View Full Version : Tech / Misc
- SX fuel pressure regulator
- tranny question
- Ultimate Tranny...
- light still on
- will low crank amp yield a low compression number
- Need help. anybody know the part number to this sensor pic inside.
- Help w/Skunk pro1 cams
- TPS or Vacuum Leak?
- Problem with my brake at low speed, please help!
- ac compressor rescueABLE?
- b16a2 obd2 to obd1 conversion questions..
- 96 accord 5spd tranny
- Lower radiator hose still cold, overheating@!!!
- Grounding Kit - Make or Buy ??
- Grounding Kit - Make or Buy?
- NEED HELP, PLEASE POST PIC FOR L OR T BRACKET FOR EG
- Need help w/B16A OBD 0 wont start just turn
- Tunning Noob ?
- Limits of the stock block?
- Honda civic + mugen exaust system
- Car wont start.... please help
- Taking out B16 J1 tranny
- cerc
- d to b series tranny questions
- Quiet Fuel Pump?? 190 VS 255??
- ASAP!!!
- prelude fuel rail
- Help! GSR oil sandwich cooler in a B18b block
- HELP - knocking noise.. can you tell me what it is?
- itr exhaust diameter
- type r clutch and flywheel
- Batronix question. which one to go with?
- can i use stock bore pistons again?
- Help Please Asap, Vtec Wiring.
- Project: B18B-T swap
- B series valve covers
- is this a oversized stock ls b18a/b piston? says pr4 "0.8"
- b18c1 intake mani
- help with buddy club spec 2
- LSVTEC Headgasket: I left all the metal rings in, likely to be the cause of my problems?
- not going into gear
- b18 swap into 89 civic
- GSR Brake Swap Into Eg Master Cylinder Question
- Q. about ECU codes
- where to buy a remanufactured Auto Tranny?
- GSR axles with a Type R transmission?
- help me out somebody
- nitrous + high compression, i need opinions
- where to buy the arp moly lube tubs with the applicator brush??
- UBERDATA or CROME tuners in san diego area? I need help please...
- WHY THE EFF IS MY CAR BLOWING OUT WHITE SMOKe!!!!!!
- Any issues with this PCV setup?
- Engine Code: P10133B B1 S1 What does it mean?
- What fuel pump to use???
- Rebuilding jdm y1 tranny what sleeve sets to order from honda
- engines turn backwards?
- h22 idles high?
- Which distributor /eg with b16jdm head gsr jdm block?
- Will heat treating my stock ring and pinion gear help?
- Apex power fc and coil packs????
- ~b20v help~
- Is it possible to remove rocker shafts with the head installed in the car?
- ls hydro tranny with 99 si internals???
- New Clutch, Bearing, Flywheel, Shifter. Tried Stuff but Still Hard to Shift. Any Ideas?
- H22 a4 compression test results...
- I need an expert...
- B16A Intake Manifold on B18C GSR
- Spoon caliper install on 93 gsr help
- Power Steering bracket/mount top and bottom for LS/VTEC
- rear caliper emergency brake disconnect? 1989
- b16 head on a b18 block??
- H22A5
- timing belt tension
- Honda Emblem Question
- power fc or aem ems
- Whats this gauge for? (OEM HONDA)
- Backpressure
- b18a1 swap into hatch where b16 (single cam Zc) used to be?
- interchangeable main relays?
- need a mechanic in this are???
- EG6 Need Wire Diagram for JDM Climate Control
- what do the balance shafts do?
- oem head gasket OS bore
- Replaced distributor, have spark now but won't stay running.
- B-Series Header Questions...
- where to buy pivot racing shift lights?
- odb1 ef? question
- b16 tranny lockedup
- best head gasket
- YS1 tranny
- JDM swap help
- Cylinder Brace
- Ls/vtec
- itr swap info needed
- What EXACTLY Do I Need To Look For?
- S80 = What Tranny? I'm trying to order the correct OBX LSD
- does anyone now how to remove the grille on a honda accord
- Strange 3 bar mapsensor problem
- Are these Skunk2 Retainers?
- Cracked Pintle cap on injector?
- epfi and mfi swap
- How to tell if a clutch is good or not?
- Help with piston selection!
- brake disc
- OEM codes returning after new trans install
- Pulled off the head, how do my pistons look?
- turbo question
- Ignition control with carburators?
- Car wont start or shut off
- exhaust question
- Race Seat Question: Gen1 CRX
- Hondabond. Anybody use it?
- **Help with Clutch ID
- "Motorsport Shifters" for B-series transmissions?
- throttle body/tps sensor !!?? WTF is wrong....help
- Noob Question??? Need Help!!!!
- Machine Shops in orange county ca???
- No one has been able to diagnose this problem......please help!!!
- LS or b16 tranny for high boost?
- Thread patter
- need valve clearance for a sohc...
- ls vtec problems
- gsr w/ b16 tranny?
- Got a used fuel rail, What do I need to get it goin? Fittings?
- right hand drive legallity
- Built motor, 1st start-up ended with a bad 'incident'
- Nissan exa help. ( no flamming )
- Question on buying a motor piece by piece...
- Buying Built Car - Need advice
- Timing belt question Should I or shouldn't I???
- Exhaust Piping sizes.
- Mini Me help.
- Another Idle problem, allready searched
- Chipmunk in my distributor?
- d series won't downshift into 3rd
- ECU/VAFC Problem???
- vtec engine balancing
- Timing Cover and Oil pump Question. b16 and gsr
- is this true?
- Trans trouble
- Distributor question
- help, E manage blue wiring 99-Si b16a2
- School Project 4wd system
- Can I use a VAFC II with a chipped P28?
- jdm type r tranny problem/wiring too
- How to hall effect sensor (help)
- b20/LS eagle RODS difference q
- timing too advaced, high idle
- ef hatch swap to mfi intake
- Crower Cams!!
- Help I.D. these injectors??
- JDM d15d
- fuel problem?
- Need help tried search difference between 99 b16 valve springs
- b series clutch preference
- not honda related but could use honda techs help...
- H22 Integra, What Axles?
- How far should i drive to get tunned?
- EF Full Hydro Conversion Help
- Big Horse Power
- lsvtec-knock sensor-mounting location
- B16a cams in GSR head LS/vtec
- Major headlight problem
- Code 21 and 22 HELP!!! searched!!!
- Where do I get these connectors?
- Tuning s100
- Fuel Rails?
- Accord injector ?
- Help to pick up cam-shafts for TWM ITBs with my specs...
- LSV/b20v Conversion kit Q
- O2 sensor lifespan
- ECU and engine conversion questions
- Where to find a 1.4k ohm surface mount resistor ?
- Dented Header Repair?
- p28 ecu automatic to manual reprogram?
- Pinched Header or Oil Pickup?
- Weird compression test results? Maybe timing belt off?
- what cam gears is good???
- anyone using the roller rocker system on a street car?
- Trouble removing rear brake rotors...
- B16/B18 mix swap. clutch ?'s
- Just installed new TPS, and have a quick question
- Quick Question
- Need cam cap and head stud removal sequence for GSR.
- NEED SOME HELP PLS... TRANNY PROB
- Can anyone identify these bolts?
- Weird Transmission Problem
- **********NEED HELP, WHAT KINd ARE THESE WHEELS***********
- Value of This Longblock.
- non ac radiator with ac ok?
- 3in Civic Exhaust- Guy with Shotgun
- J series engine
- So I guess my clutch is done, Video
- engine problem
- Can someone give me the torque spec on this bolt (5th gen Accord)?
- need some help please!
- D17A2 in a 97 civic coupe
- tranny swap ..now hard to get in 1/3/5
- Which B series header should I buy? Help, input needed!!!
- crx B18 jump timing problem?!?
- Accord shifting issues
- GSR tranny squeaking? HELP!
- Write up on how to replace syncro's?
- need civic info
- burning a quart of oil in 30 miles.....
- Engine swap help
- Oxygen sensor thread.
- Hondata s300 help
- HeLp Please on NiTrous ???'s for 99 Si
- removing ect sender, it broke! help please
- eg rear disc conv.(searched)
- vtec controller
- b16
- What to use to clean oil off of motor, trying to find source of leak.
- Need help please. OBd1 ecu problems!
- VAFC on Mini-Me questions?!
- b20z sleaves
- problem with wideband and 02 sensors
- Are IAC valves interchangeable between series?
- stalling problem
- Header - Help
- wiring questions for the GURU's only!
- A few Hondata s200 questions!!
- Would hondata be a waste for my setup?
- jdm~b16 questions
- Question about third gear grinds.
- are my bearings bad??acl's
- Chipping an Automatic ECU
- Civic and Integra ecu Harness?
- Low compression numbers (blown piston rings or valve seals?)
- honda 1.8 vtec colant probs not head gasket helppppp
- TB bypass kit MAJOR HP GAINS!!!
- help alarm install
- Registering a salvaged title.
- Honda says DO NOT FLUSH TRANSMISSION???
- what oil to use??
- honda b20z, CR-V, ecu help
- Overheating problems help!!!
- Oddessy HELP OBD2 genusies???????
- d16 turbo problem
- Transmission or clutch problem?
- tune chrome on the fly
- Gsr wiring info 2 ek
- abs lights up
- where can I get a torque plate for my h23?
- Is this cam okay?
- Can't Figure It Out!
- Help on Determining what transmission I have
- 6speed b series rant...
- Help...1990 crx temp guage and gas guage.
