- B20 questions and problems
- A/F Meter Install, ECU or O2 Sensor,Which is more accurate?
- vtec question
- Assuming your valves aren't bent....
- grinds because of short shifter?
- d series trannys
- trannys
- b18c bog problem l ~link with video inside!
- Just installed Blitz turbo timer and............
- venom injector??
- Compression, could use some clearing up
- Water in Engine uh OH!!
- wut all will i need to do with the b18a????? help asap please
- need help with fan switch from oil block to new block
- Wierd stuff with car(distributor prob/other)need answers.long
- Ok, Everyone please help. Smog on swap. Important.
- Battery suddenly losing charge overnight
- Yokohama Parada's Directional?
- Swapping in a 92 B18A in my 92 CX a few ?'s
- OBD1 to NON OBD conversion???
- Where can I buy *just* front brake pad carriers?
- Skunk2 GSR IM Problem
- Desperate for a header!!
- b16a cams in a b18a??
- Best Header for Nitrous?
- Need a good tuner in Sac,CA area?
- CTR Cams in a B16?
- headgasket or mill
- Toda B low HP ?
- Rattling coming from exhaust?
- clunking in the front suspension
- weird knocking noise???
- Car Acting Crazy! Need Help ASAP! ! !
- EK > DC2 Exhaust? Will it fit! Help! Easy Question!
- Question about loose Valvetrain
- Code 91 solution...
- Is the year of a head stamped onto the head itself???
- info on b18c1 dropped in a 90 teg
- OBD1 & OBD 2 dohc vtec distributor different?
- 96 tranny
- name that connector!!!
- for sale
- Spoon N1 exhaust?
- Horrible Exhuast HELP!!!!!!!!!!
- Frankenstein a transmission?
- what should I blame my blown out final drive on?
- JUST WONDERING?
- piston clearance
- camber question?
- i failed e-check
- Silly question...? Turbo + brake booster
- Brake Light On In Dash While Braking -- Prelude 5 Gen.
- ACT clutch question????????
- Header Wrap on Your Catalyst?
- how much should a resonator pipe (w/ res) run me?
- Timing
- B16B Civic Type R
- Code 43 persists
- Help With 97EX
- need a dyno in the pa area
- Oil burning continues...
- d16 9,000 red line? can it be easily acheived???
- what year GSR is this ECU from???
- A/C not blowing any air?? help please
- G60 rotor with ITR caliper will it work i have the fast brakes centering ring???
- DX/ VTEC SET UP need help!
- Looking for a English Manual for V-AFC 2
- jdm 97 itr axles in 96 gsr?
- what is the blue sensor plug on the y8?
- tach doesn't work after the swap
- anyone ever killed an O2 sensor this bad?
- What parts from a b20 block can be swapped to a b16 block?
- boring out the throttle body
- mushy brakes after new pads and rotor - corolla
- Car died on highway, RPM drop to 0
- VSS woes...
- 12.9 inch wilwood brakes
- Axle stuck on B16
- Racing Hart C4's
- Running with no gas
- jumpy tach after new distributer HELP!
- Are o2 sensors universal?
- vtec intake valves (33mm) on a ls head (31mm) possible
- How often does the oil pump go bad? VTEC related
- CTR Pistons with TODA B's
- Please help me with my Axels (many pictures) plus a pic of my new exhaust!
- Car Cranks but No Start (Has Spark/Fuel)
- how do you fix code 14?
- weird idle? IACV
- Installing a dfuser
- lug nuts
- Clock and Radio keeps resetting?
- turbo h22 in a accord wagon having problems with redline only hitting 6500.
- s-t front sway bar help
- What is Code 1 or 11 on a jdm p72?
- testing a relay to see if it is functioning correctly
- Shift fork question???
- What are these? what should they plug into?
- turning a honda crank?
- Ricky's Auto Center front clips...
- AFR Tuning
- HELP!!! leaking oil or burnin' oil???
- is it possible to replace Ignitor on integs?
- can you use itr valvesprings on a LS head?
- Tein Install Help please!
- Where can I get my car tuned at in Orange County
- SMS Phone number and/or website?...header performance?
- Gen 5 altezzas?
- I'm a certified honda mechanic.
- Carb tuning
- Spark plugs ITR vs. GSR
- black box under the intake...h22
- whats a b20 weigh?
- B&M Trick Shift! Does it work?
- Clutch + flywheel?
- Has anyone here gone to UTI in California?
- Ding in Dc 4-2-1 headers
- dual valve springs
- Reusing pistons rings? (New pistons to up C.R.)
- From obd2 - obd1
- Oil and Fuel stains on the driveway/street...
- which ss brake line kit for my combo?
- Will my ECU work???
- JRSC JDM B16-Civic vs. JRSC B18C1 Integra 11:30 AM 8/25/2003
- Hone before or after hot tank?
- Clicking in front end.
- tps wanted / any way to modify?
- Rear tires?
- Which is the better choice???
- PM6 convert to P28, HELP ME!
- what intakes will fit a ITR intake manifold?
- use wat kinda of gear oil that is the best
- Civic SI Brake question (quick)
- Idle problems.
- I installed my APexi RSM today
