View Full Version : Tech / Misc
- Help..Turn Signals lights wont work and full voltage on motor.
- Will a TCM code (CEL) disable vtec?
- OBDII F22B1 Turbo Accord Wagon won't fire!! Help
- Will a Y8 work in civic with Y7?
- need help with a honda civic hatch dx 1990 with a si v-tec engin
- How can I fix my aluminum rad?
- Air/Fuel gauge not working!!!!!!!! Help!!!???!!!!
- Buddy Club Spec III Exhaust
- self tuning
- question about obd2b-obd1 harness on 99 ex
- Setting Ignition Timing
- What Timing Covers are these.
- D15B VTEC OIL PAN QUESTION...
- ITR vs. OBD1 TD-44U (B16a) dizzy cap compatibility?
- which cams are these?
- clutch bleeding issues
- gsr head on ls block
- Voltage Problem
- Driver side axle problem help!!!!!
- v-tech?
- race fuel after tune ?
- valve cleaning
- Mysterious Problem
- need help to id 2 sets of camshafts
- Blowing blue smoke.
- Having engine problems PLEASE HELP!!! 98 ITR
- Why does everyone hate DC headers?
- CEL after install of Greddy Header.
- need smog "help"
- A Few questions???
- iac wont work
- H22 idle problem, *help please*
- Tuning questions
- A couple issues: idle, TPS, wideband
- fixing spun bearing w/ engine in the car .. thrust washer fell out .. how do i get it back in?
- H22 cut's out. Please help
- Kent cams worth it??
- 90 civic exhaust specs
- Reputable machine shop in NY?
- Help a noob out please!! Engine swap questions
- HELP a/c not working!!!
- B18C1 - rattle noise from valvetrain, sticky rocker arms HELP!
- Signal lights stopped working...
- Home fuel system cleaning.
- AMS MOTOR OIL??????
- Oversize head gaskets
- What size tap for GSR intake threads?
- can i use a JDM ecu in my EDM B16A2?
- JDM GSR ECU Code 41 issues??? can u figure it out??
- edelbrock throttle body
- starting problem: pgm fi relay?
- CRX help w/ correct ecu and wiring
- HELP!!!! B16a head on built b18c1 block
- B18c CRX cranks but will not start
- aluminum vs. titanium
- low position seat rail
- Why am I getting CEL code #1?
- LS VTEC TIMING BELT Question Mezier water pump.....
- D16Y7: Number of Problems | 4 Bad Codes | Possibly Electric
- D17a1 Questions
- JDM GSR ECU reverse plolarity IAB question????
- b18b1 crank pulley
- Prelude won't start after sitting
- help please
- Rexx's Fuel mileage experiment.
- Buying another mans idea of a wiring job.
- Car if being dumb
- New modified crank pully!
- what engine do i have?
- Skunk2 Pro 1 cams
- oil light on
- piston install
- fulids in clutch mater cyclinder
- euroR H22, JDM P30 ECU: timing problem
- changing head gasket for stock b20b, need help!!
- CEL light
- B16 Blox IM/BBK TB questions
- need help with obd2 and obd1 problems
- My city Mile Per Gallon increased by 5mpg with one change
- Torque Wrench - best type - beam vs click vs digital
- Engine knock at idle to 1200 rpms, any ideas?
- jdm dohc f22b install
- Setting timing..
- why is my oil leaking?
- will a type r crank with gsr pistons and rods work together in a ls block
- poor compression readings help
- fresh build started, idled, then died
- Need help very strange problem.
- Missing feels very rich and bogged down.
- *SEARCHED NO LUCK* ps conversion in 92 civic
- oil consumption during break in
- Intermittent radiator fan; causing intermittent overheating.
- dynolicous iphone/itouch application
- does mugen horn button fit in a nardi classic steering wheel?
- replacement for skunk2 throttle body
- Hydro carbon
- please no one can
- Question about battery. noob question
- Socketed hondata p28 ecu and map sensor code on two different cars, Whats up?
- audi tt 1.8
- Crower NonVtec cams
- What's a good header with a 2.25"/60mm collector?
- My axle "popped" out making a turn, and the car dropped 2"....
- toyota help needed, 95 previa, egr insufficient flow wont go away,
- Lost engine power while driving, electronics still works
- Battery not charging -- Battery and Alternator test good individually out of car
- -comet cleanser-
- compression test
- Cylinder head cam holder plate dowels
- Higher my rev??
- Battery Life Without Alternator....
- civic start problem
- Lude not running right after removing msd products and installing stock dizzy & coil
- Cometic HG, KMS Block Gaurd, holes not lining up. Take a look! (pics)
- HELP WITH VTEC
- cable b16 counter shaft bearing?
- Oil Pressure is dropping - help
- LS VTEC BUILD HELP!
- Safe to Run Water in Gas Tank? You Decide
- Autometer Gauge Wire Gauge
- FUEL INJECTOR BASIC QUESTIONS, HELP
- URGENT is it leaking or not?
- Wiring oh my! (GSR Cluster->CRX)
- B18 build Help!
- Please Read Idle and Lights Problem
- Wire tucking 101
- Motor Help
- h22a conversion to ek3 4 door (black smoke)
- question on code #43 plz
- 87 Wagon COILOVERS help!
- try to fix my vtec issue and come out with more problems... ahhhhf
- Help! what cam for turbo d16a6? *I've searched*
- wont rev past 6800
- Car startin f***in up today Need Help ASAP
- Help with Leakdown results
- black plugs/to rich?...poopballs
- Key Fob for 1999 Honda Accord LX
- Car has trouble starting..but starts eventually... Suspected Gas Issue.
- Opinions/Help on my build please...
- leaking oil from dipstick plug?
- Please Help ASAP... My clutch wont fully engage...
- B20 build question
- 89 civic not starting
- OIL PSI LIGHT!! SPUN ROD BEARING!! HELP!!
- Anyone replace ENTIRE wire harness? (OBD0 & OBD1 cars)
- how do you know if your pads are glazed?
- flywheel hotspots?
- skunk2 valves
- What can you do if a shop isn't installing the parts you paid for?
- how to disassemble the head on a b18c
- Clearance issuse with crank and thrust washers
- Idle woes been fighting this for 6 weeks (Looking for serious input)
- WILL D SERIES STOCK PRESURE REGULATER WORK ON B SERIES OR GSR??
- vtec problem!!! how do i wire it to a switch please help!!!!!!!!
- Smoke on start up,sometimes??
- Greddy Sus
- anyone have stock hp#'s on LS-LSvtec-GSR
- LSvtec build vs b18b
- litest Flywheel, clutch disk, and PP for B and D series.
- need help getting axle out
- compression check help
- H M stamp under engine code on block
- Timing Cover Question
- Coolant leaking at hose end - new hose needed?
- dizzy help pls
- 96 prelude overheating issues
- car died at idle, doesn't restart, honda dealership cannot figure it out
- Hydro Trans Better??
- Help with wires 4 VDO gauges?
- hg leak of coolent help !!!!!!
- NON-honda question ( FORD GURUS PLEASE KICK IN !! )
- Help removing roll pin from shifter rod
- High Oil Pressure
- VTEC not working on JDM b18c turbo tuned on crome p28 ecu... help
- Check Engine Light is on, and SRS light is flashing
- temp gauge problem. please help
- SO CAL Neptune help
- 84.5mm on a b20 block. makes the sleeves too weak?
- hypermiling in auto? (94 Accord LX)
- itr oil cooler
- please read my plugs
- vtec not engaging.
- Which Injectors for Turbo Setup????
- Does a valve lash adjustment increase low end/top end power? Your thoughts please
- hey quick ?
- need help wit engine
- what u think
- Skunk2 manifold issue
- Pistons Questions?????
- Could not having vtec in my ecu thro a check engine light?
- control arm
- Civic exhaust and del sol exhaust
- Water Temperature Gauge
- bumper pole
- Doin full exhaust gotta check engine light any thoughts?
- Cold IDLE help!!!!
- starter barely turns
- quick question in need of quick answer
- 97 Integra Type R vibration
- Yup, Probably seriously [freak]ed Up My Engine Today
- slight scratches in cyl walls, ok to reuse block or no?
- Building my first motor, need some help!
- s2a8 Acura tranny
- Wouldnt Stop overheating
- Difference Between Z6 & Y5 Vtec Head?
- need help with piston ring gap on 81.5 b16
- Transmission Question For The Major Built Engines.
- Speedometer not working.... Help!!!!!
- hp formula basic question
- PRW Fluid Dampers
- 1998 Civic hatch DX: d16y7 auto SWAPED to d16y7 manual: has P1509
- bad dizzy???
- when u spun rod bearing question
- Need Help on info for swap
- GSR Vtec Problem
- what is regarded as a light weight piston?
- Timing belt is too tight...Searched.
- b20 vtec consertion
- 83mm ls bottom end w/ a b20 head????
- LS/VTEC Popping Exhaust/Bad Acceleration
- What wrong? Trying to lock vtec with compressor
- Oil pan leak or Rear Main Seal issue
- which ecu would be best?!?!
- What is the real horsepower of an engine?
- swapping b16/ls diff in gsr tranny
- Valve Seal Question
- 02 sensor disconnected but no cel?
- Running an engine on a test stand.....Engine builders help!
- chipped ecu how to get it out?
- i have never seen anything like this LOOK
- 96 integra auto to manual wiring question
- Very dissapointing h22 dyno WTF!!!
- blue devil actually works/ blown head
- H2b distributor help!
- VSS issue needs resolution!
- I need help o2 problem
- info on type r n1 crank pulley help
- ITR LSD into LS Tranny - On the right track?
- B16A With S80 will not go into gear
- ok to reuse rod bearings? crankshaft from one GSR motor to another code question.
- Fuel pressure regulator
- nordskog gauges
- transmission gearing question.
- do i need a tune or can i just get a reflash
- ls vtec wierd noise?????
- trans swap into 96 dx, no speedo??
- problems with new swap, please give me some advice! I'm stumped!
- K20 block and K24 head
- changing ATF on 2005 Honda Odyssey
