View Full Version : Tech / Misc
- why can't you chip a jdm obd2 ecu?
- How does the VTEC solenoid work?
- What Compression will I have in a B16A2 with CTR pistons .10 over?
- swapping integra trans to accord
- Changing out the clutch....??
- ECU Chipping
- cap and rotor
- Tuning B16 Ignition Tables
- spring manufacturers
- who makes good black lug nuts?
- More pics of the bling
- 96 SHOC noise
- What's an equivalent of Bosch 4227 with colder rating?
- Swap from p3k to phk pistons
- power steering oil leak
- how the hell do you remove the brake hose bracket off stock struts???
- Need Tech Service Bulletins!
- b18b with ctr pistons
- Long rods relating to stroke (Att: Importreview)
- need sites
- H22a Question?
- oh snap, my engine makes weird noises
- weight difference between sohc and dohc???
- what the hell?
- endyn cam gears?
- testing starter?should it spin or just pop out
- head swaps
- Shift Light Without Tach.!!!!??
- Cam adjustments for Spec B's
- Rev stays high
- How to install this oil seal..
- I need ome Tech info please!!!
- civic stock intake help
- Did anyone ever give a review of their D.A.D. seats?
- looking for a d16 head (who to buy from?)
- estimate my whp
- Finnly got GSR w/ JRSC runnin!!!
- Integra GS-R Head Gasket install question?
- B16 w/ spray ???
- Car shakes with motor mount inserts ?
- Question about ECU and conversion harness
- B-pipe
- wiring diagram
- what would cause thermostat not to open?
- catch can
- What kind of intake...?
- W0uld a crx exhaust fit a 90' civic hatch?
- No leak cover in distributor
- Skunk2 Intake Manifold on GS-R
- To anyone that has had DSS.com axles, especially Stage 2's
- Need help for my new n/a Setup
- jdm header and high flow cat
- idle too damn high...
- motor swap?
- ceramic coated VS stainless steal
- throttle sticking on 97 Civic
- stock springs
- Diff between a cable and hydro clutch
- Timing question??? Very odd. Tech heads look here!!!!!!!!!!!!!
- Will a Jdm 96 Spec Ecu fit my 98 Europec ITR?
- cv boots
- Testpipe
- AEM EMS Obd1 or OBD2?
- Gas needle is off, but by how much.
- Exhaust Experts: Need your opinion
- Link vs. Hondata???
- B16 tranny Topping Out?
- top-end lost power?
- 93 distributor=94-95 distributor same?
- will b16 tranny bolt on to b18a??
- Help, I can't put my car in gear.
- CTR Pistons in 92gsr?
- high geared b16 tranny?
- Need help...
- How do i stop the beeping?
- car threw weird CEL last night
- Whats the general procedure for a dyno run?
- quick questions
- WHO Has modded an LS motor ?? I need some input !!
- How to make GSR intake manifold fit Type R
- laptop tuning
- I need opinions (please)
- Installing 5 point Harness?
- question about thinning stock headgaskets
- HELP!! need everyone's opinion. This is my set-up...
- LSD Question?
- what would cause excessive oil vapors inside valve head cover
- why is my oilpan leaking???
- help this noobie>>>>choice of engine
- Tire sidewall repair?
- Sylvania/Osram Silverstar bulbs
- Lightweight crank pulley?
- whistling/whining belt(s)
- ITR head on B16
- Using an e-cutout as an exhaust tuner
- 4000rmp car will not take gas
- how are the ctr and itr headers different?
- out of curiosity
- Ignition Timing
- Ctr Tranny Vs ITR Tranny
- more questions on the new v6
- N20 line pressure...
- ls will not start
- Camber kit installation
- ARP head stud problem...???
- No Start !! Has Spark, Fuel, Comp!
- Difference between LS and GSR Block
- A B16 post that I cam across on b.series.net
- Using a B18B engine on a P06 ECU (92 Dx ecu SOHC)
- ampro super duty impact wrench
- A/C Line removal Problems, helpo
- levelten automatic tranny upgrade
- Exhaust Emission Problem.
- much power difference bwtn 5w30 and 10w30?
- Clutch Question
- 2 gen Honda CRX 1.6i-16V DOHC camgear settings? Any suggestions?
- Difference between usdm b16a and jdm eg b16a
- civic camber kit on a gsr
- Engine rebuild suggestions
- sohc louder then dohc?
- Why would my car feel slower with JDM ITR ecu compared to a stock p28????
- Multi-player online racing game with real cars and parts! Prizes too!
- MPFI: Is it possible to run with the crank angle wires hooked up wrong and no codes?
- dpfi to mpfi maifold conversion
- chasis stretching
- all motor d15b6 running 10's??????????????
- Whats the difference between Eibach "Pro Kit" and "Sportline" Springs?
- -AN fitting size (fuel lines)
- Expert Opinions Only: What is max Bore size for sleeved b18c in NA motor?
- Is this real?
- What the heck is wrong with my CAR!!!!
- Jdm B16a problems. Need help.
- Car wont run...
- possible to change over the ac compressor clutch assembly?
- Electric Water Pump
- v-afc tuning for b18c
- GSR vs ITR tranny
- tranny mount bolts stripped,heelllppp!!!
- Over Reving?
- cylinder resleeving process
- energy suspension
- how much horsepower does a new accord v6 have??
- How to tell if you IAC valve is stuck open???
- Used the good ol "Honda-tech zero search.." didn't find anything, so here goes..13's w/boltons w/b16
- Toda B's installed
- Question about stock engine
- will integra rear discs work?
- Camber Kit???
- carbuerated intake manifold
- b16a2 into 92-95 civic
- boring and sleeving b18c please help me
- tranny ideas, any thoughts quicker gearing in a 160-180whp DC2
- Will ITR exhaust fit my 99 civic coupe?
- will i be able to pass smog with these mods?
- Where are the jack points on the rear side for 02 accord sedan?
- Longblocks... h22 to be specific..
- Options for LSD in 90-91 b-series cable tranny?
- my zc isnt running right anymore, and i cant figure it out.....igniter?
- where to hookup this water temp guage..
- wiring schematics
- Out of commision for a while....
- error code 20!! dnt knwo what to do
- aasco flywheel
- Cam break in period..
- other thermostat.....VS......OEM honda thermostat
- Too much oil?
- How much does a Valve Adjustment cost and who can do it????
- Valve clearence for 97 civic LX?(96-98 any civic) Forgot my helms at school and in desperate need o
- redline drop
- Looking for a better understanding.
- TSi Tranny
- using o2 simulators
- 88 crx/civic LCA and 97-01 ITR LCA...Same?
- Shifting problem
- Will the 88-91 CRX or 86-98 Integra Head Gasket fit for 92-00 SOHC Motors?
- starting woes
- need help!!! cant get my diff out, should come out with no problem?
- need help!!! cant get my diff out, should come right out..
- anyone with an s2000 ignition switch? eed help please.
- Looking for what variables......
- Bad Idle Troubleshooting
- how much compression can a b20b block take before needing to be sleeved?
- b17 crank/b16 rods - useful info...
- Suspension component that makes steering wheel vibrate under braking?
- Which injectors would be best for JRSC @ 6spi ??? RC 320's?? or bigger
- Intake Manifold trivia
- JDM B18C SiR-G vs. Civic Type R ????
- transmission swap?
- I broke a bolt that holds in the oil pan! what do i do???
- Question about intermidiate shaft....
- where can i get this VSS gear?
- volk gram lights vs volk ce28n's
- Calibrating TPS sensor on a B16A?
- Hybrid civic exhaust question
- help car wont start,still cranks and has spark
- K20A2 vs. K20A3
- help:question about pr3 ecu and gsr engine...o2 sensor wiring
- Can I turbo my stock civic engine or do i need a swap????
- 94 Accord shaking at idle...where is the idle screw???
- Which ECU guys?
- wideband O2
- Hondabond?
- why am i getting cel 67 with a stock cat?
- help!!!!
- Crank pulley bolt on F22b
- I Apoligize...
- Is this normal ?
- Smells like.....fuel!?!
- Turbo Guru's, Customize me a setup!!
- Is one long blink a code 10 or 1?
- LS VTEC Automatic Trans.? PLEASE READ LS VTEC PEEEPS.........
- Greddy Headers & Exhuast..?
- any1 juicing a stock b18c5 bottem end
- Lighter flywheel = Less top speed?
- GSR w/ JRSC 6psi with walbro 255HP and stock injectors safe???? right>?
- coupla questions
- half rad?
- Identify this throttle body please
- d16y8 intake manifold ?
- TODA SPEC C's or Skunk2 Stage III's
- Whose running TODA Spec C's?????
- Skunk2 Intake Manifold install on 95 GS-R
- shaving wheelwells..
- Replacing Pistons
- DIY header collector - how's it look?
- Short Shifter Buzz/Rattle/Noise from exaust Heat Shield
- Start car without clutch?
- detonation with nitrous?
- Orange/copper color spark plugs
- nx fuel question
- People with 96+ civics with power windows please respond..
- 90 integra springs on 91 civic hatch?
- Tuning is Everything!
- Rebuiling motor!!! Oh BOY!
- Best brake pads?
- fuel gauge had gone crazy
- GSR brakes onto 92 Si
- studdering between 500-2000 rpm ?
- too much oil ?
- Rings and Bearings?
- installing O2 sensor(butt connector)?
- i hydrolocked and need help
- i think im loosing coolant, any ideas?
- S2000 question
- how -to.....takata harness
- Header?
- HELP Code 54 crank speed fluctuation ?????????
- stuff you hook up to a vacuum line that makes your car smote....
- HELP: Need ECU map
- tranny clicking
