View Full Version : Tech / Misc
- question about tuning and hondata
- non-honda problem (grandprix-no reverse)
- Jin coilovers
- Apexi SAFC2 or VAFC2 questions
- Torque Specs
- B16A swap help
- Timing belt broken??? or what??
- used neuspeed springs settled??(searched)
- Honda transmission and differential oils
- Need help identifying spark plug wire
- Stuck at Honda Challenge race... tried everything... need help! have to race tomorrow!
- Swaybar clearance
- help with picking out a wiring harness...
- could setting fuel pressure too low via b&m fpr cause detonation?
- which direction for rods In B18A?
- Accord transmission removal HELP, it won't budge!
- somethings really wrong.... could use some help.
- gsr head b20 block, what else would i need ?
- How to properly position swabar endlink? Pics would help!
- Valve Lash and secondary lobe
- itr swap on ek ferio
- Help
- what's up with COMETIC
- Headgasket Diameter Question
- Need a new tranny
- HELP! BROKE DOWN ON ROAD. BURNED OUT 2 GEARS. WHAT DOES IT MEAN?
- Please Read Need Opinions on ls
- removing piston from caliper
- How to break my engine in?
- prothane inserts...anyone usin them?
- what does the timing banlancer do?
- Difference in obd1 b18c1 harness and obd1 b16a1 harness?
- 2 motors same set of problems! help!
- Loose rotor in distributor?
- What is your opinon on Rota rims? Are they good for autocross?
- help
- drive axles, emergency help.
- f20 vs d16z6 intake
- Exhaust cam not turning...
- How to adjust timing on a VTEC EF
- b18a obd1 or obd0
- i need all the gurus of honda oni this one, figure this out :0
- Review of my compression test results
- strange oil light problem
- tranny question
- problem summed down fuel pump or main relay???
- camber from hell.
- Compression Test Kit ---- Is it worth it?
- D15B7 head gasket question..
- spark plug gap on a b16a
- Help car dies right after startup
- 93 Del Sol Si dyno
- FUEL TEMP SENSOR?
- difference between washer/bolt & rear camber kit
- Carfax?
- I need a quick answer...
- Anybody know how to test a ECT "Switch"?
- Will a hydro tailhousing work on a cable tranny?
- Vafc2 question and tunning for gsr turbo?
- thermal wrap
- What fluid burns your eyes when it burns?
- VAFC Vs Hondata
- Clearance issues with sway bar and exhaust... Help!!
- power steering problem
- Need help for a hondata system
- 94 teg Manual to automatic...some help please
- oil filter goop?
- changed tranny's my car drives like it needs to be retuned?
- Help.. NEED GSR intake manifold vacuum diagram!!!
- what year is my swap?
- Honda "D" Series Bearings
- What should I do?
- b16 and b18 drive axles, any different?
- b16a header oxygen sensor
- getting tranny snap-ring to snap in place -------------------------------------
- Nitrous Bottles Get Hot?? (also bottle heater install help)
- LS rods VS GSR rods??
- replacing distributor?
- igntion timing settings?
- My driver side is caliper loose and making horrible scratching noises?
- Need help with an A/C Question for a 95 Civic EX
- b16a or b18c?
- Rebuilding my S1...what synchros/gears do I need?
- Horsepower
- tranny syncro help
- piston to cylinder wall clearance pr3 pistons in b18a?
- Help, Tranny issue and strange whine. Please help. Input shaft bearing??
- failed e-check need help
- timing belt or timing chain?
- Backfiring????? How can I fix this???
- (Warning: Noob Q) Dyno Results?
- how to tell diff between front & rear springs (OEM)
- loose sterring wheel....help.........!!
- FYI: Walbro 255lph HPress. flow chart
- short shifter or quick shifter????
- Vtec and VVTl-i are the same thing correct or are they closely related.
- fuel pump?
- Alternator wire associations
- 99 civic vtec wires?????
- Vtec not working on LS/VTEC...REALLY wierd problem...
- Vafc later on...
- quick alternator question
- best way to install axle
- Changing ride height again,need help.
- Running CTR pistons in a b16a3 with a .03 milled head???
- Is it headgasket, rings, or both?
- rota wheels and lug nuts???
- anti rust paint or coating for exhaust?
- H22A oil pressure
- i need a little help
- where to get exhaust gaskets for racing medalion??
- adjusting fpr with vacum line off?
- what size rod bearings???
- knock sensor grounded = no cel?
- Help , Timing Belt for Ls/Vtec .....
- Engine Swap question????? Please Help
- immeadiate emergency
- wanted stock b16 fuel injectors
- CIVIC 2000 hub removal!!! HELP
- no oil in oil filter
- keihn carbs
- where do you guys buy your headgaskets from?!@#
- HELP PLEASE!!! GSR and LS tranny
- timing question
- What is this thing? [pic]
- need help with obd2 to obd0 swap
- obd0--->obd1 or obd2?
- I need help! Suspension noise? Brake noise? 89 Hatch Si....pissing me off.
- LS/VTEC rod milling ?'s
- inquire - has anyone tried to make a heat shield to cover header?
- Best way to clean/rebuild this head (pics included)
- tranny experts need your advice!
- ITR vss sensor !!!
- Changing headgasket. Need help!@!
- N1 ECU Question
- Anyone using a High Flow Cat
- Off Topic but I need help with an Eclipse
- Where is a comprehensive list of Honda engines?
- Spark Wire resitance too low or high somethen like that
- help with wiring on OBD0 diagram
- When to upgrade fuel system?
- frustrated!!!! Starting problem....... search unsuccessful........ HELP!!!!!!!
- clicking while rolling backwards
- Injector identification question..
- my b16a wiring help
- a radiator for my 92 b16a from japan
- replacing ground wire
- Can I use a light weight flywheel with a stock clutch?
- eurepean civicz rulez par2
- sounds like an air leak next to my drivers side door
- d16y8 or d16z in 96 ex?
- Automatic Transmission Malfunction Codes OBD2???
- BB6 ODBI to ODBII conversion - need help
- b16a2 VTec issues, please help....
- clutch pics how do they look
- aftermarket b pipe w/ stock axle back
- can someone help me ID this?
- gsr camshaft install and valve adjustment
- tranny making weird growling noises
- fuel tank...safe?
- takes awhile to start(after sittin for 3hrs or more)
- What ES Bushings acutally look like..?
- o2 sensor ?
- ep3 tie rods
- suspension noob ?'s
- speedometer going insane!!
- ENGINE STAND???? STRONG ENOUGH TO HOLD A RUNNING MOTOR??????
- auto engine harness to 5spd
- Can i Use a b16 headgasket and b16 ARP headstuds in my b18c1?
- bad gas mileage...please help.. $50week on gas is killin me!!
- Throw Out Bearing Question
- Extrude Honing, I guess it can be the same as P&P but better....
- Extrude Honing
- which is the top piston ring
- idling way too high
- B16 port/polish
- quick question, timin belt tensioner, what tq spec is that?
- installing a air fuel meter
- tunning ls turbo cams NEED HELP
- help build my 92 cx....
- 1973 CL125s Charging Problem?
- Enkei NT03+M using 2 valve stems per wheel? Why?
- Extremely puzzled over OBD2b to OBD1 vtec conversion (SEARCHED AND SEARCHED).........
- to rebuild (s1) or not to rebuild (buy a new one)
- Quick Tire question...
- Oil pump install question...really need advice please!
- idle problem air conditioning stalls car
- B17a sensors, etc. on b18c1
- need opinions on vtec and rev limit points on custom p28 for lsvtec.........
- FUEL injectors took a piss... seing whats wrong
- fuel pressure settings b20z
- not going into 5th
- determining oil pressure
- ball joint boot question?
- Motor back from machine shop all plugs oil fouled??????HELP!
- anyone with a vtec controler on an s2k?
- Need some help with SK2S1 cams...!
- 1989 crx hf with d16a6 when i turn key i lose power to everything in car. HELP
- LS Distributor Cap order
- read fpr gauge B&M
- Which ECU?
- Stuttering, Misfiring, hesitiation or something... don't know how to fix it.
- it s pinkin ...
- What swaps are available for my Civic?
- did dealer rip me off?
- Can anyone recommend a good engine building book?
- D15B VTEC - What timing Belt and Waterpump Are Needed?
- Help! The end of my compression guage is stuck in the spark plug hole
- auto vs manual b16 cams
- obd 2 head or second gen head better than obd1 or first gen?
- Ok to hit the end of axle to snap it in to the tranny?
- Hatch Swap??????s
- Clutch problem???? or not
- b16 rebuild...is it worth it?
- which tranny to go with? Rebuild or upgrade?
- Autometer Tach W/ Shift Light, Shift Light Not Staying Where Set?
- will a 1 wire o2 sensor pass smog on a 4 wire ECU???
- friend is having probelms with an H23 swap.
- cant decide which spring to get.
- FOR SALE
- Coil Overs vs. Lowering Springs
- anyone silicone spray their cv boots?
- Is there anything you can do to the 92 VTEC-E motor????
- B18a1 running rich... need help
- My Distributor is apparently binding the intake cam...
- Ls harness
- OBD2 distributor on a OBD1 car?
- Overheating Problem. Pro's Please HELP!@@!
- Throw out bearing question
- when buying a new timing belt....
- interchange cam caps
- can i reuse bearings and do i really need to shot peen??
- Is a compression test on a motor 100% way to know if you have internal damage?
- ANYONE KNOW WHERE I CAN GET MY TRANNY FIXED IN THE BAY AREA FOR A FAIR PRICE????
- which head studs fit a d16a6?
- 0^2 sensor
- Piston size? before and after hone . . .
- Grinds & Fuses
- H23 OBD0 wiring H series swap in 4th gen.
- honda tune up qwestions help please
- flywheel dowels
- how to do timing on b16
- Head Swap Help!
- How do I install my APC Glo Guages
- *SEARCHED* 1995 jeep grand cherokee problem
- A/C compressor
- Probs with SPC camber adjustment
- help.....profec E-01 isnt reading rpm
- Shift Linkage Pin Lost (searched)
- Just installed cams, engine temp. gauge not working
