View Full Version : Tech / Misc
- Installing Toda cams spec B's
- Timing a 91 Si
- 5 lug question, and vtec bseries pistons in an LS?
- B16a1 BUT it will be OBD1 !!!
- help with check engine light
- Building LS/Vtec For Boost
- b16 block with a b18 head!!??
- Torque Wrench: Too Large for some jobs??
- Beam Polishing
- How much can you cut off a d16a6 head to bump compression and not get into trouble?
- Help installing my DC header on my FBP '00 Si
- NeED HELP!!!!!!!!!!
- White smoke from valve cover
- skunk 2 valvetrain q?
- E-brake handle...
- un-sieze bolts
- Oil cooler question?
- Tach and speedo dont work
- anyone w aftermarket cams on stock ls head
- axles and shift linkage help
- OEM honda rings with JE pistons?
- which springs won't need a camber kit?
- 205/45/16/ vs. 205/50/15
- tires??
- NEW setup for a 95 prelude, what do u think???
- exedy-->organic or cerametallic
- comparing bottom ends...
- Tein SS or RA's???
- OBD2->1 Integra Harness on 98 Lude
- types of caliper and rotors???
- braided clutch line
- CTR pistons in a B18C1?
- fuel supply code????
- Car would not start up after it died
- the best platform (honda car) to use to hit 12's
- window regulator...
- prelude 5 lug on a civic...i know it wont work but explain it for a guy i know
- 1st gen crank pulley on 2nd gen B16
- What would be my compression ratio?
- TDC on crank pully for the b16a?and axle question
- Using Motor Oil for Tranny?
- difference between limited edition and regular????
- how many people have camber kits?
- I NEED HELP........ NO FUEL PRESSURE!!!!!!!!!!!!
- ... h22a powered 5th gen civic hatch
- question on knock sensor
- whats depth on flywheel for cm stage 3
- Which coilovers?
- Cannot Reset ECU
- Location of two sensors???
- tourque gains from n2o
- What's a Honda/Acura engines made of?
- Injector Clip question...
- All Motor vs Turbo
- Please oh Please Read This . OIL PROBLEM ON B16A2
- for the mechanically inclined
- Look at my plugs.
- upgrading a b16
- anyone have any video or sound clips of........
- Could a D17 crank fit in a D16?
- want to change my 4 dr interior!
- GSR swaybar onto EG
- Is 00 ITR wheel direct swap for 00 Si wheel?
- stock civic redline
- will 95 gsr cat. fit on 00 civic si?
- smogging b20
- White smoke from radiator? Headgasket?
- spark plug seals
- Honda Engine Specs (88-96)
- can i use ls ecu w/ vtec controller with my ls/vtec?
- Everybody post pics of your shops....
- Cali people , new tickets cop's are giving out..
- will an apexi n1 exhaust from a 00 si fit my 99 teg LS ?
- JE high compression pistons
- Which program to use for ROM editing?
- happy holidays to all
- short shifters
- stock IM vs SK2 IM
- Hurst shifter for GSR....any thoughts??
- Here's my camber....do I need a camber kit?
- Anyone know if it's legal to use an ecu that is older than the year of the engine?
- define reslevee
- A quick cam gear question?
- Fuel Injectors
- Ditgital Gauges
- coolent bypass mod,makes inregular reving at idle
- 1980 Honda Accord Camshaft torque specs
- Automatic Transmission expert wanted!
- AutoMeter Air/Fuel Gauge Problem.
- Ecu pinout
- Stering wheel question?
- Car keeps wanting to stay at 2k while at idle???
- New Cold AIR from AEM..... Anyone?
- What should the stock compression ratio be for 1.8 RS Motor?
- Ground Control model question...
- Need a Good setup for the LX project
- need help with my H22 cable shift tranny...
- heavier rims..
- Where is the difference in an auto LS intermediate shaft, and a 5spd LS int. shaft?
- What PSI to use?
- Hondata vs AFC, in ALL MOTOR setup
- Indexing spark plugs
- Camshafts
- LS or GSR side axles / midshaft
- Internal Engine Casting Flash
- gsr shifter in 4g civic
- Can anyone recommend a reliable Honda/import dyno tuner on Long Island?
- Help! My car turned into a mouse!
- good coilovers??????????????
- bad braking
- JE Piston - Piston to deck height
- BMW E39 (540i) dash problem, please help
- b20
- Alternator Qs
- Best upgrades for a turbo car?
- Eagle Rods or Stock?
- eciu chipping
- Differences in a 94-01 GS-R Fuel Rail
- Does anyone know the rod ratio of the B16B/Civic Type R
- cylinder #3 low compression
- Enough clutch?
- Car died on me!
- How to install an oil pressure gauge in my 95 Integra?
- NGK Spark Plugs
- dropin in a 1st gen jdm b16 motor
- Which compression testers to buy?
- Terrible metal on metal screeching, Please help
- spun bearing
- how do i get the bolt off the countershaft in my tranny?
- exhaust ?
- BG transmission conditioner......OR.......Redling ATF?
- introduction
- shifting noise HELP
- Oil/coolant mixture coming out of my head.
- How do you know if CTR cams are real?
- TPS problem on a G3 integ
- all of you N/A guy's. . . .
- New GTech pro Competition
- pm5 wiring pinouts?
- B20, w/ B18 head build up?
- hole in resinator
- clutchmasters v. exedy
- Just intalled Apexi Dunk
- nsx brake calipers
- b18c1 compression question
- Need answer ASAP::Stock Civic Si cam specs
- Does this timing belt look worn?
- h22a wiring question
- Clutch/flywheel install. Special tools/items?
- Quaife Question??
- Dyno plot comparing ITR and Skunk stg 1 cams, anyone have one?
- Please help me pass AirCare!
- just sold my motor , which one, please respond
- Y1/GSR/LS tranny LSD interchange ?
- which ecu comes with an obd2 jdm b16a2 swap?
- Aftermarket 2000 Civic Si plug wires on a 1992 Acura LS...will it work?
- D16-v-tec Running to rich (Help!)
- will these axles fit..
- Can someone please let me know, if there is a gasket that goes from the B-Pipe (header) to the Cat C
- BARO Sensor??
- Detonation Issues / Cam settings after milling a head, and other ?'s..
- dist. making wierd sounds...
- Funny Noise Coming from my b18c
- ctr cams !?
- VTEC issues
- Are the b20b and b20z camshafts the same?
- How can I tell if a shock is blown? (The shocks are off the car...)
- What is the difference between a cable tranny and hydraulic?
- Air Fuel Ration guage wiring
- Additional Injector controllers
- D16 vs. D17
- What did you do to your EVAP solenoid when you installed your Skunk2 Intake manifold? 95 GS-R
- Bored out block, needs to be honed?
- B20 head gasket?
- itr header: should i cut my high flow
- SPOON B18C Engine output?
- YS1 with Type R lsd......?
- 93 Dx head fit on a ZC block? and 91 crx SI tranny on same ZC block?
- Are these torque specs the same for an H22 (97+ prelude)
- what are proportional valves???
- compression ratio?
- Best Bang In A EG For The Money?
- S1 5th gear in Y1 tranny?
- porportioning valve for conversion? Need advice..
- jdm b16a (SIR1)motor
- 3m window weld for custom soild mounts?
- help on swap...please.........!!!!!
- how much HP will a b series automatic trans withstand
- what head gasket should i use on my mini-me swap (d-series)
- engine light on??
- people with PE timing belts: is the belt really snug?
- Are My Rings Blown?
- The LS/VTEC and B18C Alternative !! Has anyone done this ??
- best motor to swap into the 91 hatch? want power
- Dome height same as Piston-to-Deck Height??
- Won't shift into fourth
- n2o spark plug question
- 5 th GEAR JDM s1 tranny !! Which 5th gear can i swap in this tranny !!
- hondata rev limit setting?
- help!!! need to install aftermarket tach in stock location!!!!
- Measuring Coilovers
- Good price for clutch install?
- HELP... wierd idle..
- Dents on oil pan
- D16Z6 Rebuild
- Best way to clean cylinder head and combustion Chamber?
- How do u put CTR lips on out EK civic? (newbie question)
- GSR intake spring same as ITR exhaust?
- What the hell is that noise>>>
- Aluminum radiator repair!
- what to use to remove sound deadening material?
- Transmission fluid?
- b16a map sensor? help!
- engine miss when VTEC engages
- JDM or USDM gsr motor how do i tell the difference
- The Official Energy Suspension Bushing Thread.
- Power loss through Gearbox
- H22 Head Gasket
- still need help with a CEL...
- Largest possible sleeved bore?
- Bad hesitation when hitting vtec, suggestions?????
- individual throttle bodies
- switch block?
- 75 shot zex on a stock b16A?
- Heater problems !!!please!!!!help!!!
- SRS Light wont come off my 97 GSR!
- dsm 450cc injector Q's???????
- the best question ever asked
- cable tranny starter on hydrotranny
- EGR vs non EGR B18A
- What do you guys think of air suspension?
- roll cage plans
- Oil Leak question.....
- Car keeps going straight when I turn the wheel... little long, bear with me
- d16 question
- Why am I going through so many ignition coils??????
- I CANT DECIDE prelude.turbo/ls turbo or maybe Pvtec/gsrturbo whats better
- Carrier Bering
- itr jdm 4-1 headers need testpipe?
- rear defroster
- d16y7 question
- H22a sH motor question-->>>
- 4thG Civic Auto to manual Help or any info?
- Help...How do I know if the clutch slave cylinder is bad?
- LS throttle body on my D16z6...benefits?
- What vehicle honda makes has the biggest engine?
- Differential Question!!!
- Rear strut lca assembly.
- sway bar?
