View Full Version : Tech / Misc
- Need help isolating an annoying rattle/noise....
- how easy is it to swap a vtec head to a sohc non vtec
- Quick (Factual) Final Drive Question
- How do you remove the LOWER BALL JOINT ??????????????
- MSD Soft Touch Rev Control - part# 8728 - need help installing
- need help asap
- What should i DO with The B20??
- Traction Bar binding issues!?
- ECU Question....
- b16/ef stock clutch cable too short
- RC 660, aem fuel rail, obd0 clips
- How does v-tec work?
- B series question
- Bent vavles
- Aftermarket shocks with stock springs?
- How to fix a code 10 ( IAT )
- Spring in my shift
- b16 smokes like a pig, blows oil, 2 heads, same problem, HELP!
- PLEASE help w/ front end problem on 95 hatch!!
- HELP!!!! my car is knocking very very Loud!!!! PLZ!!! HELP!
- compression results
- will or can KYB AGX work on an prelude sh????
- failed smog in cali
- O2 pin out on a p30 ecu need it fast ths
- vtec ?
- Air/Fuel ratio guage theory.
- What happens when your car gets over heated???
- Itr Jdm vs Itr Usdm Brakes/suspensions
- camber kit questions
- CRANE CAMS (STAGE 4)
- Wrist pin too tight....
- Reroute IAB vacuum to the manifold?
- Spring rates
- My Exhaust?
- Who makes.......
- GOOD hondata tuner on ohio area or surrounding states?
- NEED HELP FOR SCHOOL PROJECT
- b18c1 crank pulley
- brake pedal assembly question
- ls vtec question for all the lsvtec gurus
- V-AFC wiring without harness
- JDM vs. USDM B16A
- head bolts/throttle body gasket
- OBD2 Location of second O2 sensor
- NSX/Legend Caliper and big brakes on a 4 lug....parts info etc...
- please help
- D-series Header on dohc zc
- re-torquing head studs on an old engine
- vtec parts with a non vtec motor
- B18A Hi rev theory question
- idle @ 900/1300
- Tokico illuminas with Rancho dust boots
- Skunk2 Coilovers, whatelse they fit?? HELP
- Will a B16a1 crank bearing cap fit a B20?
- program for b20
- cam gears
- Tach Install on 02 SI?
- head question
- ?? would the suspension from my 00 si fit on a 92 cx????
- Software for tunning
- Easiest way to get a rubber valve stem out of a wheel?
- ls/vtec help?
- Question about a P72/Hondata
- H Series help
- Clutch sticking on cold mornings
- Which momo hub work for 94 integra?????
- overheating problem solved
- Map Project on Japanese Tracks
- JIC Coilover problem
- can I?
- expansion bottle
- anyone know a good bodyshop to roll fenders in phila area?
- for all you san diego heads
- Is it possible to over tighten the timing belt with auto tensoner?
- how do you track down a vacuum leak???
- resetting ECU other than pulling the battery plug?
- Thoughts on full throttle launch ECU's?
- auto tranny rebuild
- LS Tranny top speed?
- HELP!!PIN NUMBERS ON GSR ECU
- Serious Exhaust Questions, I hate all of them!!!
- help with h22 acura cl
- jb weld?
- z6 head
- what parts needed to complete a ex brake swap into a dx?
- obd-1 p30 ? chipped or not?
- JDM ITR tranny.. USDM synchros compatible?
- Kaaz LSD break-in question
- Chip burners, burn me one.........or hondata s100 cheap
- caliper/pads/brake lines - drag problem
- torque specs on b20 and ls
- 110k miles - - tune up??
- What is difference between b16a1 & B16a2
- Wrecked CRV
- looking for a respectable hondata tuners in san diego/escondido area?
- Map Sensor Code
- suspension issue!
- 4ht gen kyb agx ground control
- bogging at vtec
- noob questions.
- getting motor tuned
- Sudden deaths, I swapped out my distributor, but its happening again today.
- 600+cc go-kart?
- what does it take for 96-98 to 99-00 SI front conversion
- can i use stock fuel injectors with a aftermarket fuel pump?
- Block Mechining
- tokico 5 way adjustable shocks........help
- Synthetic Brake Fluid - Syn Power Valvoline
- D16A6 valvespring upgrades EXOSPEED help plz
- Venom 400
- clutch pushed in all the way and car still moves
- i cant firgure this out
- integra guage cluster on a civic?
- what to torque it to?
- Will I max out the stock injectors with my 2.1l
- LS/VTEC (CRX)???
- Help: Car turns over but the T-belt is not moving
- anyone had any experience with APEX suspension
- where should my car's idle sit?
- rebuilding tranny
- does the vafc keep pre-tuned memory after unistalled
- 2.0l b16 possible?
- car wont start-----likely fuel problem
- Boosting a 4G Prelude 2.2 Vtec
- Hondata with My Euro R
- New to the world of Honda...
- Where does the RPM signal wire run to coming from the distributor?
- 215whp LS/Vtec possible?
- Cranecams Fireball Ignition
- HELP! coilover problem
- GSR 5th gear....questions
- Help:IAC/idle surging
- In/Out settings for SAFC? Help!
- 02 Civic EX Rear Disc Conversion?
- Anyone have a answer bore questionn if you bore a b216
- Type R master cylinder possible w/o booster on a 99-00 civic si?
- LS/VTEC and VTEC Crossover
- How hard is it to change your own Valvetrain?
- Broken B18A 'cam holder' - the punch-hole-tab (?) snapped off
- Spun bearing... How do i clean out the oil galley?
- Need Some HELP on Verifying a ZC Tranny PLZ!!!
- Where to get o2 sensor bung
- SRS HELP!!
- Which NTK Spark Plugs
- how do u check if the map sensor is bad
- toulene???????
- Will a 92 integra pedal assembly fit in a +94 integra??
- HELP, weird sound
- Can't find the Honda B-series RWD tranny manufacturer...
- EG sway bar HELP plz...
- still smokeing !!or will it go away
- B series Tranny
- engine wont rev over 3k
- Thickness of 1998 ITR Head Gasket? In inches...
- Tops of piston rings?
- Need pics of B16a head without cams anyone please help
- Innovative Turbo MSBC/MSD 2-step wiring diagram over your E-Brake...
- new member, with a T-stat question
- wrist pin lock install?
- can the clutch only cause one problem?
- plugs are popping off the distributer
- quad throttle body on ZC 1.6 twin cam ??
- back fire
- 720cc Injectors
- Trans problem, can't identify
- help on the supercharger
- Sensor Problem
- Bad Understeer problem.. *help!!*
- The right way to LS/VTEC?
- Compression ratio of d15b2 with d16z6 head?
- SOMEONE HELP ME!!! idle goes up and down uuuppp, then down, up, down, uuuuppp, down...
- ls tranny usage???
- clutch chatter vs tranny slipping???
- hondata s200/old school stage2 compatible ?
- gonna grab a d16z6 for 200, blown headgasket (so says) what should i look out 4
- Smoking problem
- Wierd CEL above 2k RPMS.....
- Flywheel Steped?
- How much do jdm type R front ends go for???????
- Sqeaking nosie?
- Help... smog referee info needed!!
- need to know what wire is for the tach on the dizzy!
- **needed gsr vaccum diagram**
- Anybody know what color the heater blower wire is?
- does honing increase bore size?
- car wont start after FUEL FILTER change - any ideas?
- Trying to figure my compression ratio, need a little help
- any damage if idrive for a day with bolt in shift linkage
- HKS Dragger for EX on my DX hatch?
- Throwing a code after ignition install. Help!
- swapping out LS block for B20 and I have some Q's
- latch string loosen, cant open hood
- acura integra type r rear sway bar question
- LS motor Knock Sensor
- help with throttle body swap
- need some help,skunk2stg2cams,thinheadgasket
- did mini me to d15b8 and now it won't run
- Car Died. Think it wasn't getting fuel???
- Coilover question
- Help...having trouble with ZC swap...injectors
- what size injectors?
- running stock fuel pump?
- what exactly is running rich and lean?
- Best TB size on N7A B16A2??
- Max tire size differences w/ABS?
- Suspension tech questions; gurus help/opinions please..........
- Can suspension be rebuilt.....shocks and spring seats?
- Just changed axle and wheel bearing, still sqeaking
- Need some help!!
- california smog referee question
- Needed: wiring diagram for a 98 JDM tpye r motor (obd2) into a 92 honda civic cx (obd1) (from honda
- TPS problem...and a question
- O2 sensor four wire
- Compression ratio calculation
- K20 and F20C bell housing
- d16 tranny dead?
- What are the symptoms of a bad Intake Air Tempreture (IAT) sensor?
- 3rd gear grind. Need help please..
- need some advise on boost
- ohioins listen up need help!!!
- JDM p13 wiring schematic??
- b20 vtec
- Few ?'S
- clutch making funny noise
- Suspension HELP!
- how do u know if it is a manual or AT ecu???
- b16b with boost
- A/C and engine overheats ?
- running lean
- exospeed wholesale
- d16y8 distributor
- Updated Tranny Noises
- what parts required to install front sway bar on car without front sway bar?
- Will struts made for integra fit?
- Yea or Nea.......chipped p28/gsr
- time to change my head gasket
- car running like sh*t
- titanium piping...
- CAR wont start - no spark -please help-ASAP
- NOS Installation
- Piston question
- DC Header 4-1 on B16A
- soft brake after a long city drive
- wanna see the biggest joke?? total useless wannabe VAFC rice boy toy!
- wiring help Fog lights
- Question about Main seals..
- Need Help Fast!
- vafc hack problems
- best shocks
- how do you guys get the oil stain out of the driveway?
