View Full Version : Tech / Misc
- hypertech programmer for my truck????
- DOHC ZC Help!!!!
- Throttle body spacer (OBX)
- Nology Wires?
- Question on a 92-93 YS1 GSR Tranny .....
- Buddy Club Dampers: Integra Type R: What are these!?
- tailights dont work on eg6
- ls vtec with os ctr's?
- Wheelspin when vtec engages?
- Valve clearance info needed!!
- Vacuum pump on PCV?
- Why won't my h22 start?
- F22 on a z6 tranny planted in a del sol
- Type-R , clutch not engaging
- Do you have to switch dizzy when going from obd0 to obd1 on b16a?
- pump primes, MR clicks, no CEL's, getting spark but it doesn't start????
- b16a2 and b18c distributor caps interchangeable??
- **HELP** axle/tranny question
- Injector/Resistor box problem WTF???
- Venom Intake Manifold on D16Y8?
- turning on headlights idle drops below 500 rpm need help????
- Accord Overheating
- Accord engine swap HELP!
- Golden Eagle Manifold Injector Seal Problem, Venom rail
- where should your rpms be when starting up motor (b18c1)
- Torque Specs on ARP Head Studs?
- Rack and Pinion for 90 hatchback
- unorthondox pulleys for first gen B16A?
- Not sure how to fix engine codes
- Cranking Problems
- Idle surge, tryed everything...HELP!!!!!!!!
- broken bolt....
- help with typical issues with a 99-2000 civic d16y8 ?
- i need help on the asap
- tilton Cerametallic clutch or exedy Cerametallic twin clutch?
- Timing Belt help
- i need info on devcon
- msd blaster coil ss
- dyno tunning my car
- sbcid boost controller help!
- symptoms of scratched cylinders
- b16a in eg civic, Vtec question
- Not sure what engine and trans I have, trying to get specs to sell.
- " minnie me " question...Need help
- OBD 0 Dizzy to 89 CRX SI ECU
- d16 tb on b16 intake?
- NO CEL
- Fuel Injectors Throwing Code 16?
- crank pully bolt broken. need help asap to get out
- Ls Roller rockers?? HELP!!
- quick answer please. mugen radiator cap
- How much "play" should the throttle cable have?
- help! i need helms for 99 si
- Intake Manifold and Throttle Body Diameters
- need help finding codes
- Motor Oil Questions! ( i did search, dont be mad...)
- tps problem
- need suggestions on how to make ride height near perfect....
- jdm b16 sir2 vs jdm d15b turbo?
- homemade turbo....d series
- no fuel
- Chip for a B18C?
- wtb b16 motor mounts?
- 99 JDM ITR LSD on 94 Teg Si?
- What's the difference?
- Ground control/skunk2 coilovers on stock shocks??
- arp rod bolts vs. stock oem rod bolts...
- need some help...oil in my radiator
- Help! J's racing engine dampener
- Current problem/radiator fan won't kick on
- Replaced LCA bushings. Now one side of the car sits lower??
- Engine Codes
- automatic shift cable
- how do i test my fuel pump ?
- Tein Flex/SS or Cusco Comp S/Zero 1
- hg gone bad!
- HONDA MTF OR REDLINE
- fuel pump/ main relay problem?????please???
- stripped rotor screws
- cant seem to get aftermarket injectors to seat properly.
- What is the sensor next to the oil filter? B18a1
- 03 Accord making wirring noise...please help
- Emissions Failed Me. They Couldn't Connect to My ECU (ODBII)
- Donut gasket leaking problem.........
- K20 oil pan questions and dry sump....
- crx with b-series cv axles who makes best ones?
- Why convert to OBD1?
- brake swap help
- broken tranny
- Retarded timing
- Has any one ever seen this b16 ef mount before ? not sure who made it ..
- uberdata or stand alone
- what size NOS jet for single wet 65/75/80 shot
- Tranny noise.....noise record included
- Can not get past 3200 rpm....Code 6 and Code 9 Now what?
- what harmonic balancer for h22?
- itr rear caliper question.
- summit racing fuel pressure guages?
- vtec controler instaliation in teg
- injector question
- Do honda brake pads have asbestos in them?
- Gumout in crankcase brake booster line?
- REBUILT AND RUNNING PIG RICH
- Transmission case won't fit together
- what is b16
- how do i check trouble codes
- Emissions problem
- hyper ground systems?
- OBD 1 Dizzy to 89 CRX SI ECU
- HELP!! MY CLUTCH! Simple Yes or No question!
- Help with Gas Mileage problem...
- What should fuel pressure be at?
- itr outer and portflow inner springs rev limit ?
- simple question.
- Timing is off... Engine wont start please help me this is all I need to go tonight!
- b16 tranny w/ls 5th gear(gear ratio)
- What SHift Linkage to use for Bseries to EK?
- valve stem seal problem
- Fuel Rail
- want to convert a automatic 92 prelude.... is it worth it?
- new clutch: engagement getting higher?
- Integra 96 Rs Universal dash
- H22 EG CIVIC EGR CODE DISABLE ON P13 ECU.
- Vacuum leak....
- O2 sensor from Honda Insight the same as from a 92-95 civic VX?
- CEL 24?
- Quick Question: Oil Filter Size
- overheated now car surges when getting on the gas.
- Converting SOHC non vtec to SOHC Vtec
- less than 4 quarts of oil after draining, why??
- Romulator and Hondata RomEditor 2.5
- Special 2 ring section PISTON??
- Cam timing affecting ingition timing
- Will a d15b8 (1992 cx) distributor work on a 1996 d15b?
- OBD0 to OBD1 crx conversion.... dizzy and injector wiring questions!?!?!?!?!?!?!
- Brakes. What brakes?
- car fucked?????
- First B16a mod????
- d16y8 IM + b series throttle body + d16z6 = throwing codes??
- Powersteering pump whining noise does not come to an end!!!
- scratched block surface..anyone ever heard of filling with out getting it decked?
- Unorthodox Pulleys? what could I expect?
- torque spec
- k24 and the honda element
- Uberdata question.
- Should there be play in the a/c compressor pulley?
- snapped fuel rail stud... oops
- Guys in the US, I need your help Please!!!
- Primary O2 Sensor bad, need ideas!
- Oil Pan Gasket and Hondabond?
- Pump/Race Mix 91 and 100 octance...
- bad rings? any way to tell by looking at them?
- degree wheels?
- Engine swap plus mods on old-school Accord
- Buying Prelude soon, TECH questions
- Wiring harness!
- Which throttle cable to use?
- Brake Pedal fluctuating
- adjustin cam gears
- how to chip a JDM p72 ECU
- What is the difference between the O2 sensor before the cat, and the O2 sensor after the cat?
- Can i use B18 internals in a b16a ....
- Alternator, Vss, O2, Purge Tank fuse keeps blowing
- shifting trouble!!!!
- Blow by
- b16a2 with b18a oil pan
- Goldeneagle Fuel rail
- what benefit is there to the horizontal layout in the WRX motor?
- How do you do what you guys would call "advancing your timing" in an EJ1?
- Does anyone know where my IAT Sensor is is my 94 EJ1 Civic.
- 89-91 SI transmission work with 88 engine?
- ls/vtec
- VAFC owners
- tach
- swap help please.
- "Guarantee Void if Remover" ????
- BIGGER INJECTION & SPARK!!!
- for all u tranny gurus out there.......
- Vehicle Speed Sensor ECL
- Not just another strut bar question
- Clutch not engaging
- Too Lean or too Rich Air fuel ratio on a civic Type R engine?
- ls vs b16a1 injectors
- ECU Question
- Engine Swap Noise
- Need to know how to fix a thermostat
- I can't figure out what kind of distributor this is!
- H22 EG Civic...What axels do I use?
- True Or False???
- Autometer mechanical speedo in 4g civic
- anyone know bout k sport kontrol pro?
- High School Senior Project Help!
- main bearings, approx 40k miles should Ichange them ?
- new tires, no pull...need alignment?
- compressions affect on timing?
- Deburring combustion chambers????
- Be carefull changing oil on new CRVs.
- WHERE CAN I GET DYNO DONE!! NORTHERN CA
- pillow mounts
- how much compres doe a ls vtec have
- Car shakes, rear wheel bearing??
- Blown Motor B18c5 ITR
- Timing belt teeth stripped???
- Oil Pressure gauge ?????????
- Uberdata for an N/A Motor??
- Removing Crank Pulley
- CEL comes on when I let off the gas...
- b16 tranny leak...WTF!?
- idle and changing out distributor cap and rotor
- How to recharge the A/c system?
- vtec question
- Hondata Vs Uberdata
- MDS Digital SCI-plus wiring question
- intake makes noises
- Spring rates??
- FS ODB0 B18C DC Sports header 4-2-1
- What are the symptoms of 02 sensors going bad.
- WHAT IS THE RIGHT WAY TO INSTALL MOTOR MOUNT INSERTS?
- Mufflers size affect sound?
- sparkplug miss thread
- How hard is it to change a steering rack with hand tools?
- question about wiring harness
- Tranny prob q's
- Which Hondata intake manifold gasket?
- making a vtec ecu
- help
- Alternator Pulley question...
- Motor is acting up, pls help..
- How to tell if your o2 sensor is broken
- titon clutch adjustment???
- Need help with two step wiring to ac button...did a huge search
- fuel surge tank?
- PR3 O2 sensor problem (not typical problem)
- Honda test harness (Where can I buy one?)
- Pressure Plate
- valve spring compressor?
- Headgasket Question
- what is rear mail seal???
- clutch alignment tool?
- what ecu do i need for a ls in a crx?
- ecu not grounded...what would it affect
- quick help
- 97-2001 RL/Legend rear calipres same as rear ITR?
- 97 accord Code P0715::: input turbine speed sensor??? NEED HELP!!! Please
- stock fuel pressure setting>?
- Vafc II Wiring instructions
- Code 10 AIT.....what if its not hooked up
- Possible dumb/newb question.
- Real fast exhaust question
- Rough idle at start
