View Full Version : Tech / Misc
- Need advice on b18c5 build.....
- where can i get some cheap axles
- Question about rims/wheels
- Hi flow cats
- any way to tell what gear you are in??? (eletrical signal/sensor?)
- Noob question in engine building
- why do brakes fade?
- cant find speedometer and odometer plugs
- rsx/ep3 brake calipers compare to dc2 question
- Exhaust Prob.
- VTEC Controller Hook Up
- more tranny fluid for lsd?
- Sleeved b20 or Sleeved and bored to 84mm b18b?
- NEED HELP with my INTAKE MANIFOLD
- distributor caps ?? B-series Help please
- Honda Acura Car Weights (Excel Spread Sheet Inside, ASENDING ORDER)
- HELP: Oil Leak
- Hondata tuning in So. Cal?
- upgrading internals
- catch can question........
- resleeving blocks
- Hondata Chip install on P28 Help!!!!!!!!!!
- help! VAFC died
- Code 12 EGR
- THAT SHIT IS ANOYING. WHAT THE FUCK
- what should i get?
- need help with rough shifting????
- 1988 Crx Hf with gas problem 6mpg on the hiway
- RSX Type S 2005 cams into K20A2 head?????
- Found whats buzzing. Now what material should I use to fix it?
- First thing to do when wanting more speed
- what main caps do I use in a frankenstein motor
- Another Strange Idle, looking for some answers
- thermostat
- Cant Identify these cams
- Welding combustion chambers??
- question about none-Honda car
- Damn fuel gauge
- F22B swap in 90 accord: last few bugs
- Technical Drawings or Dimensions of Engine Parts?
- Apexi n1 to 3 inch.
- Leakdown and compression test results.
- synchro mesh, will it fix the ol' honda grind? what kinda gear oil to use?
- Greddy Turbo Timer
- Cam question
- need help please...
- SOHC Help!!!!
- Help Code 15
- Can I Use A Chipped ECU For Uberdata?
- honda dx to all wheel disc?
- MOBILE DYNO TUNING IN FLORIDA!!!!!!!!!!
- Looking for a electrical part, dont know the name
- Attempting to remove motor without cherry picker.
- Too All Tranny Heads… Quick Q about internals????
- integra died HELP
- 93 lx does not warm up.
- compression
- How to add oil to my y8 tranny? Please help!
- f22b1 fuel/msd problems
- ITR ENGINE SPECS.
- Axle will not come out of hub for NOTHING!!!!
- running rich....but not running rich?
- need help firing order for a 87 nissan stanza
- Found a Keeper in the Oil Pickup....
- Power loss after idling a while????
- affordable obd > pc interface?
- Boosting my 404's.. Tuning options.
- Ls/Vtec Help. what am i doing wrong?
- buddyclub stage 4, portflow springs
- C/R of CTR's in B17
- How hard to change A B S to reg Brakes??
- need help!! thinking of buying a used clutch. tell me if its still okay
- valve tap issue
- neeeddd help some 1 helppp>>>>
- NEED TUNING ADVISE
- If this isnt Misc, I dont know what is.. Chassis codes anybody?
- sohc power difference y8 vs. z6
- Interchangeable valve springs?
- vtec not working
- high idle.. can't adjust.. please help!
- best engine combo
- white smoke no honey smell idle (searched)
- civic cx engine harness, large yellow wire, what is this?
- Push button to start car.
- 99 b18c1 in 93 GSR
- rsx air fuel gauge.. help
- broke my timing belt.....
- Cost for a shop to shave 1mm off rod
- can this work? DA integra H22a1 swap?
- vtec solenoids the same
- B16/LS Quaife lsd into GSR tranny ???
- LINE from Oil Breather Chamber up though intake manifold
- Post your experiences with different fluids for clutch type LSDs
- Opinion on my motor blowing?
- Toyota V8 i-VVT + VTC baciscally V8 with VTEC Ton of potential!
- cam journal scar'd, what are my options?
- timing ?'s
- Engine Bay Paint Questions?
- help on teg signal light wiring
- how to set up MSD ignition..
- B20 guru's..
- need help on engine code
- Field's SFC-VTEC in a 2000 Civic SI
- This is one of the "Hmmmmm" Dew-Hickey's
- Question about flucuating Volatages
- WEirdH
- Overheating problems and sluggishness
- heads, blocks and cranks
- high speed oil burning plz help!
- nitros build
- Honda oil filters
- Is this a DOHC ZC Head or a B18A/B18B Head?
- heater blower motor queston
- transmission problem
- Reliability issue question...
- no vtec and rev limit of 7200
- what tranny sheilds are you useing?
- ???relieving crank case pressure through the oil pan????
- Bad gas mileage after cold air intake HELP
- Hondata Help!!! B20vtec
- installed first cable tranny.... Is this right?
- Eibach sway bar doesnt fit 2000 si. Help?
- New OEM piston on stock rod...heat up to install pin or just press?
- Difference between the AEM ITR and GSR pulley kit?
- torque specs for arp main studs
- obd2 fucked up!!
- datalogging ???????
- N20 Bangs upon use. help
- CEL question
- Reasons WHY the Prelude B20A and B21A cranks are "Weak"?
- cam specs help!!!!
- exhaust flame
- Interesting in Hondata.
- Running N20
- Wrong ECU causing trouble code?
- cam question
- sohc fouling plug question
- GSR stock bottom end question
- Anyone who knows about building engines please help....
- power loss ? how much would i lose if???
- What clutch for lsd YS1?
- Where find a short final drive for b serie cable tranny ?
- what harness do i need for a jdm b16 into crx
- Socket this P30?
- Help me with my calcs and plot points on a compressor map! ASAP TIA
- B16a2 problem, nosie coming for time belt area
- Tirbo Questions.
- Main Stud and Bearing Question....
- valve adjustment.
- Rebuilding D16. What measurements I need for bearings (main/rod)
- Temp Gauge fluctuating...
- Where is the 40/40 prop valve located on the DA's?
- need quick, accurate, answer
- The derivation of compression measurement and its elements
- Someone diagnose my problem please! weird noise. B18C1 *VIDEO*
- No Spark No Fuel No Dash Lights JDM GSR
- HOW TO BLACK OUT 02/04 RSX HEADLIGHTs
- having the darnest time desolder!!!
- Differences in B-Series Oil Pumps?
- how much would it be to resleeve a b18b block?
- NEEED HEEELPPP B16A2 EG WONT START AFTER SWAP
- tunning question????
- "Direct Hit" spark plugs? anyone heard of them?
- "drag race spool" vs. lsd??????
- had ecu chipped now fuel pump wont turn on
- Why 5- Lug?
- new ball joint bought/rented pressing tool need help
- tranny noises.. go away when clutch is pushed in
- O2 sensor
- car wont start, already searched
- timing belt question
- Question on compression and air fuel ratio.
- need help on vafc
- MSD Distributor Cap for H22 VTEC
- spoon axle back....
- I have a hondata chipped p28 - can I switch to uberdata and back if necessary?
- i need to know this CP 84mm COmpression ratio!i run in my b20b wif b16a2 head later
- D16 Transmission Question
- Would a bad main relay cause these things to happen??
- b18c1 block weight (measured)
- H22A Gurus needed.
- caliper bracket question
- d16y7 turbo cam?
- fuel pressure questions
- what tranny fluid for lsd tranny?
- 98 dodge neon microfiche?
- Looking for the best tuner shop in SoCal
- tuning shop in boston, ma
- Will this work?
- Help!! Engine Problem!
- tranny will go into gear with engine on ....tranny wont spin cv's ....speedo moves ...throw out is r
- skunk2 intack manafoled idling problems?
- stock head bolts???
- Kinda weird
- Rust damage, how to repair?
- 2000-2001 S2000 clutch same as 90-91 crx si ???
- Header Question.
- Engine Question
- length of LS and GSR header?
- WILL IT RUN HELP ME OUT
- dyno tuning in Richmond metro area
- oil
- LS/VTEC Question! I know another one....
- S2000 LSD ?
- Main Relay
- Datalogger cable
- Do you think I will need a afc or not?
- want 13s at the 1/4mi..help needed
- parts needed to stick vtec head on supercharged car?
- Valve/cam positioning question...
- Attn:Those who pay for oil changes
- *HELP* My Brake Lights Are Stuck On!! *HELP*
- DSMtalk is down and I need help!!
- d16y7 block w/y8 vtec head
- ECU Tuning & Wide Band O2 Sensor
- piping question
- cam install gone bad! timing issue?
- Pcv system question, LS/VTEC, searched but not found
- Honda Oil Filter Reviews
- HELP ME PLEASE!!!!!!!READ ON!
- good aftermarket radiator?
- B18C1 running lean. Code 48. Using D16Z6 fuel pressure thing.
- Difference in rear brack ('L' bracket)
- Seafoam killed my o2 sensor
- looking for ecu code
- hey i have ?
- dyno tuning in jersey??
- ? on top end rebuild gasket kit for H22
- z1 and z6 head difference?
- cleaning a bare block with soap, water, degreaser.
- question about steelies
- probably a dumb question...
- Timing Belt: Didn't align cams/crank before I took it off
- dc/ skunk 2 fit
- NEED HELP WITH DISTRIBUTOR PROBLEM
- Quick ls/vtec question
- install lsd myself??
- 92 civic hatch w/ls swap
- Hondata Gasket fake & realdeal
- GM synchromesh FM vs Synthetic?
- Racing hart c5 1 piece 17" 5x114.3 weight?
- Install Inline fuel pump? Wiring help needed.
- Rewiring: Non-stock way.?
- Pyrometer ?
- Legit block??
- P28 ecu Knock sensor?
- VSS Sensor?
- Electrical Woes.. HELP ME!!! :'(
- question on a front mount?
