suspension problem?
After a gsr front brake swap, I noticed that outside of the negative camber, my 2 front wheels are also pointing slightly inward, is this an issue that a simple alignment can resolve or should I be concerned about something else? Just wondering because I've never seen this before and it looks a bit peculiar. Thanks for any help...
yes.. that is definatly a problem with the toe of your car.. all u need is to get ur alignment done.. did u take apart just the brake assembly?? or did u take off anything else..??? when u go to ur alignment FOR BEST RESULTS.. all four tires need to be fairly new, possibly under a week... or atleast evenly worn...
Alright, thanks for the info. The entire front knuckles were swapped out on my EK in favor of GSR ones in order to utilize the brakes. So it wasn;t just the brake assembly itself that was worked on...
Nighthawk R18
Honda Civic (2006 - 2015)
12
Sep 4, 2007 08:34 PM
