View Full Version : Tech / Misc
- d16 axle help
- Check My Basemap Bin Please :)
- GSR Charcoal Canister Removal?
- Rear Disc piston tool 99-00Si
- JDM B16 Y1 LSD rebuild? Parts list and availability?
- Positioning removed Crank
- Piston to wall clearence
- i found a 95 civic hatchback
- tranny time
- What size allen wrench for ARP head studs? Head studs bind when I lift my head off, normal?
- Crankshaft Pulley bolt
- B16 Teg, Gas in Oil, CEL.. Help
- NEED HELP:2nd Gen Integra's
- radiator is not releasing pressure
- Exhaust Backpressure
- leaking gas and oil
- spoon LSD install trouble !!!!!!!!!PLESE HELP!!!!!!!!!
- PCV valve question
- Gear-X Final Drive Link/Info?
- 2000 CIVIC SI STOCK HELP NEEDED
- i just need to know
- How to tell the diffrence in distributors
- attn anyone with a b18c in a 6th gen civic...
- B20
- Fluidyne vs. Koyo
- Brake problems: deciphering between sitcking caliper pin or piston, or brake lines
- who has a helms for a 95 gsr
- NEED HELP!! LOCATION OF COOLANT HOSES
- OBII code P1367
- what honda runs about 50 fuel psi ( FPR ) ?
- Toyota Oem online parts place???
- OBD0, OBDI, OBD2 ?
- yes or no??
- Map Sensor to Wiring Harness
- Check engine light comes on all time........
- Any way to adjust clutch pedal throw?
- High Mileage Vechicles
- stripped a bolt doing valve adjustment. now what????
- help! FITV question
- Hondata Help!!!! Idk what to do
- b18 bearing help
- Looking for *AWESOME* area Hondata tuners! I have a fully built b18c1...Help!!!!
- question about injector driver
- 93 civic b16...a/c compressor question
- eg6 gauge cluster brightness????
- A few d16 build questions.
- Single Cam Question
- what size (cc) are dpfi injectors?
- question about my obdI when my car is a obdII
- Ls Fifth gear in B16 hydro tranny?
- vTech Engine
- What's the diff. between the EK, CX and DX models?
- LEAN condition 1999 gsr
- bad idle/ bad sputtering gurning rich gas!
- ok, CEL problems... cant figure out if its jumper, ecu or harness...
- Could I install NOS in my honda?
- when to change to synthetic
- Turbo Flywheel Question
- HID KIT QUESTION
- B16 in 90 teg. CEL?
- F20B Map For Aem EMS 1000 series
- all sellers beware of Waterbury CT new scam
- price to bore d16 block
- h22 tranny gears
- V-AFC TUNNING TROUBLES ON A B16A BUILT
- B16a2 99si Fuel system diagram?
- how does oil get to the head????
- Wanna wire up a New cluster but dont know which help?
- Check Engine Light Code 54
- NEED HELP FAST - manual for gen 1 SAFC needed
- Confirming bearings
- Piston Question
- sputtering around 4000 rpm
- ATS lsd speed-o gear
- wiring harness??
- Can 2 bolts hold AC Bracket ?
- Max RPM on gsR valvetrain ?
- A/C Rerouting?
- ugh injector problems help!
- where can i find magnetic drain plug...b16 oil pan
- P28 Specs....???
- anybody try this rsx guage cluster into a civic?
- Is this correct??
- obd2a distributor to obdo
- tranny help k20a2 swaped eg
- PROBLEM WITH MY GSR INTO EG SWAP
- quick obd1 p72 question
- 88mm f23a stock sleeves..... to risky?
- Wrist pin question????? Help please
- how do i eliminate my obd1 gsr oil cooler
- Wilwood big brake kit
- Ridiculous Wheel Hop
- USB for Honda ecu
- Can someone fix the search feature on this site? There's errors...
- Which 3" exhaust & catalytic converter w/ Vibrant Stealth Muffler / R Crew header?
- Which MSD modified distributor cap part # do I need???????
- tranny help...
- P0138 code ?
- Teeth count on 4.75 final drive(Search function is down)
- Losing A/C cold after header installation!!!!!
- Knocking, need help......Big nightmare
- Clearing OBDII Codes 2004 CRV
- ENGINE QUESTIONS!!!!! HELP....
- yellow and black wires
- search down- code 41- primary oxygen sensor heater?
- IACV voltages ? Desparate
- MSD Coil and Ignitor problems with AEM EMS
- GSR Transmission help
- CR-V transmission grabs at 1 RPM when coasting to a stop....
- wierd surge at 1500rpm
- D15B oil pan and d16z6 same size?
- this is funny..seafoam in the spark plug hole no car won't start
- Wierd Transmission Noise?
- Quaife / OBX LSD problem with GSR tranny passenger side axle
- Cylinder Head Flow Test Results.. . OMG!
- Clutch issue discovered (won't engage, master slave cylinder
- B18B LS INTERNALS INTO A JDM B16A BLOCK
- Arias piston rings
- Vtec Switch Code
- Question about regarding the rodknock sensor on a 99 civic si with an all motor ls vtec setup
- Throttle Position Sensor issue.
- need help with VAFC2!!!
- D16A6 Compression Question.
- wire tuck for a civic 1996-2000???????
- i need to get my car tuned (S-AFC II)
- headlight bulb keeps on blowing....
- exhaust situation setup...would this work?
- How do I find out if I have LSD Transmission?
- Question about LS block with GSR head
- Help with GSR Cams
- need help on TPS sensor removel
- OBD2 H22 - Need help with wiring OBDI Distributor
- california laws?
- B series gear ratio's and tooth counts HELP
- Unable to resolve CEL 3 MAP Sensor.
- Transmission Fluid?
- interesting story... stalling b16a swap (it's a long one)
- Non Honda Help Please! (98 Dodge Stratus)
- Broken valve spring retainer - very bad??
- just a little help
- Would a 2001 TypeR Distributor work with a 2000 intgera LS?
- DC2 with pilished motor
- really werid gearbox leaking , anyone ? please help
- oem jdm itr hid d2s bulb replacement
- slim fan too small?
- what should i do?
- Track Masters in Huntsville, AL?
- flooding
- Plastigage Help engine builders have a peek please
- B16A VALVE TAPPET TORQUE?
- Injector wiring problems. Pictures included.
- Bodyshops/ Motorshops.. Shops that are trustworthy!
- clutch problem, car wont move in gear....
- compression ratios and problems with pump gas
- CRX rear LCA question
- Idle problem/runs lean with any 12v
- B16 swap into EK. I need your knowledge...
- My problem of last year comes back again...
- check my rod bearing clearances
- Koni yellow single adjustable struts
- Stripped T-Bracket Thread in Tranny. What size?
- ebay F1 and XTD clutch, any good??
- How much do Omni flat faced stock size valves add to a b series?
- Difference between radiator caps?????
- Ideal Backpressure
- Dizzy Question
- radiator failure after replacing water pump
- Does OBD1 Acura integra GSR distributor cap/rotor cross over to anything Honda?
- Anyone know anything about these aftemarket head?
- Crack between spark plug hole and intake valves. Fixable?
- Competition Stage III review
- Fuel Pressure
- frustrating issue - stalling, idle?, ac? confused as hell.
- 1.6 injectors
- Car wont start. (searched found nothing)
- Wont Start. fuel, spark, compression...WTH
- Does this look like an ITR tranny with LSD inside?
- spark plug ?
- B&M short shifter PART # 45047 Installation question?
- Very Odd problem, car woudln't start out of nowhere
- LS tranny: gearing options?
- K24/20 Help PLEASE!!!!!
- rpm jump after 3k...and car boggs...HELP!!!!
- random bad idle and stalling
- Reverse idler gear...is this right? PLEASE HELP!!!!!!!
- stock coil & wires sufficient for for `96 vtec w/possible perf. bolt-ons?
- Missing AN Fitting to complete installation on Fuel Hardline
- code 1 civic
- honda minded portland oregon machine shop
- kaizen speed kit
- B18C5 valve cover stud stripped
- tach fluctuation, sputtering
- Dseries clutch and flywheel and a B16 tranny???
- Ignition timing question
- HELP hot start problem and idles rough
- Whats the part # for oem gsr cams.
- What wheels are these ? looks like old-school Honda.HELP !
- tranny fluid ?
- GSR tranny fit B16?
- bad compression in cylinder 2, mtoor smokes, white smoke from exhaust, real bad idle.
- ? on resurcing an ACT flywheel
- Engine Pan
- Fuel saver Fact or Fiction
- Short Circuit (Liscence Plate, Tail, and Instrument Cluster Lights)
- rod mains. Writing faces which way?
- Need help, steering wheel shaking...
- Emanage blue ignition for L15A
- A weird sound coming.....
- noob exhaust question. hatchback exhaust which cat to use?
- Speedometer Question
- I need help, very strange part throttle issues in b16a/ED6
- ARP Head Stud (Do I really need it)?
- nitrous how much timing ???
- Whats a good OBDII Code Reader?
- Is my fuel pressure within spec? How about under small engine load?
- Transmission bearing failures and causes explained
- I have a question about my Tranny.
- faze tach wire diagram?
- Pulse plugs vs. Spark plugs?
- Power Bogs when hit gas, 90 DA 4dr.
- Differential Bearings?
- Dizzy Problem...
- How Honda gets those transmissions so LIGHTWEIGHT!!!
- Camshaft positioning?
- D16Y5 (HX) Wiring diagram
- obd2 or not
- Car died while running
- rs sleeves who has them thinking of getin
- Exaust/Muffler - Cutting bumper?
- Hi Guy's
- 96 accord turn signals not working??
- tranny ?
- Is my tranny LSD?
- HELP...98 ctr into 2000 civic ex????????
- CKF - crank fluctuation sensor error (code 54)
- What OEM lsd fits 99-00 Civic Si
- Good Old Honda Accord head questions?
- AT harness on a MT car....
- Car won't crank??
- Camshaft Question
- Transmission Code
- Bad ISB question.
- NEED HELP,BRAKES TO HARD
- Uberdata tuner in New England ? T29C256 chip in an OBD1 GSR ECU....I need tuning!!!
- LS-VTEC AC and Alternator belt help!
- hard to turn crank?
- Coolant Leak?
- Starter pinion failure, causes?
- question on the PHANTOM GRIP
